MSS-26CL-B
MSS-26CL-B
    MAGNASPHERECORP
    Module
    MSS-26CL-B
MSS-26CL-B 数据手册
MAGNASPHERE MSS SERIES Architects and Engineering Specifications Related Sections Magnetic Door Contacts for use with Burglar Alarm Systems, Intrusion Detection Systems and Access Control Systems References Underwriters Laboratories Inc. (UL) UL634; Standard for Connectors and Switches used in Burglar Alarm Systems Design Requirements The Magnetic Door Contact must be made with Magnasphere BMS magnetic switch technology. The Magnetic Door Contact must be used with End of Line (EOL) resistors and be compatible with control panel models that accept contact inputs. PRODUCTS – MSS single switch series – (example:09/10C, 09 /10CT, 19C, 19/20CL, 25C, 25/26CL, 63S, 22/24S, 53/54SL, 88/89SL, 105/106S) &MSS multi-switch 300 series (example: 321S, 312C) Materials Switch and Magnet Housings made of UL 94HB plastic or aluminum –Housing dimensions to be nominally 3/8” diameter (09), 3/4" diameter (19), 1” (25) or 2.5” long (63, 321), or 4” long (105) Internal switches must be Magnasphere technology (BMS) Contacts must be fully potted using 94HB rated material Lead wires to be solid color coded Design features Magnetic Door Contacts with Magnasphere technology provides enhanced security and durability versus reed switch based contacts Contact form: One Open Loop Alarm contact (09, 19, 22, 25, 63, 105) or one Closed Loop Alarm contact (10, 20, 26, 24, 54, 88, 106) or Two or Three Alarm contacts, Open or Closed Loop or combinations of Open and Closed Loop (MSS-3XX series). Max. Electrical Rating 250 mA 30 VDC (Resistive) 0.25 W UL 634 Listed EXECUTION Installation Per Manufacturer’s Instructions
MSS-26CL-B 价格&库存
很抱歉,暂时无法提供与“MSS-26CL-B”相匹配的价格&库存,您可以联系我们找货
