KH-2FH-2X10P-H4.3-SMT 数据手册
RECOMMEND P.C.B LAYOUT
WWW.BDS666.COM
PROJECT
PROUCT NO.
1/1
1
0.00
No. of DIM.A
PCB TOLERANCE: ±0.05 (TOP VIEW)
深圳市金航标电子有限公司
UNIT
APPROVED:
SCALE
2.0FH 2xnPin H4.3 SMT
0755-83044319
A4
A
DRAWM NAME:
REV
SIZE
CHECKED:
PAGE
12/03/07
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
UNLESS OTHEWIXE SPECIFIED TOLERANCE
X :±0.3
X.X :±0.2
X.XX:±0.1
CHECKED: LI BEI LIN
DIM.B
SPECIFICATIONS
Current Rating:
1.5 Amps
Insulation Resistance:1000MΩ Min
Contact Resistance: 20mΩ Max
Withstanding Voltage: AC 500V
Operation Temperature:-40°to+105°
Contact Material:
Brass
Standard:
PA6T
Insrlator Material:
Polyester(UL 94V-0)
Contact Plating:
Gold Flash
Max.Processing Temp: 240°C for30-60seconds
(260°C for 5 seconds)
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
(1) Pin Spacing:200=2.0mm
(2) Product Name:FH=Female Header
(3) No.of Rows: 1=Single Row ;2=Dual Row
(4) No.of Pins Per Row: 1~40
(5) Insulator Material Height:43=4.3mm;72=7.2mm
(6) Connector Type:S=Straight;R=Right;Angle M=SMT
(7) Connector Material Length:24=2.4mm;28=2.8mm
(8) Insulator Material Width: 40=4.0mm 45=4.5mm
(9) Contact Plating: G0=Gold Flash;AU10=Au 1.0u"
(10)Insulator Material Option:
A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special
No. of DIM.A
DIM.B
KH-2FH-2X10P-H4.3-SMT 价格&库存
很抱歉,暂时无法提供与“KH-2FH-2X10P-H4.3-SMT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.83687
- 50+1.39655
- 150+1.23012
- 510+1.02266
- 2490+0.93021
- 5010+0.87480
- 9990+0.86325
- 20010+0.85558
