Additional Resources:
Product Page
3D Model
PCB Footprint
date
05/26/2022
page
1 of 9
SERIES: PDME1-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
1 W isolated output
unregulated output
compact SIP package
single/dual output models
continuous short circuit protection
extended temperature range (-40~105°C)
1500 Vdc isolation
no load input current as low as 5 mA
EN 62368-1, UL 62368-1
efficiency up to 85%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency2
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PDME1-S3-S3-S3
3.3
2.97~3.63
3.3
30
303
1
100
79
3
PDME1-S3-S5-S
3.3
2.97~3.63
5
1
100
82
PDME1-S3-S9-S3
3.3
2.97~3.63
9
11
111
1
100
85
3
PDME1-S3-S12-S
3.3
2.97~3.63
12
8
83
1
100
82
PDME1-S3-S15-S3
3.3
2.97~3.63
15
7
67
1
100
82
PDME1-S3-S24-S
3.3
2.97~3.63
24
4
42
1
100
84
PDME1-S3-D3-S3
3.3
2.97~3.63
±3.3
±15
±152
1
100
78
3
PDME1-S3-D5-S
3.3
2.97~3.63
±5
±10
±100
1
100
82
PDME1-S3-D9-S3
3.3
2.97~3.63
±9
±6
±56
1
100
85
3
PDME1-S3-D12-S
3.3
2.97~3.63
±12
±5
±42
1
100
82
PDME1-S3-D15-S3
3.3
2.97~3.63
±15
±4
±34
1
100
82
PDME1-S3-D24-S
3
3.3
2.97~3.63
±24
±2
±21
1
100
84
PDME1-S5-S3-S
5
4.5~5.5
3.3
30
303
1
75
74
PDME1-S5-S5-S
5
4.5~5.5
5
1
75
82
PDME1-S5-S9-S
5
4.5~5.5
9
12
111
1
75
83
PDME1-S5-S12-S
5
4.5~5.5
12
9
84
1
75
83
PDME1-S5-S15-S
5
4.5~5.5
15
7
67
1
75
83
PDME1-S5-S24-S
5
4.5~5.5
24
4
42
1
100
85
PDME1-S5-D3-S
5
4.5~5.5
±3.3
±15
±152
1
75
74
PDME1-S5-D5-S
5
4.5~5.5
±5
±10
±100
1
75
82
PDME1-S5-D9-S
5
4.5~5.5
±9
±6
±56
1
75
83
PDME1-S5-D12-S
5
4.5~5.5
±12
±5
±42
1
75
83
PDME1-S5-D15-S
5
4.5~5.5
±15
±4
±34
1
75
83
PDME1-S5-D24-S
5
4.5~5.5
±24
±3
±21
1
100
85
PDME1-S12-S3-S
12
10.8~13.2
3.3
30
303
1
75
75
PDME1-S12-S5-S
12
10.8~13.2
5
1
75
80
PDME1-S12-S9-S
12
10.8~13.2
9
12
111
1
75
80
3
3, 4
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PDME1-S │ DESCRIPTION: DC-DC CONVERTER
MODEL
(CONTINUED)
input
voltage
date 05/26/2022 │ page 2 of 9
output
voltage
output
current
output
power
ripple
& noise1
efficiency2
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PDME1-S12-S12-S
12
10.8~13.2
12
9
83
1
75
80
PDME1-S12-S15-S
12
10.8~13.2
15
7
67
1
75
81
PDME1-S12-S24-S
12
10.8~13.2
24
4
42
1
100
81
PDME1-S12-D3-S
12
10.8~13.2
±3.3
±15
±152
1
75
75
PDME1-S12-D5-S
12
10.8~13.2
±5
±10
±100
1
75
80
PDME1-S12-D12-S
12
10.8~13.2
±12
±5
±42
1
75
81
PDME1-S12-D15-S
12
10.8~13.2
±15
±4
±34
1
75
81
PDME1-S12-D24-S
12
10.8~13.2
±24
±3
±21
1
100
80
PDME1-S15-S5-S
15
13.5~16.5
5
1
75
80
PDME1-S15-S9-S
15
13.5~16.5
9
12
111
1
75
80
PDME1-S15-S12-S
15
13.5~16.5
12
9
83
1
75
80
PDME1-S15-S15-S
15
13.5~16.5
15
7
67
1
75
81
PDME1-S15-D5-S
15
13.5~16.5
±5
±10
±100
1
75
80
PDME1-S15-D12-S
15
13.5~16.5
±12
±5
±42
1
75
80
PDME1-S15-D15-S
15
13.5~16.5
±15
±4
±34
1
75
81
PDME1-S24-S3-S
24
21.6~26.4
3.3
30
303
1
75
75
PDME1-S24-S5-S
24
21.6~26.4
5
1
75
79
PDME1-S24-S9-S
24
21.6~26.4
9
12
111
1
75
80
PDME1-S24-S12-S
24
21.6~26.4
12
83
9
1
75
81
PDME1-S24-S15-S
24
21.6~26.4
15
7
67
1
75
81
PDME1-S24-S24-S
24
21.6~26.4
24
4
42
1
100
81
PDME1-S24-D5-S
24
21.6~26.4
±5
±10
±100
1
75
80
PDME1-S24-D12-S
24
21.6~26.4
±12
±5
±42
1
75
81
PDME1-S24-D15-S
24
21.6~26.4
±15
±4
±34
1
75
79
PDME1-S24-D24-S
24
21.6~26.4
±24
±3
±21
1
100
80
Notes:
1.
2.
3.
4.
5.
Measured at nominal input, 20 MHz bandwidth oscilloscope, with 10 µF tantalum and 1 µF ceramic capacitors on the output.
Measured at nominal input voltage, full load.
Model is not UL certified.
Model is not CE certified.
All specifications are measured at Ta=25°C, humidity < 75%, nominal input voltage, and rated output load unless otherwise specified.
PART NUMBER KEY
PDME1-S XX - X XX - S
Base Number
Input Voltage
Output:
S = single
D = dual
cui.com
Output Voltage
Mounting Style:
SIP
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 3 of 9
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
3.3 Vdc input models
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
2.97
4.5
10.8
13.5
21.6
3.3
5
12
15
24
3.63
5.5
13.2
16.5
26.4
Vdc
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
-0.7
-0.7
-0.7
-0.7
-0.7
5
9
18
21
30
Vdc
Vdc
Vdc
Vdc
Vdc
current
filter
at full load
3.3 Vdc output
all other output models
405
389
mA
mA
at full load
5 Vdc input models
3.3, 5 Vdc output
9, 12 Vdc output
286
254
254
mA
mA
mA
at full load
12 Vdc input models
110
mA
at full load
15 Vdc input models
88
mA
at full load
24 Vdc input models
61
mA
max
units
2,400
1,000
560
220
1,200
470
100
μF
μF
μF
μF
μF
μF
μF
±1.5
±1.2
filter capacitor
OUTPUT
parameter
maximum capacitive load5
3.3, 5 Vdc output models
9 Vdc output models
12, 15 Vdc output models
24, ±12, ±15 Vdc output models
±3.3, ±5 Vdc output models
±9 Vdc output models
voltage accuracy
see tolerance envelope curves
line regulation
for Vin change of 1%
3.3 Vdc output models
all other models
load regulation
min
from 10% to full load
3.3 input models
18
15
all other input models
5 Vdc output models
±20
±15
±10
switching frequency
100% load, nominal input voltage
temperature coefficient
at full load
Note:
typ
220
270
kHz
kHz
±0.02
%/°C
5. Tested at input voltage range and full load.
PROTECTIONS
parameter
continuous, self recovery
min
cui.com
typ
max
units
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 4 of 9
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute at 1 mA
1,500
isolation resistance
input to output at 500 Vdc
1,000
isolation capacitance
input to output, 100 kHz / 0.1 V
safety approvals
certified to 62368-1: EN, UL
conducted emissions
CISPR32/EN55032, class B (external circuit required, see Figure 3)
radiated emissions
ESD
IEC/EN61000-4-2, air ± 8 kV; contact ± 4 kV, class B
MTBF
as per MIL-HDBK-217F, 25°C
RoHS
yes
6
Note:
min
typ
max
units
Vdc
MΩ
pF
3,500,000
hours
6. Model PDME1-S5-D3-S does not have UL or CE certification.
ENVIRONMENTAL
parameter
min
operating temperature
see derating curves
storage temperature
storage humidity
non-condensing
case temperature rise
3.3 Vdc output model at 25°C
all other models at 25°C
typ
max
units
-40
105
°C
-55
125
°C
95
25
15
DERATING CURVES
cui.com
°C
°C
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 5 of 9
DERATING CURVES (CONTINUED)
cui.com
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 6 of 9
SOLDERABILITY
parameter
max
units
hand soldering
1.5 mm from case for 10 seconds
min
typ
300
°C
wave soldering
see wave soldering profile
260
°C
max
units
MECHANICAL
parameter
dimensions
19.65 x 6.00 x 10.16[0.774 x 0.236 x 0.400 inch]
min
case material
black flame-retardant and heat-resistant plastic (UL94V-0)
weight
typ
mm
2.1
g
MECHANICAL DRAWING
units: mm [inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
PIN CONNECTIONS
PIN
Function
Single
Dual
1
Vin
Vin
2
GND
GND
4
0V
-Vout
5
No Pin
0V
6
+Vout
+Vout
Recommended PCB Layout
Top View
cui.com
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 7 of 9
APPLICATION CIRCUIT
If you want to further reduce the input and output ripple, a filter capacitor may be connected to the input and output
terminals (Figures 1 & 2) provided that the capacitance is less than the maximum capacitive load of the model, otherwise
start-up problems may be caused if the capacitance is too large.
Figure 1
Single Output Models
Table 1
Vin
(Vdc)
Cin
(μF / V)
Vo
(Vdc)
Cout
(μF)
3.3
10 μF / 16 V
3.3, 5
10 μF / 16 V
9, 12
2.2 μF / 25 V
15, 24
1 μF / 50 V
5
4.7 μF
15, 24
1 μF
12
2.2 μF / 25 V
3.3
10 μF / 16 V
15
2.2 μF / 25 V
5
10 μF / 16 V
24
1 μF / 50 V
9
2.2 μF / 16 V
12
2.2 μF / 25 V
15
1 μF / 25 V
24
1 μF / 50 V
Figure 2
Dual Output Models
3.3, 5
10 μF
9, 12
2.2 μF
Table 2
cui.com
Vin
(Vdc)
Cin
(μF)
Vo
(Vdc)
Cout
(μF)
3.3
10 μF / 16 V
±3.3, ±5
10 μF / 16 V
±9, ±12
2.2 μF / 25 V
±15, ±24
1 μF / 50 V
±3.3, ±5
4.7 μF
5
4.7
±9, ±12
1 μF
12
2.2 μF / 25 V
15
24
±15, ±24
0.47 μF
±3.3
4.7 μF / 16 V
2.2 μF / 25 V
±5
4.7 μF / 16 V
1 μF / 50 V
±12
1 μF / 25 V
±15
0.47 μF / 25 V
±24
0.47 μF / 50 V
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 8 of 9
EMC RECOMMENDED CIRCUIT
Figure 3
Figure 4
Dual Output Models
Table 3
Recommended External Circuit Components
Vin (Vdc)
3.3
Vin (Vdc)
5
Vin (Vdc)
12, 15, 24
Vo (Vdc)
3.3, 5
9, 12, 15, 24
C1, C2
4.7 µF / 25 V
4.7 µF / 25 V
270 pF / 2 kVdc
CY
C3
refer to Cout in Tables 1, 2
LDM
6.8 μH
6.8 μH
Vo (Vdc)
3.3, 5, 9
12, 15, 24
C1, C2
4.7 µF / 25 V
4.7 µF / 25 V
1 nF / 4 kVdc
CY
C3
LDM
6.8 μH
6.8 μH
Vo (Vdc)
3.3, 5, 9
12, 15, 24
C1, C2
4.7 µF / 50 V
4.7 µF / 50 V
CY
270 pF / 2 kVdc
270 pF / 2 kVdc
C3, C4
LDM
6.8 μH
cui.com
6.8 μH
Product Page
3D Model
PCB Footprint
date 05/26/2022 │ page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
05/10/2019
1.01
safeties updated in features and safety line
01/12/2021
1.02
model table updated, packaging removed
03/08/2021
1.03
3.3 Vdc input model added, derating curves and circuit figures updated
05/26/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
