SH2B-05C
SH2B-05C
    IDEC(日本和泉)
    SH2B-05C
SH2B-05C 数据手册
Relays & Sockets RH Switches & Pilot Lights RH Series Compact Power Relays Key features • SPDT through 4PDT, 10A contacts • Compact power type relays • Miniature power relays with a large capacity • 10A contact capacity • Compact size saves space Signaling Lights Part Number Selection Part Number Contact DPDT Standard RH1B-U 0 RH1V2-U 0 With Indicator RH1B-UL 0 — With Check Button RH1B-UC 0 — With Indicator and Check Button RH1B-ULC 0 — Top Bracket Mounting RH1B-UT 0 — With Diode (DC coil only) RH1B-UD 0 RH1V2-UD 0 DC6V, DC12V, DC24V, DC48V, DC110V With Indicator and Diode (DC coil only) RH1B-ULD 0 — DC12V, DC24V, DC48V, DC110V Standard RH2B-U 0 RH2V2-U 0 With Indicator RH2B-UL 0 RH2V2-UL 0 With Check Button RH2B-UC 0 — With Indicator and Check Button RH2B-ULC 0 — Top Bracket Mounting RH2B-UT 0 — With Diode (DC coil only) RH2B-UD 0 RH2V2-UD 0 With Indicator and Diode (DC coil only) RH2B-ULD 0 RH2V2-ULD 0 Standard RH3B-U 0 RH3V2-U 0 With Indicator RH3B-UL 0 RH3V2-UL 0 With Check Button RH3B-UC 0 — With Indicator and Check Button RH3B-ULC 0 — Top Bracket Mounting RH3B-UT 0 — With Diode (DC coil only) RH3B-UD 0 — With Indicator and Diode (DC coil only) RH3B-ULD 0 — Standard RH4B-U 0 RH4V2-U 0 With Indicator RH4B-UL 0 RH4V2-UL 0 With Check Button RH4B-UC 0 — With Indicator and Check Button RH4B-ULC 0 — Top Bracket Mounting RH4B-UT 0 — With Diode (DC coil only) RH4B-UD 0 RH4V2-UD 0 With Indicator and Diode (DC coil only) RH4B-ULD 0 — AC6V, AC12V, AC24V, AC110-120V, AC220-240V DC6V, DC12V, DC24V, DC48V, DC100-110V DC6V, DC12V, DC24V, DC48V, DC100-110V AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V DC6V, DC12V, DC24V, DC48V, DC110V Terminal Blocks AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V DC6V, DC12V, DC24V, DC48V, DC110V Circuit Breakers PCB terminal relays are designed to mount directly to a circuit board without any socket. AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V Contactors 4PDT Coil Voltage Code (Standard Stock in bold) PCB Terminal Timers 3PDT Blade Terminal Relays & Sockets SPDT Model Ordering Information When ordering, specify the Part No. and coil voltage code: (example) RH3B-U 1705151135 800-262-IDEC (4332) • USA & Canada Part No. AC120V Coil Voltage Code 873 Relays & Sockets Signaling Lights Switches & Pilot Lights RH Sockets (for Blade Terminal Models) Relays Standard DIN Rail Mount 1 Finger-safe DIN Rail Mount 1 Through Panel Mount PCB Mount RH1B SH1B-05 SH1B-O5C SH1B-51 SH1B-62 RH2B SH2B-05 SH2B-05C SH2B-51 SH2B-62 RH3B SH3B-05 SH3B-05C SH3B-51 SH3B-62 RH4B SH4B-05 SH4B-05C SH4B-51 SH4B-62 1. DIN Rail mount socket comes with two horseshoe clips. Do not use unless you plan to insert pullover wire spring. Replacement horseshoe clip part number is Y778-011. Hold Down Springs & Clips Appearance Relay For DIN Mount Socket RH1B SY2S-02F1 2 RH2B SY4S-02F1 RH3B SH3B-05F1 2 RH4B SH4B-02F1 2 Leaf Spring (side latch) RH1B, RH2B, RH3B, RH4B SFA-202 3 SFA-302 3 Leaf Spring (top latch) RH1B, RH2B, RH3B, RH4B SFA-101 3 SFA-301 3 Item Relays & Sockets Pullover Wire Spring For Through Panel & PCB Mount Socket 2. Must use horseshoe clip when mounting in DIN mount socket. Replacement horseshoe clip part number is Y778-011. 3. Two required per relay. 2 SY4S-51F1 AC Coil Ratings Circuit Breakers Terminal Blocks Contactors Timers Rated Current (mA) ±15% at 20°C Voltage (V) AC 50Hz Coil Resistance (Ω) ±10% at 20°C AC 60Hz SPDT DPDT 3PDT 4PDT SPDT DPDT 3PDT 4PDT SPDT 6 170 240 330 387 150 200 280 330 18.8 9.4 6.4 5.4 12 86 121 165 196 75 100 140 165 76.8 39.3 25.3 21.2 24 42 60.5 81 98 37 50 70 83 300 153 103 84.5 110 9.6 — 18.1 21.6 8.4 — 15.5 18.2 6,950 — 2,200 1,800 110-120 — 9.410.8 — — — 8.0-9.2 — — — — — — 120 8.6 — 16.4 19.5 7.5 — 14.2 16.5 8,100 — 10,800 7,360 220 4.7 — 8.8 10.7 4.1 — 7.7 9.1 25,892 — 10,800 7,360 220-240 — 4.7-5.4 — — — 4.0-4.6 — — 18,820 — — 240 4.9 — 8.2 9.8 4.3 — 7.1 26,710 — 12,100 9,120 8.3 DPDT 3PDT Operation Characteristics (against rated values at 20ºC) 4PDT Max. Continuous Applied Voltage Pickup Voltage Dropout Voltage 110% 80% maximum 30% minimum DC Coil Ratings Voltage (V) Coil Resistance (Ω) ±10% at 20°C Rated Current (mA) ±15% at 20°C SPDT DPDT 3PDT 4PDT SPDT DPDT Operation Characteristics (against rated values at 20ºC) 3PDT 4PDT 6 128 150 240 250 47 40 25 24 12 64 75 120 125 188 160 100 96 24 32 36.9 60 62 750 650 400 388 48 18 18.5 30 31 2,660 2,600 1,600 1,550 100-110 — 8.2-9.0 — — — 12,250 — — 110 8 — 12.8 15 13,800 — 8,600 7,340 874 Max. Continuous Applied Voltage Pickup Voltage Dropout Voltage 110% 80% maximum 10% minimum www.IDEC.com Standard coil voltages are in BOLD. 1705151135 Relays & Sockets UL Ratings Resistive Maximum Contact Capacity Model Continuous Current SPDT 10A Resistive Load Inductive Load 1540VA 300W 990VA 210W 1650VA 300W 10A 1100VA 225W Ind. Load RH1 RH2 RH3 240V AC 10A Rated Load General Use RH4 RH1 RH2 RH3 7.5A 7.5A 7A Horsepower Rating RH4 RH1 RH2 RH3 RH4 6.5A 5A 1/3 HP 1/3 HP — Voltage (V) Res. Load 110 AC 10A 7A 120V AC — 10A 10A — 7.5A 7.5A 1/6 HP 1/6 HP — 220 AC 7A 4.5A 30V DC 10A 10A — 7A — — — — — 28V DC — — 10A — — — — — — 30 DC 10A 7A 110 AC 10A 7.5A 220 AC 7.5A 5A 30 DC 10A 7.5A CSA Ratings Resistive Voltage Note: Inductive load for the rated load — cos ø = 0.3, L/R = 7 ms TÜV Ratings RH1 RH2 RH3 RH4 240V AC 10A 10A 7.5A 7.5A 30V DC 10A 10A 10A 10A Horsepower Rating General Use RH1 RH2 RH3 RH4 RH1 RH2 RH3 RH4 RH1, 2, 3 240V AC 10A 10A — 7.5A 7A 7A 7A 5A 1/3 HP 120V AC 10A 10A 10A 10A 7.5A 7.5A — 7.5A 1/6 HP 30V DC 10A 10A 10A 10A 7A 7.5A — — — Relays & Sockets Voltage Signaling Lights DPDT 3PDT 4PDT Allowable Contact Power Voltage Switches & Pilot Lights Contact Ratings RH AC: cos ø = 1.0, DC: L/R = 0 ms Socket Specifications Sockets Finger-safe DIN Rail Mount PCB Mount Socket Wire Size Torque SH1B-05 250V, 10A Maximum up to 2–#12AWG 5.5 - 9 in•lbs 9 - 11.5 in•lbs SH2B-05 SH3B-05 SH4B-05 M3.5 screws with captive wire clamp 300V, 10A Maximum up to 2–#12AWG 9 - 11.5 in•lbs SH1B-05C (coil) M3 screws 250V, 10A (contact) M3.5 screws with captive wire clamp, fingersafe Maximum up to 2–#12AWG 5.5 - 9 in•lbs 9 - 11.5 in•lbs SH2B-05C SH3B-05C SH4B-05C M3.5 screws with captive wire clamp, fingersafe 300V, 10A Maximum up to 2–#12AWG 9 - 11.5 in•lbs SH1B-51 SH2B-51 SH3B-51 SH4B-51 Solder 300V, 10A — — SH1B-62 PCB mount 250V, 10A — — SH2B-62 SH3B-62 SH4B-62 PCB mount 300V, 10A — — Contactors Through Panel Mount Socket Electrical Rating Timers DIN Rail Mount Sockets Terminal (Coil) M3 screws (contact) M3.5 screws with captive wire clamp Terminal Blocks Accessories Item Part No. Remarks Aluminum DIN Rail (1 meter length) All DIN rail sockets BNDN1000 The BNDN1000 is designed to accommodate DIN mount sockets. Made of durable extruded aluminum, the BNDN1000 measures 0.413 (10.5mm) in height and 1.37 (35mm) in width (DIN standard). Standard length is 39” (1,000mm). DIN Rail End Stop DIN rail BNL5 9.1 mm wide. Replacement Hold-Down Spring Anchor DIN mount sockets and hold down springs. Y778-011 For use on DIN rail mount socket when using pullover wire hold down spring. 2 pieces included with each socket. 800-262-IDEC (4332) • USA & Canada Circuit Breakers Use with 1705151135 Appearance 875 Relays & Sockets Timers Relays & Sockets Signaling Lights Switches & Pilot Lights RH Specifications Contact Material Silver cadmium oxide Contact Resistance 1 50mΩ maximum Minimum Applicable Load Operating Time 2 Release Time 2 Power Consumption (approx.) 24V DC, 30 mA; 5V DC, 100 mA (reference value) SPDT DPDT 20ms maximum 3PDT 4PDT 25ms maximum SPDT DPDT 20ms maximum 3PDT 4PDT 25ms maximum SPDT AC: 1.1VA (50Hz), 1VA (60Hz) DC: 0.8W DPDT AC: 1.4VA (50Hz), 1.2VA (60Hz) DC: 0.9W 3PDT AC: 2VA (50Hz), 1.7VA (60Hz) DC: 1.5W 4PDT AC: 2.5VA (50Hz), 2VA (60Hz) DC: 1.5W Insulation Resistance Dielectric Strength 100MΩ minimum (500V DC megger) SPDT Between live and dead parts: 2,000V AC, 1 minute Between contact and coil: 2,000V AC, 1 minute Between contacts of the same pole: 1,000V AC, 1 minute DPDT 3PDT 4PDT Between live and dead parts: 2,000V AC, 1 minute Between contact and coil: 2,000V AC, 1 minute Between contacts of different poles: 2,000V AC, 1 minute Between contacts of the same pole: 1,000V AC, 1 minute 3 Operating Frequency Electrical: Mechanical: 1,800 operations/hour maximum 18,000 operations/hour maximum Vibration Resistance Damage limits: Operating extremes: 10 to 55Hz, amplitude 0.5 mm 10 to 55Hz, amplitude 0.5 mm Shock Resistance Damage limits: 1,000m/s2 (100G) Operating extremes: 200m/s2 (20G - SPDT, DPDT) 100m/s2 (10G - 3PDT, 4PDT) Mechanical Life Operating Temperature 4 500,000 operations minimum (120V AC, 10A) SPDT 3PDT 4PDT 200,000 operations minimum (120V AC, 10A) SPDT DPDT 3PDT 4PDT –25 to +70°C (no freezing) Operating Humidity 45 to 85% RH (no condensation) Weight (approx.) SPDT: 24g, DPDT: 37g, 3PDT: 50g, 4PDT: 74g Note: Above values are initial values. 1. Measured using 5V DC, 1A voltage drop method 2. Measured at the rated voltage (at 20°C), excluding contact bouncing Release time of relays with diode: 40 ms maximum 3. Relays with indicator or diode: 1000V AC, 1 minute 4. For use under different temperature conditions, refer to Continuous Load Current vs. Operating Temperature Curve. The operating temperature range of relays with indicator or diode is –25 to +40°C. Circuit Breakers Terminal Blocks Contactors Electrical Life 50,000,000 operations minimum DPDT 876 www.IDEC.com 1705151135 Relays & Sockets RH Switches & Pilot Lights Characteristics (Reference Data) Electrical Life Curves AC Load DC Load 1000 1000 (RH1) 120V AC resistive (RH1) 500 Life (X 10,000 operations) 100 50 20 10 (RH2) 1 2 100V DC resistive 240V AC resistive 120V AC inductive 3 4 5 6 7 Load Current (A) 8 9 30V DC inductive 100V DC inductive 10 10 (RH2) 120V AC resistive 1 2 3 4 5 6 Load Current (A) 7 8 9 10 7 8 9 10 7 8 9 10 1000 Relays & Sockets 1000 50 20 240V AC inductive 30V DC resistive 100 Signaling Lights Life (x 10,000 operations) 500 30V DC resistive 500 Life (X 10,000 operations) Life (x 10,000 operations) 500 100 50 100 50 240V AC resistive 120V AC inductive 240V AC inductive 20 20 1 2 3 4 5 6 7 Load Current (A) 8 9 (RH3/RH4) 1000 Life (X 10,000 operations) 10 1 2 4 5 6 Load Current (A) 7 8 9 5 6 Load Current (A) 100 50 100V DC resistive 100V DC inductive 240V AC resistive 120V AC inductive 3 4 30V DC inductive 20 240V AC inductive 3 Contactors 50 2 30V DC resistive 500 100 20 1 1000 120V AC resistive 500 Life (x 10,000 operations) 10 10 Timers 10 (RH3/RH4) 30V DC inductive 100V DC resistive 100V DC inductive 10 10 1 2 3 4 5 6 Load Current (A) (RH2/RH3/RH4) (RH1) 10.0 10.0 AC resistive DC resistive 1.0 DC inductive 0.5 1 5 10 Load Voltage (V) AC inductive DC resistive 1.0 DC inductive 0.5 50 100 200 300 800-262-IDEC (4332) • USA & Canada 0.1 1 5 10 50 100 200 Circuit Breakers 1705151135 AC resistive 5.0 AC inductive Load Current (A) Load Current (A) 5.0 0.1 Terminal Blocks Maximum Switching Capacity 300 Load Voltage (V) 877 Relays & Sockets Signaling Lights Continuous Load Current vs. Operating Temperature Curve (Basic Type, With Check Button, and Top Bracket Mounting Type) 90 90 80 80 DC Coil 70 60 AC Coil 50 40 30 20 10 0 DC Coil 70 60 50 AC Coil 40 30 80 70 60 50 AC/DC Coil 40 30 20 20 10 0 1 2 3 4 5 6 7 8 9 10 Load Current (A) Note: The rated voltage is applied to the coil. 100 90 10 0 1 2 3 4 5 6 7 8 9 10 Load Current (A) Internal Connection (View from Bottom) 1 2 3 4 5 6 7 8 9 10 Load Current (A) Basic Type SPDT DPDT 3PDT 4PDT 1 Relays & Sockets (RH3/RH4) Note: The rated voltage is applied to the coil. 100 Operating Temperature (˚C) (RH2) Note: The rated voltage is applied to the coil. 100 Operating Temperature (˚C) (RH1) Operating Temperature (˚C) Switches & Pilot Lights RH 2 3 With Check Button Front Pushbutton 4 5 6 7 8 9 10 11 12 Contacts can be operated by pressing the check button. (+) 14 13 (–) With Indicator (-L type) SPDT 3PDT 1 1 5 Below 100V AC/DC 9 6 9 14 (+) 10 13 ( – ) 4 1 8 2 5 12 6 9 ( + )14 10 DPDT 3 4 7 8 11 13( – ) 12 ( + )14 1 4 9 12 5 Below 24V AC/ DC 13( – ) 8 ( + )14 Timers 13 (–) 2 5 4PDT 1 5 Contactors 100V AC/DC and over 9 13 (–) 14 (+) 1 2 4 1 2 3 4 5 6 8 5 6 7 8 9 10 12 9 10 11 12 13 (–) (+) 14 13 (–) (+) 14 1 4 9 12 13( – ) ( + )14 5 24V AC/ DC and over 8 When the relay is energized, the indicator goes on. • Relay coils less than 100V DC do not contain a protection diode (except DPDT). • Relay coils below 100V use LED indicator, coils above 100V use neon lamp indicator. • LED color of DPDT model is green With Diode (-D type) SPDT DPDT 1 1 5 9 14 (+) 4 1 5 8 5 9 12 9 13 (–) (+) 14 13 (–) 2 4PDT 4 1 6 8 5 6 7 8 10 12 9 10 11 12 (+) 14 13 (–) 2 3 4 (+) 14 Contains a diode to absorb the back emf generated when the coil is de-energized. The release time is slightly longer. Available for DC coil only. • Diode Characteristics Reverse withstand voltage: 1,000V Forward current: 1A Circuit Breakers Terminal Blocks 13 (–) 3PDT 878 www.IDEC.com 1705151135 Relays & Sockets RH SPDT 3PDT 4PDT DPDT 1 5 9 Below 100V DC 13 (–) 14 (+) 14( + ) 9 12 8 ( + )14 13( – ) Contains an LED indicator and a surge absorber, and has the same height as the basic type. 1 4 9 12 5 24V AC/ DC and over 9 13 ( – ) 4 8 13 (–) Signaling Lights 5 1 5 Below 24V AC/ DC 1 100V DC and over Switches & Pilot Lights With Indicator LED & Diode (-LD type) LED color of DPDT model is green. 14 (+) Dimensions (mm) RH2B-U/RH2B-UL/RH2B-UD/RH2B-ULD Total length from panel surface including relay socket SH1B-05: 61.5 (63.5) max., SH1B-51: 39.6 (41.6) max. RH3B-U/RH3B-UL/RH3B-UD/RH3B-ULD Total length from panel surface including relay socket SH3B-05: 61.5 (63.5) max., SH3B-51: 39.6 (41.6) max. Total length from panel surface including relay socket SH2B-05: 61.5 (63.5) max., SH2B-51: 39.6 (41.6) max. Dimensions in the ( ) include a hold-down spring. Dimensions in the ( ) include a hold-down spring. Dimensions in the ( ) include a hold-down spring. ø2.6 hole 1 8 14 9 12 13 14 27.5 4 5 6.4 0.5 6.4 21 RH4B-U/RH4B-UL/RH4B-UD/RH4B-ULD RH1B-UT 8 10 11 14 6.4 31 RH2B-UT 4.7 Total length from panel surface including relay socket SH4B-05: 61.5 (63.5) max., SH4B-51: 39.6 (41.6) max. 6 9 13 35.6 max. 4 5 Timers 35.6 max. 2 1 14 0.5 4.7 ø2.6 hole Contactors 0.5 ø2.6 hole 4.7 10 Dimensions in the ( ) include a hold-down spring. 4.7 5.4 1 0.5 13 27.5 0.5 9 27.5 5 4.7 ø2.6 hole 4.7 4.7 ø2.6 hole 35.6 max. Relays & Sockets RH1B-U/RH1B-UL/RH1B-UD/RH1B-ULD 1 1 2 3 4 5 6 7 8 9 10 11 2 35.6 max. 12 13 14 27.5 5.9 3.5 8 9 7.25 5.4 6.4 4.7 2 35.6 max. 21.5 12 13 6.4 14 6.4 35.6 max. 3.5 14.5 4 5 27.5 0.5 6.6 ø2.6 hole 14 43.2 38 9 13 1 27.5 43.2 38 5.9 5 41 Terminal Blocks RH4B-UT ø2.6 hole 0.5 4.7 2 ø2.6 hole 4 12 14 2 3 31.5 1705151135 35.6 max. 6.4 35.6 max. 6.4 7.25 2 7.25 21.5 42 max. 800-262-IDEC (4332) • USA & Canada 4 5 6 7 8 9 10 11 12 13 28 8 10 44 38 6 9 5.9 1 5 28 5.9 43.2 38 2 Circuit Breakers 1 13 3.5 0.5 4.7 3.5 4.7 10 10 10 10 4.7 10 RH3B-UT 14 28 41.5 879 Relays & Sockets Dimensions con’t (mm) RH1V2-U/RH1V2-UD RH2V2-U/RH2V2-UL/RH2V2-UD 8-ø2.4 holes 4.7 0.5 3-ø2.4 holes 12 14 7.8 10 2 14 8 9 35.6 max. 4.4 RH3V2-U/RH3V2-UL/RH3V2-D 21 4.6 14.2 RH4V2-U/RH4V2-UL/RH4V2-UD 11-ø2.4 holes 10 30 10 10 4 6 7 8 9 10 11 12 0.5 4.6 13.15 3 5 7.25 14 13 7.25 31 2 7.8 1 14 13 27.5 11 0.5 8 10 7.8 4 6 9 0.5 35.6 max. 2 5 27.5 0.5 Relays & Sockets 1 13.15 2 2 14-ø2.4 holes 4.7 4.6 4.7 Signaling Lights 35.6 max. 4 5 13 27.5 1 5 14 12.5 0.5 9 6.6 27.5 5 13 13.15 0.5 1 7.25 0.5 2 4.7 7.15 0.5 2 2-ø2 holes 1.5 Switches & Pilot Lights RH 41 35.6 max. 4.6 Standard DIN Rail Mount Sockets SH1B-05 SH2B-05 22 4.2 DIN Rail (BNDN) 4.8 min. 14.5 ø3.2 min. 5.9 max. 5 1 5.5 min. 14 13 12 26 14.5 9 30 25 (Top View) 7.9 max. ø3.6 min. (For terminals 13 and 14) SH4B-05 31.5 18 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 47 67 8 6 5 4 2 1 36 5.5 min. 14 12 7.9 max. DIN Rail (BNDN) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 5.5 min. 9 46 50 Terminal Arrangement 8 4 6 7 3 2 11 10 5 1 46 13 10 (Top View) ø3.6 min. 18 4.4 max. 2.5 14.5 25 M3.5 Terminal Screw 14.5 25 7.9 max. 14 12 13 9 (Top View) ø3.6 min. Circuit Breakers 40 8 Terminal Arrangement 4.4 max. 36 31.5 42 DIN Rail (BNDN) 47 M3.5 Terminal Screw 4.2 8 67 32 2.5 8 4 26 9 SH3B-05 4.2 Contactors Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 4.4 max. (Top View) ø3.6 min. 7.9 max. DIN Rail (BNDN) 18 13 2.5 25 20 14 4 max. (For terminals 1, 5, and 9) Terminal Blocks 1 67 47 4.4 max. 16 M3.5 Terminal Screw 5 16 5.5 min. M3 Terminal Screw 2.5 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 31.5 8 Terminal Arrangement 47 18 M3.5 Terminal Screw 67 Timers 8 4.2 31.5 17 880 www.IDEC.com 1705151135 Relays & Sockets RH Switches & Pilot Lights Dimensions con’t (mm) Finger-safe DIN Rail Mount Sockets SH1B-05C SH2B-05C 6 35.5 M3 Terminal Screw 25 22 DIN Rail (BNDN) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 18 8 7 6 5 4 3 2 1 2 12 11 10 9 1.7 (Top View) 49 13 12 29.5 Ring terminals cannot be used. 9 (Top View) 36 25 DIN Rail (BNDN) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 4 6 2 25 7 5 1 18.7 29.5 Ring terminals cannot be used. 8 4 7 3 6 5 2 1 11 10 46 13 10 Terminal Arrangement 49 49 36 DIN Rail (BAA/BAP) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) ø5 4.2 4.2 8 When using BAA/BAP: 33 42 Terminal Arrangement 69 M3.5 Terminal Screw 9 14 (Top View) 12   1.7 7 Relays & Sockets 69 14 SH4B-05C 12 1.7 5 1 26 18.7 26 30 8 4   14 40 Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 69 46 64 1.6 13 29 ø5 36 DIN Rail (BNDN) Signaling Lights Ring terminals cannot be used. 14 SH3B-05C 32 25 26 18.2 26 36 ø5 4.2 ø5.5 Terminal Arrangement M3.5 Terminal Screw 7 4.2 30 46 50 18.7 Ring type crimping terminals cannot be used. 13 9 (Top View) 29.5 Through Panel Mount Socket SH1B-51 SH2B-51 Timers Contactors   SH3B-51 SH4B-51 Terminal Blocks   Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 881 Relays & Sockets Dimensions con’t (mm) PCB Mount Sockets SH2B-62 14 (Bottom View) 15 (Tolerance ±0.1) 15.5 5.65 13 2 21.5 min. 2.85 10 6.6 25.4 29 2-ø2 holes 8-ø2.4 holes (Tolerance 0.1) * 34 min. when using hold-down springs 25.4 45 13 14 (Bottom View) 6.6 15 11-ø2.4 holes 2 39.2 * 36 min. when using hold-down springs 2 3 4 6 7 8 10 11 12 (Tolerance 0.1) * 36 min. when using hold-down springs 45 min. 31.3 10 10 10 14-ø2.4 holes (Tolerance 0.1) Circuit Breakers Terminal Blocks Contactors Timers 30.2 31 min.* 2 6.85 1 5 9 11 11 15 3 Terminal Arrangement 31 min.* (Bottom View) 10 10 0.3 14 31 13 21.3 6.6 36 min. 7.35 4.7 2 4 6 8 10 12 12.5 6.65 25.4 0.3 31 3 36 1 5 9 4.7 6.65 SH4B-62 12.5 SH3B-62 Terminal Arrangement Relays & Sockets 4 8 12 11 * 36 min. when using hold-down springs 12.2 1 5 9 29 min.* 15 3 21.2 31 min.* Signaling Lights 2 1.5 0.3 (Bottom View) 11 5.95 3 11.85 18 0.3 13 14 Terminal Arrangement 18 min. 4.4 4.7 6.95 1 5 9 4.7 25.4 Terminal Arrangement 6.8 3-ø2.4 holes 12.5 SH1B-62 31 Switches & Pilot Lights RH 882 www.IDEC.com 1705151135
SH2B-05C 价格&库存
很抱歉,暂时无法提供与“SH2B-05C”相匹配的价格&库存,您可以联系我们找货
SH2B-05C
    • 1+85.678631+11.10559
    • 10+76.3121210+9.89151
    • 25+72.8709225+9.44546
    • 50+70.3719150+9.12154
    • 100+67.95649100+8.80846
    • 250+64.88831250+8.41076
    • 500+62.65792500+8.12166
    • 1000+60.502561000+7.84229
    库存:583
