PANEL
PCB SWITCHES
SW
3
80
-1
TG
TG series
Subminiature slide switches
DISTINCTIVE FEATURES
Single piece case
Epoxy sealed terminals
Washable version available
Wide variety of contact materials
Same PCB layout as TL, TP and TR subminiature series
ELECTRICAL SPECIFICATIONS
• Current/voltage rating with resistive load :
- Gold plated contacts : 0.4 VA 20V max. AC or DC
- Silver plated contacts : 0.5 A 48V max. AC or DC
• Contact resistance : 20 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
1,000 Vrms 50 Hz min. between terminals and frame
500 Vrms 50 Hz min. between terminals
• Electrical life at full load :
2 position switches : 60,000 cycles
3 position switches : 30,000 cycles
GENERAL SPECIFICATIONS
• Travel : 2.60 mm (.102)
• Wave soldering : 260 °C (500 °F) - 5 sec. max.
• Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F)
• Cleaning : solvents or water + detergent
MATERIALS
• Case : flame retardant thermoplastic
• Actuator : thermoplastic
• Ground plate and bracket : brass, tin plated
• Contacts and terminals : see next page
• Rubber seal : silicone, transparent
• Terminal seal : epoxy
APEM products may be recycled at end-of-life for the re-claiming of valuable metal components.
The company reserves the right to change specifications without notice.
1
Y0
Y0
P0
P0
ELECTRICAL FUNCTIONS
2
3.05
(.120)
5.55
(.218)
9.10
(.358)
9.60
(.377)
12.60
(.496)
PCB MOUNTING
12.60
(.496)
PCB SWITCHES
TG series
W0
W0
BUILD YOUR PART NUMBER
BASIC PART NUMBER
TG
SERIES
NUMBER OF POLES
3
Single pole
TERMINALS
6
ON
ON
P0
Straight PC
9
ON
OFF
ON
Y0
Straight PC,
bracket mounting
W0
Right angle,
horizontal mounting
MW
Wire-wrap
OPTIONS
CONTACT AND TERMINAL MATERIALS
ACTUATORS
MODEL
Brass, gold plated (std)
00
High (standard)
00
Standard
1
Brass, silver plated
10
Flush
50
Washable
3
Brass, gold plated
(1.27 µ gold)
8
Contact brass, gold
plated + tin plated
terminals
9
Contact brass, gold
plated (1.27 µ gold) + tin
plated term.
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
3
PANEL
PCB SWITCHES
TG series
Shown with standard actuator
2.50
(.098)
2.50
(.098)
3.30
(.129)
9.10
(.358)
3.50
(.137)
STRAIGHT PC TERMINALS
STANDARD MODEL
0.50
(.019)
1.00
(.039)
ON
ON
TG39P0••00
ON
OFF
ON
2.54
(.100)
2.54
(.100)
10.10
(.397)
WASHABLE MODEL
0.70
(.027)
Ø1.10
(.043 DIA)
5.00
(.196)
TG36P0••00
2.54
(.100)
2.54
(.100)
5.80
(.228)
ON
TG39P0••50
ON
OFF
ON
1.00
(.039)
ON
3.20
(.125)
2.50
(.098)
0.50
(.019)
2.54
(.100)
2.54
(.100)
3.30
(.129)
4.30
(.169)
3.00
(.118)
2.50
(.098)
9.60
(.378)
TG36P0••50
0.70
(.027)
2.50
(.098)
ON
ON
OFF
ON
3.30
(.129)
2.54
(.100)
0.70
(.027)
2.54
(.100)
2.54
(.100)
10.16
(.400)
5.00
(.196)
ON
TG39Y0••00
2.65
(.104)
0.50
(.019)
TG36Y0••00
2.54
(.100)
2.54
(.100)
11.10
(.437)
5.80
(.228)
2.50
(.098)
ON
ON
TG39Y0••50
ON
OFF
ON
2.54
(.100)
2.54
(.100)
11.10
(.437)
4
2.54
(.100)
3.30
(.129)
0.70
(.027)
2.54
(.100)
10.16
(.400)
5.00
(.196)
TG36Y0••50
2.65
(.104)
0.50
(.019)
Ø1.10
(.043 DIA)
3.20
(.125)
2.50
(.098)
4.30
(.169)
1.00
(.039)
3.00
(.118)
BRACKET MOUNTING - WASHABLE MODEL
2.54
(.100)
1.00
(.039)
9.60
(.378)
2.54
(.100)
2.50
(.098)
3.00
(.118)
BRACKET MOUNTING - STANDARD MODEL
5.00
(.196)
Ø1.10
(.043 DIA)
10.10
(.397)
9.60
(.378)
PCB SWITCHES
TG series
2.54
(.100)
2.54
(.100)
Ø1.10
(.043 DIA)
2.54
(.100)
4.75
(.187)
0.70
(.027)
3.00
(.118)
2.50
(.098)
OFF
ON
10.10
(.397)
0.40 )
5
(.01
5.80
(.228)
ON
TG39W0••50
ON
OFF
ON
5.08
(.200)
3.20
(.125)
4.30
(.169)
0.70
(.027)
3.00
(.118)
2.54
(.100)
2.50
(.098)
0.50
(.019)
2.54
(.100)
2.54
(.100)
10.10
(.397)
0.40 )
5
(.01
5.00
(.196)
ON
Ø1.10
(.043 DIA)
2.54
(.100)
2.50
(.098)
1.00
(.039)
TG36W0••50
5.08
(.200)
5.08
(.200)
9.60
(.378)
RIGHT ANGLE TERMINALS
HORIZONTAL MOUNTING - WASHABLE MODEL
3.30
(.129)
4.75
(.187)
ON
5.55
(.218)
2.54
(.100)
5.08
(.200)
3.05
(.120)
5.55
(.218)
3.30
(.129)
5.08
(.200)
TG39W0••00
2.54
(.100)
0.70
(.027)
ON
0.70
(.027)
5.08
(.200)
ON
3.05
(.120)
5.08
(.200)
5.08
(.200)
TG36W0••00
0.50
(.019)
5.00
(.196)
1.00
(.039)
9.60
(.378)
HORIZONTAL MOUNTING - STANDARD MODEL
2.50
(.098)
Ø1.10
(.043 DIA)
2.54
(.100)
2.54
(.100)
MATERIALS
BASIC P/N
00 or 50
To order a product, replace first • of the part number with one of the following codes.
3
8
9
Brass, gold plated (standard)
Brass, gold plated (1.27 µ gold)
Contact brass, gold plated + tin plated terminals
Contact brass, gold plated (1.27 µ gold) + tin plated terminals
ACTUATORS
BASIC P/N
00 or 50
To order a product, replace second • of the part number with one of the following codes.
00
10
High actuator (standard)
Flush actuator
5
PANEL
PCB SWITCHES
TG series
很抱歉,暂时无法提供与“TG36W010000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+98.0724310+12.71206
- 25+83.1100125+10.77264
- 100+56.24938100+7.29099
- 国内价格
- 1+70.82451
- 10+67.96070
- 25+65.26352
- 50+62.95165
- 100+60.63978
