CR18-8DP
CR18-8DP
    AUTONICS(奥托尼克斯)
    CR18-8DP
CR18-8DP 数据手册
CR Series Cylindrical, Capacitive type proximity sensor Features ● Sensing of iron, metal, plastic, water, stone, wood etc. ● Long life cycle and high reliability ● DC type: Built-in surge protection circuit, reverse polarity protection circuit AC type: Built-in surge protection circuit ● Easy to adjust of the sensing distance with sensitivity adjuster ● Red LED operation indicator ● Easy to control of level and position Please read “Safety Considerations” in the instruction manual before using. Type DC 3-wire type Appearances AC 2-wire type Model Appearances CR18-8DN M18 CR18-8DP M18 CR18-8DN2 ※ CR30-15DN M30 ※ mark can be customized. Specifications CR30-15DP CR30-15DM2 ※ M30 Model CR18-8AO CR18-8AC CR30-15AO CR30-15AC CR18-8DN CR30-15DN CR18-8AO CR30-15AO CR18-8DP CR30-15DP CR18-8AC CR30-15AC CR18-8DN2 CR30-15DN2 Diameter of the sensing side 18mm 30mm 30mm 18mm Sensing distance 8mm 15mm 15mm 8mm Installation Non-shield (non-flush) Hysteresis Max. 20% of sensing distance Standard sensing target 50×50×1mm (iron) Setting distance 0 to 5.6mm 0 to 10.5mm 0 to 5.6mm 0 to 10.5mm Power supply 12-­24VDCᜡ 100-240VACᜠ 50/60Hz (operating voltage) (10­-30VDCᜡ) (85-264VACᜠ) Current consumption Max. 15mA Leakage current Max. 2.2mA Response frequency※1 50Hz 20Hz Residual voltage Max. 1.5V Max. 20V Affection by Temp. Max. ±20% for sensing distance at ambient temperature 20℃ Control output Max. 200mA 5 to 200mA Insulation resistance Over 50MΩ (at 500VDC megger) Dielectric strength 1,500VAC 50/60Hz for 1 min Vibration 1mm amplitude at frequency of 10 to 55Hz (for 1 min) in each of X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each of X, Y, Z direction for 3 times Indicator Operation indicator: Red LED Environ- Ambient temperature -25 to 70℃, storage: -30 to 80℃ ment Ambient humidity 35 to 95%RH, storage: 35 to 95%RH Protection circuit Reverse polarity protection circuit, Serge protection circuit Serge protection circuit Protection structure IP66 (IEC standard) IP65 (IEC standard) IP66 (IEC standard) IP65 (IEC standard) Ø4mm, 3-wire, 2m Ø5mm, 3-wire, 2m Ø4mm, 2-wire, 2m Ø5mm, 2-wire, 2m Cable AWG22, Core diameter: 0.08mm, Number of cores: 60, Insulator out diameter: Ø1.25mm CR18 - Case/Nut: PA6, Standard cable (black): Polyvinyl chloride (PVC) Material CR30 - Case/Nut: Nickel plated brass, Washer: Nickel plated iron, Sensing surface: Polybutylene terephthalate, Standard cable (black): Polyvinyl chloride (PVC) Approx. 88g Approx. 243g Approx. 82g Approx. 237g ※2 Weight (approx. 76g) (approx. 206g) (approx. 70g) (approx. 200g) ※1: The response frequency is the average value. The standard sensing target is used and the width is set as 2 times of the standard sensing target, 1/2 of the sensing distance for the distance. ※2: The weight includes packaging. The weight in parenthesis in for unit only. ※Environment resistance is rated at no freezing or condensation. Model F-176 Cylindrical, Capacitive type Dimensions (unit: mm) ● CR18-8 SENSORS Ø26.5 71.8 24 2,000 53.3 CONTROLLERS Ø4 MOTION DEVICES 8 M18×1 ● CR30-15 Ø42 SOFTWARE 2,000 71 10 35 55 Ø5 (A) Photoelectric Sensors 5 M30×1.5 Control Output Diagram and Load Operation (B) Fiber Optic Sensors Connections (C) LiDAR DC 3-wire type DC 3-wire type Black Blue Brown NPN output type Main circuit Brown 10kΩ +V Load Sensing target N.O. Presence None (D) Door/Area Sensors N.C. (E) Vision Sensors (F) Proximity Sensors Load Operation (brown-black) Return Black Output H voltage L (black-blue) Blue 0V Operation Indicator (red LED) (G) Pressure Sensors ON OFF (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets PNP output type Main circuit Brown +V N.O. 0V AC 2-wire type Brown Operation ON Indicator (red LED) OFF Main circuit AC POWER Blue CR18-8AO Sensing Presence target None Load Load ~ AC 2-wire type Brown Load ~ N.C. Output H voltage (black-blue) L Load Blue Presence None Operation Load (brown-black) Return Black 10kΩ Sensing target N.O. Blue 100240VAC 50/60Hz Load N.C. Operation Return Operation ON Indicator (red LED) OFF F-177 CR Series Sensitivity Adjustment Please turn potention VR to set sensitivity as below procedure. 1. Without a sensing object, turn the potention VR to the right and stop at the proximity sensor is ON (OFF). Stop at ON (OFF) position 3. If the difference of the number of potention VR rotation between the ON (OFF) point and the OFF (ON) point is more than 1.5 turns, the sensing operation will be stable. 2. Put the object in right sensing position, turn the potention VR to the left and stop at the proximity sensor is OFF (ON). Stop at OFF(ON) position 4. If it is set in sensitivity adjustment position of potention VR at center between 1 and 2, sensitivity setting will be completed. It is stable when it is over 1.5 turns OFF position (ON position) Adjustment completed OFF position (ON position) ON position (OFF position) ON position (OFF position) ※When there is distance fluctuation between proximity sensor and the target, please adjust 2 at the farthest distance from this unit. ※Turning potention VR toward clockwise, it will be max., or turning toward counter clockwise, it will be min. The number of adjustment should be 15±3 revolution and if it is turned to the right or left excessively, it will not stop, but it idles without breakdown. ※( ) is for Normally closed type. Grounding The sensing distance will be changed by grounding status of capacitive proximity sensor and the target[50×50×1mm(Iron)]. Please check the material when installing the sensor and selecting the target. ● CR18 type ● CR30 type Operating distance (mm) 8 Ground condition OFF 4 Switch a ON OFF ON OFF Switch b ON ON OFF OFF 15 18 6 6 Operating distance (mm) Sensing target ON Sensing target Ground condition (switch b) switch b F-178 switch a switch b Cylindrical, Capacitive type Mutual-Interference & Influence by Surrounding Metals When several proximity sensors are mounted closely, malfunction of sensor may be caused due to mutual interference. Therefore, be sure to keep a minimum distance between the two sensors as below charts. SENSORS CONTROLLERS (unit: mm) Item Model CR18 CR30 A A 48 90 Face to Face B 54 90 MOTION DEVICES SOFTWARE Parallel B (A) Photoelectric Sensors (B) Fiber Optic Sensors When sensors are mounted on metallic panel, you must prevent the sensors from malfunction by any metallic object. Therefore, be sure to keep a minimum distance as below charts. (C) LiDAR ℓ (D) Door/Area Sensors (unit: mm) Ød Model CR18 CR30 ℓ 20 10 Ød 54 90 m 24 45 n 54 90 Item (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders m (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets n Materials Materials of sensing targets Sensing distance may be different by electrical characteristic of sensing target (conductivity, non dielectric constant) and status of water absorption, size etc. Effect by high frequency electrical field It may cause malfunction by machinery which generate high frequency of electrical field such as a washing machine etc. Surrounding environment There is water or oil on surface of sensing part, it may cause malfunction. If the bottle for sensing of level is coated by oil etc., it may cause malfunction. Especially, 15mm type has high sensitivity for induced objects, please be careful of waterdrops. Organic solvents Do not let the oil or oil liquid is flowed into the sensor because the case is made by plastic. F-179
CR18-8DP 价格&库存
很抱歉,暂时无法提供与“CR18-8DP”相匹配的价格&库存,您可以联系我们找货
