DATA SHEET
LEAD FREE CHIP RESISTORS
RC_P series
±0.5%, ±1%, ±5%
Product specification – March 25, 2021 V.2
Sizes 0100/0201/0402/0603/0805/
1206/1210/1218/2010/2512
Chip Resistor Surface Mount
RC_P
SERIES
SCOPE
This specification describes RC
series chip resistors with made by
thick film process.
ORDERING INFORMATION - GLOBAL PART NUMBER
APPLICATIONS
All general purpose application
RC XXXX X X X XX XXXX P
2
10
0100 to 2512
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0100/0201/0402/0603/0805/1206/1210/1218/2010/2512
FEATURES
Total lead free without RoHS
exemption
Halogen Free Epoxy
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Saving of PCB space
(2) TOLERANCE
D = ± 0.5%
F = ± 1.0%
J = ± 5.0% ( for jumper ordering, use code of J)
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
S = ESD safe reel (0100 only)
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
-= Based on spec.
(5) TAPING REEL
07= 7 inch dia. Reel
13=13 inch dia. Reel
7N = 7 inch dia. Reel, ESD safe reel (0100 only)
7W = 7 inch dia. Reel & 2 x standard power
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistance value.
Letter R/K/M is decimal point.
Example:
97R6 = 97.6Ω
9K76 = 9760Ω
1M = 1,000,000Ω
(7) DEFAULT CODE
Letter P is lead free (without RoHS exemption)
ORDERING EXAMPLE
The ordering code for a RC0402 0.0625W chip resistor value 100KΩ
with ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel
is: RC0402JR-07100KP.
www.yageo.com
Mar. 25, 2021 V.2
RC_P
SERIES
3
10
0100 to 2512
MARKING
RC0100 / RC0201 / RC0402
No Marking
ynsc007
Fig. 1
RC0603
03
Fig. 2
YNSC001
E24 series: 3 digits, 5%
First two digits for significant figure and 3rd digit for number of zeros
Value = 10 KΩ
RC0805 / RC1206 / RC1210 / RC1218 / RC2010 / RC2512
00
Fig. 3
YNSC004
Value = 10 KΩ
E24/E96 series: 4 digits, 1%, 0.5%
First three digits for significant figure and 4th digit for number of zeros
Note
For further marking information, please see special data sheet "Chip resistors marking".
CONSTRUCTION
The resistor is constructed on top of a high-grade
ceramic body. Internal metal electrodes are added
on each end to make the contacts to the thick
film resistive element. The composition of the
resistive element is a noble metal imbedded into a
glass and covered by a second glass to prevent
environmental influences. The resistor is laser
trimmed to the rated resistance value. The
resistor is covered with a protective epoxy
coat, finally the two external terminations (matte
tin on Nibarrier) are added, as shown in Fig.4.
Outlines
For dimensions, please refer to Table 1
marking layer
overcoat
primary glass layer
resistive layer
(Jumper chip is a conductor)
inner electrode
termination(Ni/matte tin)
inner electrode
H
ceramic substrate
I2
overcoat
I1
W
YNSC086
L
Fig. 4 Chip resistor outlines
www.yageo.com
Mar. 25, 2021 V.2
SERIES
RC_P
4
10
0100 to 2512
DIMENSION
Table 1
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
RC0100
0.40±0.02
0.20±0.02
0.13±0.02
0.10±0.03
0.10±0.03
RC0201
0.60±0.03
0.30±0.03
0.23±0.03
0.10±0.05
0.15±0.05
RC0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.25±0.10
RC0603
1.60±0.10
0.80±0.10
0.45±0.10
0.25±0.15
0.25±0.15
RC0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.35±0.20
RC1206
3.10±0.10
1.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
RC1210
3.10±0.10
2.60±0.15
0.55±0.10
0.45±0.15
0.50±0.20
RC1218
3.10±0.10
4.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
RC2010
5.00±0.10
2.50±0.15
0.55±0.10
0.45±0.15
0.50±0.20
RC2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.20
0.50±0.20
ELECTRICAL CHARACTERISTICS
Table 2
CHARACTERISTICS
TYPE POWER
Fig. 4
Operating
Max.
Max.
Dielectric
Temperature Working Overload Withstanding
Range Voltage
Voltage
Voltage
RC0100
1/32W
-55℃ to +125℃
RESISTANCE
RANGE
Temperature Coefficient
of Resistance
Jumper Criteria
E24 ±5%
15V
30V
30V
1Ω ≤ R ≤ 1MΩ 1Ω≤R≤10Ω:-200~+600ppm℃
E24/E96 ± 1%
10Ω
很抱歉,暂时无法提供与“RC0402FR-0722RP”相匹配的价格&库存,您可以联系我们找货
