WS742905S-8/TR
WS742905S-8/TR
    WILLSEMI(韦尔)
    SOP8L
    WS742905S-8/TR
WS742905S-8/TR 数据手册
WS742905 WS742905 3.5MHz Low-Power Amplifiers 36V Operational Http://www.willsemi.com Descriptions SOP-8L WS742905 consist of dual channel independent, high MSOP-8L gain, internally frequency compensated operational amplifiers which are designed specifically to operate from a single power supply over a wide range of voltages. These devices are particularly useful in interface circuits with digital systems and can be operated from the single common 5VDC power supply. SOP-8L/MSOP-8L The WS742905 is available in 8-pin SOP and MSOP packages. Standard products are Pb-Free Pin configuration (Top view) and halogen-Free. Features  Single Supply Voltage : 3~36V  Quiescent Current per Amp : 120A Typical  GBWP : 3.5MHz  Slew Rate : 2V/s  Offset Voltage : 3.5mV Maximum  Offset Voltage Temp. Drift : 3V/ °C  THD+N : -100dB  CMRR/PSRR/Gain : 130/120/125dB  Output Short-Circuit Curr. : 18mA  SOP-8L Marking 742905 = Device code 2905 = Device code GM = Special code Input Common-Mode Voltage Range Includes Ground  No Output Crossover Distortion  No Phase Reversal from Overdriven Input  Rail-to-Rail Output Swing  -40°C to 125°C Operation Range Walkie-Talkie  Battery Management Solution  Transducer Amplifiers  Summing Amplifier  Multivibrators  Oscillators  DC Gain Blocks Will Semiconductor Ltd. Y = Year code W = Week code Order information Applications  MSOP-8L 1 Device Package Shipping WS742905S-8/TR SOP-8L 4000/Reel &Tape WS742905M-8/TR MSOP-8L 4000/Reel &Tape Jul, 2020 - Rev. 1.0 WS742905 Pin Descriptions Pin Number Symbol Descriptions 1 OUTA 2 -INA Inverting input 3 +INA Non-inverting input 4 V- 5 +INB Non-inverting input 6 -INB Inverting input 7 OUTB 8 V+ Output Negative supply Output Positive supply Absolute Maximum Ratings Parameter Symbol Value Unit Supply Voltage VCC(2) 42 V Input Differential Voltage VIDR(3) 42 Input Common Mode Voltage Range VICR V to V -2 V Output Short-Circuit Duration tSO Unlimited / Operating Fee-Air Temperature Range TA -40 to 125 °C Storage Temperature Range TSTG -65 to 150 °C Junction Temperature Range TJ 150 °C Lead Temperature Range TL 260 °C - V + Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are only stress ratings, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions are not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. All voltage values, except differential voltage are with respect to network terminal. 3. Differential voltages are at IN+ with respect to IN–. ESD, Electrostatic Discharge Protection Symbol Parameter HBM Human Body Model ESD CDM Charged Device Model ESD Will Semiconductor Ltd. Condition MIL-STD-883H Method 3015.8 JEDEC-EIA/JESD22-A114A JEDEC-EIA/JESD22-C101E 2 Minimum level Unit ±1500 V ±1500 V Jul, 2020 - Rev. 1.0 WS742905 Electronics Characteristics The * denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 30V, VCM = VOUT = VS/2, Rload = 2kΩ, Cload =100pF. Symbol Parameter Conditions VCM= VSUPPLY/2 * Min. Typ. Max. Unit -3.5 0.1 3.5 mV VOS Input Offset Voltage VOS Input Offset Voltage Drift 3 μV/°C IIB Input Bias Current 20 pA IOS Input Offset Current 20 pA Vn Input Voltage Noise f=0.1Hz to10Hz 8 VP-P en Input Voltage Noise Density f=1KHz 32 f=10KHz 23 CMRR Common Mode Rejection Ratio VCM Common Mode Input Voltage Range PSRR Power Supply Rejection Ratio DC, VS=30V, VCM=0V to * 105 VS=5V to 30V * V- VS=5V to 30V * 105 120 * 90 95 28V VS=5V, VOUT=0.1V to AVOL Open Loop Large Signal Gain 4.9V, RLOAD=2k VS=15V, VOUT=1V to 14V, RLOAD=10k VOH High Level Output Voltage VOL Low Level Output Voltage ISC Output Short-Circuit Current IQ Quiescent Current per Amplifier PM Phase Margin GM Gain Margin GBWP Gain-Bandwidth Product tS Settling Time 130 dB V+-2 * 90 dB 125 13.6 RLOAD=10k 14.7 RLOAD=2k -13.9 RLOAD=10k -14.7 V V * 18 21 Sink Current, VS=30V * 18 23 VS=5V No Load * 120 165 VS=30V No Load * 140 175 VS=30V RLOAD=2k, V dB RLOAD=2k Source Current, nV/√Hz mA A 67 º -15 dB f=1kHz 3.5 MHz AV=1, VOUT=1V, 0.1% 1.4 s 2 V/s 58 kHz -100 dB 95 dB CLOAD=100pF RLOAD=2k, CLOAD=100pF AV=1, VS=±15V, SR Slew Rate VOUT=-10V to 10V, RLOAD=10k, CLOAD=100pF FPBW Full Power Bandwidth THD+N Total Harmonic Distortion and Noise Xtalk Channel Separation Will Semiconductor Ltd. f=1kHz, AV=1, RLOAD=2k, VOUT=2VPP f=1kHz 3 Jul, 2020 - Rev. 1.0 WS742905 Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. 2. A heat sink may be required to keep the junction temperature below the absolute maximum rating when the output is shorted indefinitely. 3. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. 4. Full power bandwidth is calculated from the slew rate FPBW = SR/(π • VP-P). Will Semiconductor Ltd. 4 Jul, 2020 - Rev. 1.0 WS742905 Typical Characteristics TA=25°C, VS=±15V, VCM=0V, Rload=Open, unless otherwise noted Small-Siganl Step Response, 100mV Step Large-Siganl Step Response, 2V Step Negative/Positive Over-Voltage Recovery 0.1Hz to 10Hz Integrated Input Noise, Gain = 50000 Input Offset Voltage Distribution Will Semiconductor Ltd. Open-Loop Gain and Phase 5 Jul, 2020 - Rev. 1.0 WS742905 Typical Characteristics (continued) TA=25°C, VS=±15V, VCM=0V, Rload=Open, unless otherwise noted Quiescent Supply Current vs. Temperature Short-Circuit Current vs. Temperature PSRR vs. Frequency Quiescent Supply Current vs. Supply Voltage PSRR vs. Temperature CMRR vs. Temperature Will Semiconductor Ltd. 6 Jul, 2020 - Rev. 1.0 WS742905 Typical Characteristics (continued) TA=25°C, VS=±15V, VCM=0V, Rload=Open, unless otherwise noted Input Offset Voltage vs. Common-Mode Voltage Input Offset Voltage vs. Temperature Input Bias Current vs. Common-Mode Voltage Crosstalk, Vin+=1kΩ to GND THD+Noise vs. Vin+ THD+Noise vs. Frequency Will Semiconductor Ltd. 7 Jul, 2020 - Rev. 1.0 WS742905 PACKAGE OUTLINE DIMENSIONS SOP-8L D E E1 L c θ e SIDE VIEW A1 TOP VIEW A A2 b SIDE VIEW Symbol Dimensions In Millimeters (mm) Min. Typ. Max. A 1.35 1.55 1.75 A1 0.05 0.15 0.25 A2 1.25 1.40 1.65 b 0.33 - 0.51 c 0.15 - 0.26 D 4.70 4.90 5.10 E 3.70 3.90 4.10 E1 5.80 6.00 6.20 e 1.27BSC L 0.40 - 1.27 θ 0° - 8° Will Semiconductor Ltd. 8 Jul, 2020 - Rev. 1.0 WS742905 TAPE AND REEL INFORMATION SOP-8L Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed RD Reel Dimension 7inch 13inch W Overall width of the carrier tape 8mm 12mm P1 Pitch between successive cavity centers 2mm 4mm 8mm Pin1 Pin1 Quadrant Q1 Q2 Q3 Will Semiconductor Ltd. 9 Q4 Jul, 2020 - Rev. 1.0 WS742905 PACKAGE OUTLINE DIMENSIONS MSOP-8L D e c E E1 L b θ TOP VIEW A A2 A1 SIDE VIEW SIDE VIEW Symbol Dimensions In Millimeters (mm) Min. Typ. Max. A - - 1.10 A1 0.02 - 0.15 A2 0.75 0.80 0.95 b 0.25 - 0.38 c 0.09 - 0.23 D 2.90 3.00 3.10 E 4.75 4.90 5.05 E1 2.90 3.00 3.10 e 0.65 BSC L 0.40 - 0.80 θ 0° - 6° Will Semiconductor Ltd. 10 Jul, 2020 - Rev. 1.0 WS742905 TAPE AND REEL INFORMATION MSOP-8L Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed RD Reel Dimension 7inch 13inch W Overall width of the carrier tape 8mm 12mm P1 Pitch between successive cavity centers 2mm 4mm 8mm Pin1 Pin1 Quadrant Q1 Q2 Q3 Will Semiconductor Ltd. 11 Q4 Jul, 2020 - Rev. 1.0
WS742905S-8/TR 价格&库存
很抱歉,暂时无法提供与“WS742905S-8/TR”相匹配的价格&库存,您可以联系我们找货
