Document No
TRLM-200S014B
Issued date
2015/11/03
page
1/6
Lead-Free Current Sensing Resistors
RLM Series
1. Scope:
This specification applied to the products of Lead-Free current sensing resistor of metal foil for Lead-Free
RLM series manufactured by TA-I TECHNOLOGY CO., LTD.
2. Type Designation:
RLM
Item
Series
No
F
Resistance
tolerance
20:2010
F:±1%
(5025)
E
Packaging
C
Power Rating
E: Embossed Tape
R010
Resistance
I=3/4W
e.g :
G:±2%
D=3/2W
R010=10mΩ
J:±5%
S=1/2W
C=1W
3. Construction and Dimension :
3.1 Construction:
Over-Coat
Ni / Sn
Plating
Metal Alloy Plate
3.2 Dimension:
UNIT : mm
Style
L
W
C
T
Material
1.5±0.3(≦3mΩ)
RLM20
5.0±0.2
2.5±0.2
Strip: Alloy
0.60 ±0.20 Over Coating:Polymer
0.6±0.3(R>3mΩ)
Compound UL-94V-0 grade
RLM Series
Document No
TRLM-200S014B
Issued date
2015/11/03
page
2/6
4. Features:
Type
RLM20
3/2W、3/4W、1/2W、1W
2~50mΩ
-55℃~+170℃
Power Rating
Resistance Value
Operation Temperature Range
±50ppm/℃
Temperature Coefficient of Resistance
±1%,±2%,±5%
Over 100MΩ
(P*R)1/2
Tolerance
Insulation Resistance
Maximum Working Voltage(V)
5. Reliability Tests :
Test Items
Resistance
Load Life
Short Time Overload
Moisture no Load
Reference
standard
IEC60115-1 4.8
JIS C 5201-1 4.8
IEC60115-1 4.25.1
JIS C 5201-1 4.25.1
Condition of Test
+25℃ ~ +125℃
Test Limits
Refer 4.0
1000hours at rated power, 70
℃, 1.5hours “ON”, 0.5hour
< ±1%
“OFF”
IEC60115-1 4.13
JIS C 5201-1 4.13
5 X rated power for 5s
< ±0.5%
IEC60115-1 4.24.2.1a)
JIS C 5201-1 4.24.2.1a)
85℃, 85%RH, 1000hrs
< ±1%
Temperature cycle
IEC60115-1 4.19
JIS C 5201-1 4.19
-55℃ & +155℃, 300cycle,
< ±1%
15min per extreme condition
Resistance to Soldering Heat
IEC60115-1 4.18
JIS C 5201-1 4.18
260±5℃ for10±1 sec
< ±0.5%
Solderability
IEC60115-1 4.17
JIS C 5201-1 4.17
245±5℃, 2±0.5sec
At least 95% of surface
area of electrode shall be
covered with new solder
High Temperature Exposure
IEC60115-1 4.23.2
JIS C 5201-1 4.23.2
170℃, 1000hrs
< ±1%
Low Temperature Storage
EC60115-1 4.23.4
JIS C 5201-1 4.23.4
-55℃, 1000hrs
100 MΩ
RLM Series
Document No
TRLM-200S014B
Issued date
2015/11/03
page
3/6
Power Ratio (%)
5.1Derating Curve
100
-55
70
170
Ambient Temperature (℃)
5.2 Rated Voltage
The rated voltage is calculated by the following formula:
V:Rated Voltage(V)
V= 𝐏 × 𝐑
P:Rated Power(W)
R:Resistance Value(Ω)
6. Recommended Solder Pad Dimension
L
b
a
Cu Trace
Resistance Range
(Ω)
Sensing Trace
a
b
L
0.002-0.003
3.4±0.2
3.5±0.2
2.0±0.2
0.004-0.050
3.4±0.2
1.5±0.2
3.5±0.2
Unit: mm
RLM Series
Document No
TRLM-200S014B
Issued date
2015/11/03
page
4/6
7. Number of Package:
4000 Pieces / package
8. Label:
Date Code
Series
Resistance
QTY: 4000 PCS
T019C0071H
LOT NO:
R010 FEC
0308
RLM20FEC
Tolerance
Package
Power Rating
9. Taping
Packing
Emboss
Type
RLM20
A
2.8±0.2
B
5.3±0.2
W
12.±0.2
F
5.5±0.05
E
1.75±0.1
P1
4.0±0.1
P2
2.0±0.05
P0
D0
T
4.0±0.05
ψ1.5
(+0.1/-0.1)
0.85±0.15
Unit: mm
RLM Series
Document No
TRLM-200S014B
Issued date
2015/11/03
page
5/6
10. Reel Specification
Series
RLM 20
ψA
ψB
178.0 ±2.0
60.0 ±1.0
ψC
13.0 ±1.0
W
T
13.0 ±1.0
15.5 ±1.0
Unit: mm
11. Peeling Strength of Top Cover Tape
Test Condition: 0.1 to 0.7 N at a peel-off speed of 300 mm / min.
pull
300 mm/min
top cover tape
10 ~15∘
standard: 0.1 ~ 0.7 N
carrier tape
12. Storage Conditions:
Temperature: 5℃~35℃,Humidity:40%~75%
13. Shelf Life:
2 years from manufacturing date.
RLM Series
Document No
TRLM-200S014B
Issued date
2015/11/03
page
6/6
14. Recommend IR – Reflow profile : (solder : Sn96.5 / Ag3 / Cu0.5)
Peak : 260
5
℃ , 10±1 sec
5
Pre – heat Zone : 150 to 180 ℃, 90±30 sec
Soldering Zone : 230℃ or higher , 30±10 sec
Iron Solder:350±10℃ , 3+1/-0 sec
15. ECN
Engineering Change Notice: The customer will be informed with ECN if there is significant
modification on the characteristics and materials described in approval sheet.
16. Manufacturing Country & City :
TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan )
Tel: (+886) 3-3246169
Fax : (+886) 3-3246167
Associated companies :
(1)TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou)
Tel :(+86) 512-63457879
Fax : (+86) 512-63457869
(2) TA-I TECHNOLOGY ELECTRONIC (DONGGUAN ) CO., LTD. ( China –Dongguan )
Tel : (+86) 769-8339-4790〜3
Fax : (+86) 769-8339-4794
(3) FORTUNE TASK RESISTOR FACTORY
( China – Dongguan )
(4) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia – Penang )
Tel :(+60) 4- 3900480
Fax : (+60) 4-3901481
(5) P.T.TAI ELECTRONIC Indonesia ( Indonesia – Jakarta )
Tel :(+62) 21-44820254
Fax : (+62) 21-44820256
很抱歉,暂时无法提供与“RLM20FECR050”相匹配的价格&库存,您可以联系我们找货
