MFR-25FRF52-820R
MFR-25FRF52-820R
    YAGEO(国巨)
    AXIAL_D2.4X6.3MM
    金属膜电阻 820Ω ±1% 250MW
MFR-25FRF52-820R 数据手册
Through-hole resistors General Type Metal Film Resistors Normal & Miniature Style [ MFR Series ] FEATURES Power Rating 1/6W, 1/4W, 1/2W, 1W, 2W, 3W Resistance Tolerance ±0.5%, ±1%, ±2%, ±5% T.C.R. ±50ppm/°C, ±100ppm/°C DERATING CURVE For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. INTRODUCTION The MFR Series Metal Film Resistors are manufactured using a vacuum sputtering system to deposit multiple layers of mixed metal alloys and passivative materials onto a carefully treated high grade ceramic substrate. After a helical groove has been cut in the resistive layer, tinned connecting leads of electrolytic copper are welded to the end-caps. The resistors are coated with layers of blue color lacquer. Rated Load (%) 70 155 °C 100 80 60 40 20 20 40 60 80 100 120 140 160 Ambient Temperature (°C) DIMENSIONS Unit: mm STYLE ød H L øD DIMENSION Normal Miniature L øD H ød MFR-12 MFR25S 3.4±0.3 1.9±0.2 28±2.0 0.45±0.05 MFR-25 MFR50S 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 MFR-50 MFR1WS 9.0±0.5 3.3±0.3 26±2.0 0.55±0.05 MFR100 MFR2WS 11.5±1.0 4.5±0.5 35±2.0 0.8±0.05 MFR200 MFR3WS 15.5±1.0 5.0±0.5 33±2.0 0.8±0.05 5 Note: ELECTRICAL CHARACTERISTICS STYLE MFR-12 MFR25S Power Rating at 70°C 1/6W 1/4W Maximum Working Voltage 200V 250V 300V 350V 400V 500V Maximum Overload Voltage 400V 500V 600V 700V 800V 1,000V Voltage Proof on Insulation 300V 700V 1,000V Resistance Range 1Ω - 4M7Ω & for E24 & E96 series value Operating Temp. Range -55°C to +155°C Temperature Coefficient ±50ppm/°C, ±100ppm/°C 400V MFR-25 MFR50S MFR-50 1/2W MFR1WS MFR100 1W 500V MFR2WS MFR200 MFR3WS 2W 3W Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±0.25%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±1.5%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±0.75%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±0.25%+0.05Ω Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
MFR-25FRF52-820R
物料型号:文档中列出了多种型号,包括MFR-12、MFR25S、MFR-25、MFR50S、MFR-50、MFR100、MFR2WS、MFR200和MFR3WS。
器件简介:金属膜电阻器采用真空溅射系统制造,将多层混合金属合金和被动材料沉积在经过特殊处理的高等级陶瓷基板上。电阻层切割螺旋槽后,将镀锡的电解铜连接引线焊接到端盖。
引脚分配:文档未明确说明引脚分配,但提到了连接引线焊接到端盖。
参数特性:包括功率等级(1/6W, 1/4W, 1/2W, 1W, 2W, 3W)、电阻公差(±0.5%, ±1%, ±2%, ±5%)和温度系数(±50ppm/°C, ±100ppm/°C)。
功能详解:文档提供了电阻器的电气特性,包括最大工作电压、最大过载电压、绝缘电压测试、电阻范围、工作温度范围和温度系数。
应用信息:文档未直接提供应用信息,但根据电气特性和测试结果,这些电阻器适用于需要精确电阻和稳定性能的场合。
封装信息:提供了不同型号的尺寸数据,包括直径(D)、高度(H)和引线外径(od)。
MFR-25FRF52-820R 价格&库存
很抱歉,暂时无法提供与“MFR-25FRF52-820R”相匹配的价格&库存,您可以联系我们找货
MFR-25FRF52-820R
    • 50+0.05422
    • 500+0.05303
    • 1500+0.05228
    库存:2046
    MFR-25FRF52-820R
    • 1+0.884161+0.11461
    • 10+0.3696510+0.04792
    • 25+0.3063725+0.03971
    • 50+0.2678150+0.03472
    • 100+0.23606100+0.03060
    • 250+0.20014250+0.02595
    • 500+0.17760500+0.02302
    • 1000+0.158481000+0.02055
    库存:4512
    MFR-25FRF52-820R
    • 5000+0.124465000+0.01614
    • 10000+0.1132710000+0.01468
    • 15000+0.1075215000+0.01394
    • 25000+0.1010225000+0.01310
    • 35000+0.0971435000+0.01259
    • 50000+0.0933650000+0.01210
    库存:4512
