3.2*1.5*1.0mm Right Angle SMD LED
E6C1204YGAC1UDA
LIGHT EMITTING DIODE SPECIFICATION
CUSTOMER NAME:
DESCRIPTION:
E6C1204YGAC1UDA
REVISION:
V2.2
ISSUE DATE:
2022-03-25
Contains trade secret information which is the property of Ekinglux and shall not be made available to, or copied or
used by anyone outside Ekinglux without its written authorization. Copyright © 2017 Ekinglux Optoelectronics Technology
Co., Ltd. All rights reserved
www.ekingluxs.com
Tel:021-59909181
1
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Features:
●RoHS compliant
●Long operating life
●Ideal for backlight and indicator
●Various Colors brightness Available
●Moisture sensitivity level: 3
Application:
●Backlight
●Decoration lighting
●motormeter
●Indicator
Part Number
E6C1204YGAC1UDA
Dice Material
AlGaInP
Emitted Color
Yellow Green
Lens Color
Water Clear
Electro-Optical Characteristics(Ta=25℃, @20mA)
Parameter
Luminous Intensity
Radiation Bandwidth
Forward Voltage
Peak Wavelength
Dominant Wavelength
CIE Coordinates CIE
Color Temperature
Viewing Angle
Reverse Current
Symbol
IV
△λ
VF
λp
λd
x,y
Tc
2θ1/2
IR
Min.
10
1.90
565
Typ.
30
30
2.00
573
570
120
Max.
70
2.40
575
10
Unit
mcd
nm
v
nm
nm
k
deg
uA
Absolute Maximum Ratings(Ta=25℃)
Parameter
Power Dissipation
Peak Forward Current(1/10 Duty Cycle, 0.1ms Pulse Width)
Forward Current
Reverse Voltage
Electrostatic Discharge
Operating Temperature Range
Storage Temperature Range
Reflow Soldering
www.ekingluxs.com
Tel:021-59909181
2
Symbol
Pd
IFP
IF
VR
ESD
Topr
Tstg
Tsld
021-59909182
Max.
Unit
60
mW
100
mA
25
mA
5
v
2000
v
o
-40to+85
C
o
-40to+90
C
260℃for 10secs
Sales@ekingluxs.com
E6C1204YGAC1UDA
Optical & Electrical Characteristics
100%
Relative lntensity(%)
Ta=25°c
80%
60%
40%
20%
0%
350
400
450
500
550
600
650
Wavelength (nm)
Forward Current vs.Forward Voltage
Forward Currenr If(mA)
Forward Current(mA)
Ta=25°c
50
40
30
2.0 2.4 2.8 3.2
Forward Voltage(V)
3.6
50
60
70
80
90 100
Relative lntensity vs.Ambient Temperature
1.2
Ta=25°c
1.0
Relative lntensity
3.5
Relative lntensity
10
Ambient Temperature(°c)
4.0
3.0
2.0
1.5
1.0
80
70
60
50
40
30
Relative lntensity vs.Forward Currenr
Maximum Driving Forward DC Current vs.Ambient
Temperature(De-rating based on Tj max.=115°c)
60
10
700
0.8
0.6
0.4
0.2
40
50
Forward Current(mA)
-20°
-30°
-40°
Radiation Pattern
-10° 0° 10°
Ta=25°c
60
80
100
20°
30°
40°
50°
-50°
-60°
60°
-70°
70°
80°
-80°
-90°
1.0
www.ekingluxs.com
0.5
Tel:021-59909181
3
0.5
021-59909182
90°
1.0
Sales@ekingluxs.com
E6C1204YGAC1UDA
Bin Limits
Bin Range Of Luminous Intensity (Unit:mcd)
Bin Code
L1
L2
L3
Min
10
30
50
Max
30
50
70
Condition
IF=20mA
Bin Range Of Forward Voltage (Unit:V)
Bin Code
V1
V2
V3
V4
V5
Min
1.9
2.0
2.1
2.2
2.3
Max
2.0
2.1
2.2
2.3
2.4
Condition
IF=20mA
Bin Range Of Wavelength (Unit:nm)
Bin Code
YG1
YG2
YG3
YG4
YG5
Min
565
567
569
571
573
Max
567
569
571
573
575
Condition
IF=20mA
Notes:
1.Tolerance of Luminous Intensity ±10%
2.Tolerance of Forward Voltage ±0.1V
www.ekingluxs.com
Tel:021-59909181
4
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Reliability Test Items And Conditions
Test Items
Reference
Thermal Shock
Test Conditions
Time
-40℃(30min)
100
-100℃(30min) Cycles
-10℃~65℃;
10cycles
0%~90%RH
MIL-STD-202G
Temperature And Humidity
Cyclic
High Temperature Storage
Low Temperature Storage
High Temperature High
Humidity Storage
High Temperature Life Test
JEITA ED-4701 200
203
JEITA ED -4071 200
201
JEITA ED -4071 200
202
JEITA ED -4071 100
103
JESD22-A108D
Life Test
Resistance to Sodering
Heat
GB/T 4937,Ⅱ,
2.2&2.3
Criterion
22
0/22
22
0/22
Ta=100℃
1000H
22
0/22
Ta=-40℃
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
2 times
22
0/22
Ta=60℃;
RH=90%
Ta=80℃
Ta=25℃
IF=20mA
Tsol*=(240±5)
℃10secs
JESD22-A108D
Quantity
Criteria For Judging Damage
Test Items
Forward Voltage
Recerse Current
Symbol
VF
IR
Test Conditions
IF=IFT
VR=5V
Luminous Intensity
IV
IF=IFT
Resistance to
Soldering Heat
www.ekingluxs.com
Initial Data±10%
IR≤10uA
Average IV degradation≤30%;Single LED IV
degradation≤50%
Meterial without internal cracks,no meterial
between stripped,no deaded light
Tel:021-59909181
5
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Product size (Unit:mm)
NOTES:
1. All dimensions are in millimeters (inches)
2. Tolerances are 0.2mm (0.008inch) unless otherwise noted
Recommended Soldering Pad Design (Unit:mm)
Taping and package Spec
●Tape Specification:3,000pcs Per Reel
www.ekingluxs.com
Tel:021-59909181
6
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Packaging
LabelStyle
www.ekingluxs.com
Tel:021-59909181
7
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Table of Classification Reflow Profiles
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150°C
60-120 seconds
200 °C
60-120 seconds
3 °C/second max
3 °C/second max
Liquidous temperature (TL)
Time at liquidous (tL)
183 °C
60-150 seconds
217 °C
60-150 seconds
Peak package body temperature (Tp)*
230 °C ~235 °C
255 °C ~260 °C
235 °C
260 °C
20 seconds
30 seconds
6 °C/second max
6 °C/second max
6 minutes max
8 minutes max
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate (Tsmax to Tp)
Classification temperature (Tc)
Time (tp) within 5 °C of the specified
Average ramp-down rate (Tp to Tsmax)
Time 25 °C to peak temperature
1. Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
2.Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.ekingluxs.com
Tel:021-59909181
8
021-59909182
Sales@ekingluxs.com
E6C1204YGAC1UDA
Precautions
1. Storage:
●Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep
moisture to
aminimum.
●Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and beused
within a year.
●After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH. It is
recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 60%RH.
●If the moisture absorbent material has fade away or the LEDs have exceeded the storage time,
baking treatment should
be performed based on the following condition: (70±5)℃ for 24 hours.
2. Static Electricity:
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the
forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands
or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
3. Vulcanization:
LED curing is due to sulfur being in bracket and the +1 price of silver in the chemical reaction generated Ag2S in the
process. It will lead to the capacity of reflecting of silver layer reducing, light color temperature drift and serious
decline ,seriously affecting the performance of the product.So we should take corresponding measures to avioding
vulcanization, such as to avoid using sulphur volatile substances and keeping away from high sulphur content of the
material.
www.ekingluxs.com
Tel:021-59909181
9
021-59909182
Sales@ekingluxs.com
很抱歉,暂时无法提供与“E6C1204YGAC1UDA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23868
- 200+0.18479
- 600+0.15477
