0.10 PIN
2.5
0.35
9.0
0.57
14.5
A
0.30
7.6
28°
10°
0.25
6.3
0.43
11.0
0.140
3.56
0.040
1.02
0.030
0.76
CENTER
PIN
SLEEVE
SHUNT
0.26
6.5
0.05 TYP
1.3
0.120
3.05
SLEEVE
CENTER
PIN
0.14
3.4
3 PLACES
0.02
0.5
SLEEVE
A
0.02
0.5
0.008
0.20
0.10
2.5
0.030
0.76
SLEEVE
SHUNT
0.29
7.5
0.42
10.7
RECOMMENDED PC BOARD LAYOUT
(COMPONENT SIDE)
0.120
3.05
SLEEVE
SHUNT
0.140
3.56
CENTER
PIN
CENTER PIN
SLEEVE SHUNT
SLEEVE
0.120
3.05
SLEEVE
NOTES:
0.24
6.0
REF
1. THIS PRODUCT IS RoHS COMPLIANT.
2. MATERIALS:
CENTER PIN: COPPER ALLOY, NICKEL PLATED
SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED
PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED
HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK
0.24
6.0
REF
1. ALL DIMENSIONS IN INCHES [mm]
- TWO PLACE DECIMALS
0.02 [0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
SIZE
REV
ECO NUMBER
DATE
REVISIONS
PC
BY
10-12-17
DO NOT SCALE DRAWING
SolidWorks CAD File
MULT
NAME
TEMPER
BY
SRC
SPEC No.
SCALE
4:1
CHKD
TJK
8/17/18
APVD
TJK
8/17/18
LOCKING POWER JACK,
PC TERMINALS, 0.10 [2.5 mm], RoHS
B
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
TJK
APVD
WIDTH
FINISH
DATE DRAWN
08-30-18
0.423
10.74
CUSTOMER DRAWING
SECTION A-A
UNLESS OTHERWISE SPECIFIED
0.541
13.74
ALTERNATE PC BOARD LAYOUT
(COMPONENT SIDE)
JACK MATING FACE
(EDGE OF PC BOARD)
STAR SYMBOL DENOTES CRITICAL DIMENSION
28064
0.295
7.49
0.189
4.80
SCHEMATIC
A
0.189
4.80
JACK MATING FACE
(EDGE OF PC BOARD)
LOCKING SHOULDER
3. SPECIFICATIONS:
LIFE: 5000 CYCLES;
INSERTION FORCE: 5LB [2.3 KG] MAX;
WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN;
CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST;
INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC;
DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE;
CURRENT (CARRYING): 5A
OPERATING TEMPERATURE: -30 C TO +65 C
0.295
7.49
LOCKING GROOVE
0.54
13.8
0.423
10.74
0.12
3.0
0.19
4.7
0.10
2.5
0.120
3.05
0.541
13.74
SHEET
PART No.
1
OF
1
RAPC712BKZ
REV
A
很抱歉,暂时无法提供与“RAPC712BKZ”相匹配的价格&库存,您可以联系我们找货
