TJ-L3FYTLDRMFCSFLC2R-A5
    TOGIALED(台湾统佳)
    插件,D=3mm
    发光二极管/LED 红色 插件,D=3mm 620nm~630nm 500mcd
TJ-L3FYTLDRMFCSFLC2R-A5 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 承 認 書 Specification For Approval Customer: (客戶) Description: (產品描述) 3MM圓頭霧狀紅髮紅燈珠 Part number:(產品型號) TJ-L3FYTLDRMFCSFLC2R-A5 Date: (日期) Approved By: (客戶承認) Prepared By:(我司承認) Approval 核准 Check Design 審核 製作 Sales 業務 Customer Service Hotline:400-676-8616 TEL:0769-8662 5999 0769-8200 2226 E-MIAL∶dg@togialed.com FAX:0769-8200 2227 WEB:www.togi aled. c om TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 3.8 Features : * Low power consumption * Small efficiency. * Versatile mounting on p.c board or panel. * I.C compatible/ low current requirement. * Package Dimensions: 1 5.3 3 Unit : mm 2.0 18.5 0 .5 2. 54 0.5 pin*2 Note: 1:All dimensions are in millimeters (inches). 2:Tolerance is ±0.25mm (.010”) unless otherwise noted. 3: Specifications are subject to change without notices. 4:This specification is for reference only for one year 2/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Absolute Maximum Ratings at Ta=25℃ Parameter Rating Unit 72 mW Peak Forward Current(1/10 Duty Cycle 0.1ms pulse Width 100 mA Forward Current(IF) 20 mA Reverse Voltage(VR) 5 V Power Dissipation(Pd) Operating Temperature Range -20℃ ~ +80℃ Storage Temperature Range -30℃ ~ +100℃ Lead Soldering Temperature(4.0mm Form Body 260℃ for 5 Seconds ` Electronical / Optical Charateristics at Ta=25℃ Test Condition Parameter Min Tvo Max Unit Luminous Intensity(IV) 200 ----- 500 mcd If=20mA Viewing Angle(2 θ1/2) ----- 45 ----- deg If=20mA The wavelength(λ) 620 —— 630 nm If=20mA Forward Voltage(VF) 1.8 ----- 2.6 V If=20mA ----- 5 µA Vr=5V Reverse Current(IR) Selection Guide : Lens color Chip Material Emittedcolor λp(nm ) Red Diffused AlGaInP 3/8 Red 630 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Selection Guide 0° 10° 20° 30° 光 谱 分布 特 性 曲线 Relative Spectral Distribution 1. 2 1. 0 40° 0. 8 1.0 50° 0. 6 60° 0. 4 0.8 70° 0. 2 80° 90° 0 350 400 450 500 550 600 650 700 750 0 0.5 波 长( Wavelength ) (nm ) SPATIAL DISTRIBUTION 2.5 Luminous Intensity Relative Volue at IF=20mA Forward Current(mA) 50 40 30 20 10 0 2.0 1.5 1.0 0.5 0 1.5 1.7 1.9 2.1 2.3 2.5 0 10 20 30 40 50 Forward Voltage(V) IF-Forward Current(mA) FORWARD CURRENT Vs. FORWARD VOLTAGE LUMINOUS INTENSITY Vs. FORWARD CURRENT Relative Luminous Intensity 50 Forward Current(mA) 相 对 光 强 ( Relativ e Lu mino us In ten s ity ) ( % ) Typical Electrical/Optical Characteristics Curves(25℃ Ambient Temperature Unle 40 30 20 10 2.5 2.0 1.5 1.0 0.5 0 0 0 20 40 60 80 -40 100 Ambient Temperature(° C) -20 0 20 40 60 Ambient Temperature(° C) FORWARD CURRENT DERATING CURVE LUMINOUS INTENSITY Vs. AMBIENT TEMPARATURE 4/8 80 90 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Labe P/N: The product model IV: Luminous intensity rank VF: Forward voltage rank TC: Color temperature Q`T: number QC: Production order The packing Desiccant Aluminum moisture-proof bag The cardboard Package specification: Package Method: packaged in anti-static bag White:Packaged in sorted light and color 2000pcs/bag note: General light 2000pcs/bag Package specification mentioned above is under normal circumstance. Specific demand can be negotiated 5/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Supporter shaping: Shaping of the supporter must be conducted before welding. While shaping, the bending position of the supporter must at least be located at 3mm from the bottom of the encapsulating resin. Also, avoid multiple bending on the same position。Please choose the appropriate apparatus to fixate the supporter in order to avoid exerting extra pressure on resin. Using the jointing section of the pin and resin as fulcrum is strictly prohibited since the pressure mounted would directly damage the internal 。illuminating structure and thus cause irreversible defection of the product..Due to the same reason, the interval between the welding hole on the PCB board should be strictly matched with the pin interval of the product when assembling the product. 6/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Reliability experiment items and conditions Serial number 1 Sample quantity Acceptance/rejection 20 0/1 20 0/1 -40℃- +100℃ 20min 10s 20min Testing time;100 cycle 20 0/1 High temperature;100℃ 20 0/1 20 0/1 -40℃-- +100℃ 60min 20min 60min Testing time;20 A cycle 20 0/1 260℃(Max), The biggest not more than 5 seconds 20 0/1 Testing project Test conditions Life test Test current;20MA temperature;25℃ Testing time;1000 hours 2 3 High temperature high humidity (static test) Cold and hot impact temperature;=+65℃ humidity;90% RH Testing time;240 hours High temperature 4 storage Testing time;1000 hours 5 6 7 Low temperature Low temperature;-40℃ storage Testing time;1000 hours temperature cycle Reflow soldering note Reliability experiment unqualified decision criteria IV; Attenuation of more than 30% VF; Change more than 20% ; 1. The same project experimental results of the test must be completed within two hours 2. Testing must be in every experiment is completed. Material return to normal conditions to carry out 7/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD ESD protective 1 Electrostatic generation 1;Friction: in the daily life. Any two different material object contact after the separation, can produce a staticelectric,Static electricity and the most common method,Is triboelectrification。The insulation material, the better,More letEasy triboelectrification。In addition,Any two different material object contact after separation,Can also produce electrostatic。 2. Induction: in view of the conductive material is concerned, because the surface of the electronic can free flow, such as placed it in electric fieldbecauseGay repellent,Opposites attract,Are negative ions will transfer, In its surface can produce charge。 3. Transmission: in view of the conductive material is concerned, because the surface of the electronic can free flow,If charged object contact, will be charge transfer. 4. The harm of static electricity LED: .1 For the moment's electric field or the heat generated by the current,Make LED localinjury,For the performance of the leakage current increase quickly,Can stillwork,But the brightness is reduced (white light will change color), life is damaged。 5 Because the electric field or current failure LED insulating layer,Make device can't work (destroyed),Performance for die lamp。 6;Electrostatic protection and elimination measures: a. For the whole process (production, testing, packaging, etc.) All LED directly contact member must do it well Prevent and Eliminate electrostatic measures, basically have: workshop laid anti-static floor and well grounded。 b. Table for esd workstation, the production of the good earth c. Operator wear anti-static clothing, with wrist strap, gloves or foot ring。 d. Application of ion fan, welding solder iron well grounding measures。 e. The package antistatic material 8/8
1. 物料型号:T J-L3FY T LD R M FC SFLC 2R - A 2. 器件简介:文档提到了低功耗、小尺寸、多用途安装在PCB板或面板上、与IC兼容/低电流需求等特点。 3. 引脚分配:文档中提到了2个引脚,但具体的引脚功能没有详细说明。 4. 参数特性: - 功耗:72mW - 峰值正向电流(1/10占空比,0.5ms脉冲宽度):100mA - 正向电流:20mA - 反向电压:5V - 工作温度范围:-20°C ~ +80°C - 存储温度范围:-30°C ~ +100°C - 引脚焊接温度(4.0mm for body):260°C for 5 seconds 5. 功能详解:文档提供了电气/光学特性表,包括光强、视场角度、波长、正向电压和反向电流等参数。 6. 应用信息:文档中提供了选择指南,包括不同颜色的透镜和芯片材料。 7. 封装信息:提供了封装尺寸和公差信息,以及包装规格和防静电措施。
TJ-L3FYTLDRMFCSFLC2R-A5 价格&库存
很抱歉,暂时无法提供与“TJ-L3FYTLDRMFCSFLC2R-A5”相匹配的价格&库存,您可以联系我们找货
  • 20+0.13780
  • 200+0.11286
  • 600+0.09902
  • 2000+0.08044
  • 10000+0.07316
  • 20000+0.06926
库存:55768
  • 20+0.12631
  • 200+0.10345
  • 800+0.09076
  • 2000+0.07374
  • 10000+0.06706
库存:12268
  • 1+0.16940
  • 50+0.08426
  • 2000+0.06380
库存:5
