US2JG
US2JG
    SK(時科)
    SMA(DO-214AC)
    特性:适用于表面贴装应用。 低外形封装。 玻璃谐振芯片结。 易于拾取和放置。 高效率。 符合欧盟RoHS 2011/65/EU指令
US2JG 数据手册
US2AG THRU US2MG SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER PINNING Reverse Voltage - 50 to 1000 V PIN Forward Current - 2 A FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • High efficiency • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: US2A~US2M Simplified outline SMA and symbol MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter US2AG US2BG U S2DG U S2GG U S2JG U S2KG U S2MG Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 70 A Maximum Instantaneous Forward Voltage at 2 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . REV.08 1.0 1.3 1.65 5 100 IR t rr μA 75 50 V ns RθJA RθJC 65 20 °C/W T j , T stg -55 ~ +150 °C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 1 of 3 US2AG THRU US2MG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Peak Forward Surage Current (A) Instaneous Forward Current (A) T J =25°C 1.0 US2AG~US2DG US2GG 0.1 US2JG~US2MG 0.01 0.001 0 0.5 1.0 1.5 2.0 60 80 100 120 140 90 75 60 45 30 15 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 2.5 Instaneous Forward Voltage (V) REV.08 40 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 10 Number of Cycles 2 of 3 100 US2AG THRU US2MG PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D The recommended mounting pad size 1.8 (71) 1.8 (71) 2.4 (94) mm Unit : (mil) REV.08 0.3 12 Marking Type number 1.8 (71) a 3 of 3 Marking code US2AG US2A US2BG US2B US2DG US2D US2GG US2G US2JG US2J US2KG US2K US2MG US2M
US2JG 价格&库存
很抱歉,暂时无法提供与“US2JG”相匹配的价格&库存,您可以联系我们找货
US2JG
    • 5000+0.05775
    库存:18000
    US2JG
      • 5000+0.06421
      库存:30000
      US2JG
      库存:9059
      US2JG
      库存:5000
      US2JG
        • 5000+0.06421
        库存:9000
        US2JG
        • 5000+0.07560
        • 15000+0.07350
        • 85000+0.07140
        库存:5000
        US2JG
          • 5000+0.06421
          库存:3000
