ASD2613-R
ASD2613-R
    TINYCIRCUITS
    ASD2613-R
ASD2613-R 数据手册
    COMPASS TINYSHIELD ASD2613-R     DESCRIPTION This TinyShield features the high performance and low power Honeywell HMC5883L 3-axis compass. The HMC5883L includes state-of-the-art, high-resolution HMC118X series magneto-resistive sensors plus an ASIC containing amplification, automatic degaussing strap drivers, offset cancellation, and a 12-bit ADC that enables 1° to 2° compass heading accuracy. The Compass TinyShield incorporates level shifters and a local power supply to ensure proper and safe operation over the entire TinyDuino operating voltage range up to 5V. TECHNICAL DETAILS To see what other TinyShields this will work with or conflict with, check out the TinyShield Compatibility Matrix Honeywell HMC5883L Compass Specs o 3-axix (X, Y & Z) o Digital resolution: 12bit (2 milli-gauss Field Resolution in ±8 Gauss Fields) o 1° to 2° Degree Compass Heading Accuracy o Wide Magnetic Field Range (+/-8 Oe) o Low Power: 100uA TinyDuino Power Requirements o Voltage: 3.0V - 5.5V o Current: 100uA Due to the low current, this board can be run using the TinyDuino coin cell option Pins Used o A5/SCL - I2C Serial Clock line o A4/SDA - I2C Serial Data line Dimensions o 20mm x 20mm (.787 inches x .787 inches) o Max Height (from lower bottom TinyShield Connector to upper top TinyShield Connector): 5.11mm (0.201 inches) o Weight: .96 grams (.03 ounces) NOTES o You can also use this shield without the TinyDuino – there are 0.1″ spaced connections for power, ground, and the two I2C signals along the side of the TinyShield to allow you to connect a different system.        https://tinycircuits.com/products/compass‐tinyshield 10‐16‐17
ASD2613-R 价格&库存
很抱歉,暂时无法提供与“ASD2613-R”相匹配的价格&库存,您可以联系我们找货
ASD2613-R
  • 2+131.434782+17.07271
