TSB772CK
Taiwan Semiconductor
Low VCESAT PNP Transistor
FEATURES
KEY PERFORMANCE PARAMETERS
Low VCE(SAT) -0.3 @ IC =-2A, IB = -200mA (Typ.)
Complementary part with TSD882
Epitaxial Planar Type
Compliant to RoHS Directive 2011/65/EU and in
accordance to WEEE 2002/96/EC.
Halogen-free according to IEC 61249-2-21
Low Speed Switching Applications
UNIT
BVCEO
-30
V
BVCBO
-50
V
IC
-3
A
-0.5
V
IC= -2A, IB= -200mA
en
de
d
Power Supply
VALUE
VCE(SAT)
APPLICATION
PARAMETER
mm
TO-126
PARAMETER
Collector-Base Voltage
Collector-Emitter Voltage
tR
Emitter-Base Voltage
eco
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
LIMIT
UNIT
VCBO
-50
V
VCEO
-30
V
VEBO
-5
V
DC
Collector Current
IC
Pulse
o
No
Collector Power Dissipation
-3
A
-7 (note)
1
TA = 25 C
PD
o
TC = 25 C
Operating Junction Temperature
+150
o
TSTG
- 55 to +150
o
SYMBOL
LIMIT
RӨJC
6.25
TJ
Operating Junction and Storage Temperature Range
W
10
C
C
Note: Single pulse, Pw≤350µs, Duty≤2%
THERMAL PERFORMANCE
PARAMETER
Junction to Case Thermal Resistance
1
UNIT
o
C/W
Version: G1609
TSB772CK
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
IC = -50µA, IE = 0
BVCBO
-50
V
Collector-Emitter Breakdown Voltage
IC = -1mA, IB = 0
BVCEO
-30
V
Emitter-Base Breakdown Voltage
IE = -50µA, IC = 0
BVEBO
-5
V
Collector Cutoff Current
VCB = -30V, IE = 0
ICBO
-1
µA
Emitter Cutoff Current
VEB = -33V, IC = 0
IEBO
-1
µA
Collector-Emitter Saturation Voltage
IC = -2A, IB= -200mA
*VCE(SAT)
-0.3
-0.5
V
Base-Emitter Saturation Voltage
*VBE(SAT)
-1
-2
V
DC Current Transfer Ratio
VCE = -2V, IC = -1A
100
500
VCE =-5V, IC=-100mA,
Transition Frequency
f=100MHz
VCB = -10V, f=1MHz
VCB = -30V, IE = 0
80
MHz
Cob
55
pF
ICBO
-1
µA
mm
* Pulse Test: Pulse Width ≤380µS, Duty Cycle≤2%
ORDERING INFORMATION
fT
en
Output Capacitance
de
*hFE
d
Collector-Base Breakdown Voltage
PACKAGE
PACKING
TSB772CK B0G
TO-126
250pcs / Bulk Bag
TSB772CK C0G
TO-126
50pcs / Tube
No
tR
e co
PART NO.
2
Version: G1609
TSB772CK
ELECTRICAL CHARACTERICS CURVES (TA=25oC, unless otherwise noted)
Figure 2. VCE(SAT) vs. Collector Current
en
de
d
Figure 1. DC Current Gain
Figure 4. Power Derating Curve
No
tR
e co
mm
Figure 3. VBE(SAT) vs. Collector Current
3
Version: G1609
TSB772CK
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
MARKING DIAGRAM
mm
en
de
d
TO-126
No
tR
e co
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
Y =Nov Z =Dec
W =Sep X =Oct
L = Lot Code
4
Version: G1609
TSB772CK
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: G1609
很抱歉,暂时无法提供与“TSB772CK C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+1.362994000+0.17483
