Through-hole resistors
Professional Type
Metal Film Resistors
Miniature Style [ MF0 Series ]
FEATURES
Power Rating
0.4W, 0.6W
Resistance Tolerance
±0.5%, ±1%, ±2%, ±5%,
T.C.R.
±50ppm/°C, ±100ppm/°C
DERATING CURVE
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
INTRODUCTION
The MF0 Series Metal Film Professional
Resistors are manufactured using a vacuum
sputtering system to deposit multiple layers of
mixed metal alloys and passivative materials
onto a carefully treated high grade ceramic
substrate. After a helical groove has been cut
in the resistive layer, tinned connecting leads of
electrolytic copper are welded to the end-caps.
The resistors are coated with layers of blue
color lacquer.
70
Rated Load (%)
155 °C
100
80
60
40
60
80
Ambient Temperature (°C)
100 120 140 160
DIMENSIONS
Unit: mm
ød
H
L
øD
STYLE
DIMENSION
Miniature
L
øD
H
ød
MF0204
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
MF0207
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
9
Note:
ELECTRICAL CHARACTERISTICS
STYLE
MF0204
MF0207
Power Rating at 70°C
0.4W
0.6W
Maximum Working Voltage
250V
350V
Maximum Overload Voltage
500V
700V
Voltage Proof on Insulation
300V
500V
Resistance Range
1Ω - 4M7Ω & 0Ω for E24 & E96 series value
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
±50ppm/°C , ±100ppm/°C
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±0.25%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±1.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±1.5%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±0.75%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±0.25%+0.05Ω
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“MF0207FTE52-7K5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.760561+0.09831
- 10+0.4021410+0.05198
- 100+0.21593100+0.02792
- 250+0.17310250+0.02238
- 500+0.14687500+0.01899
- 1000+0.139881000+0.01808
- 5000+0.135515000+0.01752
- 10000+0.1302610000+0.01684
- 15000+0.1250215000+0.01616
- 50000+0.1197750000+0.01549
- 国内价格 香港价格
- 1+0.885961+0.11452
- 10+0.4771410+0.06168
- 25+0.3987925+0.05155
- 50+0.3514050+0.04543
- 100+0.30806100+0.03982
- 250+0.26233250+0.03391
- 500+0.23338500+0.03017
- 1000+0.208771000+0.02699
- 国内价格
- 100+0.23223
- 1300+0.22911
- 2500+0.22390
- 国内价格
- 1+0.70706
- 10+0.37395
- 100+0.20099
- 250+0.16098
- 500+0.13679
- 1000+0.13020
- 5000+0.12565
- 10000+0.12098
- 15000+0.11631
- 50000+0.11163
- 国内价格 香港价格
- 5000+0.164795000+0.02130
- 10000+0.1504010000+0.01944
- 15000+0.1430215000+0.01849
- 25000+0.1346525000+0.01741
- 35000+0.1296635000+0.01676
- 50000+0.1248050000+0.01613
