HA1B-V2E2R
HA1B-V2E2R
    IDEC(日本和泉)
    HA1B-V2E2R
HA1B-V2E2R 数据手册
Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices L6 (Oversize) Series — Miniature Switches and Pilot Devices Key features: UL Recognized File No. E55996 Signaling Lights • 5/8” (16mm) mounting holes • Locking lever removable contact blocks • Solder terminal or PCB terminal options • Available assembled or as sub-components • Worldwide approvals • Incandescent or LED illumination • Snap action contacts CSA Certified File No. LR21451 Operating Temperature Operation: –25 to +55°C (without freezing), 45 to 85% RH Storage: -30 to +80°C (without freezing) Vibration Resistance 5 to 55Hz, 1.0 peak-peak amplitude max Shock Resistance Operating limit: 100 m/sec2 (approximately 10G) Damage limit: 1000 m/sec2 (approximately 100G) Mechanical Life Momentary pushbuttons 2,000,000 operations minimum All others: 250,000 operations minimum Degree of Protection IP65 (conforming to IEC 60529) Dielectric Strength Switch unit: between live and ground: 2500 volt AC, 1 minute between terminals of different poles: 2500 volt AC, 1 minute between terminals of same pole: 1000 volt AC, 1 minute Illumination unit: between live part and ground: 2500 volt AC, 1 minute Insulation Resistance 100MΩ minimum (using 500V DC megger) Rated Insulation Voltage 250V AC/DC Rated Thermal Current Gold Contacts (pcb): 3A Silver Contacts (solder): 5A Contact Resistance 50Ω maximum initial value Minimum Recommended Load (reference value for silver contacts) 5V AC/DC, 1mA Terminal Style 0.110” Solder Tab /PCB Contact Form Snap Action, Double Throw Contact Material Solder Tab: Pure Silver /PCB: Gold Plated Silver Electrical Life (at full load) Momentary pushbuttons: 100,000 operations minimum (1800 operations / hour) All others: 100,000 operations minimum (1200 operations / hour) Lamp Current Draw 5V DC LED: 8mA 6V AC/DC LED: 7mA 12V AC/DC LED: 8mA 24V AC/DC LED: 8mA 120V AC = 8mA Lamp Life Incandescent: 2000 hours./LED 50,000 hours. (on pure DC, half-life intensity) 800-262-IDEC (4332) • USA & Canada 6V AC/DC incandescent: 100 mA 12V AC/DC incandescent: 50 mA 24V AC/DC incandescent: 25 mA Circuit Breakers 1705151131 AC resistive AC inductive DC resistive DC inductive Gold Clad Contacts (PCB terminals) 30V 125V AC inductive 0.1A DC resistive 0.1A — Terminal Blocks Lamp Ratings Rated Operating Current Silver Contacts (Solder Terminals) 30V 125V 250V — 5A 2A — 2A 1.5A 3A 0.4A — 1A 0.2A — Contactors EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 N0.14 Timers Conforming to Standards Relays & Sockets Contact Ratings Registration No. R9551089 (E-stops) Registration No. J9551458 (all other switches) Registration No. R95650511 (Pilot Lights) 555 Switches & Pilot Devices Switches & Pilot Devices ø16mm - L6 Series Built-in LED Lamp Ratings Model LFTD-5k LFTD-1k Rated Voltage 5V DC 12V AC/DC 24V AC/DC 120V AC Operating Voltage 5V DC ±5% 12V AC/DC ±10% 24V AC/DC ±10% 120V AC ±5% AC — 9mA 9mA 8mA DC 8mA 8mA 8mA — Lamp Base Current Draw Signaling Lights Specify a color code in place of k in the Part No: A (amber), G (green), R (red), S (blue), W (white), Y (yellow) Lamp Base Color Same as illumination color Voltage Marking Stamped on the lamp base Life (reference value) Approx. 50,000 hours A, R, W, Y (+) (–) Relays & Sockets G, S Timers X2 (–) G, S X1 X1 X2 Non-Illuminated Pushbuttons (Assembled) Non-Illuminated Pushbuttons Style Operation Oversize Round Extended Momentary Maintained Oversize Square Flush Contactors A, R, W, Y X1 (+) X1 Internal Circuit Momentary Maintained Oversize Square Extended Momentary Maintained Terminal Blocks LFTD-H2k SX6S/8x5.4 Color Code k Mushroom Momentary Maintained Circuit Breakers LFTD-2k Contact X2 X2 Terminal Style Solder Tab PCB SPDT HA1B-M2C5-j HA1B-M2C1V-j DPDT HA1B-M2C6-j HA1B-M2C2V-j SPDT HA1B-A2C5-j HA1B-A2C1V-j DPDT HA1B-A2C6-j HA1B-A2C2V-j SPDT HA2B-M1C5-j HA2B-M1C1V-j DPDT HA2B-M1C6-j HA2B-M1C2V-j SPDT HA2B-A1C5-j HA2B-A1C1V-j DPDT HA2B-A1C6-j HA2B-A1C2V-j SPDT HA2B-M2C5-j HA2B-M2C1V-j DPDT HA2B-M2C6-j HA2B-M2C2V-j SPDT HA2B-A2C5-j HA2B-A2C1V-j DPDT HA2B-A2C6-j HA2B-A2C2V-j SPDT HA1B-M3C5-j HA1B-M3C1V-j DPDT HA1B-M3C6-j HA1B-M3C2V-j SPDT HA1B-A3C5-j HA1B-A3C1V-j DPDT HA1B-A3C6-j HA1B-A3C2V-j jButton Color Codes Color Code Color Code Black B Blue S Green G White W Red R Yellow Y 1. In place of j specify Button Color Code from table. 2. Illuminated (translucent) style lenses also available, specify as such: instead of LA1B-M1C5-j use LA1B-M1C5L-k in place of k (specify Lens Color Code from next page.) 3. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1B-M1C1V-j becomes LA1B-M1C5V-j). 556 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Non-Illuminated Pushbuttons (Sub-Assembled) Safety Lever Lock Style Operator + Button Buttons/Lenses Momentary Maintained Oversize Round Style = Contacts Button Terminal Style Lens Style Oversize Round Flush HA1B-MO HA1B-AO HA2B-MO HA2B-AO HA1A-B1-j HA1A-L1-k* Oversize Round Extended HA1A-B2-j Contacts Solder Tab PCB SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V – Relays & Sockets Oversize Square Complete Part Signaling Lights Operators + Gold + Silver Contact Safety Lever Lock Mushroom HA1B-MOL HA1B-A0L Style Oversize Square Flush 1. In place of j specify Button Color Code from table on right. 2. In place of k specify Lens Color Code from table on right. 3. *requires HA1L-M0 or HA1L-A0 operator instead of HA1B-M0 or HA1B-A0. 4. **requires HA2L-M0 or HA2L-A0 instead of HA2B-M0 or HA2B-A0. HA9Z-LS HA2A-L1-k** Timers HA2A-B1-j Part Number j Button Color Code Oversize Square Extended HA2A-B2-j – HA1A-B3-j HA1A-L3-k Code Black B Green G Red R Blue S White W Yellow Y Contactors Mushroom Color k Lens Color Code Code Amber A Green G Red R Blue S Yellow Y White W Terminal Blocks Color Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 557 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - L6 Series HA1B/HA1E Stop Switch Key features: • PCB or Solder Terminals • Locking Lever Removable Contact Blocks • Positive Action Contacts • 1 or 2 form B (SPST-NC) Contacts • IP65 Protection • 16mm Mounting Hole • Tamper Proof Construction CSA File No. LR21451 File No. DK95-00138 Direct Opening Action UL Recognized File No. E55996 Timers Nameplates Contact Form 1 or 2 form B (SPST-NC) Termination PCB or Solder Terminal Contact Material Silver Applicable Standards EN60947-5-1, UL508, CSA 22.2. No. 14 Rated Insulation Voltage 250V AC/DC Degree of Protection IP65 Conditional Short-Circuit Current and Short-Circuit Protective Device 50 A (at 250V) 10A 250V Fuse, operation class M according to IEC269-1 and IEC269-2 Positive Opening Operation Positive opening travel 3.4mm Minimum force required to achieve positive opening operation of all break contacts. 10.3 N (2 form B contacts) Maximum travel including travel beyond the minimum travel position 5.5mm Maximum frequency of actuation 1,200 operations/hour Pollution Degree HAAV–Yellow Plastic ø43mm Relays & Sockets Specifications Part Number Blank HAAV-0 3 Positive Action Stop Switch Style Contactors Marking Accessories: Shroud Operation Stop Switch Pushlock/ Turn Reset Terminal Style Contact DPST(NC) (2 form B) Short Body SPST-NC (1 form B) DPST-NC (2 form B) Solder Tab PCB HA1B-V2E2R HA1BV2E2VR HA1E-V2S1R HA1E-V2S2R — Style Part Number Applicable Standards XA9Z-KG1 SEMI S2 Compliant (Approved by TUV) Buzzers (IP40) Buzzer Ratings Terminal Style Style Buzzer-Rectangular Circuit Breakers Terminal Blocks 1. Button is non-removable, available in red and as complete assembled unit only. 2. Stop Switch does not come with safety lever lock. 558 Operating Voltage 6V AC/DC ± 10% 12V to 24 AC/DC ± 10% Solder/ Tab LA3Z-1X2 LA3Z-1X4 PCB LA3Z-1X2V LA3Z-1X4V www.IDEC.com Frequency 2 khz ± 500 HZ Amplitude 80db @ 0.1m (at rated voltage) Operating Voltage 6V AC/DC or 12 - 24V AC/DC ± 10% Adjustable Cycle 55 to 600 cycles per minute Current Draw DC: 7mA AC: 20mA Life 1000 hrs. minimum Insulation Voltage 60V AC/DC Operating Temperature -20 to 55ºC (no freezing), 45 to 85% RH Degree of Protection IP40 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Pilot Lights (Assembled) Pilot Lights kLens/LED Color Codes Style Terminal Style Solder Tab PCB Oversize Round HA1P-1C0l-k HA1P-1C0lV-k Color Code Amber A Green G Red R S W Yellow Y Signaling Lights Blue White lVoltage/Lamp Code Oversize Square Voltage HA2P-1C0l-k HA2P-1C0lV-k HA1P-1l-k — HA2P-1l-k — 5V DC LED 1 6V AC/DC LED 2 12V AC/DC LED 3 24V AC/DC LED 4 120V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 Relays & Sockets Oversize Round Unibody Code Oversize Square Unibody Timers 1. In place of k specify Lens/LED Color Code from table. 2. In place of l specify Voltage Code from table. Contactors Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 559 Switches & Pilot Devices Switches & Pilot Devices ø16mm - L6 Series Pilot Lights (Sub-Assembled) Terminals + Safety Lever Lock Signaling Lights Operators + Lamp Holder + + Operator Lenses Style = Part Number Style HA1A-P1-k HA1P-0 Relays & Sockets Lens Completed Unit Solder Tab PCB HA-C00 HA-C00V Oversize Round Oversize Round Not required for unibody operators. Oversize Square Lamp Holder HA2A-P1-k HA2P-0 Style Part Number HA9Z-AH In place of k specify lens color code. Oversize Round Unibody HA1P-00 Safety Lever Lock Lamps Style LED Oversize Square Unibody HA2P-00 Voltage Part Number 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120 V AC LFTD-5k LFTD-6k LFTD-1k LFTD-2k LFTD-H2k 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 Incandescent Contactors + Terminals Style Part Number Oversize Square Timers Lamp Part Number HA9Z-LS k Lens/LED Color Codes Color Code Amber A Green G Red R Blue S Yellow Y White W Circuit Breakers Terminal Blocks In place of k specify LED color code from table below. Style 560 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Illuminated Pushbuttons (Assembled) Illuminated Pushbuttons Style kLens Color Codes Operation Contact Momentary SPDT DPDT Oversize Round Terminal Style Solder Tab PCB HA1L-M1C5l-k HA1L-M1C6l-k HA1L-M1C1lV-k HA1L-M1C2lV-k SPDT DPDT HA1L-A1C5l-k HA1L-A1C6l-k HA1L-A1C1lV-k HA1L-A1C2lV-k Momentary SPDT DPDT HA2L-M1C5l-k HA2L-M1C6l-k HA2L-M1C1lV-k HA2L-M1C2lV-k Oversize Square Maintained Momentary Maintained SPDT DPDT SPDT DPDT HA2L-A1C5l-k HA2L-A1C6l-k HA1L-M3C5l-k HA1L-M3C6l-k HA1L-A3C5l-k HA1L-A3C6l-k HA2L-A1C1lV-k HA2L-A1C2lV-k HA1L-M3C1lV-k HA1L-M3C2lV-k HA1L-A3C1lV-k HA1L-A3C2lV-k A Green G Red R Blue S Yellow Y White W lVoltage/Lamp Code Voltage Code 5V DC LED 1 6V AC/DC LED 2 12V AC/DC LED 3 24V AC/DC LED 4 120 V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 Relays & Sockets Mushroom SPDT DPDT Code Signaling Lights Maintained Color Amber Timers 1. In place of k specify Lens Color Code from table. 2. In place of l specify Voltage Code from table. 3. PCB terminal models also available with silver contacts change “1” or “2” to “5” or “6” respectively, (ie LA1LM1C14V-j becomes LA1L-M1C54V-j). 4. Light independent of switch position. Contactors Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 561 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - L6 Series Illuminated Pushbuttons (Sub-Assembled) Terminals + Safety Lever Lock + Operators Lamp Holder + Lamp + Lenses Style Momentary Maintained HA1L-MO + Lens = Completed Unit Lamps Style Part Number Oversize Round Oversize Round Operator HA1L-A0 Style LED HA1A-L1-k Voltage Part Number 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120 V AC LFTD-5k LFTD-6k LFTD-1k LFTD-2k LFTD-H2k 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 Oversize Square HA2L-MO HA2L-AO HA2A-L1-k Contacts Terminal Style Mushroom HA1B-MOL Style Timers Contactors k Lens/LED Color Codes Code Amber A Green G Red R Blue S Yellow Y White W Solder Tab PCB SPDT DPDT HA-C10 HA-C20 HA-C10V HA-C20V SPDT DPDT HA-C50 HA-C60 HA-C50V HA-C60V HA1B-AOL HA1A-L3-k Color Contacts Gold Mushroom Silver Relays & Sockets Incandescent Oversize Square In place of k specify lens color code. Lamp Holder Style Part Number HA9Z-AH Safety Lever Lock Terminal Blocks Style Part Number Circuit Breakers HA9Z-LS 562 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Selector Switches (Assembled) Selector Switches Contact Operations Oversize Round Position 90˚ 2 -Position Style Maintained Spring return from right 45˚ 3-Position Terminal Style Solder Tab PCB L R DPDT HA1S-2C6 HA1S-2C2V L R DPDT HA1S-21C6 HA1S-21C2V L Spring return from right L Spring return from left L 2-Way spring return L C C C C DPDT HA1S-3C6 HA1S-3C2V DPDT HA1S-31C6 HA1S-31C2V R DPDT HA1S-32C6 HA1S-32C2V R DPDT HA1S-33C6 HA1S-33C2V R R (for all selectors) Operator Position and Contact Operation Contacts Left 2-pos. (DPDT) Left Right Contact Contact NO NC NO NC C Right C Left Right Contact Contact NO NC NO NC C C Left Right Contact Contact NO NC NO NC Left C C 3-pos. (DPDT) Left Right Contact Contact NO NC NO NC Center C Right Relays & Sockets 1. All assembled selector switches use DPDT contacts. 2. For SPDT contacts see sub-components on next page. 3. PCB terminal models also available with silver contacts change “1” or “2” to “5” or “6” respectively, (ie LA1S-21C2V becomes LA1S-21C6V). Signaling Lights Maintained Contact C Left Right Contact Contact NO NC NO NC C As viewed from front of switch. C Timers Contactors Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 563 Switches & Pilot Devices Selector Switches (Sub-Assembled) Contact + Safety Lever Lock + Operator Operators Complete Part Contacts Function Terminal Style Part Number 2 Maintained Spring from right HA1S-2Y HA1S-21Y 3 Maintained Spring from right Spring from left Spring from both HA1S-3Y HA1S-31Y HA1S-32Y HA1S-33Y Safety Lever Lock Part Number HA9Z-LS Contacts Solder Tab PCB Gold Position SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V Silver Style Oversize Round Style = Style SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V 1. All assembled switches listed on previous page use DPDT contacts. 2. SPDT Contacts for use on 2 position selector switch only Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - L6 Series 564 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Key Switches (Assembled) Key Switches Position 90˚ 2 -Position Style L Spring return from right L Maintained L Spring return from right L Spring return from left L 2-Way spring return L PCB DPDT HA1K-2C6l HA1K-2C2Vl DPDT HA1K-21C6B HA1K-21C2VB R DPDT HA1K-3C6l HA1K-3C2Vl R DPDT HA1K-31C6l HA1K-31C2Vl R DPDT HA1K-32C6l HA1K-32C2Vl R DPDT HA1K-33C6D HA1K-33C2VD R C C C C C Terminal Style Solder Tab R Signaling Lights 45˚ 3-Position Oversize Round Maintained Contact Relays & Sockets 1. In place of l specify Key Retention Code from next page. 2. All assembled key switches have DPDT contacts. For SPDT see sub-assembled on next page. 3. PCB terminal models also available with silver contacts change “1” or “2” to “5” or “6” respectively, (ie LA1K-2C2Vl becomes LA1K-2C6Vl). Contact Operations l Key Retention Option Codes (for all selectors) Operator Position and Contact Operation Contacts 2-pos. (DPDT) C Right C Left Right Contact Contact NO NC NO NC C C C 3-pos. (DPDT) Center Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) Key cannot be removed from a spring-return position. Left Right Contact Contact NO NC NO NC C C Left Right Contact Contact NO NC NO NC C Terminal Blocks Right A Contactors Left C Left Right Contact Contact NO NC NO NC Description Timers Left Left Right Contact Contact NO NC NO NC Code C As viewed from front of switch. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 565 Switches & Pilot Devices Selector Switches (Sub-Assembled) Contact + Safety Lever Lock + Operator Operators = Complete Part Contacts 2 3 Function Maintained Spring from right Maintained Spring from right Spring from left Spring from both Terminal Style Part Number Style HA1K-2l HA1K-21B HA1K-3l HA1K-31l HA1K-32l HA1K-33D Contacts Solder Tab PCB Gold Position SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V Silver Style Oversize Round Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - L6 Series SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V 1. All assembled switches listed on previous page use DPDT contacts. 2. SPDT Contacts for use on 2 position selector switch only 1. In place of l specify key removable code from table on right. 2. Operator includes two keys. Timers Safety Lever Lock Style Part Number HA9Z-LS l Key Retention Option Codes Terminal Blocks Contactors Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) Circuit Breakers Key cannot be removed from a spring-return position. 566 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Illuminated Selector Switches (Assembled) Illuminated Selector Switches 90˚ 2 -Position 45˚ 3-Position 90˚ 2 -Position 45˚ 3-Position 90˚ 2 -Position LA1F-2C2lV-k L R DPDT LA1F-21C6l-k LA1F-21C2lV-k L Spring return from left L 2-Way spring return L L Maintained L Spring return from right L Spring return from left L 2-Way spring return L L L Spring return from right L Maintained Spring return from right C C L L C C C C C C C C C C L Spring return from right L Spring return from left L 2-Way spring return L C C C C LA1F-3C6l-k LA1F-3C2lV-k DPDT LA1F-31C6l-k LA1F-31C2lV-k C 2-pos. (DPDT) R DPDT LA1F-32C6l-k LA1F-32C2lV-k R DPDT LA1F-33C6l-k LA1F-33C2lV-k Left Right Contact Contact NO NC NO NC C LA2F-2C6l-k LA2F-2C2lV-k DPDT LA2F-21C6l-k LA2F-21C2lV-k R DPDT LA2F-3C6l-k LA2F-3C2lV-k R DPDT LA2F-31C6l-k LA2F-31C2lV-k R DPDT LA2F-32C6l-k LA2F-32C2lV-k R DPDT LA2F-33C6l-k LA2F-33C2lV-k R R R 3-pos. (DPDT) Center C C Left Right Contact Contact NO NC NO NC Right C C As viewed from front of switch. DPDT LA3F-2C6l-k LA3F-2C2lV-k DPDT LA3F-21C6l-k LA3F-21C2lV-k DPDT LA3F-3C6l-k LA3F-3C2lV-k DPDT LA3F-31C6l-k LA3F-31C2lV-k R DPDT LA3F-32C6l-k LA3F-32C2lV-k R DPDT LA3F-33C6l-k LA3F-33C2lV-k R DPDT HA1F-2C6l-k HA1F-2C2lV-k R C C Left Right Contact Contact NO NC NO NC k Lens/LED Color Codes Color Code Color Code Amber Green A Blue S G Yellow Y Red R White W l Voltage/Lamp Code Voltage R C Left Right Contact Contact NO NC NO NC Left DPDT C DPDT HA1F-21C6l-k HA1F-21C2lV-k R DPDT HA1F-3C6l-k HA1F-3C2lV-k R DPDT HA1F-31C6l-k HA1F-31C2lV-k R DPDT HA1F-32C6l-k HA1F-32C2lV-k R DPDT HA1F-33C6l-k HA1F-33C2lV-k 800-262-IDEC (4332) • USA & Canada Code 5V DC LED 1 6V AC/DC LED 2 12V AC/DC LED 3 24V AC/DC LED 4 120V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 1. In place of k specify Lens/LED Color Code from table above. 2. In place of l specify Voltage Code from table above. 3. All switches listed have DPDT contacts. For SPDT see sub-assembled on next page. 4. PCB terminal models also available with silver contacts change “1” or “2” to “5” or “6” respectively, (ie LA1F-2C24V-k becomes LA1F-2C64V-k). 5. Light independent of switch position. 567 Circuit Breakers Maintained C DPDT Left Right R R L L R R L Maintained Spring return from left C L Spring return from right Spring return from right C Left Right Contact Contact NO NC NO NC Terminal Blocks 45˚ 3-Position LA1F-2C6l-k Operator Position and Contact Operation Contacts Contactors 1705151131 DPDT Spring return from right 2-Way spring return Oversize Round R L Maintained PCB L Maintained Maintained Solder Tab (for all selectors) Timers Rectangular Spring return from right Terminal Style Relays & Sockets Square Maintained Contact Signaling Lights 45˚ 3-Position Round Position 90˚ 2 -Position Style Contact Operations Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - L6 Series Illuminated Selector Switches (Sub-Assembled) Contacts + Safety Lever Lock + Lamp Holder + Lamp + Operators Operator + Lens/Handle = Completed Unit Safety Lever Lock Style Position 2 3 Maintained Spring from right Spring from left Spring from both LA1F-30 LA1F-310 LA1F-320 LA1F-330 2 Maintained Spring from right LA2F-20 LA2F-210 3 Maintained Spring from right Spring from left Spring from both LA2F-30 LA2F-310 LA2F-320 LA2F-330 2 Maintained Spring from right LA3F-20 LA3F-210 3 Maintained Spring from right Spring from left Spring from both LA3F-30 LA3F-310 LA3F-320 LA3F-330 2 Maintained Spring from right HA1F-20 HA1F-210 3 Maintained Spring from right Spring from left Spring from both HA1F-30 HA1F-310 HA1F-320 HA1F-330 Square Rectangular Timers Part Number LA1F-20 LA1F-210 Round Oversize Round Function Maintained Spring from right Style Part Number HA9Z-LS Lamp Holder Style Part Number HA9Z-AH Lamps Style LED Voltage Part Number 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120V AC LFTD-5k LFTD-6k LFTD-1k LFTD-2k LFTD-H2k 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 Incandescent Lenses/Handles Contacts Style Terminal Style Style Contacts Terminal Blocks Gold Contactors In place of k specify LED color code from table below. SPDT DPDT Solder Tab HA-C10 HA-C20 PCB Part Number Standard LA1A-F-k HA-C10V HA-C20V Silver Oversize HA-C50 HA-C60 HA-C50V HA-C60V All assembled selectors on previous pages use DPDT contacts. SPDT contacts are for use only on two position selectors. HA1A-F-k Color Code Amber A Green G Red R Blue S Yellow Y White W In place of k specify lens color code from table. Circuit Breakers SPDT DPDT k Lens/LED Color Codes 568 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Pushbutton Selectors (Assembled) Pushbutton Selectors j Button Color Codes Terminal Style Style 2 Position 3 Position Color Code Color Code Solder Tab PCB Amber A Blue S HA1R-2C6-j HA1R-2C2V-j Green G Yellow Y Red R White W HA1R-3C6-j HA1R-3C2V-j Contact Operation Contacts Operator Position and Contact Information Down Contact Operation Left Pushed Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC C C Left Right Contact Contact NO NC NO NC 3 Position Center Normal C C C C Left Right Contact Contact NO NC NO NC C C Normal — Right Pushed — Normal Pushed Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC C 2-pos. (DPDT) Spring Return from Bottom Blocked C C Left Right Contact Contact NO NC NO NC C C 3-pos. (DPDT) Left Right Contact Contact NO NC NO NC All models C C C C Left Right Contact Contact NO NC NO NC C C C Left Right Left Right Left Right Contact Contact Contact Contact Contact Contact NO NC NO NC NO NC NO NC NO NC NO NC C C C C C Left Right Contact Contact NO NC NO NC C C Left Right Contact Contact NO NC NO NC Maintained Spring from Top Up Left Right Contact Contact NO NC NO NC C C C C Relays & Sockets 2 Position 2-pos. (DPDT) Operator Position Style Center Left Right Contact Contact NO NC NO NC Signaling Lights 1. In place of j specify Button Color Code. 2. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie HA1R-2C2V-j becomes HA1R-2C6V-j). 3. Pushed position, momentary only. C As viewed from front of switch. Lever Switches Operation Contacts Terminal Type Solder Tab PCB DPDT LA1T-2C6 LA1T-2C2V DPDT LA1T-21C6 LA1T-21C2V DPDT LA1T-22C6 LA1T-22C2V DPDT LA1T-3C6 LA1T-3C2V DPDT LA1T-31C6 LA1T-31C2V DPDT LA1T-32C6 LA1T-32C2V DPDT LA1T-33C6 LA1T-33C2V Timers Style U Maintained 2 -Position D U Spring return from top D Contactors U Spring return from bottom D U Maintained C D C D Terminal Blocks 3-Position U Spring return from top U Spring return from bottom C D U Spring return from both C D 1705151131 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1T-2C2V becomes LA1T-2C6V). 2. Terminology: U = up, D = down, C = center. 569 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - L6 Series Switch Engraving Order Form – L6 Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Please check one of the boxes below to indicate your choice of engraving options: Relays & Sockets Rectangular Switch Round Switch Square Switch # of Lines Letter Height Max. Characters Per Line # of Lines Letter Height Max. Characters Per Line 1 5/32 6 1 5/32 5 # of Lines Letter Height Max. Characters Per Line 5/32 3 1/8 3 1 5/32 6 2 Timers 3 5/32 5 1/8 6 2 Custom* 1/8 6 3 Custom* 4 N/A 2 1/8 6 1/8 6 4 N/A 3 4 N/A *Engraving is possible, but character size will be smaller than standard sizes. Contactors 1. 2. 3. 4. Above mentioned specifications hold true for standard size pushbuttons (round, square and rectangular). Oversize pushbuttons and pilot lights allow you to engrave 1 additional character. Engraving is done on the button itself for non-iIlluminated push buttons and on marking plate for illuminated pushbuttons and pilot lights. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Enter text to be engraved: Sample Letter Sizes 1/8 Letters: Line 1: 5/32 Letters: Terminal Blocks Line 2: Line 3: Line 4: Circuit Breakers For IDEC Internal Use Only: Work Order #: 570 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Accessories Item Specifications Appearance Part Number Notes Made of metal MT-001 Used for tightening the plastic locking ring when installing the L6 series unit on a panel. Tightening torque should not exceed 9kgf cm when tightening the locking ring. Lamp Holder Tool (Made of Rubber) Made of rubber. Used for removing and replacing LED and incandescent lamps in illuminated units. OR-44 Rubber tool used for replacing LED and incandescent lamps. Lens Removal Tool For Illuminated pushbuttons and pilot lights. MT-101 Used for removing the lens or button from the housing. LED Lamp 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120V AC Incandescent Lamp 6V AC/DC 12V AC/DC 24V AC/DC Switch Guard 180 degrees opening, spring return Terminal Cover Made of white nylon LFTD-5k LFTD-6k LFTD-1k LFTD-2k LFTD-H2k HA9Z-K1 Prevents inadvertent switch operation. IP65 oiltight rated. All removable contacts H6-VL2 Covers terminals to prevent possible electric shock. Unibody Pilot Lights H6-PVL Oversize Round/Sq Fills unused panel cutouts. Made of nitrile rubber. Pushin installation from front of panel. IP65 (oiltight) rated. Aluminum AL-BM6 Fills unused panel cutouts. Made of aluminum. Screwon locking ring from inside of panel. IP65 (oiltight) rated. for HA1K (#231) – oversize KG9Z-SK Pair of keys. Mounting Hole Plug HA9Z-P1-W HA9Z-P2-W HA9Z-P13-W HA9Z-LN L6 oversize Replacement Selector Inserts HA9Z-LP HA9Z-HC1-j Replacement Safety Lever Lock Prevents rotation of switches in panel. (included with all assembled switches) Applicable to round oversize selectors only j = (G, R, S, W, Y) Terminal Blocks Replacement Anti-Rotation Ring All models Contactors Oversize Round Oversize Square Mushroom Replacement Engraving Inserts Replacement Locking Ring Timers AL-B6 Rubber Replacement Keys 0.5W, T 1-3/4 miniature flange base Relays & Sockets LH-06 LH-14 LH-28 T 1-3/4 miniature flange base. In place of j specify LED Color Code (A, G, R, S, W, Y). Signaling Lights Ring Wrench HA9Z-LS Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 571 Switches & Pilot Devices Switches & Pilot Devices ø16mm - L6 Series Item Appearance Description Used With Part Number ø24mm round, metal (aluminum color), panel cut-out ø20.2mm Illuminated selector switches. LA9Z-SM61 ø24mm round, plastic (black), panel cut-out ø20.2mm + Signaling Lights Flush Bezel Relays & Sockets LA9Z-S61B L6 Switch LA9Z-S71B 024mm square, plastic (black), panel cut-out 020.2mm Flush Bezel = 24 x 30mm rectangular, plastic (black), panel cut-out ø20.2 x 26.2mm Switch Guard w/ Flush Bezel (spring return) LA9Z-S81B Flush Switch Rectangular, plastic (black) LA9Z-KS8 Flush bezels not applicable for oversize units. Lever Switches (LA1T) Buzzer (LA3Z) Dimensions (mm) PC Board Terminal 0.8W×0.5t 2-R0.6 Tab Terminal 2.8W×0.5t Panel Thickness 0.5 to 6 K C LO R15.5 24 2 6 17.8 5.5 1.2 2.7 18 X1 6 ø21 Timers X2 15.8 ø18 10.8 1 2.6 10.5 9 36 24 13.5 9 Emergency Stop Switch (HA1B) Rubber Washer " .61 RO m) .5m (15 LOCK Panel Thickness 0.02"-0.24" (0.5~6.0mm) Stopper Locking Ring 8" 0.9 m) Ø .9m 4 (2 PCB Terminal 0.34" Contactors + (8.7mm) NC NC - 0.21" (5.4mm) ø0.70" ø0.83" (17.8mm) (21mm) 0.62" (15.8mm) 0.20" 0.41" (5.2mm) (10.5mm) 1.42" (36mm) 0.53" (13.5mm) 0.43" (11mm) 0.98" (25mm) Circuit Breakers Terminal Blocks Emergency Stop Switch (HA1E) - Short Body Style 572 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices Illuminated Selector Switches (LA*F) Panel Thickness 0.5 to 6 6.4 Gasket Locking Ring LOCK 6.8 1.45 T OP Anti-rotation Ring Round Square Rectangular ø1 8 Tab Terminal Width 2.8×0.5t PC Board Terminal Width 0.8×0.5t 6 17.8 1.2 5 NO C 5 18 6 NC X1 X2 NO X2 C ø21 15.8 NC 1 Signaling Lights 1 K C LO R15.5 0.6 2 2.6 1 10.5 9 5.5 13.5 9 PC Board Terminal 24 18 36 17 Solder/Tab Terminal PC Board Drilling Layout (Bottom View) ø16.2 Illuminated Pushbuttons, Illuminated Selector Switches 6.4 +0.2 0 Pilot Lights, Selector Switches, Key Selector Switches 6.8 Relays & Sockets Panel Cut-Out Pushbutton Lever Switches 6.8 7.85 1.45 .2 le Ho .2 Ho ø1 le le Ho ø1 24 .2 ø1 5 5 5 24 5 5 5 1 1 1 1.45 HA1B E-Stop Timers PCB Mounting Pattern 0.21" (5.3mm) 0.21" (5.3mm) 0.34" (8.7mm) Ø (1. 0.0 2m 5" m) 0.21" (5.4mm) Contactors NO C NC NO C NC X2 X2 Terminal Blocks X1 Oversize Flush Pushbutton and Pilot Lights 1.02 [25.9] 0.43 [11.0] 0.94 [24.0] Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 573 Switches & Pilot Devices NO C NC NO NC Oversize Extended Non-Illuminated Pushbutton C Switches & Pilot Devices ø16mm - L6 Series Oversize Unibody Pilot Lights 1.48 [37.5] NO NO C Timers C NC Mushroom Pushbuttons NC Relays & Sockets Signaling Lights 0.59 [15.1] 1.18 [30.0] 0.79 [20.0] NO C NC NO C Contactors NC Oversize Selector Switch 0.94 [23.8] Circuit Breakers Terminal Blocks 0.77 [19.5] 574 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices NO C NC NO C NC Oversize Key Switch Signaling Lights 1.54 [39.0] NO C NC NO C NC Lever Switch Relays & Sockets 0.94 [23.8] Selector Switches Flush Bezel 14.8 8 2 ø2 4 4 ø2 8.5 18 24 18 20 Contactors 21.4 Rectangular 17 24 2 20 21.4 8.5 2 10 Timers Square ø1 Lever 2 8 ø1 0.9 0.8 9.8 Illuminated Plastic Metal ø 20 22.6 Round Flush Bezel Gasket ø21.4 Mounting Bracket 26 27.4 23 24 30 9.3 2 Square Rectangular 26.2 +0.2 – 0.1 20.2 +0.2 – 0.1 24 min.∗ Circuit Breakers 24 min.∗ 1705151131 24 min.∗ 24 min.∗ 24 min.∗ +0.2 20.2 -0.1 ø2 0. 2 + – 0 0.2 .1 Round Terminal Blocks Flush Bezel Mounting Hole Layout 30 min.∗ 800-262-IDEC (4332) • USA & Canada 575 Switches & Pilot Devices Terminal Configurations X1 X2 X1 Steady Slow Quick Input Terminal (X1) Buzzer Sound Switch C C Input Terminal (X2) X2 NC NO NC X1 X2 Lamp Terminal (−) C H6-VL2 NO X2 Lamp Terminal (+) X2 Lamp Terminal (−) Buzzer TOP X2 X1 NC Lamp Terminal (+) NO NC NO Illuminated Pushbuttons TOP TOP AL-B6 47 2 AL-BM6 4 ø18 6 ø16.5 TOP 15 21 LFTD 2.5 LED Lamp Internal Circuit 12 ø17.8 Relays & Sockets Pilot Lights 17.6 Signaling Lights AL-K6SP Non Illuminated Pushbutton C Switches & Pilot Devices ø16mm - L6 Series Gasket Locking Ring Timers Panel Thickness 0.5 to 6 LED Chip Protective Diode Zener Diode AL-B6 ø18 ø16.5 6 Circuit Breakers Terminal Blocks Contactors 2 576 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - L6 Series Switches & Pilot Devices General Instructions Pushbutton Assembly Lamp Installation Lamps can be replaced in two ways: 1. If contacts are accessible (or pushbutton not installed in a panel) then it is easiest to first remove the contacts from the operator. This will allow easy access to the lamp/lamp-holder assembly. Grab lamp, depress slightly, and turn counter clockwise. Lamp can then be removed by pushing it back through the lamp holder. Signaling Lights 2. If contacts are not accessible, then the lamp can be replaced by first removing the lens from the operator. Just pull lens straight out either with a fingernail or optional lens removal tool (MT-101). Lamp/lamp-holder assembly can then be removed with lamp removal tool (OR-44). Insert lamp removal tool through operator, depress slightly, turn counter clockwise, then pull lamp/lamp-holder assembly out. Lamp can then be removed by pushing it back through the lamp holder. All buttons and lenses can be engraved directly on the outside surface. Illuminated lenses also allow for engraving on a plate that is underneath the colored section of the lens. Remove the colored section of the lens by pulling on the edge while simultaneously unhooking it from the latches on the lens holder. The marking plate will then be accessible. It can then be engraved or a thin marked insert (such as mylar or paper) can be sandwiched between the marking plate and colored section of the lens. Relays & Sockets Engraving Lenses Fitting Grooves Grooves Engraving Surface Color Lens Marking Plate Lens Holder Timers Panel Mounting Before any unit can be mounted into a panel, the contact block must be removed. Slide metal locking lever and pull contact off. Loosen and remove the locking ring and square anti-rotation ring from the operator and insert operator through panel cutout from the front of the panel. Slide on anti-rotation ring and tighten locking ring, using locking ring wrench (MT-001). Slide contact block onto operator, observing TOP marking on both parts. Slide metal locking lever in direction indicated by LOCK. The yellow plastic safety lever lock can then be snapped onto the locking lever; this will prevent vibration or maintenance actions from releasing the contact from the operator. PCB Mounting Contactors Being able to separate the contacts from the operator allows for assembly of the front panel components (operator and lens) to be performed in tandem with the PC board assembly and soldering. For applications where multiple rows of pushbuttons are mounted closely together, or where other components may obstruct access to the contact locking lever, be sure to include access holes in the PC board (refer to PC board layout dimensions for location). Also be sure to allow for space above and to the side of contact to ensure that no components block the contact block locking lever. PC board pins are designed to rest on the PCB, take this into consideration to ensure that pins do not short closely spaced traces. Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 577
HA1B-V2E2R 价格&库存
很抱歉,暂时无法提供与“HA1B-V2E2R”相匹配的价格&库存,您可以联系我们找货
