Hall Effect Current Sensors L18P***D15 Series
Features:
Advantage:
Open Loop type
Printed circuit board mounting
Integrated primary
Voltage output
Busbar version from 40A to 60A
Insulated plastic case according
to UL94V0
Excellent accuracy and linearity
Wide nominal current range
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
TA=25ºC, VCC=±15V, RL=10kΩ
L18P003 L18P005 L18P010 L18P015 L18P020 L18P025 L18P030 L18P040 L18P050 L18P060
Symbol
D15
D15
D15
D15
D15
D15
D15
D15
D15
D15
Parameters
If
±3A
±5A
±10A
±15A
±20A
±25A
±30A
±40A
±50A
±60A
Maximum Current
Ifmax
±9A
±15A
±30A
±45A
±60A
±75A
±90A
±120A
±150A
±180A
Output Voltage
VOUT
±4V ±0.040V @ ±If
±4V ±0.050V @ ±If
Offset Voltage
VOE
0V ±0.040V @ If = 0A
0V ±0.050V @ If = 0A
Rated current
Accuracy1
X
± 1% @ If
Output Linearity
εL
≤ ±1% @ If
Power Supply
VCC
±15V ±5%
Consumption Current
IC
≤15mA
Response Time
tr
≤ 5µs (@ di/dt = 10A / 5µs)
Output Temperature
Characteristic1
TCVOUT
≤ ±2.0mV/ ºC
Offset Temperature
Characteristic
TCVOE
≤ ±1.5mV/ ºC
1
≤25mV (0A ⇔ If)
VOH
Hysteresis error
≤40mV (0A ⇔ If)
Vd
AC3000V for 1minute (sensing current 0.5mA), inside of aperture ⇔ terminal
RIS
> 500MΩ (500V DC), inside of aperture ⇔ terminal
f
DC .. 50kHz
Operating Temperature
TA
-20ºC~+85ºC
Storage Temperature
TS
-20ºC~+85ºC
Withstand Voltage
Insulation Resistance
2
Frequency Bandwidth
1
Without offset — 2 Small signal only to avoid excessive heating of magnetic core
Electrical Performances
Saturation Characteristic (L18P050D15)
2.0
15.0
0.0
10.0
Output Voltage (V)
Attenuation (dB)
Frequency Characteristic (L18P050D15)
-2.0
-4.0
-6.0
-8.0
5.0
0.0
-5.0
- 10.0
- 15.0
-10.0
0.1
1
10
If frequency (kHz) @ If=3.0Arms
pending
L18PXXXD15revB, August 2008
100
- 200.0
- 150.0
-100.0
- 50.0
0.0
50.0
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
100.0
150.0
200.0
Mechanical dimensions in mm
17.5
Terminal Pin Identification
1: -VCC
2: GND
3: +VCC
4: Output
5: Primary input current (+)
6: Primary input current (-)
15
3
5±1
14.4
15.2
17
1.3
φD
φ0.6
φ0.8
Φ1.1
φ1.4
φ1.6
4 1.5
4 3 2 1
4 - 0.25x0.5
6 (-)
4 3 2 1
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
3. Cover is optional
4 - 0.25x0.5
2.54
7.62
Electrical connection diagram
+If
-VCC
+VCC
-If
GND
RL = 10kΩ
VOUT
Package & Weight Information
pending
2.8
5 (+)
18 MAX
5 (+)
11
1
6
6 (-)
8.8
5
18 MAX
3
A
3A
5A
10A
15A
20~30A
1
5.4
Weight
Pcs/box
Pcs/carton
Pcs/pallet
8g
100
600
9600
很抱歉,暂时无法提供与“L18P020D15AHV”相匹配的价格&库存,您可以联系我们找货
