EC21AFA-512-STD
EC21AFA-512-STD
    QUECTEL(移远)
    Module
EC21AFA-512-STD 数据手册
Build a Smarter World Quectel EC21 IoT/M2M-optimized LTE Cat 1 Module Quectel EC21 is a series of LTE category 1 module optimized specially for M2M and IoT applications. It features cost-effective, low power LTE connectivity, and delivers M2M-optimized speeds of 10Mbps downlink and 5Mbps uplink. These make EC21 an ideal solution for numerous IoT applications that are not reliant on high speed connectivity but still require the longevity and reliability of LTE networks. EC21 is compatible with Quectel UMTS/HSPA+ UC20 module and multi-mode LTE EC20/EC25 module in the compact and unified form factor. It contains 11 variants: EC21-E, EC21-EU, EC21-EC, EC21-A, EC21-V, EC21-AU, EC21-AUT, EC21-AUV, EC21-J, EC21-KL and EC20-CEL. This makes it backward-compatible with existing EDGE and GSM/GPRS networks, ensuring that it can easily migrate from LTE to 2G or 3G network. EC21 supports Qualcomm® IZat™ location technology Gen8C Lite (GPS, GLONASS, BeiDou, Galileo and QZSS). The integrated GNSS greatly simplifies product design, and provides quicker, more accurate and more dependable positioning. A rich set of Internet protocols, industry-standard interfaces and abundant functionalities (USB serial drivers for Windows 7/8/8.1/10, Linux, Android/eCall*) extend the applicability of the module to a wide range of M2M and IoT applications such as smart metering, wearable devices, environmental monitoring, asset tracking, fleet management, security and alarm systems, and so on. Key Benefits Cost-effective, lower-power LTE connectivity optimized for broadband IoT applications LTE Cat 1 Max 10Mbps (DL) Max 5Mbps (UL) Max 42Mbps (DL) Max 5.76Mbps (UL) LCC Package Embedded Abundant Protocols eCall* Multi-constellation GNSS USB 2.0 High Speed Interface USB Drivers Quectel Enhanced AT Commands Worldwide LTE, UMTS/HSPA+ and GSM/GPRS/EDGE coverage Multi-constellation GNSS receiver available for applications requiring fast and accurate fixes in any environment Feature refinements: supports DFOTA*, eCall* and DTMF MIMO technology meets demands for data rate and link reliability in modem wireless communication systems Rev.: V1.8 | Status: Released EMAIL US: info@quectel.com VISIT US: www.quectel.com 29.0 mm Quectel EC21 IoT/M2M-optimized LTE Cat 1 Module Variants for EMEA/Korea/Thailand EC21-E: LTE FDD: B1/B3/B5/B7/B8/B20 WCDMA: B1/B5/B8 GSM: B3/B8 EC21-EU: LTE FDD: B1/B3/B7/B8/B20/B28A WCDMA: B1/B8 GSM: B3/B8 EC21-EC: LTE FDD: B1/B3/B7/B8/B20/B28A WCDMA: B1/B8 GSM: B3/B8 Variants for North America EC21-A: LTE FDD: B2/B4/B12 WCDMA: B2/B4/B5 EC21-V: LTE FDD: B4/B13 Variants for Australia/New Zealand/Taiwan/ Brazil EC21-AU: LTE FDD: B1/B2①/B3/B4/B5/B7/B8/B28 LTE TDD: B40 WCDMA: B1/B2/B5/B8 GSM: B2/B3/B5/B8 EC21-AUT: LTE FDD: B1/B3/B5/B7/B28 WCDMA: B1/B5 EC21-AUV: LTE FDD: B1/B3/B5/B8/B28 WCDMA: B1/B5/B8 Variant for Japan EC21-J: LTE FDD: B1/B3/B8/B18/B19/B26 Variant for Korea EC21-KL: LTE FDD: B1/B3/B5/B7/B8 Variant for China EC20-CEL: LTE FDD: B1/B3/B5 Data LTE: LTE FDD: Max 10Mbps (DL)/Max 5Mbps (UL) LTE TDD: Max 8.96Mbps (DL)/Max 3.1Mbps (UL) UMTS: DC-HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps (DL)/Max 384Kbps (UL) GSM: EDGE: Max 296Kbps (DL)/Max 236.8Kbps (UL) GPRS: Max 107Kbps (DL)/Max 85.6Kbps (UL) Voice Speech Codec Modes: HR/FR/EFR/AMR/AMR-WB Echo Arithmetic: Echo Cancellation/Noise Suppression Audio: Digital Audio and VoLTE (Voice over LTE) (Optional) Interfaces UART × 2 : Main UART and Debug UART USB x 1: USB 2.0 with High Speed up to 480Mbps (U)SIM x 1: 1.8V/3.0V (U)SIM Interface Digital Audio through PCM Interface (Optional) NETLIGHT × 2 : NET_STATUS and NET_MODE ADC × 2 SDIO × 2 (for Wi-Fi and SD Card) RESET (Active Low) PWRKEY (Active Low) Solder Pads for Primary, Rx-diversity and GNSS Antennas Enhanced Features SDIO Interface for Wi-Fi Function (Optional) UART/PCM Interfaces for BT4.0 Function* (Optional) eCall* DTMF Audio Playback/Audio Recording QuecFile* (U)SIM Card Detection DFOTA*: Delta Firmware Upgrade Over the Air GNSS: GPS/GLONASS/BeiDou/Galileo/QZSS (Optional) Electrical Characteristics Output Power: Class 3 (23dBm±2dB) for LTE FDD bands Class 3 (23dBm±2dB) for LTE TDD bands Class 3 (24dBm+1/-3dB) for WCDMA bands Class E2 (27dBm±3dB) for GSM850 8-PSK Class E2 (27dBm±3dB) for EGSM900 8-PSK Class E2 (26dBm±3dB) for DCS1800 8-PSK Class E2 (26dBm±3dB) for PCS1900 8-PSK Class 4 (33dBm±2dB) for GSM850 Class 4 (33dBm±2dB) for EGSM900 Class 1 (30dBm±2dB) for DCS1800 Class 1 (30dBm±2dB) for PCS1900 Consumption: 20uA @Power off 3mA @Sleep, Typ. 22mA @Idle Sensitivity: LTE B1: -101.5dBm (10M) LTE B2: -101dBm (10M) LTE B3: -101.5dBm (10M) LTE B4: -101dBm (10M) LTE B5: -101dBm (10M) LTE B7: -99.5dBm (10M) LTE B8: -101dBm (10M) LTE B12: -101dBm (10M) LTE B13: -100dBm (10M) LTE B18: -101.7dBm (10M) LTE B19: -101.4dBm (10M) LTE B20: -102.5dBm (10M) LTE B26: -101.5dBm (10M) LTE B28: -102dBm (10M) WCDMA B1: -110dBm WCDMA B2: -110dBm WCDMA B4: -110dBm Copyright © 2018 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: 7th Floor, Hongye Building, No.1801 Hongmei Road, Xuhui District, Shanghai 200233, China Tel: +86 21 51086236 Email: info@quectel.com 32.0 mm 2.4mm WCDMA B5: -110.5dBm WCDMA B8: -110.5dBm GSM850: -109dBm EGSM900: -109dBm DCS1800: -109dBm PCS1900: -109dBm Software Features USB Serial Driver: Windows 7/8/8.1/10, Windows CE 5.0/6.0/7.0*, Linux 2.6/3.x/4.1~4.14, Android 4.x/5.x/6.x/7.x/8.x RIL Driver: Android 4.x/5.x/6.x/7.x/8.x NDIS Driver: Windows 7/8/8.1/10 ECM Driver*: Linux 2.6/3.x/4.1~4.14 Gobinet Driver: Linux 2.6/3.x/4.1~4.14 Linux qmi wwan Driver: 3.x (3.4 and later)/4.1~4.14 Protocols: TCP/UDP/PPP/FTP/HTTP/NTP/PING/QMI/ CMUX*/HTTPS*/SMTP*/MMS*/FTPS*/SMTPS*/ SSL*/FILE* General Features Temperature Range: -40°C ~ +85°C Dimensions: 29.0mm × 32.0mm × 2.4mm Weight: Approx. 4.9g LCC Package Supply Voltage: 3.3V~4.3V, 3.8V Typ. 3GPP E-UTRA Release 11 Bandwidth: 1.4/3/5/10/15/20MHz 3GPP TS27.007, 27.005 and Enhanced AT Commands Approvals RoHS Compliant GCF (Global) CE/Vodafone/Deutsche Telekom (Europe) FCC/PTCRB/AT&T/Verizon (North America) RCM/Telstra (Australia) JATE/TELEC/DOCOMO (Japan) NCC (Taiwan) KC/SKT/KT (Korea) IC/Rogers (Canada) Anatel (Brazil) FAC (Russia) Telefonica* (Spain) CCC/SRRC/NAL (China) ①: LTE B2 of EC21-AU Does Not Support Rx-diversity * Under Development
EC21AFA-512-STD 价格&库存
很抱歉,暂时无法提供与“EC21AFA-512-STD”相匹配的价格&库存,您可以联系我们找货
