HSBA6066
HSBA6066
    HUASHUO(华朔)
    DFN-8(5.7x5.1)
    1个N沟道 耐压:60V 电流:78A
HSBA6066 数据手册
HSBA6066 N-Ch 60V Fast Switching MOSFETs Description ⚫ ⚫ ⚫ ⚫ ⚫ Product Summary Advanced Trench MOS Technology Low Gate Charge Low RDS(ON) 100% EAS Guaranteed Green Device Available 60 V RDS(ON),typ 4.4 mΩ ID 78 A PRPAK5X6 Pin Configuration Application ⚫ ⚫ ⚫ VDS Motor Control. DC/DC Converter. Synchronous rectifier applications. Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage 60 V VGS Gate-Source Voltage ID@TC=25℃ ID@TC=100℃ IDM ±20 V Continuous Drain Current1 78 A Continuous Drain Current1 57 A 210 A 93 mJ 43 A 75 W Pulsed Drain Current2 EAS Single Pulse Avalanche Energy IAS Avalanche Current PD@TC=25℃ Total Power Dissipation 3 4 TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter RθJA Thermal Resistance Junction-Ambient RθJC Junction-Case1 www.hs-semi.cn Thermal Resistance Ver 2.0 Typ. 1 Max. Unit --- 55 ℃/W --- 1.8 ℃/W 1 HSBA6066 N-Ch 60V Fast Switching MOSFETs Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol Parameter Min. Typ. Max. Unit VGS=0V , ID=250uA 60 --- --- V VGS=10V , ID=30A --- 4.4 5.2 VGS=4.5V , ID=20A --- 6.4 7.8 VGS=VDS , ID =250uA 1.2 1.65 2.3 VDS=48V , VGS=0V , TJ=25℃ --- --- 1 VDS=48V , VGS=0V , TJ=55℃ --- --- 5 Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.3 ---  Qg Total Gate Charge (4.5V) --- 33 --- Qgs Gate-Source Charge --- 18 --- Qgd Gate-Drain Charge --- 6 --- BVDSS Drain-Source Breakdown Voltage RDS(ON) Static Drain-Source On-Resistance2 VGS(th) IDSS IGSS Gate Threshold Voltage Drain-Source Leakage Current Conditions VDS=30V , VGS=10V , ID=20A m V uA nC --- 7.5 --- Rise Time VDD=30V , VGS=10V , RG=3.3, --- 6 --- Turn-Off Delay Time ID=20A --- 29 --- Fall Time --- 7.5 --- Ciss Input Capacitance --- 1670 --- Coss Output Capacitance --- 438 --- Crss Reverse Transfer Capacitance --- 25 --- Min. Typ. Max. Unit --- --- 78 A --- --- 210 A Td(on) Tr Td(off) Tf Turn-On Delay Time VDS=30V , VGS=0V , f=1MHz ns pF Diode Characteristics Symbol IS Parameter Continuous Source Current1,5 Conditions VG=VD=0V , Force Current Pulsed Source Current2,5 Diode Forward Voltage2 VGS=0V , IS=A , TJ=25℃ --- --- 1.2 V trr Reverse Recovery Time IF=15A , dI/dt=100A/µs , --- 23 --- nS Qrr Reverse Recovery Charge TJ=25℃ --- 60 --- nC ISM VSD Note : 1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=43A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. www.hs-semi.cn Ver 2.0 2 HSBA6066 N-Ch 60V Fast Switching MOSFETs Typical Characteristics Fig.1 Typical Output Characteristics Fig.2 On-Resistance vs. Gate-Source Voltage Fig.3 Source Drain Forword Characteristicsdiode Fig.5 Normalized VGS(th) vs. TJ www.hs-semi.cn Fig.4 Gate-Charge Characteristics Fig.6 Normalized RDSON vs. TJ Ver 2.0 3 HSBA6066 N-Ch 60V Fast Switching MOSFETs Fig.7 Capacitance Fig.8 Safe Operating Area Fig.9 Normalized Maximum Transient Thermal Impedance EAS= VDS 90% BVDSS 1 L x IAS2 x 2 BVDSS BVDSS-VDD VDD IAS 10% VGS Td(on) Tr Ton Td(off) Tf Toff VGS Fig.10 Switching Time Waveform www.hs-semi.cn Fig.11 Unclamped Inductive Switching Waveform Ver 2.0 4 HSBA6066 N-Ch 60V Fast Switching MOSFETs Ordering Information Part Number HSBA6066 www.hs-semi.cn Package code PRPAK5*6 Ver 2.0 Packaging 3000/Tape&Reel 5
HSBA6066 价格&库存
很抱歉,暂时无法提供与“HSBA6066”相匹配的价格&库存,您可以联系我们找货
HSBA6066
  • 1+2.89440
  • 10+2.25720
  • 30+1.97640
  • 100+1.63080
  • 500+1.39320
  • 1000+1.29600
库存:1451
