MMC3630KJ
MMC3630KJ
    MEMSIC(美新)
    SMD
    MMC3630KJ
MMC3630KJ 数据手册
h ±30 Gauss, High Performance, Low Cost 3-axis Magnetic Sensor MMC3630KJ FEATURES  Fully integrated 3-axis magnetic sensor and electronic circuits requiring fewer external components  Superior Dynamic Range and Accuracy:  ±30 G FSR with 16 bits operation  1 mG per LSB resolution  2 mG total RMS noise  Enables heading accuracy of 1º  Output data rate up to 600 Hz  Ultra Small Low profile package 1.2x1.2x0.5 mm  Degaussing with built-in SET/RESET function  Eliminates thermal variation induced offset error (Null field output)  Clears the residual magnetization resulting from strong external fields  On-chip sensitivity compensation  On-chip temperature sensor  Motion_Detection and Data_Ready Interrupt  Low power consumption  1 µA power down current  I2C Slave, FAST (≤400 KHz) mode  1.8V single low power supply compatible  Low to 1.2V I2C interface  RoHS compliant  P2P compatible with AK09911 APPLICATIONS  Electronic Compass & GPS Navigation  Position Sensing DESCRIPTION The MMC3630KJ is a complete 3-axis magnetic sensor with on-chip signal processing and integrated I2C bus. The device can be connected directly to a microprocessor, eliminating the need for A/D converters or timing resources. It can measure Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, or for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. MEMSIC MMC3630KJ Rev.A FUNCTIONAL BLOCK DIAGRAM magnetic fields within the full scale range of 30 Gauss (G), with 1 mG per LSB resolution at 16 bits operation mode and 2 mG total RMS noise level, enabling heading accuracy of 1º in electronic compass applications. Contact MEMSIC for access to advanced calibration and tilt-compensation algorithms. An integrated SET/RESET function provides for the elimination of error due to Null Field output change with temperature. In addition it clears the sensors of any residual magnetic polarization resulting from exposure to strong external magnets. The SET/RESET function can be performed for each measurement or periodically as the specific application requires. The MMC3630KJ is packaged in an ultra-small low profile BGA package (1.2x 1.2 x 0.5 mm) and with an operating temperature range from -40 C to +85 C. The MMC3630KJ provides an I2C digital output with 400 KHz, fast mode operation. MEMSIC, Inc. One Technology Drive, Suite 325, Andover, MA 01810, USA Tel: +1 978 738 0900 Fax: +1 978 738 0196 www.memsic.com Page 1 of 17 6/30/2016 SPECIFICATIONS (Measurements @ 25 C, unless otherwise noted; VCAP=3 V, VDD= 1.8 V unless otherwise specified) Parameter Field Range (Each Axis) Conditions Min Total applied field -30 Supply Voltage Typ Units +30 G VCAP1 2.6 3 3.6 V VDD 1.62 1.8 3.6 V 1.2 1.8 3.6 V 5.0 ms 2 VIO(I C interface and INT) Supply Voltage rise time Supply Current2,6 (7 measurements/second) Max BW=00 240 300 µA BW=01 120 150 µA BW=10 60 80 µA 40 50 µA 1.0 1.0 µA BW=11 Power Down Current6 Operating Temperature -40 85 C Storage Temperature -55 125 C 0.3 0.5 %FS 0.03 0.2 %FS 0.015 1.0 2.0 2.0 2.0 3.0 4.0 16 100 200 400 600 1.0 0.1 3.0 5.0 4.0 4.0 5.0 5.0 1024 %FS Degrees % mG mG mG mG Bits Hz Hz Hz Hz Degrees % counts/G 5 % Linearity Error6 (Best fit straight line) Hysteresis6 FS=±30 G Happlied=±15 G 3 sweeps across ±30 G Repeatability Error6 3 sweeps across ±30 G Alignment Error Transverse Sensitivity BW=00 BW=01 BW=10 BW=11 Total RMS Noise6 Output resolution BW=00 BW=01 BW=10 BW=11 Max Output data rate Heading accuracy3 Sensitivity4,7 Sensitivity Change Over Temperature6 30 G -5 -40~85 C Delta from 25 C 30 G +5 -0.5 Null Field Output7 +0.5 G 1.0 C/Count 32768 Temperature Sensor Output 7 Disturbing Field5 0.6 0.8 Counts 36 Maximum Exposed Field G 10,000 G 1 Not applicable when using internal charge pump circuitry 2 Supply current is proportional to how many measurements performed per second 3 MEMSIC product enables users to utilize heading accuracy to be 1.0 degree typical when using MEMSIC’s proprietary software or algorithm 4 Sensitivity of the orthogonal axes is analytically derived from raw data and is subsequently processed by MEMSIC software drivers 5 This is the magnitude of external field that can be tolerated without changing the sensor characteristics. If the disturbing field is exceeded, a SET/RESET operation is required to restore proper sensor operation 6 Based on 3lots characterization result. 7 Based on shipment test result. MEMSIC MMC3630KJ Rev.A Page 2 of 17 6/30/2016 DIGITER INTERFACE (VIO=1.8V) Symbol VIH Parameter (Units) High Level Input Voltage (Volts) VIL Low Level Input Voltage (Volts) VHYS IIL Hysteresis of Schmitt Trigger Input (Volts) Input Leakage, All Inputs (uA) VOH VOL High Level Output Voltage (Volts) Low Level Output Voltage (Volts) MEMSIC MMC3630KJ Rev.A Minimum 0.7*VIO Typical Maximum 0.3*VIO 0.1 -10 10 0.8*VIO 0.2*VIO Page 3 of 17 6/30/2016 I2C INTERFACE I/O CHARACTERISTICS (VIO=1.8 V) Parameter Symbol Test Condition Min. Typ. Max. Unit Logic Input Low Level VIL -0.5 0.3* VIO V Logic Input High Level VIH 0.7*VIO VIO V Hysteresis of Schmitt input Vhys 0.2 Logic Output Low Level VOL 0.4 V Input Leakage Current Ii -10 10 µA SCL Clock Frequency fSCL 0 400 kHz START Hold Time tHD;STA 0.6 µS START Setup Time tSU;STA 0.6 µS LOW period of SCL tLOW 1.3 µS HIGH period of SCL tHIGH 0.6 µS Data Hold Time tHD;DAT 0 Data Setup Time tSU;DAT 0.1 0.1VIO
MMC3630KJ 价格&库存
很抱歉,暂时无法提供与“MMC3630KJ”相匹配的价格&库存,您可以联系我们找货
