RDS-16S-74385-SMT-TR 数据手册
Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/06/2020
page
1 of 5
SERIES: RDS-74385-45A-SMT │ DESCRIPTION: ROTARY DIP SWITCH
FEATURES
10 and 16 positions
raised actuator
surface mount
tube or tape and reel packaging
SPECIFICATIONS
parameter
conditions/description
max
units
rated voltage
switching
non-switching
min
typ
42
42
Vdc
Vdc
rated current
switching
non-switching
100
400
mA
mA
withstanding voltage
for 1 minute
250
contact resistance
insulation resistance
80
at 250 Vdc
100
operating torque
actuator travel
Vac
90
continuous rotation
mΩ
MΩ
120
150
360
gf*cm
degrees
operating temperature
-60
125
°C
storage temperature
-60
125
°C
life
at rated voltage, current, 15~20 cycles/minute
flammability rating
UL94V-0
RoHS
yes
IP level
IP67 (IEC 60529:2001)
25,000
PART NUMBER KEY
RDS - XXS - 74385 - 45A - SMT - XX
Base Number
No. of Positions:
10 =10 Positions
16 =16 Positions
cuidevices.com
Packaging:
“blank” = Tube
TR = Tape and Reel
steps
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: RDS-74385-45A-SMT │ DESCRIPTION: ROTARY DIP SWITCH
date 10/06/2020│ page 2 of 5
MECHANICAL DRAWING
units: mm
tolerance: ±0.3 mm
unless otherwise noted
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
actuator
LCP (UL94V-0)
red (10 position)
gray (16 position)
2
housing
LCP (UL94V-0)
black
3
face plate
stainless steel
4
terminals
copper alloy
gold
10 POSITION
ON
ഋ
OFF
Ⴠ
TYPE
10 STEP
16 POSITION
ഋ
Ⴠ
16 STEP
CODE
POS
1
2
4
8
2
3
4
5
6
7
8
9
A
B
C
D
E
F
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 10/06/2020│ page 3 of 5
SOLDERABILITY
parameter
hand soldering
for maximum 3 seconds
min
255
Temperature (°C)
reflow soldering
typ
260
217
min 30 s
200
150
60 to 150 s
60 to 180 s
25
25˚C to Peak Temp (8 minutes)
Time (sec)
PACKAGING (TUBE)
units: mm
Tube Size: 13.0 x 14.50 x 540 mm
Tube QTY: 70 pcs
cuidevices.com
max
units
350
°C
260
°C
Product Page
3D Model
PACKAGING (TAPE & REEL )
units: mm
Reel Size: Ø330 mm
QTY: 600 pcs
cuidevices.com
PCB Footprint
date 10/06/2020│ page 4 of 5
Product Page
3D Model
PCB Footprint
date 10/06/2020│ page 5 of 5
REVISION HISTORY
rev.
1.0
description
date
initial release
10/06/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
RDS-16S-74385-SMT-TR 价格&库存
很抱歉,暂时无法提供与“RDS-16S-74385-SMT-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+25.463511+3.08009
- 10+24.0373510+2.90758
- 25+21.8523625+2.64328
- 100+18.93863100+2.29083
- 250+17.16998250+2.07690
- 500+15.92118500+1.92584
- 国内价格 香港价格
- 1300+14.776491300+1.78738
- 2600+13.423682600+1.62374
- 6500+12.878676500+1.55782
