ST10UC1
ST10UC1
    SWITCHCRAFT
    ST10UC1
ST10UC1 数据手册
HANDLE FLEX RELIEF 2.71 68.8 0.076 1.93 PIN REF 5/16-32 THREAD REF 0.75 19.1 2.39 60.6 0.230 [5.84] I.D. CABLE RANGE 0.220 - 0.51 12.9 0.330 I.D. 8.38 0.076 1.93 PIN REF 1.96 49.8 0.297 I.D. 7.54 FLEX RELIEF ST10U STYLE POWER JACK 0.076 1.93 PIN REF 1.96 49.8 ST10U STYLE POWER JACK 0.076 1.93 PIN REF 0.75 19.1 2.39 60.6 0.50 12.7 0.51 12.9 ST10UC HANDLE 2.71 68.8 1.64 41.5 1.64 41.5 0.250 [5.59 - 6.35] ST10UCFL T 10581 280 STYLE HANDLE ST10U STYLE POWER JACK HANDLE ST10U STYLE POWER JACK 0.200 [5.08] I.D. CABLE RANGE 0.190 - 0.51 12.9 0.220 [4.83 - 5.59] ST10UCF ST10UC1 B CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. NOTES: UNLESS OTHERWISE SPECIFIED 1. PARTS ARE SHIPPED UNASSEMBLED. 1. ALL DIMENSIONS IN INCHES [mm] 2. THESE ASSEMBLIES ARE RoHS COMPLIANT. 3. SEE SHEET 2 FOR SPECIFICATIONS. SIZE - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] 02-21-22 PC TJK DATE DRAWN A ECO 27926 8-17-17 SRC TJK 12-21-16 DATE REVISIONS BY APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER BY SPEC No. SCALE CHKD SRC SRC 12-21-16 0.85:1 APVD TJK 8-17-17 CABLE POWER JACK, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON 28475 ECO NUMBER MULT FINISH B REV WIDTH SHEET PART No. 1 OF ST10UC SERIES 2 REV B Mechanical Specifications Life: Mechanical only Vibration: Operating Forces: 5000 cycles minimum using S10 style plugs Mil-Std 202G Method 201A (jack or when mated with locking plug) 3 lb maximum insertion. 0.2 lb minimum withdrawal when using S10 type plug Electrical Specifications Voltage Rating: Current Rating: Insulation Resistance: Contact Resistance (initial): 24 V AC/DC Refer to current rating table below 1000MΩ min. initial 10 mΩ max Operating Temperature Rating: Insulation Resistance Thermal Shock: -40 °C to +105 °C(-40ºF to +221°F) MIL-STD 202G Method 302 Condition B Only) MIL-STD 202G Method 107G (jack or when mated with sealed locking plug) Environmental Specifications Material Specifications Handle, Housing: B Flex relief: Insulator: Center Pin: Center & Shunt Terminals: Sleeve Spring Contact: Copper alloy, nickel plated (ST10UC1) Zinc Alloy, nickel plated (ST10UC, ST10UCF, ST10UCFL) Thermoplastic elastomer, black Thermoplastic, black Copper Alloy, Gold over Silver Plated Copper Alloy, Matte Tin Plated Copper Alloy, Gold over Silver Plated CURRENT CARRY WHEN MATED TO A S10 STYLE PLUG Wire (awg) 16 18 20 Current Rating (Amps) at Operating Temperature (º C) 90º C max 13 12 11 95º C max 12 11 10 100º C max 11 10 9 105º C max 10 9 8 Note: AC/DC Power Plugs & Jacks are for current carry only. Do not connect or disconnect under load. The circuitry on-off switch should be off before connecting or disconnecting the Power Plug to Jack. CUSTOMER DRAWING SCALE 1:1 DATE DRAWN 12-21-16 DRAWN BY SHEET PART No. OF ST10UC SERIES SRC SolidWorks CAD File 2 B 2 REV B
ST10UC1 价格&库存
很抱歉,暂时无法提供与“ST10UC1”相匹配的价格&库存,您可以联系我们找货
