RS2JF
RS2JF
    JINGDAO(晶导微电子)
    SMAF(DO-214AD)
    表面安装快恢复二极管 VRRM=600V If=2A VF=1.3V CJ=22pF trr=250ns SMAF
RS2JF 数据手册
山东晶导微电子股份有限公司 RS2AF THRU RS2MF Jingdao Microelectronics co.LTD Surface Mount Fast Recovery Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 2 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Fast reverse recovery time • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: RS2A-RS2M MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 27mg / 0.00095oz Simplified outline SMAF and symbol Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols RS2AF RS2BF RS2DF RS2GF RS2JF RS2KF RS2MF Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Forward Voltage at 2 A VF 1.3 V IR 5 100 μA Cj 22 pF Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range t rr 150 250 500 ns RθJA RθJC 65 20 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.01 SMAF-F-RS2AF~RS2MF-2A1KV Page 1 of 3 山东晶导微电子股份有限公司 RS2AF THRU RS2MF Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.01 www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 RS2AF THRU RS2MF Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View mil Bottom View A C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm Marking 1.6 (63) 1.8 (71) 2.2 (86) mm Unit : (mil) 2016.01 ∠ 7° The recommended mounting pad size 1.6 (63) g pad e E A pad D E A V M JD512256B0 Type number Marking code RS2AF RS2A RS2BF RS2B RS2DF RS2D RS2GF RS2G RS2JF RS2J RS2KF RS2K RS2MF RS2M Page 3 of 3
RS2JF 价格&库存
很抱歉,暂时无法提供与“RS2JF”相匹配的价格&库存,您可以联系我们找货
RS2JF
  • 50+0.07514
  • 500+0.07065
  • 2000+0.06165
  • 5000+0.05715
  • 15000+0.05265
  • 30000+0.05040
库存:3000
RS2JF
  • 20+0.20650
  • 100+0.12800
  • 800+0.08450
  • 3000+0.06040
  • 6000+0.05740
  • 30000+0.05310
库存:5649
