SCT63240FIAR
SCT63240FIAR
    SCT(芯洲科技)
    FCQFN19_4X3MM
    SCT63240是一款高度集成的电源管理IC,可使符合WPC规范的无线充电发射端系统实现高性能、高效率和高性价比,支持最高20W的功率传输,可与无线专用控制器或基于通用MCU的发射端控制器配合使用。该...
SCT63240FIAR 数据手册
SCT63240 SILICONCONTENT TECHNOLOGY TECHNOLOGYHigh-Efficiency PMIC for Wireless Power Transmitter 20W High-Integration, FEATURES DESCRIPTION • • • • The SCT63240 is a highly integrated Power Management IC allows achieving high performance, high efficiency and cost effectiveness of wireless power transmitter system compliant with WPC specification to support up to 20W power transfer, working with a wireless application specific controller or a general MCU based transmitter controller. • • • • • • • • • • VIN Input Voltage Range: 4.2V-20V PVIN Input Voltage Range: 1V~17V Up to 20W Power Transfer Integrated Full-Bridge Power Stage with 13-mΩ Rdson of Power MOSFETs Integrated High Efficiency 5V-1A Step-down DC/DC Converter Optimized for EMI Reduction Build-in 3.3V-200mA LDO Provide 2.5V Voltage Reference Integrated Lossless Input Current Sensor with ±2% accuracy for FOD and current Demodulation 3.3V and 5V PWM Signal Logic Compatible Input Under-Voltage Lockout Over Current Protection Over Temperature Protection 3mm*4mm QFN-19L Package This device integrates a 4-MOSFETs full bridge power stage,gate drivers, a 5V step-down DC/DC converter, a 3.3V LDO, a 2.5V accurate voltage reference and input current sensor for both system efficiency and easy-to-use. The proprietary gate driving scheme optimizes the performance of EMI reduction to save the system cost and design. The proprietary lossless current sensing circuitry with ±2% accuracy monitors input current of full bridge to support Foreign Object Detection FOD and current demodulation. The buildin 5V step-down DC/DC converter and 3.3V low dropout regulator LDO can provide power supplies to transmitter controller and external circuitries. APPLICATIONS • • • The SCT63240 features input Under-Voltage Lockout UVLO, over current, short circuit protection, and over temperature protection. WPC Compliant Wireless Chargers of 5W to 15W Systems for Mobiles, Tablets and Wearable Devices General Wireless Power Transmitters for Consumer, Industrial and Medical Equipment Proprietary Wireless Chargers and Transmitters The SCT63240 is available in a compact 3mm*4mm QFN package. TYPICAL APPLICATION Power Transfer Efficiency with 15W RX @ Vout=12V C3 VIN PVIN1 GND PGND PVIN2 C4 L1 BST3 PVIN C1 90.00 C2 80.00 70.00 BST1 C8 SW3 C5 SW1 SCT63240 VDD SW2 V3P3 BST2 EN ISNS PWM1 VREF C9 C6 Efficiency(%) VIN 60.00 50.00 40.00 30.00 20.00 PWM2 10.00 C7 AGND 0.00 0 3 6 9 12 15 Output Power(W) For more information www.silicontent.com © 2018Silicon Content Technology Co., Ltd. All Rights Reserved 1 SCT63240 DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING SCT63240FIA(1) (1) For Tape & Reel, Add Suffix R (e.g. SCT63240FIAR) PACKAGE DISCRIPTION 3240 QFN-19L ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise noted(1) EN PWM1 PWM2 AGND ISNS VREF DESCRIPTION MIN MAX UNIT VIN -0.3 24 V PVIN1, PVIN2 -0.3 20 V SW1,SW2 -1 20 V SW3 -1 24 V BST1,BST2 -0.3 26 V BST3 -0.3 30 V BST1-SW1,BST2-SW2,BST3-SW3 VDD, V3P3, VREF, ISNS, EN, PWM1, PWM2 Operating junction temperature TJ(2) -0.3 6 V -0.3 6 V -40 125 °C Storage temperature TSTG -65 150 °C (1) CONFIDEN TIAL P relimi nary D atashe et 19 PVIN1 18 17 16 15 1 PGND 14 13 BST1 12 SW1 11 SW2 10 BST2 2 PVIN2 3 4 5 6 7 8 9 VIN GND SW3 BST3 VDD V3P3 Figure 1. Top view 19-Lead QFN 3mm*4mm Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. (2) PIN FUNCTIONS NAME NO. PVIN1 1 PGND 2 PVIN2 3 VIN 4 GND SW3 5 6 PIN FUNCTION Input supply voltage of half-bridge FETs Q1 and Q2. Connected to the drain of high side FET Q1. a local bypass capacitor from PVIN1 pin to PGND pin should be added. Path from PVIN1 pin to high frequency bypass capacitor and PGND must be as short as possible. PGND is the common power ground of the full bridge, connected to the source terminal of low side FETs Q2 and Q4 internally. Input supply voltage of half-bridge FETs Q3 and Q4. Connected to the drain of high side FET Q1. Local bypass capacitor from PVIN1 pin to PGND pin should be added. Path from PVIN1 pin to high frequency bypass capacitor and PGND must be as short as possible. Input supply voltage of the Buck converter. Add a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Power ground of the Buck converter. Switching output of the Buck converter. Connect SW3 to an external power inductor. 2 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved SCT63240 BST3 7 VDD 8 V3P3 9 BST2 10 SW2 SW1 11 12 BST1 13 VREF ISNS 14 15 AGND 16 PWM2 17 PWM1 18 EN 19 Power supply bias for the high-side power MOSFET gate driver of Buck converter. Connect a 0.1uF capacitor from BST3 pin to SW3 pin. Output voltage of the Buck converter. Connect 22uF capacitor from this pin to GND pin. VDD is also the input power supply for gate driver of power stage, the 3.3V LDO and the 2.5V voltage reference. 3.3V LDO output. Connect 1uF capacitor to ground. Power supply bias for the high-side power MOSFET gate driver of Q3 as shown in the block diagram. Connect a 0.1uF capacitor from BST2 pin to SW2 pin. Switching node of the half-bridge FETs Q3 and Q4. Switching node of the half-bridge FETs Q1 and Q2. Power supply bias for the high-side power MOSFET gate driver of Q1 as shown in the block diagram. Connect a 0.1uF capacitor from BST1 pin to SW1 pin. Output of the 2.5V LDO. Connect a 1uF capacitor to ground. Current detection output. The voltage of the pin is proportional to the input current. Analog ground of the IC PWM logic input to the FET Q3 and Q4 as shown in the Block Diagram. Logic HIGH turns off the low-side FET Q4, and turns on the high-side FET Q3. Logic LOW turns off the high-side FET Q3 and turns on the low-side FET Q4. When PWM input is in the tristate mode, both Q3 and Q4 are turned off. PWM logic input to the FET Q1 and Q2 as shown in the Block Diagram. Logic HIGH turns off the low-side FET Q2, and turns on the high-side FET Q1. Logic LOW turns off the high-side FET Q1 and turns on the low-side FET Q2. When PWM input is in the tristate mode, both Q1 and Q2 are turned off. Enable pin. Pull the pin high or keep it floating to enable the IC. When the device is enabled, Buck converter will start to work if VIN higher than UVLO threshold. After VDD is established, power stage responds to PWM input logic then. CONFIDEN TIAL P relimi anry D atashe et RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER VIN DEFINITION Input voltage range Input voltage range Operating junction temperature PVIN TJ MIN MAX UNIT 4.2 1 -40 20 17 125 V °C MIN MAX UNIT -2 +2 kV -1 +1 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014specification, all pins(2) (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER RθJA RθJC THERMAL METRIC Junction to ambient thermal resistance(1) Junction to case thermal resistance(1) DFN-19L 42 45 UNIT °C/W For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 3 SCT63240 (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT63240 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads of the SCT63240. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. ELECTRICAL CHARACTERISTICS VIN=VPVIN1=VPIN2=12V, VDD=5V, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION MIN Input supplies and UVLO VIN Operating input voltage PVIN Operating input voltage TYP MAX UNIT 4.2 20 V 1 17 V 3.6 400 3.8 440 1 3 V mV V mV μA VIN rising ISHDN VIN UVLO Threshold Hysteresis VDD UVLO Threshold Hysteresis Shutdown current from VIN pin ISHDN_PVIN Shutdown current from PVIN1,PVIN2 EN=0V, PVIN=12V 1 3 uA ISHDN_VDD Shutdown current from VDD 18 26 uA IVINQ Quiescent current from VIN pin IPVINQ Quiescent current from PVIN1, PVIN2 EN=0V, VDD=5.5V EN floating, VDD=5.5V, no switching, no loading on Buck and LDO EN floating, VDD=5.5V, no switching, no loading on Buck and LDO EN floating, VDD=5.5V, no switching, no loading on Buck and LDO VIN_UVLO VDD_UVLO VDD rising EN=0V, VIN=12V 210 uA 50 uA 270 uA ENABLE INPUTS and PWM logic VEN_H Enable high threshold 1.18 V VEN_L Enable low threshold 1.1 V VIH PWM1, PWM2 Logic level high V3P3=3.3V, VDD=5V VIL PWM1, PWM2 Logic level low V3P3=3.3V, VDD=5V VTS PWM1, PWM2 Tri-state voltage CONFIDEN TIAL P relimi nary D atashe et IQ Quiescent current from VDD pin 2.65 V 1.2 0.55 V 2 V Power Stage RDSON_Q1 High-side MOSFETQ1 on-resistance VBST1-VSW1=5V 13 mΩ RDSON_Q2 Low-side MOSFETQ2 on-resistance VDD=5V 13 mΩ RDSON_Q3 High-side MOSFETQ3 on-resistance VBST2-VSW2=5V 13 mΩ RDSON_Q4 Low-side MOSFETQ4 on-resistance VDD=5V 13 mΩ ILIM How-side current limit threshold Buck converter FSW Switching frequency VDD ILIM_HS THIC_W Output voltage High-side power MOSFET peak current limit threshold Over current protection hiccup wait time 4 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. 12.5 A 540 600 660 4.925 5 5.075 All Rights Reserved KHz V 1.5 A 0.85 ms SCT63240 SYMBOL PARAMETER TEST CONDITION MIN TYP MAX UNIT 27 ms RDSON_H Over current protection hiccup restart time High side FET on-resistance 380 mΩ RDSON_L Low side FET on-resistance 200 mΩ TSS Internal soft-start time 2 ms 3.3V LDO V3P3 Output voltage I3P3 Output current Capability 200 mA ISC1 Short current 50 mA THIC_R Cout=1uF, VDD=5V 2.5V REFFERENCE OUTPUT V2P5 Output voltage reference Cout=1uF, VDD=5V 3.267 2.475 3.3 2.5 3.333 2.525 V V I3P3 Output current Capability 100 mA ISC2 Short current 40 mA Current Sense VISNS0 Voltage with no input current RISNS Input current to output voltage gain IPGND=0A ,Tj=25℃ PWM1=PWM2=0V VISNS=VISNS0+IPGND*RISNS VISNS1 Voltage with 0.6A input current VISNS2 Voltage with 1A input current 0.585 0.6 0.615 V 0.98 1 1.02 V/A IPVIN=0.6A, Tj=25℃ 1.176 1.2 1.224 V IPVIN=1A, Tj=25℃ 1.568 1.6 1.632 V CONFIDEN TIAL P relimi anry D atashe et Protection TSD Thermal shutdown threshold Hysteresis TJ rising 155 35 °C °C For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 5 SCT63240 90.00 90.00 80.00 80.00 70.00 70.00 60.00 60.00 Efficiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 50.00 40.00 30.00 50.00 40.00 30.00 20.00 20.00 10.00 10.00 Vout=5V Vout=9V 0.00 0.00 0 1 2 3 4 0 5 2 6 8 10 Figure 2. Transfer Efficiency with 5W RX@ Vout=5V Figure 3. Transfer Efficiency with 10W RX@ Vout=9V 90.00 100.00 80.00 95.00 70.00 90.00 60.00 50.00 40.00 CONFIDEN TIAL P relimi nary D atashe et 30.00 20.00 10.00 Vout=12V Efficiency(%) Efficiency(%) 4 Output Power(W) Output Power(W) 85.00 80.00 75.00 VIN=5V 70.00 VIN=9V 65.00 VIN=12V 60.00 0.00 0 3 6 9 12 0 15 0.2 0.4 0.8 1 Iload(A) Output Power(W) Figure 4. Transfer Efficiency with 15W RX@ Vout=12V Figure 5. Buck Converter Efficiency 3.5 3 3 2.7 2.4 Vsense(V) 2.5 Vout(V) 0.6 2 1.5 1 2.1 1.8 1.5 1.2 0.5 0.9 0.6 0 0 0.05 0.1 0.15 0.2 0.25 0.3 0 Figure 6. 3.3V LDO Iout vs Vout 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Iin(A) Iout(A) Figure 7. Current Sense Output Voltage vs Iin 6 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 2 2.2 SCT63240 FUNCTIONAL BLOCK DIAGRAM VIN BST3 Q5 VDD Enable SW3 BUCK Controller BIAS EN logic VIN UVLO Reference EN Q6 GND AGND VDD V3P3 3.3V LDO VDD UVLO 3-stage logic PWM1 VREF 2.5V LDO 3-stage logic CONFIDEN TIAL P relimi anry D atashe et PWM2 PVN2 PVN1 Over Current Detection Over Current Detection BST2 BST1 Q1 Q3 SW1 VDD PWM1 Control PWM2 Control Q2 SW2 VD D Q4 Current sense I/V ISNS PGND Figure 8. Functional Block Diagram For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 7 SCT63240 OPERATION Overview The SCT63240 is a highly integrated power management unit optimized for wireless power transmitter applications. This device integrates the power functions required to a wireless power transmitter including 5V buck converter as power supply for external transmitter controller and internal 5V power supply to increase system efficiency, full bridge power stage to convert DC input power to AC output for driving LC resonant circuit, lossless current sensing with ±2% accuracy, 3.3V output LDO for powering MCU and a 2.5V reference voltage. The SCT63240 has four power input pins. VIN is connected to the power FETs of buck converter. PVIN1 and PVIN2 are connected to the power FETs of the full bridge and conducts high currents for power transfer. VDD is the output feedback pin of the 5V output buck converter and at the mean while as the power supply for internal two LDOs and full bridge MOSFET's gate driver. VIN and PVIN1, PVIN2 can be powered separately for more flexibility of system power design. The operating voltage range for VIN is from 4.2V to 20V. An Under-voltage Lockout(UVLO) circuit monitors the voltage of VIN pin and disable the IC operation when VIN voltage falls below the UVLO threshold of 3.2V typically. The maximum operating voltage for PVIN is up to 17V while the minimum voltage accepted can be down to 1V. Another UVLO circuit also supervise the VDD voltage which is the power supply for gate drivers of full bridge MOSFETs. Full bridge will work when VDD UVLO release. Two independent PWM signals control two separate half bridge MOSFETs with internal adaptive non-overlap circuitry to prevent the shoot-through of MOSFETs in each bridge. PWM logics are compatible for both 3.3V and 5V IOs so the SCT63240 can accept PWM signal from the controller with using either 3.3V or 5V power supply. The buck converter and full bridge of power MOSFETs includes proprietary designed gate driver scheme to resist switching node ringing without sacrificing MOSFET turn-on and turn-off time, which further erases high frequency radiation EMI noise caused by the MOSFETs hard switching. This allows the user to reduce the system cost and design effort for EMI reduction. CONFIDEN TIAL P relimi nary D atashe et The SCT63240 full protection features include VIN and VDD under-voltage lockout, over current protection with cycle-by-cycle current limit and hiccup mode, output hard short protection for buck converter and 4-MOSFETs full bridge, current limit and current fold back at hard short for two LDOs and whole chip thermal shutdown protection. Enable and Start up Sequence When the VIN pin voltage rises above 3.6V and the EN pin voltage exceeds the enable threshold of 1.18V, the buck converter and two LDOs enable at once. And the device disables when the VIN pin voltage falls below 3.2V or when the EN pin voltage is below 1.1V. VDD ramp up after buck converter works, and also the V3V and VREF output do. Once VDD rise up to 3.8V and V3V is higher than 3V, 4-MOSFETs full bridge allows PWM signal to control for switching. PWM input cannot control full bridge of MOSFETs if VDD drop to 3.36V or V3V drop to 2.7V. An internal 1.5uA pull up current source to EN pin allows the device enable when EN pin is floating to simply the system design. If an application requires a higher system under voltage lockout threshold, two external resistors divider(R1 and R2) in Figure 9 can be used to achieve an expected system UVLO. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. VIN Vrise R1 = 1.18 ∗ (1 + ) − 1.5uA ∗ R R2 1.5uA (1) EN Vfall R1 = 1.1 ∗ (1 + ) − 5.5uA ∗ R1 R2 4uA R1 (2) R2 20K + 1.21V Figure9. System UVLO by enable divider 8 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved SCT63240 5V Output Buck Converter The SCT63240 fully integrates synchronous buck converter with up to 20V input voltage and 5V fixed output voltage, which offers up to 1A output current capability. The device employs 600KHz fixed frequency peak current mode control with the internal loop compensation network and built-in 2ms soft-start which makes this buck converter easily to be used by minimizing the off-chip component count. Pulse Skipping Modulation(PSM) is adopted to improve the light load efficiency. The buck converter's output, a fixed 5V voltage, supports the power requirement on system such as transmitter controller or mechanical fan meanwhile it is also the power supply of the SCT63240's 3.3V LDO, VREF LDO and gate drivers of 4-MOSFETs full bridge. Connect 22uF capacitor from VDD to GND and add a 0.1uF local bypass ceramic capacitor placed close to the IC. The converter has proprietary designed gate driver scheme to resist switching node ringing without sacrificing MOSFET turn-on and turn-off time, which further erases high frequency radiation EMI noise caused by the MOSFETs hard switching. An external 100nF ceramic bootstrap capacitor between BST3 and SW3 pin powers floating high-side power MOSFET gate driver. The bootstrap capacitor voltage is charged from an integrated voltage regulator when highside power MOSFET is off and low-side power MOSFET is on. Buck converter implements over current protection with cycle-by-cycle limiting high-side MOSFET peak current and also low-side MOSFET valley current to avoid inductor current running away during unexpected overload and hiccup protection in output hard short condition. When overload or hard short happens, the converter cannot provide output current to satisfy loading requirement even though the inductor current has already been clamped at over current limitation. Thus, output voltage drops below regulated voltage continuously. When output voltage under regulation lasts for 850 us, the converter stops switching; After remaining OFF for 13.6 ms,the device will attempt to restart from soft-start. CONFIDEN TIAL P relimi anry D atashe et The hiccup protection mode above greatly reduces the average short circuit current to alleviate thermal issues and protect the regulator. Full bridge and PWM Control The SCT63240 integrate full bridge power stage with only 13mohm on-resistance for each power MOSFET optimized for wireless power transmitter driving the LC resonant circuit. This full bridge is able to operate in a wide switching frequency range from 20KHz to 400KHz for different applications which is completely compatible with WPC's frequency requirement from 100KHz to 205KHz. PWM1 input controls the half bridge comprised of high side MOSFET Q1 and low side MOSFET Q2, and PWM2 input controls the half bridge comprised of high side MOSFET Q3 and low side MOSFET Q4 as shown in block diagram. The PWM1 and PWM2 independently control the SW1 and SW2 duty cycle and frequency. Logic HIGH will turn off low side FET and turn on high side FET, and logic LOW will turn off high side FET and turn on low side FET. PWM1 and PWM2 also support tri-state input. When PWM input logic first enters tri-state either from logic HIGH or logic LOW, the states of its controlled FETs stay the same. If the PWM input stays in the tri-state for more than 60ns, its controlled FETs are all turned off, and the corresponding SW output becomes high impedance. The FETs stay off until the PWM logic reaches logic HIGH or logic LOW threshold. An external 100nF ceramic bootstrap capacitor between BST1 and SW1 pin powers floating high-side power MOSFET Q1's gate driver, and the other 100nF bootstrap capacitor between BST2 and SW2 pin powers for the Q2's. When low side FET is on which means SW is low, the bootstrap capacitor is charged through internal path by VDD power supply rail. PWM cannot been kept as high level for more than 2ms since the voltage of bootstrap capacitor will be discharged by internal leakage current if high side FET keeps on. For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 9 SCT63240 Full Bridge Over Current Protection The SCT63240 integrates cycle-by-cycle current limit and hiccup mode for over-current protection. The current of the high side FET Q1 和 Q3 is sensed and compared to the current limit threshold during each switching cycle. If the current exceeds the threshold, 12.5A typical, the high side FET turns off immediately in present cycle to avoid current increasing even PWM signal is still kept in high level. The over current counter is incremented. If one high side FET occurs over current in 5 consecutive cycles, then all 4 internal FETs are turned off regardless of the PWM inputs. The full bridge enters hiccup mode and will attempt to restart after a time-out period of 24ms typically. Current Sense The SCT63240 has a proprietary lossless average current sensing circuit that measures the average input current of full bridge with ±2% accuracy and reports a proportional voltage directly to the ISNS pin. This voltage information on ISNS pin can be send to specialized controller or general MCU for Foreign Object Detection FOD and current demodulation. When the full bridge of MOSFETs does not work, no current flows to PGND. The DC bias voltage on ISNS pin is 600mV.This DC bias helps set up a suitable voltage bias for the following analog to digital converter in MCU or amplifier for current demodulation. The average input current to voltage conversion gain on ISNS is 1V/A. The equation 3 represent the corresponding relation for the output voltage on ISNS pin and average current to PGND from full bridge. VISNS = 600mV + IPGND ∗ 1V/A (3) 3.3V LDO The SCT63240 has an integrated low-dropout voltage regulator which powered from VDD and supply regulated 3.3V voltage on V3V pin. The output current capability is 200mA. This LDO can be used to bias the supply voltage of MCU directly. It is recommended to connect a decoupling ceramic capacitor of 1uF to 10uF to the V3V pin. Capacitor values outside of the range may cause instability of the internal linear regulator. CONFIDEN TIAL P relimi nary D atashe et VREF Voltage Reference Output The SCT63240 also has an integrated low-dropout voltage regulator which powered from VDD and supply regulated 2.5V voltage on VREF pin. The accuracy of the VREF voltage is ±1% and output current capability is 100mA . This voltage regulator can be used as the supply voltage or a reference voltage to external IC and circuit. It is recommended to connect a decoupling ceramic capacitor of 1uF to 10uF to the VREF pin. Capacitor values outside of the range may cause instability of the internal linear regulator. Thermal Shutdown The SCT63240 protects the device from the damage during excessive heat and power dissipation condition. Once the junction temperature exceeds 155C, the thermal sensing circuit stops Buck converter, two LDOs and full bridge of 4-MOSFETs' working. When the junction temperature falls below 120C, then the device restarts. 10 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved SCT63240 APPLICATION INFORMATION Typical Application VIN=4.2V~17V 4 C6 10uF 7 C8 22uF 5V C5 0.1uF 5 C7 0.1uF 6 L1 10uH VIN PVIN1 GND PGND BST3 PVIN2 SW1 VDD C9 1uF C1 0.1uF C2 22uF 3 C3 0.1uF C4 22uF 13 R2 0ohm C12 0.1uF SW2 V3P3 C10 1uF BST2 EN 18 R5 100K ISNS PWM1 17 PWM2 C14 12 11 10 R1 0ohm 19 PWM1 R4 SCT63240 9 3.3V 2 SW3 BST1 8 1 VREF PWM2 AGND C11 0.1uF R3 C13 15 14 16 2.5V C15 1uF R6 100K CONFIDEN TIAL P relimi anry D atashe et Figure 10. Same Input to VIN and PVIN VIN=4.2V~20V 4 C6 10uF 7 C8 22uF L1 5V C5 0.1uF 5 C7 0.1uF 6 10uH PVIN1 VIN GND PGND BST3 PVIN2 VDD=5V 8 VDD C9 1uF 9 3.3V 2 C1 0.1uF C2 22uF 3 C3 0.1uF C4 22uF SW3 BST1 SW1 PVIN=1V~17V 1 13 R2 0ohm 18 17 PWM2 R5 100K C14 12 V3P3 SW2 BST2 11 10 R1 0ohm PWM1 R4 SCT63240 C10 1uF 19 C12 0.1uF EN PWM1 PWM2 ISNS VREF AGND C11 0.1uF R3 C13 15 14 16 2.5V C15 1uF R6 100K Figure 11. Separate Input to VIN and PVIN For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 11 SCT63240 Application Waveforms Figure 12. Power Up Figure 13. Power Down CONFIDEN TIAL P relimi nary D atashe et Figure 14. VDD Ripple and SW3 @VIN=9V, IOUT=20mA Figure 15. VDD Ripple and SW3 @VIN=9V, IOUT=600mA Figure 16. Full bridge @Vin=5V, RX=5W Figure 17. Full bridge @Vin=9V, RX=10W 12 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved SCT63240 Layout Guideline Proper PCB layout is a critical for SCT63240’s stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 1. 2. 3. 4. 5. 6. 7. 8. 9. Bypass capacitors from PVIN to PGND should put next to PVIN and PGND pin as close as possible especially for the two small capacitors. PGND connect to bottom layer by via between capacitors. Bypass capacitors from VIN to GND should put next to VIN and GND pin as close as possible especially for the small capacitor. Buck converter output capacitor's ground should connect to GND directly to minimize the power loop. VDD pin can connect to the DC/DC's output capacitor from bottom layer, connect to the point behind the capacitor while not connect to inductor. Bypass capacitor for VDD place next to VDD pin. Bypass capacitor for V3P3 place next to V3P3 pin. Bypass capacitor for VREF place next to VREF pin. AGND pin connect to common ground by Kelvin connection. CONFIDEN TIAL P relimi anry D atashe et Figure 24. PCB Layout Example For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 13 SCT63240 PACKAGE INFORMATION CONFIDEN TIAL P relimi nary D atashe et FCQFN-19L (3x4) Package Outline Dimensions Symbol A A1 b b1 c D Nd Ne e e1 E L L1 L2 L3 L4 Min. 0.80 0 0.20 2.90 3.90 0.35 1.95 0.45 2.25 0.075 Dimensions in Millimeters Nom. 0.85 0.02 0.25 0.18 REF 0.203 REF 3.00 2.50 BSC 2.00 BSC 0.50 BSC 1.00 BSC 4.00 0.40 2.00 0.50 2.30 0.125 Max. 0.90 0.05 0.30 3.10 4.10 0.45 2.05 0.55 2.35 0.175 NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. 14 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved SCT63240 TAPE AND REEL INFORMATION Orderable Device SCT63240FIAR Reel Width 12 Package Type QFN 3mmx4mm A Ø329±1 Pins 19 SPQ 5000 REEL DIMENSIONS B C 12.8±1 Ø100±1 D Ø13.3±0.3 t 2.0±0.3 CONFIDEN TIAL P relimi anry D atashe et TAPE DIMENSIONS W (mm) A0 (mm) B0 (mm) K0 (mm) t (mm) P (mm) 12+0.30 −0.10 3.40±0.10 4.40±0.10 1.14±0.10 0.25±0.02 8±0.10 E (mm) F (mm) P2 (mm) D (mm) D1 (mm) P0 (mm) 10P0 (mm) 1.75±0.10 5.50±0.05 2.00±0.05 1.500+0.10 1.500+0.25 4.00±0.10 40.0±0.20 For more information www.silicontent.com© 2018Silicon Content Technology Co., Ltd. All Rights Reserved 15 SCT63240 RELATED PARTS PN DESCRIPTION SCT63241 COMMENTS 20W High-Integration, HighEfficiency PMIC for Wireless Power Transmitter Optimize for 5W and multi-coil TX No 5V-1A Step-down DC/DC converter compared with SC63240. External 5V power supply is needed. • • • • • • • • • • • • VIN=4.2V~20V 4 C6 10uF C5 0.1uF 5 6 7 VIN Input Voltage Range: 4.2V-20V PVIN Input Voltage Range: 1V~17V Up to 20W Power Transfer Integrated High Efficiency Full-Bridge Power Stage Optimized for EMI Build in 3.3V-200mA LDO Provide 2.5V Voltage Reference Integrated Input Current sense with ±2% accuracy for FOD and modulation 3.3V and 5V PWM Signal compatible Input Under-Voltage Lockout Over current protection 3mm*4mm QFN-19L Package PVIN1 VIN GND PGND GND PVIN2 VDD=5V 8 VDD C9 1uF 9 3.3V 2 C1 0.1uF C2 22uF 3 C3 0.1uF C4 22uF NC BST1 SW1 PVIN=1V~17V 1 13 R2 0ohm 18 17 PWM2 R5 100K C14 12 V3P3 SW2 BST2 11 10 R1 0ohm PWM1 R4 SCT63241 C10 1uF 19 C12 0.1uF EN PWM1 PWM2 ISNS VREF AGND C11 0.1uF R3 C13 15 14 16 2.5V C15 1uF R6 100K Figure 25. SCT63241 Typical Application NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 16 Silicon Content Technology Co., Ltd. #1 Floor 2 Building 15, Yard 33 Dijin Road, Haidian District, Beijing 100095 TEL:(8610) 64779806 FAX: (8610) 64779806 www.silicontent.com© Silicon Content Technology
SCT63240FIAR 价格&库存
很抱歉,暂时无法提供与“SCT63240FIAR”相匹配的价格&库存,您可以联系我们找货
