M24308/24-69Z
M24308/24-69Z
    POSITRONIC(宝西)
M24308/24-69Z 数据手册
INCH-POUND MIL-DTL-24308/24H w/AMENDMENT 5 8 June 2018 SUPERSEDING MIL-DTL-24308/24H w/AMENDMENT 4 8 April 2015 DETAIL SPECIFICATION SHEET CONNECTORS, ELECTRIC, RECTANGULAR, NONENVIRONMENTAL, MINIATURE, POLARIZED SHELL, RACK AND PANEL, PIN CONTACTS PRINTED WIRING BOARD TERMINATION TYPES This specification is approved for use by all Departments and Agencies of the Department of Defense. The requirements for acquiring the product described herein shall consist of this specification sheet and MIL-DTL-24308. FIGURE 1. Shell, plug, printed wiring board type. AMSC N/A FSC 5935 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 +0.010 -0.020 FIGURE 1. Shell, plug, printed wiring board type – Continued. 2 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 FIGURE 1. Shell, plug, printed wiring board type – Continued. 3 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 Dimensions and configurations Shell Size 1 2 3 4 5 A B C D E F G H J K L 1.228 (31.19) 1.198 (30.43) 1.556 (39.52) 1.526 (38.76) 2.103 (53.42) 2.073 (52.65) 2.744 (69.70) 2.714 (68.94) 2.650 (67.31) 2.620 (66.55) .671 (17.04) .661 (16.79) .999 (25.37) .989 (25.12) 1.539 (39.09) 1.529 (38.84) 2.187 (55.55) 2.177 (55.30) 2.084 (52.93) 2.074 (52.68) .989 (25.12) .979 (24.87) 1.317 (33.45) 1.307 (33.20) 1.857 (47.17) 1.847 (46.91) 2.505 (63.63) 2.495 (63.37) 2.411 (61.24) 2.401 (60.99) .334 (8.48) .324 (8.23) .334 (8.48) .324 (8.23) .334 (8.48) .324 (8.23) .334 (8.48) .324 (8.23) .446 (11.33) .436 (11.07) .509 (12.93) .479 (12.17) .509 (12.93) .479 (12.17) .509 (12.93) .479 (12.17) .509 (12.93) .479 (12.17) .620 (15.75) .590 (14.99) .432 (10.97) .412 (10.46) .432 (10.97) .412 (10.46) .436 (11.07) .416 (10.57) .436 (11.07) .416 (10.57) .436 (11.07) .416 (10.57) .238 (6.05) .229 (5.82) .238 (6.05) .229 (5.82) .236 (5.99) .224 (5.69) .236 (5.99) .224 (5.69) .236 (5.99) .224 (5.69) .769 (19.53) .749 (19.02) 1.093 (27.76) 1.073 (27.25) 1.635 (41.53) 1.615) (41.02) 2.282 (57.96) 2.262 (57.45) 2.188 (55.58) 2.168 (55.07) .432 (10.97) .412 (10.46) .432 (10.97) .412 (10.46) .432 (10.97) .412 (10.46) .432 (10.97) .412 (10.46) .544 (13.82) .524 (13.31) .060 (1.52) .035 (0.89) .060 (1.52) .035 (0.89) .070 (1.78) .050 (1.27) .070 (1.78) .050 (1.27) .070 (1.78) .050 (1.27) .040 (1.02) .020 (0.51) .040 (1.02) .020 (0.51) .049 (1.24) .029 (0.74) .049 (1.24) .029 (0.74) .049 (1.24) .029 (0.74) .185 .130 .210 .155 .185 .130 .210 .155 .154 .099 .185 .130 .154 .099 .185 .130 .210 .155 .210 .155 .185 .130 .320 .275 .154 .099 (4.70 mm) (3.30 mm) (5.33 mm) (3.94 mm) (4.70 mm) (3.30 mm) (5.33 mm) (3.94 mm) (3.91 mm) (2.51 mm) (4.70 mm) (3.30 mm) (3.91 mm) (2.51 mm) (4.70 mm) (3.30 mm) (5.33 mm) (3.94 mm) (5.33 mm) (3.94 mm) (4.70 mm) (3.30 mm) (8.13 mm) (6.99 mm) (3.91 mm) (2.51 mm) Application data and dimensions. Applicable dash number M24308/24 -1 through –5 (See note 14) -7 through –11 (See note 14) -13 through –17 (See note 14) -19 through –23 (See note 14) -25 through –29 (See note 14) -31 through –35 (See note 14) -37 through –41 (See note 14) -43 through –47 (See note 14) -49 through –53 (See note 14) -55 through –59 (See note 14) -61 through –65 (See note 14) -67 through –71 (See note 14) -73 through –77 (See note 14) Applicable Configurations Applicable board thickness Nominal pin diameter 1 and 2 .094 (2.39 mm) .030 (0.76 mm) 1 and 2 .125 (3.18 mm) .030 (0.76 mm) 1 and 2 .094 (2.39 mm) .040 (1.02 mm) 1 and 2 .125 (3.18 mm) .040 (1.02 mm) 1 and 3 .062 (1.57 mm) .030 (0.76 mm) 1 and 3 .094 (2.39 mm) .030 (0.76 mm) 1 and 3 .062 (1.57 mm) .040 (1.02 mm) 1 and 3 .094 (2.39 mm) .040 (1.02 mm) 1 and 3 .125 (3.18 mm) .030 (0.76 mm) 1 and 3 .125 (3.18 mm) .040 (1.02 mm) 1 and 2 .094 (2.39 mm) .020 (0.51 mm) 1 and 2 .125 (3.18 mm) .020 (0.51 mm) 1 and 4 .062 (1.57 mm) .020 (0.51 mm) M FIGURE 1. Shell, plug, printed wiring board type – Continued. 4 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. N .033 .027 .033 .027 .043 .037 .043 .037 .033 .027 .033 .027 .043 .037 .043 .037 .033 .027 .043 .037 .023 .017 .023 .017 .023 .017 (0.84 mm) (0.69 mm) (0.84 mm) (0.69 mm) (1.09 mm) (0.94 mm) (1.09 mm) (0.94 mm) (0.84 mm) (0.69 mm) (0.84 mm) (0.69 mm) (1.09 mm) (0.94 mm) (1.09 mm) (0.94 mm) (0.84 mm) (0.69 mm) (1.09 mm) (0.94 mm) (0.58 mm) (0.43 mm) (0.58 mm) (0.43 mm) (0.58 mm) (0.43 mm) MIL-DTL-24308/24H w/AMENDMENT 5 Inches .005 .010 .015 .030 .040 .062 .065 .070 .092 mm 0.13 0.25 0.38 0.76 1.02 1.57 1.65 1.78 2.34 Inches .104 106 .112 .115 .120 .125 .135 .220 mm 2.64 2.69 2.84 2.92 3.05 3.18 3.43 5.59 Inches .247 .251 .283 .302 .340 .395 .484 .507 .594 mm 6.27 6.38 7.19 7.67 8.64 10.03 12.29 12.88 15.09 NOTES: 1. Dimensions are in inches. 2. Metric equivalents are given for information only. 3. Pin diameter .041/.039 (1.04/0.99 mm) diameter pin for arrangements (see MIL-DTL-24308, appendix A) A-1-1, A-2-1, A-3-1, A-4-1 and A-5-1. Pin diameter .0305/.0295 (.775/.749 mm) diameter for arrangements A-1-2, A-2-2, A-3-2, A-4-2, and A-5-2. 4. Copyright notice. All information disclosed in this military specification sheet which is or may be copyrighted by ITT Cannon Electric is reproduced herein with the expressed permission of the copyright owner. 5. The 90 ° bracket shall be one piece flame resistant glass-filled nylon, polyester or two piece metal and nylon of which the metal pieces shall be coated with a material in accordance with IPC-CC-830. 6. The 90 ° bracket shall be furnished as an integral part of the connector assembly. 7. Spacers will be supplied with connectors (not attached to the connector). 8. Layout shown for reference only to locate CL. See applicable insert arrangement. Connectors may be fastened to board for test. 9. Dimensions are .150 (3.81 mm) minimum full pin diameter extension (sizes 3 through 6) and .159 (4.04 mm) minimum full pin diameter extension (sizes 1 and 2). 10. Unless otherwise specified, tolerance is ± .010 inch (0.25 mm). 11. In the event of a conflict between the text of this specification sheet and the references cited herein, the text of this specification sheet shall take precedence. 12. Referenced Governments documents of the issue listed in ASSIST Online database at https://assist.dla.mil/ specified in the solicitation form a part of this standard to the extent specified herein. 13. Indentation on the ends of the termination side of the shell, for the purpose of securing the insulator in the shell, is permitted. This may result in the “F” dimension being undersized in these areas. However the “F” dimension shall be maintained for the remainder of the connector. 14. For classes M, N and D use table I for applicable dash numbers. FIGURE 1. Shell, plug, printed wiring board type – Continued. 5 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 REQUIREMENTS: The connectors shall conform to figure 1 and the specification Part or Identifying Numbers (PIN) indicated in table I. TABLE I. Design standards. 1/ PIN PIN PIN PIN Class G Class M Class N Class D Shell size Shell detail Insert arrangement Contact configurations reference Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Straight Straight Straight Straight Straight Straight Mating end PWB tail M24308/24-1 M24308/24-2 M24308/24-3 M24308/24-4 M24308/24-5 M24308/24-7 M24308/24-101 M24308/24-102 M24308/24-103 M24308/24-104 M24308/24-105 M24308/24-107 M24308/24-201 M24308/24-202 M24308/24-203 M24308/24-204 M24308/24-205 M24308/24-207 M24308/24-301 M24308/24-302 M24308/24-303 M24308/24-304 M24308/24-305 M24308/24-307 1 2 3 4 5 1 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 number 2/ A-1-1 A-2-1 A-3-1 A-4-1 A-5-1 A-1-1 M24308/24-8 M24308/24-9 M24308/24-10 M24308/24-11 M24308/24-108 M24308/24-109 M24308/24-110 M24308/24-111 M24308/24-208 M24308/24-209 M24308/24-210 M24308/24-211 M24308/24-308 M24308/24-309 M24308/24-310 M24308/24-311 2 3 4 5 1 and 2 1 and 2 1 and 2 1 and 2 A-2-1 A-3-1 A-4-1 A-5-1 Size 20 Size 20 Size 20 Size 20 Straight Straight Straight Straight M24308/24-13 M24308/24-14 M24308/24-15 M24308/24-16 M24308/24-17 M24308/24-19 M24308/24-20 M24308/24-21 M24308/24-22 M24308/24-23 M24308/24-25 M24308/24-26 M24308/24-27 M24308/24-28 M24308/24-29 M24308/24-31 M24308/24-32 M24308/24-113 M24308/24-114 M24308/24-115 M24308/24-116 M24308/24-117 M24308/24-119 M24308/24-120 M24308/24-121 M24308/24-122 M24308/24-123 M24308/24-125 M24308/24-126 M24308/24-127 M24308/24-128 M24308/24-129 M24308/24-131 M24308/24-213 M24308/24-214 M24308/24-215 M24308/24-216 M24308/24-217 M24308/24-219 M24308/24-220 M24308/24-221 M24308/24-222 M24308/24-223 M24308/24-225 M24308/24-226 M24308/24-227 M24308/24-228 M24308/24-229 M24308/24-231 M24308/24-313 M24308/24-314 M24308/24-315 M24308/24-316 M24308/24-317 M24308/24-319 M24308/24-320 M24308/24-321 M24308/24-322 M24308/24-323 M24308/24-325 M24308/24-326 M24308/24-327 M24308/24-328 M24308/24-329 M24308/24-331 M24308/24-232 M24308/24-233 M24308/24-234 M24308/24-235 M24308/24-237 M24308/24-332 M24308/24-333 M24308/24-334 M24308/24-335 M24308/24-337 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 2 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 A-1-1 A-2-1 A-3-1 A-4-1 A-5-1 A-1-1 A-2-1 A-3-1 A-4-1 A-5-1 A-1-1 A-2-1 A-3-1 A-4-1 A-5-1 A-1-1 A-2-1 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Straight Straight Straight Straight Straight Straight Straight Straight Straight Straight Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle M24308/24-33 M24308/24-34 M24308/24-35 M24308/24-37 M24308/24-132 M24308/24-133 M24308/24-134 M24308/24-135 M24308/24-137 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 1 and 3 1 and 3 1 and 3 1 and 3 A-3-1 A-4-1 A-5-1 A-1-1 Size 20 Size 20 Size 20 Size 20 Rt Angle Rt Angle Rt Angle Rt Angle M24308/24-38 M24308/24-39 M24308/24-40 M24308/24-41 M24308/24-43 M24308/24-44 M24308/24-45 M24308/24-46 M24308/24-47 M24308/24-138 M24308/24-139 M24308/24-140 M24308/24-141 M24308/24-143 M24308/24-144 M24308/24-145 M24308/24-146 M24308/24-147 M24308/24-238 M24308/24-239 M24308/24-240 M24308/24-241 M24308/24-243 M24308/24-244 M24308/24-245 M24308/24-246 M24308/24-247 M24308/24-338 M24308/24-339 M24308/24-340 M24308/24-341 M24308/24-343 M24308/24-344 M24308/24-345 M24308/24-346 M24308/24-347 2 3 4 5 1 2 3 4 5 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 1 and 3 A-2-1 A-3-1 A-4-1 A-5-1 A-1-1 A-2-1 A-3-1 A-4-1 A-5-1 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Size 20 Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle Rt Angle See footnotes at end of table. 6 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 TABLE I. Design standards- Continued. 1/ PIN Class G PIN Class M PIN Class N PIN Class D Shell size Shell detail Insert arrangement Contact configurations reference Size 20 Rt Angle Mating end PWB tail M24308/24-49 M24308/24-149 M24308/24-249 M24308/24-349 1 1 and 3 number 2/ A-1-1 M24308/24-50 M24308/24-150 M24308/24-250 M24308/24-350 2 1 and 3 A-2-1 Size 20 Rt Angle M24308/24-51 M24308/24-151 M24308/24-251 M24308/24-351 3 1 and 3 A-3-1 Size 20 Rt Angle M24308/24-52 M24308/24-152 M24308/24-252 M24308/24-352 4 1 and 3 A-4-1 Size 20 Rt Angle M24308/24-53 M24308/24-153 M24308/24-253 M24308/24-353 5 1 and 3 A-5-1 Size 20 Rt Angle M24308/24-55 M24308/24-155 M24308/24-255 M24308/24-355 1 1 and 3 A-1-1 Size 20 Rt Angle M24308/24-56 M24308/24-156 M24308/24-256 M24308/24-356 2 1 and 3 A-2-1 Size 20 Rt Angle M24308/24-57 M24308/24-157 M24308/24-257 M24308/24-357 3 1 and 3 A-3-1 Size 20 Rt Angle M24308/24-58 M24308/24-158 M24308/24-258 M24308/24-358 4 1 and 3 A-4-1 Size 20 Rt Angle M24308/24-59 M24308/24-159 M24308/24-259 M24308/24-359 5 1 and 3 A-5-1 Size 20 Rt Angle M24308/24-61 M24308/24-161 M24308/24-261 M24308/24-361 1 1 and 2 A-1-2 Size 22 Straight M24308/24-62 M24308/24-162 M24308/24-262 M24308/24-362 2 1 and 2 A-2-2 Size 22 Straight M24308/24-63 M24308/24-163 M24308/24-263 M24308/24-363 3 1 and 2 A-3-2 Size 22 Straight M24308/24-64 M24308/24-164 M24308/24-264 M24308/24-364 4 1 and 2 A-4-2 Size 22 Straight M24308/24-65 M24308/24-165 M24308/24-265 M24308/24-365 5 1 and 2 A-5-2 Size 22 Straight M24308/24-67 M24308/24-167 M24308/24-267 M24308/24-367 1 1 and 2 A-1-2 Size 22 Straight M24308/24-68 M24308/24-168 M24308/24-268 M24308/24-368 2 1 and 2 A-2-2 Size 22 Straight M24308/24-69 M24308/24-169 M24308/24-269 M24308/24-369 3 1 and 2 A-3-2 Size 22 Straight M24308/24-70 M24308/24-170 M24308/24-270 M24308/24-370 4 1 and 2 A-4-2 Size 22 Straight M24308/24-71 M24308/24-171 M24308/24-271 M24308/24-371 5 1 and 2 A-5-2 Size 22 Straight M24308/24-73 M24308/24-173 M24308/24-273 M24308/24-373 1 1 and 4 A-1-2 Size 22 Rt Angle M24308/24-74 M24308/24-174 M24308/24-274 M24308/24-374 2 1 and 4 A-2-2 Size 22 Rt Angle M24308/24-75 M24308/24-175 M24308/24-275 M24308/24-375 3 1 and 4 A-3-2 Size 22 Rt Angle M24308/24-76 M24308/24-176 M24308/24-276 M24308/24-376 4 1 and 4 A-4-2 Size 22 Rt Angle M24308/24-77 M24308/24-177 M24308/24-277 M24308/24-377 5 1 and 4 A-5-2 Size 22 Rt Angle 1/ These connectors mate with connectors specified in MIL-DTL-24308/1, MIL-DTL-24308/2, MIL-DTL-24308/5, and MIL-DTL-24308/23. 2/ For insert arrangements see MIL-DTL-24308, Appendix A. NOTE: Qualification by similarity: Qualification of connectors of one shell size of one configuration with a specific printed wiring tail length and diameter shall qualify all connectors of the same shell size and configuration with all other printed wiring tail lengths and diameters. 7 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use. MIL-DTL-24308/24H w/AMENDMENT 5 PIN: Consists of the letter M, the basic number of the specifications sheet, and a dash number compiled from the code. PIN example: M24308/24 -50 F Specification sheet number Dash sheet number from table I Finish: For class G and N: A = Pure electrodeposited aluminum. F = Cadmium ((Navy-SH prohibits the use of cadmium finished connectors for shipboard application.) K = Zinc nickel P = Passivated stainless steel T = Nickel Fluorocarbon Polymer Z = Zinc For class M: Class M connectors have a gold finish, no suffix is required. For class D: Class D connectors have a nickel finish, no suffix is required. Amendment notations. The margins of this specification are marked with vertical lines to indicate modifications generated by this amendment. This was done as a convenience only and the Government assumes no liability whatsoever for any inaccuracies in these notations. Bidders and contractors are cautioned to evaluate the requirements of this document based on the entire content irrespective of the marginal notations. Referenced documents. In addition to MIL-DTL-24308, this document references the following: MIL-DTL-24308/1 MIL-DTL-24308/2 MIL-DTL-24308/5 MIL-DTL-24308/23 IPC-CC-830 CONCLUDING MATERIAL Custodians: Army - CR Navy - EC Air Force - 85 NASA - NA DLA - CC Preparing activity: DLA - CC (Project 5935-2018-086) Review activities: Army - AT, CR4, MI Navy - AS, CG, MC, SH Air Force - 99 NOTE: The activities listed above were interested in this document as of the date of this document. Since organizations and responsibilities can change, you should verify the currency of the information above using the ASSIST Online database at https://assist.dla.mil/. 8 Source: http://assist.dla.mil -- Downloaded: 2019-09-10T15:13Z Check the source to verify that this is the current version before use.
M24308/24-69Z 价格&库存
很抱歉,暂时无法提供与“M24308/24-69Z”相匹配的价格&库存,您可以联系我们找货
M24308/24-69Z
    • 1+1028.309761+132.01911
    • 10+877.8296010+112.69978
    • 25+765.7624525+98.31209
    库存:25
