ME6212C12M5G
ME6212C12M5G
    MICRONE(南京微盟)
    SOT23-5
    IC LDO 1.2V 500mA 2% SOT23-5 Microne
ME6212C12M5G 数据手册
ME6212 High Speed LDO Regulators, High PSRR, Low noise, ME6212 Series General Description Features The ME6212 series are highly accurate, low noise,  Maximum Output Current: 350mA (VIN=4.3V,VOUT=3.3V) CMOS LDO Voltage Regulators. Offering low output noise, high ripple rejection ratio, low dropout and very  Dropout Voltage: 120mV@ IOUT =100mA fast turn-on times, the ME6212 series is ideal for  Operating Voltage Range: 2V~6.0V today’s cutting edge mobile phone. Internally the  Highly Accuracy: ±2% ME6212 includes a reference voltage source, error  Low Power Consumption: 50uA(TYP.) amplifiers, driver transistors, current limiters and phase  Standby Current: 0.1uA(TPY.) compensators. The ME6212’s current limiters' foldback  High Ripple Rejection: 65dB@1KHz(ME6212C33) circuit also operates as a short protect for the output  Low output noise: 50uVrms current limiter and. the output pin. The ME6212 series is  Line Regulation: 0.05%(TYP.) also fully compatible with low ESR ceramic capacitors, reducing cost and improving output stability. This high level of output stability is maintained even during frequent load fluctuations, due to the excellent transient response performance and high PSRR achieved across a broad range of frequencies.The CE function allows the output of regulator to be turned off, resulting in greatly reduced power consumption. Typical Application Package  Mobile phones   Cordless phones, radio communication equipment  Portable games  Cameras, Video cameras  Reference voltage sources  Battery powered equipment V06 www.microne.com.cn 5-pin SOT23-5 Page 1 of 14 ME6212 Typical Application Circuit VIN Vout VSS ME6212 CE NC CIN 1uF Selection Guide CIN 1uF ME6212C30M5G表面丝印内容:CGXX 说明:CG是料号固定代码,XX是年月不固定 ME 62 12 X XX XX G Environment mark Package M5:SOT23-5 Output Voltage 33:3.3V …… Version or Function Product Type Product Series Microne product series Output voltage Package ME6212C12M5G 1.2V SOT23-5 ME6212C15M5G 1.5V SOT23-5 ME6212C18M5G 1.8V SOT23-5 ME6212C21M5G 2.1V SOT23-5 ME6212C25M5G 2.5V SOT23-5 ME6212C28M5G 2.8V SOT23-5 ME6212C29M5G 2.9V SOT23-5 ME6212C30M5G 3.0V SOT23-5 ME6212C33M5G 3.3V SOT23-5 ME6212C50M5G 5.0V SOT23-5 NOTE: If you need other voltage and package, please contact our sales staff。 V06 www.microne.com.cn Page 2 of 14 ME6212 Pin Configuration VOUT NC 5 4 1 2 3 VIN VSS CE SOT23-5 Pin Assignment Pin Number Pin Name Functions 1 VIN Power Input 2 VSS Ground 3 CE ON / OFF Control 4 NC No Connect 5 VOUT Output SOT23-5 Block Diagram V06 www.microne.com.cn Page 3 of 14 ME6212 Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 6.5 V Output Current IOUT 500 mA Output Voltage VOUT Vss-0.3~VIN +0.3 V CE Pin Voltage VCE Vss-0.3~VIN +0.3 V Power Dissipation SOT23-5 PD 0.6 W Thermal resistance (Junction to air) SOT23-5 θJA 210 ℃/W Operating Ambient Temperature Range TOPR -40 ~ +85 ℃ Junction Temperature TJ -40 ~ +150 ℃ Storage Temperature Range TSTG -55 ~ +150 ℃ Electrical Characteristics ME6212C12 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC ,unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V Maximum Output Current IOUTMAX VIN= VOUT+1V Load Regulation ∆VOUT Dropout Voltage VDIF1 (Note 1) Output Voltage Min. X 0.98 Typ. VOUT (T) (Note 1) Max. Units X 1.02 V 250 mA 8 mV IOUT =100mA 280 mV VDIF2 IOUT =200mA 500 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.03 %/V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Line Regulation Output noise VIN= VOUT+1V , 1mA≤IOUT≤100mA 1.0 V 0.5 50 IOUT=10mA, Ripple Rejection Rate PSRR VIN = [VOUT +1]V 1kHZ +1Vp-pAC IOUT=100mA, V uVrms 65 dB 57 10kHZ ME6212C15 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Output Voltage V06 Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V www.microne.com.cn Min. X 0.98 Typ. VOUT (T) (Note 1) Max. Units X 1.02 V Page 4 of 14 ME6212 Maximum Output Current IOUTMAX Load Regulation ∆VOUT Dropout Voltage VDIF1 (Note 1) 250 mA 9 mV IOUT =100mA 200 mV VDIF2 IOUT =200mA 400 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.05 %/V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Line Regulation Output noise VIN= VOUT+1V VIN= VOUT+1V , 1mA≤IOUT≤100mA 1.0 V 0.5 50 IOUT=10mA, Ripple Rejection Rate PSRR VIN= [VOUT +1]V 1kHZ +1Vp-pAC IOUT=100mA,1 V uVrms 65 dB 57 0kHZ ME6212C18 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V IOUTMAX VIN= VOUT+1V 250 mA Load Regulation ∆VOUT VIN= VOUT+1V , 1mA≤IOUT≤100mA 9 mV Dropout Voltage VDIF1 IOUT =100mA 200 mV (Note 1) VDIF2 IOUT =200mA 400 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.05 %/V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Output Voltage Maximum Output Current Line Regulation Output noise Ripple Rejection Rate ME6212C21 VIN = [VOUT +1]V+1Vp-pAC X 0.98 Typ. VOUT (T) (Note 1) Max. Units X 1.02 V 1.0 V 0.5 50 IOUT=10mA,1kHZ 65 IOUT=100mA,10kHZ 57 V uVrms dB (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Output Voltage V06 PSRR Min. Symbol Conditions Min. Typ. Max. Units VOUT(E) (Note 2) IOUT=30mA, VIN= VOUT+1V X 0.98 VOUT (T) (Note 1) X 1.02 V www.microne.com.cn Page 5 of 14 ME6212 Maximum Output Current IOUTMAX VIN= VOUT+1V 300 mA Load Regulation ∆VOUT VIN= VOUT+1V,1mA≤IOUT≤100mA 9 mV Dropout Voltage (Note 1) VDIF1 IOUT =100mA 200 mV VDIF2 IOUT =200mA 400 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA Line Regulation ∆VOUT ∆VIN • VOUT IOUT =40mA VOUT+1V ≤VIN≤6.5V 0.04 %/V CE“High”Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Output noise Ripple Rejection Rate Short-circuit Current ME6212C25 VIN=[VOUT+1] V+1Vp-pAC PSRR 1.0 0.5 50 IOUT=10mA, 1kHZ 65 IOUT=100mA, 10kHZ 57 IOUT=200mA, 10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT =0V ISHORT V V uVrms dB 150 mA (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units Output Voltage VOUT(E) (Note 2) IOUT=30mA, VIN= VOUT+1V X 0.98 VOUT (T) (Note 1) X 1.02 V Maximum Output Current IOUTMAX VIN= VOUT+1V 300 mA Load Regulation ∆VOUT VIN=VOUT+1V, 1mA≤IOUT≤100mA 9 mV Dropout Voltage (Note 1) VDIF1 IOUT =100mA 110 mV VDIF2 IOUT =200mA 220 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA Line Regulation ∆VOUT ∆VIN • VOUT IOUT =40mA VOUT+1V ≤VIN≤6.5V 0.04 %/V CE“High”Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Output noise Ripple Rejection Rate Short-circuit Current V06 PSRR ISHORT VIN=[VOUT+1] V+1Vp-pAC V 0.5 50 IOUT=10mA, 1kHZ 65 IOUT=100mA, 10kHZ 57 IOUT=200mA, 10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT=0V www.microne.com.cn 1.0 150 Page 6 of 14 V uVrms dB mA ME6212 ME6212C28 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V Maximum Output Current IOUTMAX VIN= VOUT+1V Load Regulation ∆VOUT Dropout Voltage VDIF1 (Note 1) Output Voltage Min. X 0.98 Typ. VOUT(T) (Note1) Max. Units X 1.02 V 350 mA 7 mV IOUT =100mA 110 mV VDIF2 IOUT =200mA 220 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA ∆VOUT I OUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.04 %/V CE“High”Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Line Regulation Output noise VIN= VOUT+1V , 1mA≤IOUT≤100mA 1.0 0.5 50 IOUT=10mA, PSRR VIN=[VOUT+1]V IOUT=100mA, +1Vp-pAC 10kHZ dB 57 10kHZ ISHORT uVrms 57 IOUT=200mA, Short-circuit Current V 65 1kHZ Ripple Rejection Rate V VIN= VOUT+1V, VCE=VIN, VOUT=0V 120 mA ME6212C29 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V IOUTMAX VIN= VOUT+1V 350 mA Load Regulation ∆VOUT VIN= VOUT+1V ,1mA≤IOUT≤100mA 7 mV Dropout Voltage VDIF1 IOUT =100mA 110 mV (Note 1) VDIF2 IOUT =200mA 220 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0.1 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.04 %/V CE“High”Voltage VCEH Start up CE “Low” Voltage VCEL Shut down Output Voltage Maximum Output Current Line Regulation V06 www.microne.com.cn Min. X 0.98 Typ. VOUT (T) (Note 1) Max. Units X 1.02 V 1.0 V 0.5 Page 7 of 14 V ME6212 Output noise Noise Ripple Rejection Rate Short-circuit Current ME6212C30 PSRR ISHORT uVrm 50 IOUT =40mA,300Hz~50kHz VIN IOUT=10mA,1kHZ 65 =[VOUT+1]V IOUT=100mA,10kHZ 57 +1Vp-pAC IOUT=200mA, 10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT=0V s dB 120 mA (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V IOUTMAX VIN= VOUT+1V 350 mA Load Regulation ∆VOUT VIN= VOUT+1V , 1mA≤IOUT≤100mA 8 mV Dropout Voltage VDIF1 IOUT =100mA 100 mV (Note 1) VDIF2 IOUT =200mA 210 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.05 %/V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Output Voltage Maximum Output Current Line Regulation Output noise Ripple Rejection Rate Short-circuit Current ME6212C33 PSRR ISHORT VIN=[VOUT +1]V+1Vp-pAC Min. X 0.98 Typ. VOUT (T) (Note 1) Max. Units X 1.02 V 1.0 V 0.5 50 IOUT=10mA,1kHZ 65 IOUT=100mA,10kHZ 57 IOUT=200mA,10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT=0V V uVrms dB 150 mA (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V IOUTMAX VIN= VOUT+1V 350 mA Load Regulation ∆VOUT VIN= VOUT+1V , 1mA≤IOUT≤100mA 9 mV Dropout Voltage VDIF1 IOUT =100mA 120 mV (Note 1) VDIF2 IOUT =200mA 260 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-byCurrent ICEL VCE=0V 0.1 μA Output Voltage Maximum Output Current V06 www.microne.com.cn Min. X0.98 Typ. VOUT (T) (Note 1) Max. Units X1.02 V Page 8 of 14 ME6212 ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Line Regulation Output noise Ripple Rejection Rate Short-circuit Current PSRR ISHORT VIN=[VOUT+1]V +1Vp-pAC 0.05 1.0 V 0.5 50 IOUT=10mA,1kHZ 65 IOUT=100mA,10kHZ 57 IOUT=200mA,10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT=0V %/V 14 V uVrms dB 28 50 mA Typ. Max. Units X 1.02 V ME6212C50 (VIN= VOUT+1V,VCE = VIN,CIN=CL=1uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions VOUT(E) IOUT=30mA, (Note 2) VIN= VOUT+1V IOUTMAX VIN= VOUT+1V 350 mA Load Regulation ∆VOUT VIN= VOUT+1V , 1mA≤IOUT≤100mA 8 mV Dropout Voltage VDIF1 IOUT =100mA 100 mV (Note 1) VDIF2 IOUT =200mA 200 mV Supply Current ISS VIN= VOUT+1V 50 μA Stand-by Current ICEL VCE=0V 0 μA ∆VOUT IOUT =40mA ∆VIN • VOUT VOUT+1V ≤VIN≤6.5V 0.05 %/V CE “High” Voltage VCEH Start up CE “Low” Voltage VCEL Shut down EN IOUT =40mA,300Hz~50kHz Output Voltage Maximum Output Current Line Regulation Output noise Ripple Rejection Rate Short-circuit Current PSRR ISHORT VIN= [VOUT+1]V +1Vp-pAC Min. VOUT X 0.98 (T) (Note 1) 1.0 V 0.7 50 IOUT=10mA,1kHZ 65 IOUT=100mA,10kHZ 57 IOUT=200mA,10kHZ 57 VIN= VOUT+1V, VCE=VIN, VOUT=0V 130 V uVrms dB mA Note : 1. VOUT (T) :Specified Output Voltage 2.VOUT (E) :Effective Output Voltage ( le. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while maintaining a certain Iout value.) 3.VDIF:VIN1 –VOUT (E)’ VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout {VOUT (T)+1.0V} is input. V06 www.microne.com.cn Page 9 of 14 ME6212 Type Characteristics (1) )Input VoltageVS.Output Voltage(Ta = 25 °C) ME6212C33M5G ME6212C30M5G Input Voltage VS.Output Voltage Input Voltage VS.Output Voltage 3.8 3.5 3 Output Voltage(V) Output Voltage(V) 3.4 1mA 2.6 50mA 2.2 1.8 3 1mA 2.5 50mA 2 100mA 100mA 1.5 1.4 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 1.5 6.5 2 2.5 3 3.5 Input Voltage(V) 5 5.5 6 6.5 ME6212C18M5G Input Voltage VS.Output Voltage Input Voltage VS.Output Voltage 1.9 Output Voltage(V) 3.2 Output Voltage(V) 4.5 Input Voltage(V) ME6212C28M5G 2.8 1mA 2.4 2 50mA 1.6 100mA 1.8 1.7 1mA 1.6 1.5 50mA 1.4 1.3 100mA 1.2 1.2 1.1 1.5 2.5 3.5 4.5 5.5 6.5 1.5 2.5 3.5 Input Voltage(V) 5.5 6.5 ME6212C30M5G Input Voltage VS.Supply Current Input Voltage VS.Supply Current 120 100 100 Supply Current(uA) 120 80 60 40 20 80 60 40 20 0 0 0 V06 4.5 Input Voltage(V) (2)Input Voltage VS. Supply Current(Ta = 25 °C) ME6212C33M5G Supply Current(uA) 4 0.5 1 1.5 2 2.5 3 3.5 4 Input Voltage(V) 4.5 5 5.5 6 6.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 Input Voltage(V) www.microne.com.cn Page 10 of 14 6 6.5 ME6212 ME6212C28M5G ME6212C18M5G Input Voltage VS.Supply Current Input Voltage VS.Supply Current 60 100 Supply Current(uA) Supply Current(uA) 120 80 60 40 20 50 40 30 20 10 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Input Voltage(V) 4.5 5 5.5 6 0 6.5 0.5 1 1.5 2 2.5 (3)Output Voltage VS. Output Current 3.5 4 4.5 5 5.5 4 3.35 3.5 3 3.25 2.5 3.2 Vout 3.3 Vout 2 V o u t 1.5 3.15 1 3.1 0.5 3.05 0 3 0.001 200 400 600 800 Iout(mA) 0.01 0.1 -0.5 1 10 100 R (5)Power Dissipation(W) VS Ambient Temperature 0.6 Power Dissipation(W) 0.5 0.4 0.3 0.2 0.1 0 0 12.5 25 37.5 50 62.5 75 87.5 100 112.5 125 Ambient Temperature(℃) V06 6.5 Vout vs R 3.4 0 6 (4)Output Voltage VS. Output Load R Vout vs Iout Vout(V) 3 Input Voltage(V) www.microne.com.cn Page 11 of 14 ME6212 (6)PSRR ME6212C18M5G V06 ME6212C28M5G www.microne.com.cn Page 12 of 14 ME6212 Packaging Information  SOT23-5 DIM Millimeters Inches Min Max Min Max A 1.05 1.45 0.0413 0.0571 A1 0 0.15 0.0000 0.0059 A2 0.9 1.3 0.0354 0.0512 A3 0.6 0.7 0.0236 0.0276 b 0.25 0.5 0.0098 0.0197 c 0.1 0.23 0.0039 0.0091 D 2.82 3.05 0.1110 0.1201 e1 1.9(TYP) 0.0748(TYP) E 2.6 3.05 0.1024 0.1201 E1 1.5 1.75 0.0512 0.0689 e 0.95(TYP) L 0.25 L1 0.0374(TYP) 0.6 0.0098 0.59(TYP) θ 0 c1 0.0232(TYP) 8° 0.2(TYP) V06 0.0236 www.microne.com.cn 0.0000 8° 0.0079(TYP) Page 13 of 14 ME6212  The contents of this document will be updated with the product's improvement without prior notice. Please consult our sales staff before using this document to ensure that you are using  The application circuit examples described in this document are only used to indicate the representative use of the product an  Please use this product within the limits stated in this document. We will not be responsible for  The products described in this document are not allowed to be used in equipment or devices that affect the human body without the written permission of our company, including but not limited to: health equipment, medical equipment, disaster prevention equipment, fuel control equipment, automobile equipment, aviation equipme  Although our company has always been committed to improving product quality and reliability, semiconductor products have a certain probability of malfunction or wrong work. To prevent personal injury or property damage caused by such accidents, please pay full attention to safety design, for example: Alternate design, fire protection design, and prevention of wrong  When exporting this product or this document overseas, you should abide by applicable import and exp  Copying or reprinting part or all of this document in any form without the permission of our company is strictly prohibited. V06 www.microne.com.cn Page 14 of 14
ME6212C12M5G 价格&库存
很抱歉,暂时无法提供与“ME6212C12M5G”相匹配的价格&库存,您可以联系我们找货
ME6212C12M5G
  • 10+0.24354
  • 100+0.19176
  • 600+0.18984
  • 1200+0.18604
  • 3000+0.18046
库存:1677
