NJM2125F(TE1)
NJM2125F(TE1)
    JRC(⽇本无线)
    NJM2125F(TE1)
NJM2125F(TE1) 数据手册
NJM2125 SINGLE-SUPPLY OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM2125 is a single-supply operational amplifier of small surface mount package. The features of single-supply operation, low operating voltage ( minimum 2.7V ) and small package are most suitable for portable items. ■ FEATURES ● Single-Supply Operation ● Low Operating Voltage ● Low Operating Current ● Slew Rate ● Small Package ● Bipolar Technology ■ PACKAGE OUTLINE NJM2125F ( +2.7V~20V ) ( 1.0mA typ. ) ( 1.2V/μs typ. ) ( SOT−23−5 ) ■ PIN CONFIGURATION PIN FUCTION 1. +INPUT 2. GND 3. -INPUT NJM2125F (Top View) 4. OUTPUT + 5. V ■ EQUIVALENT CIRCUIT V+ OUTPUT -INPUT +INPUT GND Ver. 03 -1- NJM2125 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL + V VID VIC PD Topr Tstg RATINGS +20 +20 -0.3~+20 ( Note ) (SOT−23−5) 200 -40~85 -40~125 UNIT V V V mW ˚C ˚C ( note ) When the supply voltage is less than +20V, the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( V+=5V,Ta=25˚C ) PARAMETER Input Offset Voltage Input Offset Current SYMBOL VIO IIO TEST CONDITION MIN. TYP. MAX. UNIT RS=0Ω - 2 5 7 50 mV nA Input Bias Current IB - 25 250 nA Large Signal Voltage Gain AV RL≥2kΩ 88 100 - dB Maximum Output Voltage Swings Input Common Mode Voltage Range Common Mode Rejection Ratio VOM VICM CMR RL=2kΩ 3.5 0~3.5 70 90 - V V dB Supply Voltage Rejection Ratio SVR 80 94 - dB Output Source Current Output Sink Current Operating Current Slew Rate Unity Gain Frequency -2- ISOURCE ISINK ICC SR fT + VIN =1V,VIN =0V + VIN =0V,VIN =1V RL=∞ 20 30 - mA 8 - 20 1.0 1.2 1.75 - mA mA V/μs - 1.2 - MHz Ver. 03 NJM2125 ■ TYPICAL CHARACTERISTICS Voltage Gain Phase Margin vs. Frequency (V+=5V, RL=2kΩ, CL=10pF) 0 4 8 12 16 20 Operating Voltage V+ (V) Maximum Output Voltage Swing vs. Output source current (V+=5V, Ta=25℃) Load Resistance[Ω] Ver. 03 -3- NJM2125 ■ TYPICAL CHARACTERISTICS Temperature Operating Current vs. Temperature (V+=5V) Ambient Temperature Ta(℃) Ambient Temperature Ta(℃) Input bias Current vs. Temperature Input bias Current Temperature Ambient Temperature Ta(℃) Temperature Ambient Temperature Ta(℃) -4- [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver. 03
NJM2125F(TE1)
物料型号:NJM2125 器件简介:NJM2125是一款单电源运放,具有小尺寸贴片封装,适用于低电压操作,最低工作电压为2.7V,非常适合便携设备。
引脚分配:1. +INPUT 2. GND 3. -INPUT 4. OUTPUT 5. V+ 参数特性:单电源操作,低工作电压(+2.7V~20V),低工作电流(典型值1.0mA),压摆率(典型值1.2V/μs),小尺寸封装(SOT−23−5),双极技术。
功能详解:NJM2125具有单电源操作能力,能在2.7V至20V的电压范围内工作,提供低输入偏置电压、低输入偏置电流、高电压增益、大信号电压增益、最大输出电压摆动、输入共模电压范围、共模抑制比、电源电压抑制比、输出源电流、输出沉电流、工作电流、压摆率和增益带宽积等特性。
应用信息:适用于便携设备,如电池供电设备。
封装信息:SOT-23-5封装。
NJM2125F(TE1) 价格&库存
很抱歉,暂时无法提供与“NJM2125F(TE1)”相匹配的价格&库存,您可以联系我们找货
