FN 350 -30 -33
FN 350 -30 -33
    SCHAFFNER(夏弗纳)
    FN 350 -30 -33
FN 350 -30 -33 数据手册
DATA SHEET Standard Performance Single-Phase Filters FN350 Compact EMC/RFI Filter for Motor Drives Compact filter solution for single-phase motor drive applications Approvals & Compliances Industrial grade safety terminal blocks Designed to meet EN 55011/14/22 Compliant with IEC 60950 Features and Benefits Performance indicators High component values optimized for common and differential-mode attenuation in the lower frequency range makes this filter ideal for a large variety of single-phase motor drive applications Supplied in a relatively small housing design with safety terminal blocks for fast and easy installation in primarily industrial environments FN 350 also meets IEC 60950 requirements, thus providing additional application flexibility Typical Applications Single-phase motor drives Automation equipment Power supplies, SMPS Office equipment Technical Specifications Testing and measurements equipment Maximum continuous operating voltage 1x 250 VAC Operating frequency DC to 400 Hz Rated currents 8 to 55 A @ 40°C max High potential test voltage P –> E 2000 VAC for 2 sec P –> N 1100 VDC for 2 sec Protection category IP 20 Overload capability 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour Temperature range (operation and storage) -25°C to +100°C (25/100/21) Flammability corresponding to UL 94 V-2 or better Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 MTBF @ 40°C/230 V (Mil-HB-217F) 420,000 hours Typical electrical schematic 2 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 05. Jul 2022 Filter Selection Table Filter Rated current Leakage current* Power loss Input/Output @ 40°C (25°C) @ 230 VAC/50 Hz @ 25°C/50 Hz connections [A] [mA] [W] FN 350-8-29 8 (9.0) 4.9 5.2 -29 0.7 FN 350-12-29 12 (13.5) 4.9 5.7 -29 0.7 FN 350-20-29 20 (22.4) 4.9 6.1 -29 0.7 FN 350-30-33 30 (33.6) 5.4 6.1 -33 FN 350-55-.. 55 (61.5) 11.0 9.9 -33 [kg] 0.7 -24 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Typical Filter Attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 8 A types 12 A types 20 and 30 A types Weight 55 A types 1.2 3 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET Mechanical Data 8 to 30 A types 55 A types (terminal -33) 55 A types (terminal -24) Dimensions 8A 12 A 20 A 30 A 55 A (-33) 55 A (-24) A 99.5 99.5 99.5 99.5 180 180 B 105 105 105 105 115 115 C 57 57 57 57.6 60 60 D 84.4 84.4 84.4 84.4 85 85 E 51 51 51 51 115 115 F 95 95 95 95 100 100 G 6 x 4.4 6 x 4.4 6 x 4.4 6 x 4.4 6.5 6.5 H 0.6 0.6 0.6 1.2 1 1 I 19.5 19.5 19.5 25 25 23.7 J M6 M6 M6 M6 M6 M6 K 18 18 18 16 12.9 12.9 L 16 16 16 19 18.3 17 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Filter Input/Output Connector Cross Sections -29 -33 Solid wire 6 mm2 16 mm2 Flex wire 4 mm2 10 mm2 AWG type wire AWG 10 AWG 6 Recommended torque 0.6-0.8 Nm 1.5-1.8 Nm Please visit www.schaffner.com to find more details on filter connectors. -24 (M6) 3.5-4.0 Nm 05. Jul 2022 4 Standard Performance Single-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 05. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN 350 -30 -33 价格&库存
很抱歉,暂时无法提供与“FN 350 -30 -33”相匹配的价格&库存,您可以联系我们找货
