U444-06N-DP-C
U444-06N-DP-C
    TRIPPLITE
    U444-06N-DP-C
U444-06N-DP-C 数据手册
USB-C to Displayport 4K 60Hz Adapter with PD Charging MODEL NUMBER: U444-06N-DP-C Highlights ● Supports USB DisplayPort Alternate Mode for transmitting audio/video ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● USB-C PD charging port supports power input up to 20V 3A (60W) ● Reversible USB-C plug connects in either direction ● Plug-and-play operation with no software or drivers required Applications Adds DisplayPort and USB-C PD charging ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. ● Connect to a 4K DisplayPort monitor via the USB-C port on your laptop, computer or tablet ● Charge the host computer via the 60W PD Charging port System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with DisplayPort input (DP port) Description The U444-06N-DP-C USB 3.1 Gen 1 USB-C to DisplayPort 4K Adapter expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for transmitting digital audio and 4K video to a large display and powering and charging a PD Chargingcompliant mobile device—all at the same time. With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your primary display to another, duplicate the same video on both displays, or change the second display to your primary. The plug-and-play U444-06N-DP-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. To transmit digital audio and 4K video to a DP television, projector or monitor, connect the adapter’s DP to the display using a DP cable (sold separately). The port supports UHD video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz. The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) the U444-06N-DP-C is connected to. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). Features Turn Your Device's USB-C Port into a Multiport WorkstationIdeal for transmitting audio/video to a large display and powering and charging a PD Charging-compliant mobile device simultaneouslyPlugand-play operation with no software, drivers or external power requiredHalf the footprint of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 4K Video and Digital Audio to DP DisplayCompatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate ModeSupports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 HzExtends video from your primary display to anotherDuplicates the same video on 2 displaysConverts a secondary display to your primary display Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 deviceSupports power input up to 20V 3A (60W) Note: USB-C PD port does not support Quick Charge (QC). 1/4 Package Includes ● U444-06N-DP-C USB 3.1 Gen 1 USB-C to DisplayPort 4K Adapter ● Owner’s manual Built-In Cable with Reversible USB-C Connector Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193735 Product Type USB-C Adapter Technology DisplayPort Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output DISPLAYPORT (FEMALE) Number of Monitors Supported 1 Video Ports DISPLAYPORT (FEMALE) Video Ports Details HDCP 1.3; DisplayPort 1.2 Resolutions Supported 3840 x 2160 @ 60 Hz Supported Resolutions 3840x2160 (4K) Max Supported Video Resolution 3840 X 2160 (4K X 2K) @ 60HZ Mirror Mode No HDR Support Yes 3D Video Supported Yes INPUT Built-In Cable Length (ft.) 0.33 Built-In Cable Length (m) 0.1 Built-In Cable Length (in.) 3.94 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) No 2/4 POWER USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 60W CHARGING Number of Charging Ports 1 Total Charging Amps 3 Total Charging Watts 60 Charging Method AC Charging Port Type USB C (FEMALE) Charging Ports Details Charge the host PC with up to 20V/3A (60W) of power Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0) Charging Ports / Amps 3A / 2A / 1.5A PHYSICAL Material of Construction PVC, ABS Color White Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8 mm Number of Displays 1 Shipping Dimensions (hwd / cm) 2.01 x 11.68 x 9.91 Shipping Dimensions (hwd / in.) 0.79 x 4.60 x 3.90 Shipping Weight (kg) 0.09 Shipping Weight (lbs.) 0.20 Unit Dimensions (hwd / in.) 0.45 x 1.9 x 1.6 Unit Packaging Type Box Unit Weight (lbs.) 0.06 Unit Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Operating Humidity Range 10% to 85% RH, Non-Condensing 3/4 Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Number of Ports 2 Side A - Connector 1 USB C (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Displayport Specification 1.2 HDCP Specification 2.2 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
U444-06N-DP-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-DP-C”相匹配的价格&库存,您可以联系我们找货
