Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/09/2019
page
1 of 3
SERIES: SJ-435107 │ DESCRIPTION: 3.5 MM AUDIO JACK
FEATURES
• grounded spring tabs
• shielded
• metal bushing
PART NUMBER KEY
SJ - 435107 X
Base Number
Switch Options
"blank" = no switch
RS = isolated ring switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
0.3
-25
life
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
85
5,000
flammability rating
UL94V-0
RoHS
yes
Note:
Vdc
MΩ
any direction for 10 seconds
operating temperature
units
1.0
100
insertion/withdrawal force
terminal strength
max
°C
cycles
1. When measured at a current of less than 100 mA /1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds at
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: SJ-435107 │ DESCRIPTION: 3.5 MM AUDIO JACK
date 10/09/2019 │ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
terminal (1~6)
copper alloy
tin
shield
copper alloy
nickel
bushing
brass
nickel
plastic
PA66
12.0 0.472
0.3
10.8 0.425
1.0 0.039
0.3 (2 PLCS)
5.20 0.205
3.00 0.118
6.00 0.236
3.600 0.142
7.3 0.287
1.00 0.039
(2 PLCS)
4.00 0.157
2.4 0.094
0.3 (8 PLCS)
0.80 0.031
(8 PLCS)
0.7 0.028
2.4 0.094
2.4 0.094
1.6 0.063
8.5 0.335
10.5 0.413
(2 PLCS)
3.1 0.122
3.6 0.142
4.5 0.177
4.5 0.177
5.1 0.201
5.5 0.217
4.9 0.193
7.4 0.291
10.7 0.421
5.00 0.197
10.5 0.413
(2 PLCS)
8.5 0.335
2.40 0.094
6
5
11.3 0.445
5.00 0.197
3
1.30 X 0.80 [0.051 X 0.031]
(8 PLCS)
2.40 0.094
(2 PLCS)
1
2
6
1.0 0.039
+0.0
-0.1
(2 PLCS)
4
5.1 0.201
5
1
4.5 0.177
5.5 0.217
3
2
4
SJ-435107
7.4 0.291
1
4
2
3
5
6
1
4
2
3
Schematic
4.9 0.193
SJ-435107RS
10.7 0.421
PCB LAYOUT
TOP VIEW
PIN
1
sleeve
sleeve
2
tip
tip
3
ring 1
ring 1
4
ring 2
ring 2
5
NP
isolated ring 1
6
NP
isolated ring 1
switch (N-O)
ø3.5 MATING PLUG
cuidevices.com
3.1 0.122
3.6 0.142
0.7 0.028
2.4 0.094
Model No.
1.6 0.063
1.1 0.043
+0.1
-0.0
(2 PLCS)
4.5 0.177
Product Page
3D Model
PCB Footprint
date 10/09/2019 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2012
1.01
updated schematic and spec
06/07/2012
1.02
added drawing dimension, updated spec
01/03/2014
brand update
10/09/2019
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ-435107RS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 80+7.3317980+0.88439
- 240+7.29753240+0.88026
- 400+7.29737400+0.88024
- 1200+7.297211200+0.88022
- 2000+7.297042000+0.88020
- 国内价格 香港价格
- 10+7.5128310+0.90623
- 30+7.4777130+0.90199
- 125+7.47755125+0.90197
- 300+7.47739300+0.90195
- 1250+7.477231250+0.90193
- 国内价格
- 10+9.81505
- 20+9.35163
- 50+8.88821
- 100+8.62266
- 国内价格
- 2+10.34615
- 10+9.81505
- 20+9.35163
- 50+8.88821
- 100+8.62266
