1N914BWS RRG
1N914BWS RRG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD323F
    1N914BWS RRG
1N914BWS RRG 数据手册
1N4148WS/1N4448WS/1N914BWS Taiwan Semiconductor 200mW High Speed SMD Switching Diode FEATURES ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT VRRM 100 V VF at IF = 100mA 1 V TJ 150 °C Package SOD-323F Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● Case: SOD-323F Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 4.85mg (approximately) SOD-323F ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Power dissipation 1N4148WS 1N4448WS 1N914BWS S1 S2 UNIT S3 PD 200 mW VRRM 100 V IF 150 mA IFRM 300 mA Junction temperature range TJ -65 to +150 °C Storage temperature range TSTG -65 to +150 °C Repetitive peak reverse voltage Forward current Non-repetitive peak forward current 1 Version: M2106 1N4148WS/1N4448WS/1N914BWS Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 625 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) 1N4448WS 1N914BWS IF = 5 mA, TJ = 25°C 1N4148WS IF =10 mA, TJ = 25°C 1N4448WS 1N914BWS IF =100 mA, TJ = 25°C IR = 5µA, TJ = 25°C Reverse voltage IR = 100µA, TJ = 25°C Reverse current @ rated VR (2) Junction capacitance Reverse recovery time VR = 20V, TJ = 25°C VR = 75V, TJ = 25°C 1MHz, VR = 0V IF = 10mA, IR = 60mA, RL = 100Ω, IRR = 1mA SYMBOL MIN MAX UNIT 0.62 0.72 V - 1.00 V - 1.00 V 75 - V 100 - V - 25 nA - 5 µA CJ - 4 pF trr - 4 ns VF VR IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING 1N4148WS RRG SOD-323F 3K / 7" Reel 1N4148WS RR SOD-323F 3K / 7" Reel 1N4148WS R9G SOD-323F 10K / 13" Reel 1N4148WS R9 SOD-323F 10K / 13" Reel 1N4448WS RRG SOD-323F 3K / 7" Reel 1N4448WS RR SOD-323F 3K / 7" Reel 1N4448WS R9G SOD-323F 10K / 13" Reel 1N4448WS R9 SOD-323F 10K / 13" Reel 1N914BWS RRG SOD-323F 3K / 7" Reel 1N914BWS RR SOD-323F 3K / 7" Reel 1N914BWS R9G SOD-323F 10K / 13" Reel 1N914BWS R9 SOD-323F Notes: 1. “G” means green compound (halogen-free according to IEC 61249-2-21) 2 10K / 13" Reel Version: M2106 1N4148WS/1N4448WS/1N914BWS Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Voltage VS. Forward Current Fig.2 Reverse Current vs Reverse Voltage 100 1.4 1 25°C 0.8 0.6 0.4 10 Reverse Current (uA) Forward Voltage (V) 1.2 125°C 1 0.1 0.2 0 0.01 0.01 0.1 1 10 100 1000 0 20 40 Forward Current (mA) 80 120 Fig.4 Typical Junction Capacitance 1.2 10 250 10 TJ=125°C 0.1 TJ=25°C 100 0.01 50 1.0 UF1DLW TJ=125°C TJ=25°C 0.90.1 (A) 150 1 (A) UF1DLW 1 Junction Capacitance (pF) 1.1 200 0.8 0.01 0.7 Pulse width Pulse width 0.001 0 100 Reverse Volatge (V) Fig.3 Admissible Power Dissipation Curve Power Dissipation (mW) 60 0.3 0 0.4 25 0.5 0.6 0.7 0.8 50 75 100 0.9 125 1 1.1 150 1.2 Ambient Temperature (°C) 0.001 0.6 0.3 0.4 0 1 2 0.5 3 0.6 4 0.7 0.8 5 6 7 0.9 8 9 1 10 1.1 Reverse Voltage (V) 3 Version: M2106 1.2 1N4148WS/1N4448WS/1N914BWS Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-323F SUGGESTED PAD LAYOUT 4 Version: M2106 1N4148WS/1N4448WS/1N914BWS Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: M2106
1N914BWS RRG 价格&库存
很抱歉,暂时无法提供与“1N914BWS RRG”相匹配的价格&库存,您可以联系我们找货
1N914BWS RRG
  • 1+0.877571+0.11274
  • 10+0.5857510+0.07525
库存:55
1N914BWS RRG
  • 1+0.878371+0.11284
  • 10+0.5862910+0.07532
库存:55
