PMEG4010CEH
PMEG4010CEH
    NEXPERIA(安世)
    PMEG4010CEH
PMEG4010CEH 数据手册
PMEG4010CEH; PMEG4010CEJ 1 A very low VF MEGA Schottky barrier rectifiers Rev. 02 — 22 March 2007 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifiers with an integrated guard ring for stress protection, encapsulated in small and flat lead Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package Configuration Nexperia JEITA PMEG4010CEH SOD123F - single PMEG4010CEJ SOD323F SC-90 single 1.2 Features n n n n Forward current: IF ≤ 1 A Reverse voltage: VR ≤ 40 V Very low forward voltage Small and flat lead SMD plastic packages 1.3 Applications n n n n n Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Reverse polarity protection Low power consumption applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tsp ≤ 55 °C - - 1 A VR reverse voltage - - 40 V - 490 570 mV VF [1] forward voltage Pulse test: tp ≤ 300 µs; δ ≤ 0.02. IF = 1 A [1] PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 2. Pinning information Table 3. Pinning Pin Description 1 cathode 2 anode Simplified outline Symbol [1] 1 1 2 2 sym001 001aab540 [1] The marking bar indicates the cathode. 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PMEG4010CEH - plastic surface-mounted package; 2 leads SOD123F PMEG4010CEJ SC-90 plastic surface-mounted package; 2 leads SOD323F 4. Marking Table 5. Marking codes Type number Marking code PMEG4010CEH C9 PMEG4010CEJ EP © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 2 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage - 40 V IF forward current IFRM repetitive peak forward current Tsp ≤ 55 °C - 1 A tp ≤ 1 ms; δ ≤ 0.25 - 7 A IFSM non-repetitive peak forward current square wave; tp = 8 ms PMEG4010CEH - 9 A PMEG4010CEJ - 10 A [1] - 375 mW [2] - 830 mW [1] - 350 mW [2] - 830 mW total power dissipation Ptot Tamb ≤ 25 °C PMEG4010CEH PMEG4010CEJ Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Min Typ Max Unit [2] - - 330 K/W [3] - - 150 K/W [2] - - 350 K/W [3] - - 150 K/W PMEG4010CEH - - 60 K/W PMEG4010CEJ - - 55 K/W PMEG4010CEH PMEG4010CEJ Rth(j-sp) thermal resistance from junction to solder point [4] [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [4] Soldering point of cathode tab. © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet [1] Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 3 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF IR Cd [1] Parameter Conditions Min Typ Max Unit IF = 1 mA - 210 240 mV IF = 10 mA - 270 310 mV IF = 100 mA - 340 390 mV IF = 500 mA - 420 490 mV [1] forward voltage reverse current diode capacitance IF = 700 mA - 450 520 mV IF = 1 A - 490 570 mV VR = 5 V - 0.8 - µA VR = 10 V - 1.1 - µA VR = 40 V - 6 50 µA VR = 1 V; f = 1 MHz - 69 77 pF Pulse test: tp ≤ 300 µs; δ ≤ 0.02. © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 4 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 006aaa755 104 006aaa756 105 IF (mA) 4 IR 10 (µA) 103 103 102 (1) (2) (3) (1) (2) (3) (4) (5) 102 10 (4) 1 10 10−1 10−2 1 (5) 10−3 10−1 0.0 10−4 0.2 0.4 0.6 0.8 0 10 20 30 VF (V) 40 VR (V) (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 1. Forward current as a function of forward voltage; typical values Fig 2. Reverse current as a function of reverse voltage; typical values 006aaa757 160 Cd (pF) 120 80 40 0 0 10 20 30 40 VR (V) f = 1 MHz; Tamb = 25 °C Fig 3. Diode capacitance as a function of reverse voltage; typical values © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 5 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 8. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig 4. Duty cycle definition 9. Package outline 1.7 1.5 1.2 1.0 1.35 1.15 1 0.80 0.65 0.5 0.3 1 0.55 0.35 3.6 3.4 2.7 2.3 2.7 2.5 1.8 1.6 2 2 0.70 0.55 Dimensions in mm 0.25 0.10 0.40 0.25 0.25 0.10 04-11-29 Fig 5. Package outline SOD123F Dimensions in mm 04-09-13 Fig 6. Package outline SOD323F (SC-90) 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description PMEG4010CEH SOD123F 4 mm pitch, 8 mm tape and reel PMEG4010CEJ SOD323F [1] 3000 10000 -115 -135 For further information and the availability of packing methods, see Section 14. © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Packing quantity Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 6 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 11. Soldering 4.4 4 2.9 1.6 solder lands solder resist 2.1 1.6 1.1 1.2 solder paste occupied area 1.1 (2×) Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 7. Reflow soldering footprint SOD123F 3.05 2.80 2.10 1.60 solder lands solder resist 1.65 0.95 0.50 0.60 occupied area solder paste 0.50 (2×) 001aab169 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 8. Reflow soldering footprint SOD323F (SC-90) © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 7 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG4010CEH_PMEG4010CEJ_2 20070322 Product data sheet - PMEG4010CEJ_1 Modifications: PMEG4010CEJ_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • Legal texts have been adapted to the new company name where appropriate. Type number PMEG4010CEH added Section 1.1 “General description”: amended Table 1 “Product overview”: added Table 7 “Thermal characteristics”: Table note 1 amended Section 8 “Test information”: added 20060413 Product data sheet - © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet - Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 8 of 10 PMEG4010CEH; PMEG4010CEJ Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PMEG4010CEH_PMEG4010CEJ_2 Product data sheet Rev. 02 — 22 March 2007 Nexperia B.V. 2017. All rights reserved 9 of 10 Nexperia PMEG4010CEH; PMEG4010CEJ 1 A very low VF MEGA Schottky barrier rectifiers 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 March 2007
PMEG4010CEH 价格&库存
很抱歉,暂时无法提供与“PMEG4010CEH”相匹配的价格&库存,您可以联系我们找货
PMEG4010CEH
    • 1+1.12830
    • 10+0.97390
    • 30+0.74110
    • 100+0.68870
    • 300+0.67220
    • 3000+0.65220
    库存:14884
