TD03G1372BT
TD03G1372BT
    FH(风华)
    贴片电阻 0603 13.7KΩ ±0.1% 1/10W ±25ppm/℃
TD03G1372BT 数据手册
T THIN FILM CHIP FIXED RESISTOR - T SERIES -T Thin Film Chip Fixed Resistor - T Series ( 0.01%; 2ppm/ ) Low TCR and high accuracy( 0.01%; 2ppm/ ) Suit for re-flow and wave soldering Excellent moisture resistance, corrosion resistance ROHS Compliant with RoHS directive Halogen free requirement / Medical Equipment Test/Measurement Equipment Printer Equipment Automatic Equipment Controller Converters Communication Device Mobile phone etc. T E 05 G Product Code Power Rating Code Dimensions T.C.R Code Code T A C D E F T Series Thin Film Chip Fixed Resistor G Y R H J Power rating 1/32W 1/16W 1/10W 1/8W 1/4W 1/2W 1/6W 1/3W 3/4W 1W Code Type Code 0201 2 2 02 0402 3 3 D 5 0603 05 0805 06 1206 1210 1210 10 2010 12 2512 Resistance Value Code T.C.R (ppm/ ) 01 03 B 1003 Example: 10R0 10 1000 100 4321 4.32K Packaging Style Code Resistance Tolerance Code Code 4digit T Tolerance T 0.01% A 0.05% B 0.1% C 0.25% E 10 F 15 G 25 D 0.5% H 50 F 1% Code Packaging Style T Tape & Reel C Ceramic Substrate Bottom Electrode Top Electrode Edge Electrode Barrier Layer External Electrode NiCr Resistor Layer Passivation Protective Coating Unit:mm Type L a t W 0201 0.60 0.05 0.30 0.05 0.23 0402 1.00 0.10 0.50 0.10 0.30 b 0.05 0.10 0.05 0.15 0.05 0.10 0.20 0.10 0.25 0.10 0603 1.60 0.15 0.80 0.15 0.40 0.10 0.30 0.20 0.30 0.20 0805 2.00 0.20 1.25 0.15 0.50 0.10 0.30 0.20 0.40 0.20 1206 3.20 0.20 1.60 0.15 0.55 0.10 0.40 0.20 0.50 0.20 1210 3.20 0.20 2.50 0.20 0.55 0.10 0.40 0.20 0.50 0.20 2010 5.00 0.20 2.50 0.20 0.55 0.10 0.60 0.20 0.60 0.20 2512 6.40 0.20 3.20 0.20 0.55 0.10 0.60 0.20 0.60 0.20 1 Case 100 70 -55 75 Percent Rated Load Operating Temperature Range: -55 155 50 25 0 -75 -50 -25 0 75 50 25 100 125 Ambient temperaturt( 70 ( Note: For resistors operated in ambient over 70 the above figure. 155 ) ) ,rated load(rated power) shall be derated in accordance with Standard electrical specifications ( ) Item 70 Limiting Max .Overload Rated Power Element Voltage Voltage at 70 (note) Type 0201 1/32W 15V Resistance Range 0.01% 0.05% 1/16W 50V 49.9 100V --- 49.9 ~ 10 ~ 255K 12K 50V 100V --24.9 0805 1/10W 100V 200V 4.7 ~ 4.7 332K 1M 24.9 1206 1/8W 150V 1210 300V 1/4W --24.9 2010 1/4W 150V 300V --24.9 2512 1/2W 150V 300V 24.9 ~ 499K --2 3 5 1 10 15 25 50 2.49M --- 2 3 5 300K 10 15 1M 1 25 50 3M --- 2 3 5 300K 4.7 4.7 ~ 4.7 3M 1M 2 1M 4.7 ~ 4.7 3M 1M 100K 24.9 25 50 2M --- 4.7 3 10 15 1M 300K 4.7 ~ 4.7 2.49M 1M 24.9 ~ 499K 2 5 1 4.7 100K 24.9 25 50 150K 4.7 ~ 4.7 1M 2M 3 10 15 1M --- 24.9 ~ 499K 2 511K 30K 49.9K 24.9 25 50 511K 5 1 4.7 3 5 10 15 60K 4.7 24.9 ~ 200K --- 4.7 --- 24.9 2 60K 69.8K 15K 24.9 ~ 4.7 ~ 332K 100K 25 50 33K --20K 49.9 49.9 TCR (ppm/ ) 4.99K 49.9 4.99K 49.9 24.9 1/16W 1% 0.5% 49.9 12K 24.9 0603 0.25% ----- 30V 49.9 0402 0.1% 10 15 1M 1 3M 25 50 T THIN FILM CHIP FIXED RESISTOR - T SERIES High power rating electrical specifications ( ) Item 70 Limiting Max .Overload Rated Power Element Voltage Voltage at 70 (note) Type Resistance Range 0.01% 0.05% 49.9 0.1% 0.25% 4.99K 1/10W 50V --- 12K 49.9 12K 24.9 1/10W 0603 75V 100V 150V 60K 10 49.9 69.8K 15 4.7 1/8W 150V 4.7 10 150V 300V 1206 1/3W 200V 400V 400V 200V --- 10 24.9 499K 1 2 200V 10 1M 15 1M --- 10 1M 1M 49.9K --- 25 50 2 3 10 25 15 50 25 50 2 3 100K 5 4.7 1M 49.9K --- 10 25 15 50 2 3 100K 5 4.7 --- 400V 400V 24.9 2K 4.7 4.7 --- 400V 10 4.7 1M 470K 10 25 15 50 10 15 1M 25 50 470K 10 15 1M 470K 1 1 1M 1 1M 25 50 4.7 1M 1 1M 25 50 155 . Note: 1 Rated Voltage= Power Rating Resistance Value or Limiting element voltage whichever is lower. 2 Operating temp. Range -55 50 5 = -55 25 400V 2512 1W 511K 499K 4.7 --200V 5 100K 24.9 499K 3/4W 3 400V 2010 200V 2 --- 24.9 1/2W 50 49.9K 24.9 200V 25 1 24.9 499K 1/3W 50 4.7 24.9 1/3W 25 49.9K 4.7 24.9 1210 1M --- 24.9 200V 15 24.9 24.9 1/4W 10 332K 4.7 1M 1/4W 3 332K 30K 4.7 511K 50 2 5 4.7 4.7 332K 300V 24.9 200K 25 30K --0805 255K --- 24.9 24.9 3 49.9 255K --- 2 5 15K 150V 24.9 100K 1/8W 1/6W 10 TCR (ppm/ ) 10K 100V 49.9 1% --- 49.9 0402 0.5% 155 . 3 Specification Test Item Normal power rating (IEC 60115-1) Test Method (IEC 60115-1) High power rating IEC 60115-1 4.8 +25 /-55 /+25 within specified T.C.R T.C.R /+125 /+25 IEC 60115-1 4.6 Insulation Resistance 1000M 100V 15V , 1 , Apply DC 100V 15V between substrate and termination for 1 minute, then check the insulation resistance. Min IEC 60115-1 4.7 Voltage Proof 100V/s 60s 5s. Apply max. overload voltage of AC RMS at a rate of app roximately 100V/s between substrate and terminations for 60s 5s. No breakdown or flashover IEC 60115-1 4.13 Short Time Overload No mechanical damage R (0.2%R+0.05 ) 2.5 ( ) 5 No mechanical damage Apply 2.5 times rated voltage or Max overload voltage, R (0.5%R+0.05 ) whichever is lower, for 5 s. Resistance to Soldering Heat No mechanical damage R (0.2%R+0.05 ) Solder-ability 95% 95% Cover Min Damp Heat, Steady State IEC 60115-1 4.17 245 5 3 0.3 245 5 3s 0.3s IEC 60115-1 4.19 -55 155 100 -55 155 100 cycles. No mechanical damage R (0.25%R+0.05 ) Rapid Change of Temperature 70 Endurance at 70 IEC 60115-1 4.18 270 5 10 1 270 5 10s 1s IEC 60115-1 4.25.1 70 2 ( ) 1.5 , 0.5 1000 Resistor should be exposed at 70 2 , and apply rated voltage or limitingelement voltage, whichever is lower, for 1.5h on, 0.5h off for 1000h. No mechanical damage R (0.2%R+0.05 ) No mechanical damage R (0.5%R+0.05 ) No mechanical damage R (0.3%R+0.05 ) IEC 60115-1 4.24 40 2 93% 3%RH ( No mechanical ) 1.5 0.5 1000 damage Resistor should be exposed at 40 2 93% 3%RH, R (0.5%R+0.05 ) and apply rated voltage or limiting element voltage, whichever is lower, for 1.5h on, 0.5h off for 1000h. No mechanical damage R (0.2%R+0.05 ) Operation at Low Temperature No mechanical damage -55 R (0.5%R+0.05 ) No mechanical damage R (0.2%R+0.05 Endurance at UpperCategory Temperature No mechanical damage R (0.2%R+0.05 Substrate Bending Test 1 9 IEC 60115-1 4.36 -55 5 5 , 1h without load rated voltage or limiting element voltage whichever is lower for 45min, 15min without load. ) ) IEC 60115-1 4.25.3 155 2 96 Resistor should be exposed at 155 2 IEC 60115-1 4.33 (Duration):60s 5s (Bending Distance): 0201 0402 0603 0805 5mm 1206 1210 4mm 2010 2512 2mm Packaging see the appendix 1-9 Page . 4 for 96 hours. PACKAGING AND PRECAUTION OF CHIP RESISTOR Chip fixed resistor C A B unit: mm unit: mm Thick Film Resistor and Thin Film Resistor Type 01005 0201 0402 0603 0805 1206 1210 2010 2512 A 0.17 0.23 0.45 0.80 1.05 1.90 2.00 3.50 4.80 B 0.60 0.84 1.45 2.50 3.25 4.50 4.60 6.50 7.80 Metal Foil Resistor Type C 0.22 0.38 0.60 0.95 1.40 1.75 2.70 2.70 3.40 0603 0805 1206 2010 2512 R003~R004 R005~R030 R003~R004 R005~R047 R003~R004 R005~R068 R003~R009 R010~R100 R002~R004 R005~R200 A 0.4 0.6 0.5 0.8 0.8 1.8 1.6 2.7 1.0 3.8 B C 2.8 1.0 3.2 1.4 4.4 1.8 6.3 2.9 8.0 3.4 Thick film chip network resistor A B Q1 Q2 Q3 Q2 Q3 Q2 Q1 RCMY08 / RCMT08 / RCML08 unit: mm A B Q1 Q2 Q3 RCMY08 0.30 0.90 0.20 0.20 0.20 RCMT08 0.38 1.60 0.40 0.20 0.30 RCML08 0.80 2.70 0.60 0.40 0.40 Type 1 Paper Taping 01005 0201 0402 RCMY08 RCMT08 For 01005 0201 0402 RCMY08 RCMT08 unit: mm Type A B W F E 01005 0.45 0.02 0.25 0.02 8.00 0.02 3.50 0.05 1.75 0.05 0201 0.70 0.10 0.40 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0402 1.20 0.10 0.70 0.10 8.00 0.20 3.50 0.05 1.75 0.10 RCMY08 1.57 0.05 0.77 0.05 8.00 0.20 3.50 0.05 1.75 0.10 RCMT08 2.20 0.10 1.20 0.10 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm Type P P0 P1 D0 T1 T 01005 2.00 0.05 4.00 0.10 2.00 0.05 1.55 0.02 0.17 0.02 0.31 0.02 0201 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 0.28 0.04 0.42 0.05 0402 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.42 0.05 RCMY08 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 RCMT08 2.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 0603 0805 1206 1210 RCML08: For 0603 0805 1206 1210 RCML08: 2 PACKAGING AND PRECAUTION OF CHIP RESISTOR unit: mm Type B A W F E 0603 1.85 0.10 1.10 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0805 2.35 0.10 1.65 0.10 8.00 0.20 3.50 0.05 1.75 0.10 1206 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 1210 3.50 0.20 2.80 0.20 8.00 0.20 3.50 0.05 1.75 0.10 RCML08 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm T Type P0 P D0 P1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 0603 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.60 0.10 0.75 0.10 0805 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1206 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1210 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 RCML08 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 Embossed Taping 2010 2512 For 2010 2512 unit: mm W B0 A0 Type t E F 2010 5.50 0.15 2.82 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 2512 6.78 0.15 3.45 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 unit: mm K0 Type P P0 D0 P1 D1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 2010 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.84 0.10 0.84 0.10 2512 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.81 0.10 1.00 0.10 3 Reel unit: mm M W 01005 0201 0402 0603 0805 1206 1210 RCMY08 RCMT08 RCML08 178 2.0 9.5 1.0 2010 2512 178 2.0 13.0 0.5 Type A B C D 12.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 58.0 2.0 15.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 57.0 2.0 T Packaging Quantity Tape & reel Packaging style W M Type Quantity(pcs) 178 178 01005 2.0 E-24 ( 0201 0402 RCMY08 RCMT08 20000 10000 9.5 unit 0.001 1.0 1.1 2.0 1.2 1.3 g Quantity 0.01 0.1 2010 2512 5000 4000 12.5 1 10 100 2.2 1.6 0.52.7 2.0 A 0603 0805 1206 RCMY08 RCMT08 RCML08 01005 0201 0402 50000 10000 2.0 1.5 1210 2010 2512 4000 0.5 1 ) 1.5 13.0 1.8 T 0603 0805 1206 1210 RCML08 1.0 E-24 series( 10 n Case 2.4 1k 10k 100k 1M 3.3 15.53.6 1.5 3.9 3.0 4.3 4 10M 100M 4.7 5.1 5.6 6.2 1000M ) 6.8 2.0 7.5 0.5 8.2 9.1 1 PACKAGING AND PRECAUTION OF CHIP RESISTOR E-96 ( 10 n E-96 series ( unit 0.001 0.01 ) 0.1 1 10 100 1k 10k 100k 1M 10M 100M 1000M ) 1.00 1.33 1.78 2.37 3.16 4.22 5.62 7.50 1.02 1.37 1.82 2.43 3.24 4.32 5.76 7.68 1.05 1.40 1.87 2.49 3.32 4.42 5.90 7.87 1.07 1.43 1.91 2.55 3.40 4.53 6.04 8.06 1.10 1.47 1.96 2.61 3.48 4.64 6.19 8.25 1.13 1.50 2.00 2.67 3.57 4.75 6.34 8.45 1.15 1.54 2.05 2.74 3.65 4.87 6.49 8.66 1.18 1.58 2.10 2.80 3.74 4.99 6.65 8.87 1.21 1.62 2.15 2.87 3.83 5.11 6.81 9.09 9.31 1.24 1.65 2.21 2.94 3.92 5.23 6.98 1.27 1.69 2.26 3.01 4.02 5.36 7.15 9.53 1.30 1.74 2.32 3.09 4.12 5.49 7.32 9.76 E 96 0603 E-96 series(0603) multiplied Cross-reference List and Resistance Cross-reference List multiplied code Code 10 0 10 1 10 2 10 A B C D E-96 E-96 resistance 3 10 4 10 5 10 6 10 7 10 -1 10 -2 10 -3 E F G H X Y Z Code E-96 E-96 resistance Code E-96 E-96 resistance Code E-96 E-96 resistance 01 100 25 178 49 316 73 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 562 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 5 Description for Resistance Value Code and Marking of Thick Film Chip Resistor Resistance Value Code All the resistance value code of thick film chip resistor is corresponding with the marking . Marking E-24 (0603 5%) 10 E-24 series: Express resistance value on the glass side with three digits, the first tow digits should be significant and the third one denote number of zeros. 30K For example: 33 E-24 (0603 1%& 0.5%) E-24 series(0603 1%& 0.5%): One short bar under marking letter. For example: E-96 E24 1%& 0.5% 0805 1206 1210 2010 2512 E-96 series & E-24 series:For the dimension type of 0805 1206 1210 2010 2512 express the resistance value with four digits, the first three digits are significant figures and the fourth de notes the number of zeros. For example: 100K E-96 0603 E-96 For the dimension type of 0603, express the resistance value with three code, the first two digit code denote the resistance of E-96 series, and the third code of letter denote the multiplier (see the table three and four ). For example: R 2M The decimal point should be expressed by R For example: 0 . 1 5.6 The jumper should be expressed by For example: 01005 0201 0402 on the glass side. 0 0 For the dimension type of 01005 0201 0402 there is no mark For example: IEC IEC E24 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. To get agreement by both party if there special requirement for the marking. 6 PACKAGING AND PRECAUTION OF CHIP RESISTOR Description for Resistance Value Code and Marking of Thin Film Chip Resistor Resistance Value Code 0201 0402 0603 0805 1206 1210 2010 2512 All resistance value code of thin film chip resistor,including 0201 0402 0603 0805 1206 1210 2010 2512 size used four digits. Example TD03G4701BT 4701=4.7K 1R50=1.5 To use four digits code represent resistance value , Example 4701=4.7K 1R50=1.5 Marking E24 E96 E96 . When resistance value belongs to E24 as well as E96 series, we suggest preferentially use E96 series. Example 10K=1002, 103 0805 1206 1210 2010 2512 Marking for 0805 1206 1210 2010 2512 Size Resistor 0805 1206 1210 2010 2512 For 0805 1206 1210 2010 2512 size resistor , express the resistance value with four digits code; Example 100K 0603 Marking for 0603 Size Resistor 0603-E96 For resistance value belongs to E96 series, express the resistance value with three digits code. Example 2M 0603-E24 For resistance value belongs to E24 series, express the resistance value with three digits code. Example 30K The decimal point should be expressed by "R" . Example 5.6 0201 0402 For the dimension type of 0201 0402 there is no mark on the glass side. Example 7 Description for Resistance Value Code and Marking of Current Sensing Thick Film Chip Resistor Resistance Value Code 0402 0603 0805 1206 1210 2010 2512 All resistance value code of current sensing thick film chip resistor, including 0402 0603 0805 1206 1210 2010 2512 size used four digits. Example RBF03MR010FT R010=10m 30M1=30.1m To use four digits code represent resistance value , Example R010=10m 30M1=30.1m Marking E -24 E-96 For 0805 (0805 1206 1210 2512 2010 5% 1% 0.5%) 2512 w hen resistance value belongs to E24 and E96 series, we suggest preferentially use four digits. Resistance Value Mark Code R00X 1m R0XX 10m RXXX 100m Sample R 9m R005=5m R 99m R033=33m R 999m R100=100m XMXX 1m R 10m (Contains two significant digits after the decimal point.) 5M10=5.1m XXMX 10m R 100m (Contains one significant digit after the decimal point.) 30M1=30.1m E -24 E-96 (0603 5% 1% 0.5%) For 0603,when resistance value belongs to E24 and E96 series, we suggest preferentially use three digits. Mark Code Resistance Value Range V0X 1m VXX 10m RXX 100m XMX Sample R 9m V05=5m R 99m V33=33m R 999m R100=100m 1m R 10m (Contains one significant digit after the decimal point.) 5M1=5.1m 0402 For 0402, there is no mark on the glass side. IEC IEC E24 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. To get agreement by both party if there special requirement for the marking. 8 PACKAGING AND PRECAUTION OF CHIP RESISTOR 1 2 3 4 5 6 7 1 Use in various types of liquid, including water, oils, chemicals, and organic solvents. 2 Use outdoors where the products are exposed to direct sunlight, or in dusty places. 3 Use in places where the products are exposed to sea winds or corrosive gases, including Cl2, H2S, Nh3, SO2, and No2 etc. 4 Use in places where the products are exposed to static electricity or electromagnetic waves. 5 Use in proximity to heat-producing components, plastic cords, or other flammable items. 6 Use involving sealing or coating the products with resin or other coating materials. 7 Use involving unclean solder or use of water or water-soluble cleaning agents for cleaning after soldering. 1 2 3 4 : 5 30 30% 70% 1 Avoid applying power exceeding normal rated power, exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 2 Be careful when pick up the products with tweezers. There may be a care that the overcoat and / or the body can be chipped. 3 Soldering tip shall not touch the product when install product manually. 4 Storage conditions: T 5 30 , RH 30% 70%. Recommended wave solder profile Recommended reflow profile Recommended solder alloy 96.5Sn/3.0Ag/0.5Cu 9
TD03G1372BT 价格&库存
很抱歉,暂时无法提供与“TD03G1372BT”相匹配的价格&库存,您可以联系我们找货
TD03G1372BT
  • 20+0.14152
  • 100+0.12834
  • 500+0.11955
  • 1000+0.11076
  • 5000+0.10021
  • 10000+0.09581
库存:4620
