KRE2ANA1BBD
KRE2ANA1BBD
    ZF
    KRE2ANA1BBD
KRE2ANA1BBD 数据手册
Sealed Rocker Switch Single Pole KR Series Features • • • Snap-in mounting RoHS compliant 100,000 cycles mechanical life • • IP65 Lighted and non-lighted versions available 1 Standard Parts North America KRE2ALA2GBB KRE2ALA2RBB North America and Europe KRE2ANA1BBD KRE2BNA1BBB KRE2DNA1BBB Europe KRE2AEA2GBB KRE2AEA2RBB 1 The part number configuration matrix below provides details to the part numbers above. For configurable part numbers that are not listed above, not listed in your region, or for custom part numbers, contact the factory or your distributor. KRE2ALA 2RBB Part Number Breakdown KR E 2 A L A Series Contact Rating2 KR E Circuitry 2 Single pole Switch Function A 3 B D Lighting Options ON-OFF N Non-lighted ON-ON (ON)-OFF E L C M 220 VAC neon 110 VAC neon 28 VDC LED 14 VDC LED Terminal Type 4.8 mm (0.189”) quick A connect 2 See Electrical Specifications section Available only with non-lighted version 3 2RBB Actuator Type 1 Non-lighted 2 Lighted Actuator Color4 A Amber B Black G Green R Red Housing Color B Black Actuator Marking B Blank D O –– 4 Black actuator is only available for non-lighted; others only for lighted. www.switches-sensors.zf.com ZF Electronics Systems Pleasant Prairie, LLC (“ZF”) acquired the rights to the CHERRY branded switches and sensors in 2008. Although ZF divested its interest in the CHERRY name in 2015, the switches and sensors remain unchanged and are now sold under the ZF brand. Page 1 of 2, Last update 2017-11-02, Specifications subject to change without notice. Electrical Specifications Dielectric Strength Insulation Resistance Initial Contact Resistance Electrical Ratings – UL1054 1500 VAC for 1 minute 100 MΩ min at 500 VDC 0.050 Ω max VAC 16 A 125 VAC 1/3 HP / 10 A 250 VAC 1/2 HP Electrical Life at Rated Load Minimum Operations VDC 16 A 12 VDC / 6 A 28 VDC UL 6,000 UL File No: E23301 Material and Environmental Specifications Actuator Housing Spring Contacts Movable Arm Terminals Rubber Boot Operating Temperature Range Ingress Protection Polycarbonate Nylon 66 94 V-2 Steel Wire Silver Alloy Silver Silver-Plated Copper Alloy Silicone -25 OC to +85 OC (-13 OF to +185 OF) IP65 Circuitry and Switch Functions – (ON)-OFF has same connections as ON-OFF; spring return on switch Dimensions mm (inches) 4.8±0.1 (0.189) www.switches-sensors.zf.com ZF Electronics Systems Pleasant Prairie, LLC (“ZF”) acquired the rights to the CHERRY branded switches and sensors in 2008. Although ZF divested its interest in the CHERRY name in 2015, the switches and sensors remain unchanged and are now sold under the ZF brand. Page 2 of 2, Last update 2017-11-02, Specifications subject to change without notice.
KRE2ANA1BBD
1. 物料型号:文档列出了北美、北美和欧洲以及欧洲的型号,例如北美的型号为KRE2ALA2GBB和KRE2ALA2RBB,欧洲的型号为KRE2AEA2GBB和KRE2AEA2RBB。
2. 器件简介:这个密封的摇臂开关系列具备快装、符合RoHS标准、100,000次机械寿命、IP65防护等级、有无照明版本的选择。
3. 引脚分配:文档中提到了不同的开关功能和照明选项,例如ON-OFF、ON-ON,以及220V AC氖灯、110V AC氖灯、28V DC LED和14V DC LED。
4. 参数特性:包括介质耐压、绝缘电阻、初始接触电阻、电气额定值、电气寿命等,例如1500 VAC 1分钟的介质耐压,100 MΩ最小绝缘电阻。
5. 功能详解:文档中详细描述了开关的工作原理和电路功能,包括(ON)-OFF和ON-OFF的连接方式。
6. 应用信息:ZF Electronics Systems收购了CHERRY品牌的开关和传感器权利,并在2015年出售了CHERRY名称的利益,但开关和传感器保持不变,现在以ZF品牌销售。
7. 封装信息:包括操作温度范围(-25°C 至 +85°C)、防护等级(IP65)、尺寸和推荐面板开孔尺寸。
KRE2ANA1BBD 价格&库存
很抱歉,暂时无法提供与“KRE2ANA1BBD”相匹配的价格&库存,您可以联系我们找货
KRE2ANA1BBD
