KH-2FH-1X18P-H4.3
KH-2FH-1X18P-H4.3
    KINGHELM(金航标)
    插件,P=2mm
    排母 间距:2mm 1x18P 直插
KH-2FH-1X18P-H4.3 数据手册
SPECIFICATIONS ∅0.8 RECOMMEND P.C.B LAYOUT PCB TOLERANCE:±0.05 (TOP VIEW) (1) Pin Spacing:200=2.0mm (2) Product Name:FH=Female Header (3) No.of Rows: 1=Single Row ;2=Dual Row (4) No.of Pins Per Row: 1~40 (5) Insulator Material Height:43=4.3mm;72=7.2mm (6) Connector Type:S=Straight;R=Right;Angle M=SMT (7) Connector Material Length:24=2.4mm;28=2.8mm (8) Insulator Material Width: 40=4.0mm 45=4.5mm (9) Contact Plating: G0=Gold Flash;AU10=Au 1.0u" (10)Insulator Material Option: A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special PIN 0.5X0.2 深圳市金航标电子有限公司 WWW.BDS666.COM KH-2FH-1X18P-H4.3 0755-83044319 UNLESS OTHEWIXE SPECIFIED TOLERANCE X :±0.3 X.X :±0.2 X.XX:±0.1 X° :±5° X.X° :±1° X.XX°:±0.5° CHECKED: LI BEI LIN 12/03/07 DRAWM NAME: SIZE REV A4 A CHECKED: No. of DIM.A 1 2.0FH 1xnPin H4.3 DIP SCALE PROUCT NO. UNIT PROJECT / / APPROVED: Current Rating: 1.5 Amps Insulation Resistance:1000MΩ Min Contact Resistance: 20mΩ Max Withstanding Voltage: AC 500V Operation Temperature:-40°to+105° Contact Material: Brass Standard: PA6T Insrlator Material: Polyester(UL 94V-0) Contact Plating: Gold Flash Max.Processing Temp: 240°C for30-60seconds (260°C for 5 seconds) PAGE 1/1 / / 0.00 DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B
KH-2FH-1X18P-H4.3 价格&库存
很抱歉,暂时无法提供与“KH-2FH-1X18P-H4.3”相匹配的价格&库存,您可以联系我们找货
