PRESSURE INDICATORS
PZ-30
ϚʔΩϯά
&.$ࢦྩద߹
marking
11 kinds of display multiplier
Full 3-digit red LED
Compatible with
EMC directive
※ Except for
Current output type
Small 30 mm square face
Compatible with our analog sensors
■ FEATURES
● Pressure indicators separated from sensor
- Can be used with variety of sensors
● Wide range of applications such as pneumatic
equipment or semiconductor equipment
● Any range of pressure sensors is available
● Low power consumption by non display mode
● Set data protection by panel lock function
■ MODEL NUMBER DESIGNATION
P Z - 3 0 - N V S T I
Series name
Switch output interface
Analog output
N:NPN open collector
P:PNP open collector
Blank:Voltage output
I:Current output
Input signal type
Sensor connection type
V:1 ~ 5 V
I:4 ~ 20 mA
ST:One-touch type terminal
CN:Connector type terminal
■型式一覧 LIST OF MODEL NUMBERS
Analog output
Switch output type
NPN
Analog output
PNP
NPN
Analog Current output
PNP
Input signal type
PZ-30-NVST
PZ-30-NIST
PZ-30-PVST
PZ-30-PIST
PZ-30-NVSTI
PZ-30-NISTI
PZ-30-PVSTI
PZ-30-PISTI
PZ-30-NVCN
PZ-30-NICN
PZ-30-PVCN
PZ-30-PICN
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
※ Verify the above model numbers when placing orders.
Marked
is manufactured upon receipt of order basis.
PZ-30
PRESSURE INDICATORS
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 VDC.
Imput
General specifications
Item
PZ-30
Model number
Operating temp. range
Operating humidity
− 10 ~ 50
°C
35 ~ 85
%RH
IP40
Protection grade
Storage temp.
Net weight
°C
− 20 ~ 70
g
Approx. 80 (Including 2 m cable)
Insulation resistance
100 MΩ minimum
Dielectric strength
500 VDC 1 minute
10.8 ~ 30 VDC(Including ripple percentage)※
Supply voltage
Consumption current
50 mA maximum
1 ~ 5 V (V) / 4 ~ 20 mA (I)
Input signal
Input impedance
10 kΩ (V) / 250 Ω (I)
kΩ
3
No. of digit
LED
Display
Display element
Approx. 4 times/s
Display cycle
“–” LED is ON
Negative pressure display
Display accuracy
± 1 %F.S. (Without sensor's error)
± 0.5 % (0 ~ 50 °C, Reference temp. 25 °C)
Thermal error
1 count
Resolution
NPN/PNP
Output status
2-point output (Transistor, Open collector output)
Switching capacity
30 VDC 100 mA maximum
1.2 V maximum (NPN), 2.2 V maximum (PNP)
Switch
Residual voltage
0 ~ 300 counts Adjustable
Hysteresis setting
± 0.2 %F.S. ± 1 count
Repeatability
With pretection function
Short circuit protection
Approx. 5 ms (“F – 0”) (Selectable 5 ms ~ 2.5 s)
Response
± 0.5 %F.S. (0 ~ 50 °C, Refernce temp. 25°C)
Analog output
Thermal error
State indication
Output 1 (Green LED), Output 2 (Red LED) Lighted when output is ON.
Voltage output
1~5V
Current output
4 ~ 20 mA(Load resistance 500 Ω minimum)
※ When analog current output type of PZ30 is chosen or when a sensor of current output type is connected, supply voltage is 24 VDC ± 10 %
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Vibration
10 ~ 500 Hz, 98.1 m/s or 1.5 mm P-P, 3 directions for 2 hours each
Shock
Moisture resistance
EMC
Permissible change
2
490 m/s2, 3 directions for 3 times each
40 °C, 90 ~ 95 %RH, 240 hrs.
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1: 2006 Table 2
Pressure indication, switch operating points
and analog output variation :
± 1 %F.S. maximum each after test
Pressure indication, switch operating pressure and
analog output: ± 5 %F.S. maximum during test
PZ-30
PRESSURE INDICATORS
■ INTERNAL ELECTRICAL SCHEMATICS
● Voltage analog output
・Current input NPN output
1
2
・Current input PNP output
Indicator
Indicator
1
2
Power B
Power B
V+
Sensor
Com
Main circuit
S.Output1
S.Output2
Sensor
Main circuit
S.Output1
S.Output2
Load Load
Common
A.Output
LED
LED
Pressure indication
Pressure indication
・Voltage input NPN output
2
Is
Com
Common
A.Output
1
V+
Load Load
Is ™
・Voltage input PNP output
Indicator
Indicator
1
2
Power B
Power B
V+
Sensor
Com
Load Load
Vs ™
Main circuit
V+
S.Output1
S.Output2
Sensor
Common
A.Output
Com
S.Output1
Vs ™
Main circuit
S.Output2
Load Load
Common
A.Output
LED
LED
Pressure indication
Pressure indication
※ When connecting the 2-wire type of current output sensors, please do not connect the 3 (Com.) terminal.
● Current analog output
Indicator
1
Indicator
2
1
Power B
V+
Sensor
Com
A.Output
Is ™
Main circuit
Load Load
V+
S.Output1
S.Output2
Sensor
Common
Com
2
Power B
S.Output1
Is
Main circuit
Common
LED
LED
Pressure indication
Pressure indication
Indicator
Indicator
1
S.Output2
A.Output Load Load
1
2
2
Power B
Power B
V+
Sensor
Com
A.Output
Vs ™
Main circuit
V+
Load Load
S.Output1
S.Output2
Common
Sensor
Com
Vs ™
S.Output1
Main circuit
A.Output
LED
Pressure indication
(Note) Refer to the PIN allocation for the rear terminal number of the PZ-30 and the connector pin terminal number.
(Please from the table on dimension drawing)
S.Output2
Load
Load
Common
LED
Pressure indication
PZ-30
PRESSURE INDICATORS
■ ANALOG OUTPUT MODE
Analog output
● Analog output setting : The second figure in triple digits LED
indicates output mode in the initial
setting.
Output mode is fixed by rated pressure.
−Pr
Code
Output mode
“1”
R mode (Compound)
“2”
G mode (Positive)
“3”
V mode (Negative)
1 V
(4 mA)
5 V
(20 mA)
Pr
(Vzero)
5V
(20 mA)
1 V
(4 mA)
5V
(20 mA)
1V
(4 mA)
■ SWITCH OUTPUT MODE
● Switch output can be set when blinking red LED indicates (SW2) in the intial setting.
● The mode is set at “Separate (H/H), 1” prior to shipment. The mode is initialized at “Separate (L/L), 4” when rated pressure is set at “-12P” or
“-12F” (negative pressure).
SW1
Output
Mode
Operation
Separate
HI
LO
Separate mode
SW2
Window
comparator
A
B
Separate
HI
LO
A
B
C-1
C-2
C-3
C-4
C-5
C-6
C-7
C-8
Pressure
setting
(Operating point)
(HI operation)
Window
comparator
OFF
-Pr
ON
-Pr
P1: SW1
P2: SW2
H
H
Window comparator mode
ON
Pr
(Lower limit) : Setting 1
(Upper limit) : Setting 2
Setting 2
-Pr
(HI operation)
(A operation)
OFF
P1
H
P2
H
ON
Pr
(B operation)
ON
P1: SW1
H
P2: SW2
OFF
H
P1≦P2 or P1≧P2
Setting 1
ON
Pr
OFF
-Pr
P1
P2
H
H
OFF
Pr
P1≦P2–2H
H:Switch hysteresis、
P1=Setting 1, P2=Setting 2
Note 1. In the Separate Mode, setting 1 corresponds to SW1, and Setting 2
corresponds to SW2.
Note 2. In the Window Comparator Mode, the minimum value for SW1 and
SW2 corresponds to Setting 1 and the maximum value corresponds
to Setting 2.
PZ-30
PRESSURE INDICATORS
■ SELECTION OF DISPLAY MULTIPLIER/RATED PRESSURE
● Selection of display multiplier
● Selection of rated pressure
pressure in the initial setting.
● Display multiplier is set at “1” (kPa) prior to shipment.
● Rated pressure is set at “12P” (0 ~ 100 kPa) prior to
● Please set any code when blinking red LED indicates negative
Mode (1/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
pressure, SW1, SW2 in the initial setting.
shipment.
Pressure reference
Pressure unit
Rated pressure range
0 ~ 10
0 ~ 35
0 ~ 50
Setting code
“11P”
“41P”
“51P”
“-12P”
“12P”
“42P”
“52P”
“62P”
“72P”
“13P”
“23P”
0.00
9.99
0.00
0.10
0.0
99.9
0.0
75.0
0.00
0.10
0.0
99.9
0.00
1.45
0.0
35.0
0.00
0.35
0.0
50.0
0.00
0.51
0.0
-99.9
0.00
-1.02
0.0
99.9
0.00
1.02
0.00
3.57
0.00
5.10
0.00
6.12
0.00
7.14
0.00
9.99
0.0
20.4
0.00
0.35
0.00
5.07
0.00
0.50
0.00
7.25
0.00
-1.02
0.0
-14.5
0.00
1.02
0.0
14.5
0.00
3.50
0.00
5.00
0.00
6.00
0.00
7.00
0.00
9.99
0.0
20.0
0.0
50.7
0.0
72.5
0.0
87.0
0.00
2.95
0.0
10.3
0.0
14.7
0.00
1.00
0.00
0.29
0.00
2.00
Rated pressure display
(PL ~ PH)
Gauge/Absolute
kPa
MPa
0 ~ -100 0 ~ 100 0 ~ 350 0 ~ 500 0 ~ 600 0 ~ 700 0 ~ 1000 0 ~ 2.00
“A” × 0.001 (MPa)
“b”
× 0.2953
Mode (2/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
“A” × 0.001 (MPa)
“b”
× 0.2953
Pressure reference
Pressure unit
Setting code
(PL ~ PH)
Gauge/Absolute
MPa
Compound
kPa
0 ~ 3.50 0 ~ 5.00 0 ~ 10.0 0 ~ 20.0 0 ~ 35.0 -10 ~ 10 -100 ~ 100 -100 ~ 200 -100 ~ 300 -100 ~ 500 -100 ~ 600 -100 ~ 1000
“43P”
“53P”
“14P”
“24P”
“44P”
0.0
35.7
0.0
51.0
0.0
35.0
0.0
50.0
0.0
99.9
0.00
0.50
0.00
3.50
0.00
0.72
0.00
5.00
0.00
1.45
0.00
9.99
0.00
2.90
0.00
20.0
“11r”
“12r”
“22r”
“32r”
“52r”
“62r”
“13r”
-9.99
9.99
-0.10
0.10
-99.9
99.9
-75.0
75.0
-999
999
-0.10
0.10
-99.9
99.9
-1.45
1.45
-99.9
99.9
-1.02
1.02
-999
999
-750
750
-100
200
-1.02
2.04
-100
300
-1.02
3.06
-100
500
-1.02
5.10
-100
600
-1.02
6.12
-100
999
-1.02
9.99
-1.00
1.00
-999
999
-14.5
14.5
-1.00
2.00
-1.00
3.00
-1.00
5.00
-1.00
6.00
-1.00
9.99
-14.5
29.0
-14.5
43.5
-14.5
72.5
-14.5
87.0
-0.10
0.10
-29.5
29.5
-0.10
0.20
-29.5
59.0
-0.10
0.30
-29.5
88.5
-0.10
0.50
-29
147
-0.10
0.60
-29
177
-14
145
-0.01
0.14
-0.10
1.00
-29
295
0.00
5.07
0.00
35.0
-2.95
2.95
PZ-30
PRESSURE INDICATORS
Pressure reference
Pressure unit
Mode (3/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
Setting code
(PL ~ PH)
Gauge/Absolute
(× 1 / 0.0102) kPa
0 ~ 0.10 0 ~ 0.35 0 ~ 0.50 0 ~ -1.00 0 ~ 1.00 0 ~ 3.50 0 ~ 5.00 0 ~ 7.00 0 ~ 10.0
“11F”
“41F”
“51F”
“-12F”
“12F”
“42F”
“52F”
“72F”
“13F”
0.00
9.80
0.00
0.10
0.0
99.9
0.0
73.5
0.00
0.09
0.0
98.0
0.00
1.42
0.0
34.3
0.00
0.35
0.0
49.0
0.00
0.50
0.0
-98.0
0.00
-1.00
0.0
98.0
0.00
1.00
0.00
3.50
0.00
5.00
0.00
7.00
0.00
9.99
0.00
0.34
0.00
4.97
0.00
0.49
0.00
7.10
0.00
-0.98
0.0
-14.2
0.00
0.98
0.0
14.2
0.00
3.43
0.00
4.90
0.00
6.86
0.00
9.80
0.0
49.7
0.0
71.0
0.0
99.5
0.00
2.89
0.0
10.1
0.0
14.4
0.0
-28.9
0.0
28.9
0.00
0.98
“A” × 0.001 (MPa)
“b”
× 0.2953
■ OUTLINE DIMENSION
Unless otherwise specified, tolerance: ± 0.5 (Unit: mm)
● One-touch type terminal
□31.4
35
□30
kPa
SW1
36.4
SW2
5 core cable
L = 2000 ± 100
AWG26 UL No.2844
Window
10
PZ-30
2 – M3
Depth 6
1
3
Push button
Wire input
Terminal : OCN-051 manufactured by Osada
Wire : AWG16 26
Wire strip length : 9 10 mm
8.5
● Connector type terminal
□31.4
□30
35
7.5
2-M3 Depth 6
1 2 3 Rear Terminal No.
kPa
10
7.8
PZ-30
26.5
21
5 core cable
L = 2000 ± 100
AWG26 UL No.2844
3 2 1 Connector Pin No.
Connector : 0-171826-3 (Pitch 2.5) manufactured by AMP
(Housing : 0-171822-3)
8.5
Wire color
Brown
Gray
Black
White
Blue
Connection
Power ⊕
Analog output
Switch output 1
Switch output 2
Common
Connector pin No. Rear terminal No.
Connection of pressure sensor
3
1
V+:Power supply voltage output (Input voltage)
2
2
Sensor signal: Voltage output Vs (1 ~ 5V) /Current output Is (4 ~ 20mA)
1
3
COMMON(※)
PZ-30
PRESSURE INDICATORS
■ HOW TO MOUNT OPTIONAL ACCESSORIES
● Rear panel mounting bracket set
● Panel mounting bracket set
(51)
35
7
35
35
7
φ4.2
12
(51)
35
φ4.2
12
35
Material : SUS304 (t = 1.5)
25
35
25
φ4.2x5.2 Slot
2-M3x4
φ4.2x5.2 Slot
Associated screw
2-M3x4
Associated screw
2-M3x4
Associated screw
φ4.2
15.5
(5.7)
4.5
31.2
24.7
36 +0.5
+0.5
43 maximum
43 maximum
□40
□40
kPa
Recommended : 50 minimum
36 +0.5
6 maximum
kPa
PZ-30
Panel cut dimension
(Recommended board thickness : 5 maximum)
Panel cut dimension
Name
Series Name
Contents
(PG-30/PG-35)
ACPG-003
Panel holder cover
Panel holder
Panel stopper (2 pcs.)
Holder cover set
ACPG-004
Panel holder cover
Panel holder
Holder stopper set
ACPG-007
Panel holder
Rear panel bracket set (Z)
ACPG-011
Rear panel bracket set (Z) and M3 × 4, male screw (2 pcs.)
Panel bracket set (Z)
ACPG-012
Panel panel bracket set (Z) and M3 × 4, male screw (2 pcs.)
Panel holder set
(46)
(46)
6 maximum
PZ-30
(30)
φ4.2x5.2 Slot
24.7
(5.7)
□42.6
(30)
(20.5)
4.5
(14)
6
φ4.2x5.2 Slot
30
□42.6
(20.5)
9
(14)
(46)
(46)
6
24
9
24
φ4.2
15.5
● Panel holder set
2-M3x4
Associated screw
很抱歉,暂时无法提供与“PZ-30-PICN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+1213.125812+157.15844
