B3155-30-A
B3155-30-A
    GCT
    B3155-30-A
B3155-30-A 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number   USB3155 A Rev Micro USB Receptacle, Type B, SMT, Horizontal, Mid-Bottom Mount USB3155 AO Prepared Checked VJ Date 09/10/14 Page 1  Approved ST                         PRELIMINARY     www.gct.co     PRODUCT SPECIFICATION Part Number Product Description Doc Number   USB3155 A Rev Micro USB Receptacle, Type B, SMT, Horizontal, Mid-Bottom Mount USB3155 AO Prepared Checked VJ Date 09/10/14 Page 2  Approved ST 1.0 SCOPE.   This specification covers performance, tests and quality requirements for the Micro USB Receptacle. USB3155 (Type B, SMT, Horizontal, Mid-Bottom Mount).     2.0 PRODUCT NAME AND PART NUMBER. Micro USB Receptacle, 5 Pin, Type B: USB3155. 3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL. Please refer to drawings. 4.0 RATINGS. 4.1 Current rating: Signal (Pins 2, 3, 4) 1.0A Power (Pins1, 5)..... 1.8A 4.2 Voltage rating ……………………… 30V AC 4.3 Operating Temperature Range …… -30°C to +85°C  5.0 TEST AND MEASUREMENT CONDITIONS. Product is designed to meet electrical, mechanical and environmental performance requirements specified in Paragraph 6.0. All tests are performed in ambient conditions unless otherwise specified. 6.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional inspection as per quality plan. Product shall meet requirements of product drawing and specification. www.gct.co     PRODUCT SPECIFICATION Part Number Product Description Doc Number   USB3155 A Rev Micro USB Receptacle, Type B, SMT, Horizontal, Mid-Bottom Mount USB3155 AO Prepared Checked VJ Date 09/10/14 Page 3  Approved 6.1 Electrical Performance. Item Test Condition Requirement Low-signal Level Contact Resistance (initial) Mate connectors, measure by dry circuit, 20 mV, 100mA Max. In accordance with EIA-364-23. 30 mΩ Max. Insulation Resistance Mate connectors, apply 100V DC for 1 minute at sea level between adjacent terminal or ground. In accordance with EIA-364-21. 1000 MΩ Min. Dielectric Strength Mate connectors, apply 100V AC for 1 minute at sea level. In accordance with EIA-364-20. No Breakdown. 6.2 Mechanical Performance. Item Test Condition Requirement Mating/Un-mating Force (initial) Mate/Un-mated at a rate of 12.5mm/min. In accordance with EIA-364-13. Mating force: 35N Max. Un-Mating force: 8N Min. to 25N Max. Cycle rate, 500 cycles per hour if done automatically and 200 if manual cycles. In accordance with EIA-364-09. 10,000 cycles. Low Level Contact Resistance: 10mΩ Max. change allowed Mating force: 35N Max. Un-Mating force: 8N Min. to 25N Max. Durability Vibration Mechanical Shock Mate connectors and subject to 5.35 Gs RMS. For a period of 15 minutes in each of the 3 mutually perpendicular axes. In accordance with EIA-364-28 Test condition V test letter A. Mate connectors and subject to the following shock conditions, 3 shocks shall be applied along 3 mutually perpendicular axis, passing 100 mA current during the test. (Total of 18 shocks) Test Pulse: Half Sine Peak Value: 294 m/s² (30G) Duration: 11ms. In accordance with EIA-364-27. Test condition H. www.gct.co     Appearance: No Damage. Contact Resistance: 10mΩ Max. change allowed Discontinuity: 1.0µ second Max. Appearance: No Damage. Contact Resistance: 10mΩ Max. change allowed. Discontinuity: 1.0µ second Max. ST PRODUCT SPECIFICATION Part Number Product Description Doc Number   USB3155 A Rev Micro USB Receptacle, Type B, SMT, Horizontal, Mid-Bottom Mount USB3155 AO Prepared Checked VJ Date 09/10/14 Page 4  Approved ST 6.3 Environmental Performance and Others. Item Test Condition Requirement Cyclic Humidity Test Subject mated connectors to Duration: 168 hours(7 cycles) temperature between -25°C to +65°C with 90 to 95% RH. In accordance with EIA-364-31. Test condition A method III Appearance: No Damage. Contact Resistance: 10mΩ Max. change allowed. Insulation Resistance: 1000 MΩ Min. Dielectric Strength: No Breakdown. Salt Spray Subject mated/unmated connectors to 5% salt-solution concentration, 35°C for 48 hours. In accordance with EIA-364-26, Test Condition B. Low Level Contact Resistance: 50mΩ Max. No visible rust Temperature Life Subject mated connectors to temperature life at +85°C for 96hours. In accordance with EIA-364-17. Test condition 2 Method A. Contact Resistance: 10mΩ Max. change allowed. no physical damage. Temperature Rise Mate connector and measure the temperature rise of contact when the maximum AC rated current is passed and in accordance with EIA-364-70. +30°C Max. change allowed. Thermal Shock Mate module and subject to follow condition for 10 cycles. At -55°C to +85°C. In accordance with EIA-364-32, test condition I. Solderability Dip solder-tails in flux then immerse in solder bath at 245 ±5°C up to 0.5mm from the bottom of the housing for 4~5 seconds. In accordance with EIA-364-52, category 2. 95% of immersed area must show no voids, pin holes. Resistance to Soldering Heat (Reflow Soldering) Sample mounted on PCB and subject to solder bath method, Temperature:260°C for 10±1 sec (High Temp. Thermoplastic). In accordance with EIA-364-56. Without deformation of shell or excessive looseness of the terminals (pin.) Resistance to Soldering Heat (Hand Soldering) Sample mounted on PCB and subject to hand iron soldering, Temperature:350±10°C for 3±1 sec (High Temp. Thermoplastic). Without deformation of shell or excessive looseness of the terminals (pin.)   www.gct.co     No Damage 10mΩ Max. change allowed. PRODUCT SPECIFICATION Part Number Product Description Doc Number   USB3155 A Rev Micro USB Receptacle, Type B, SMT, Horizontal, Mid-Bottom Mount USB3155 AO Prepared VJ Checked Date 09/10/14 Page 5  Approved   7.0 RESISTANCE TO INFRARED REFLOW SOLDERING HEAT 7.1 Lead Free Process: Reflow soldering cycles limited to two times Temp 260ºC   TEMPERATURE ON BOARD PATTERN SIDE Peak temp 260ºC MAX.(10sec. Max)   200ºC Min   40 sec. Min     Slope
B3155-30-A 价格&库存
很抱歉,暂时无法提供与“B3155-30-A”相匹配的价格&库存,您可以联系我们找货
