EMVH250ARA471MKE0S
EMVH250ARA471MKE0S
    NCC(贵弥功)
    SMD,D12.5xL13.5mm
    EMVH250ARA471MKE0S
EMVH250ARA471MKE0S 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MVH - High heat resistance, 125℃ Series ・Lower ESR, Higher ripple current ・Endurance : 1,000 to 5,000 hours at 125℃ ・Suitable to fit for automotive equipment ・Solvent resistant type except 63 to 100Vdc (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MVH 125℃ MVE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 10 to 100Vdc (at 20℃, 120Hz) ±20% (M) F60 to JA0 I=0.01CV or 3µA, whichever is greater. KE0 to MN0 I=0.03CV or 4µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80V 100V F60 to JA0 0.24 0.20 0.16 0.14 0.14 0.12 0.12 0.10 tanδ (Max.) KE0 to MN0 0.22 0.18 0.16 0.14 0.12 0.14 0.10 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80V 100V Z(-25℃)/Z(+20℃) 3 2 2 2 2 2 2 2 F60 to JA0 Z(-40℃)/Z(+20℃) 6 4 4 3 3 3 3 3 Z(-25℃)/Z(+20℃) 4 3 2 2 2 2 2 KE0 to MN0 Z(-40℃)/Z(+20℃) 8 6 4 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for the specified time at 125℃. F60 to H63 (10 to 100Vdc) : 1,000hours Time HA0 to JA0 (10 to 100Vdc) : 2,000hours KE0 to MN0 (10 to 100Vdc) : 5,000hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage(Vdc) 10 to 50Vdc 63 to 100Vdc Capacitance change ≦±30% of the initial value ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦300% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except F80, HA0) 0.3max. L±0.5 (Note) φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.5 (Note) Note : L±0.3 for F80 A±0.2 W B±0.2 Vent (Except F60 to HA0) Code : G(Vibration resistant structure) code : F80, HA0 to MN0 Size code P C±0.2 Code : A code : F60 to MN0 Note : L±0.3 for F60 and F80 A±0.2 : Dummy terminals F60 F80 H63 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 D 6.3 6.3 8 8 10 12.5 12.5 16 16 18 18 L 5.7 7.7 6.3 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 A 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 7.2 7.2 9.0 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.9 1.9 2.3 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MV H AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 10µF:100,470µF:471) Taping·Tray code Terminal code (A, G) Voltage code (ex. 10V:100,50V:500, 100V: 101) Series code Category ◆MARKING F60 to JA0 EX) 35V47µF 74H 47 35V KE0 to MN0 EX) 16V1,000µF 0V MVH 1000 16V Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001W 2022 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MVHSeries - ◆STANDARD RATINGS WV Cap (Vdc) (µF) Size code ESR Rated ripple (Ω max./ current 100kHz) (mArms/125℃) F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 LH0 MH0 MH0 MN0 F60 HA0 HA0 JA0 JA0 KE0 KE0 LH0 MH0 MH0 F60 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 KE0 LH0 LH0 MH0 MN0 F60 F60 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 LH0 KG5 LH0 MH0 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.10 0.10 0.10 0.058 1.6 0.40 0.40 0.30 0.30 0.14 0.14 0.10 0.10 0.10 1.6 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.14 0.10 0.10 0.10 0.058 1.6 1.6 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.10 0.11 0.10 0.10 WV Cap (Vdc) (µF) Part No. Size code ESR Rated ripple (Ω max./ current 100kHz) (mArms/125℃) F60 H63 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 KE0 LH0 KG5 LH0 MH0 F80 H63 HA0 HA0 JA0 HA0 JA0 KE0 KG5 LH0 LN0 HA0 HA0 JA0 HA0 JA0 JA0 HA0 HA0 JA0 JA0 KE0 KG5 LH0 MN0 2.8 1.6 2.0 1.6 2.0 1.6 0.70 0.70 0.50 0.50 0.23 0.23 0.15 0.18 0.15 0.15 2.0 2.0 0.70 0.70 0.50 0.70 0.50 0.25 0.20 0.18 0.11 0.75 0.75 0.55 0.75 0.55 0.55 0.75 0.75 0.55 0.55 0.33 0.26 0.24 0.16 20℃ -40℃ 100kHz 120Hz 10 16 25 35 100 100 220 220 220 330 330 470 1,000 2,200 2,200 3,300 4,700 47 100 220 220 330 470 680 680 1,000 2,200 33 47 47 100 100 100 220 220 330 330 470 470 680 680 1,000 10 22 33 33 47 47 47 100 100 220 330 330 470 470 680 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 1.5 1.5 1.5 0.87 24.0 6.0 6.0 4.5 4.5 2.1 2.1 1.5 1.5 1.5 24.0 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 2.1 1.5 1.5 1.5 0.87 24.0 24.0 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 1.5 1.5 1.5 1.5 110 110 110 110 220 220 296 296 750 1,000 1,200 1,200 1,550 69 220 220 296 296 750 750 1,000 1,200 1,200 69 110 110 110 110 220 220 296 296 750 750 1,000 1,000 1,200 1,550 69 69 110 110 110 110 220 220 296 296 750 1,000 900 1,000 1,200 − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − Part No. 20℃ -40℃ 100kHz 120Hz EMVH100□RA101MF80G EMVH100ARA101MH63G EMVH100□RA221MF80G EMVH100ARA221MH63G EMVH100□RA221MHA0G EMVH100□RA331MHA0G EMVH100□RA331MJA0G EMVH100□RA471MJA0G EMVH100□RA102MKE0S EMVH100□RA222MLH0S EMVH100□RA222MMH0S EMVH100□RA332MMH0S EMVH100□RA472MMN0S EMVH160ARA470MF60G EMVH160□RA101MHA0G EMVH160□RA221MHA0G EMVH160□RA221MJA0G EMVH160□RA331MJA0G EMVH160□RA471MKE0S EMVH160□RA681MKE0S EMVH160□RA681MLH0S EMVH160□RA102MMH0S EMVH160□RA222MMH0S EMVH250ARA330MF60G EMVH250□RA470MF80G EMVH250ARA470MH63G EMVH250□RA101MF80G EMVH250ARA101MH63G EMVH250□RA101MHA0G EMVH250□RA221MHA0G EMVH250□RA221MJA0G EMVH250□RA331MJA0G EMVH250□RA331MKE0S EMVH250□RA471MKE0S EMVH250□RA471MLH0S EMVH250□RA681MLH0S EMVH250□RA681MMH0S EMVH250□RA102MMN0S EMVH350ARA100MF60G EMVH350ARA220MF60G EMVH350□RA330MF80G EMVH350ARA330MH63G EMVH350□RA470MF80G EMVH350ARA470MH63G EMVH350□RA470MHA0G EMVH350□RA101MHA0G EMVH350□RA101MJA0G EMVH350□RA221MJA0G EMVH350□RA331MKE0S EMVH350□RA331MLH0S EMVH350□RA471MKG5S EMVH350□RA471MLH0S EMVH350□RA681MMH0S 50 *1 63 *1 80 *1 100 10 10 22 22 33 33 33 47 47 100 100 220 220 330 330 470 10 10 22 33 33 47 47 100 220 330 470 10 22 22 33 33 47 10 22 22 33 47 68 100 220 42.0 51 30.0 83 30.0 83 30.0 83 30.0 83 30.0 83 11.0 160 11.0 160 7.5 247 7.5 247 3.5 550 3.5 550 2.3 850 2.7 700 2.3 850 2.3 920 100 60 110 60 35.0 100 35.0 100 25.0 170 35.0 100 25.0 170 12.5 500 10.0 600 9.0 820 5.5 1,100 50.0 70 50.0 70 35.0 115 50.0 70 35.0 115 35.0 115 50.0 70 50.0 70 35.0 115 35.0 115 16.5 450 13.0 550 12.0 650 8.0 950 − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − EMVH500ARA100MF60G EMVH500ARA100MH63G EMVH500□RA220MF80G EMVH500ARA220MH63G EMVH500□RA330MF80G EMVH500ARA330MH63G EMVH500□RA330MHA0G EMVH500□RA470MHA0G EMVH500□RA470MJA0G EMVH500□RA101MJA0G EMVH500□RA101MKE0S EMVH500□RA221MKE0S EMVH500□RA221MLH0S EMVH500□RA331MKG5S EMVH500□RA331MLH0S EMVH500□RA471MMH0S EMVH630□RA100MF80G EMVH630ARA100MH63G EMVH630□RA220MHA0G EMVH630□RA330MHA0G EMVH630□RA330MJA0G EMVH630□RA470MHA0G EMVH630□RA470MJA0G EMVH630□RA101MKE0S EMVH630□RA221MKG5S EMVH630□RA331MLH0S EMVH630□RA471MLN0S EMVH800□RA100MHA0G EMVH800□RA220MHA0G EMVH800□RA220MJA0G EMVH800□RA330MHA0G EMVH800□RA330MJA0G EMVH800□RA470MJA0G EMVH101□RA100MHA0G EMVH101□RA220MHA0G EMVH101□RA220MJA0G EMVH101□RA330MJA0G EMVH101□RA470MKE0S EMVH101□RA680MKG5S EMVH101□RA101MLH0S EMVH101□RA221MMN0S □ : Enter the appropriate terminal code. are not recommended for new designs (NRND). The products shown in *1: Assembly boards with the designated products attached cannot be cleaned. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Size code F60 to JA0 KE0 to MN0 Capacitance(µF) Frequency(Hz) 10 22 to 470 47 to 100 220 to 470 680 to 1,000 2,200 to 3,300 4,700 120 0.66 0.93 0.40 0.50 0.60 0.75 0.85 1k 0.86 0.97 0.75 0.85 0.87 0.90 0.95 10k 0.93 1.00 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 1.00 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001W 2022
EMVH250ARA471MKE0S 价格&库存
很抱歉,暂时无法提供与“EMVH250ARA471MKE0S”相匹配的价格&库存,您可以联系我们找货
