D65ZOV321RA160
D65ZOV321RA160
    MAIDA
    插件
D65ZOV321RA160 数据手册
STANDARD SERIES INTRODUCTION The Standard Series is our broadest and most comprehensive line of radial-leaded varistors. These components consist of wire leads and have nominal disk diameters from 5mm to 25mm. They are available with maximum continuous operating voltages (MCOV) ranging from 11VAC to 1000VAC (up to 1500VAC upon request). The Standard Series is designed to handle most low and medium power applications requiring throughhole components. Most sizes are available in Tape and Reel and ammo pack. STYLE DESIGNATION The Maida Style Number is the typical means to identify our components when ordered. The style number identifies several parameters that are important for the characteristics of the device. An alternative ordering method, if known, is by our Item Number. The Item Number is a unique designation for each MOV design, whereas numerous MOV designs may be made with the same Maida Style Number. The following example is the standard part numbering system when ordering our Standard Series components by the Maida Style Number: STANDARD MARKING Minimum marking shall consist of an abbreviated style designation and, when space is available, the manufacturer’s initials or company logo. For example: MDC Z131 20UL Where: MDC - Company Initials ZZinc Oxide Varistor 131 - AC Voltage rating (130VAC) 20 Rating code UL UL recognition, if applicable A manufacturing date code and/or special markings are available upon request. Other safety agency designations are included where applicable. D 65 21 ZOV 131 RA 20 T1N 1. 2. Coating Designation D – Epoxy Coating P – Phenolic Coating Neither – Denotes no conformal coating. Nominal Disk Diameter 58 – 5mm 69 – 14mm 73 – 7mm 64 – 16mm 68 – 8mm 63 – 18mm 61 – 10mm 65 – 20mm 71 – 11mm 66 – 25mm 62 – 12mm 3. Lead Configuration (Refer to lead codes) 4. Material Identifier Zinc Oxide Varistor 5. AC Voltage Rating Two significant figures plus number of zeroes that follow, i.e. 131 is 130 VAC 6. Special Instructions, RA is standard 7. Rating Code, up to four numbers 8. Optional Taping Code T – Tape & Reel, Tape & Ammo Followed by up to two digit alphanumeric T D H Lead Length d NOM. X Z Maida Development Company - sales@maida.com - (757) 723-0785 – www.maida.com Y STANDARD SERIES ELECTRICAL SPECIFICATIONS Continuous Maida Style Number D58ZOV110RA00 D73ZOV110RA01 D6121ZOV110RA02 D6921ZOV110RA04 D6521ZOV110RA10 D58ZOV140RA00 D73ZOV140RA01 D6121ZOV140RA02 D6921ZOV140RA04 D6521ZOV140RA13 D58ZOV170RA00 D73ZOV170RA01 D6121ZOV170RA03 D6921ZOV170RA05 D6521ZOV170RA15 D58ZOV200RA00 D73ZOV200RA01 D6121ZOV200RA03 D6921ZOV200RA06 D6521ZOV200RA20 D58ZOV250RA01 D73ZOV250RA02 D6121ZOV250RA04 D6921ZOV250RA07 D6521ZOV250RA24 D58ZOV300RA01 D73ZOV300RA02 D6121ZOV300RA05 D6921ZOV300RA09 D6321ZOV300RA26 D6521ZOV300RA30 D58ZOV350RA01 D73ZOV350RA02 D6121ZOV350RA06 D6921ZOV350RA10 D6521ZOV350RA35 D58ZOV400RA01 D73ZOV400RA03 D6121ZOV400RA07 D6921ZOV400RA12 D6521ZOV400RA40 D58ZOV500RA01 D73ZOV500RA02 D6121ZOV500RA03 D7121ZOV500RA04 D6221ZOV500RA05 D6921ZOV500RA06 D6521ZOV500RA42 D58ZOV600RA01 D73ZOV600RA02 D6121ZOV600RA03 D7121ZOV600RA04 D6221ZOV600RA05 D6921ZOV600RA06 D6521ZOV600RA45 D58ZOV750RA01 D73ZOV750RA02 D6121ZOV750RA03 D7121ZOV750RA04 D6221ZOV750RA05 D6921ZOV750RA06 D6521ZOV750RA55 D58ZOV950RA01 D73ZOV950RA02 D6121ZOV950RA03 D7121ZOV950RA04 D6221ZOV950RA05 D6921ZOV950RA06 D6521ZOV950RA65 Recognitions To Nominal Safety Size Agency Standards A B C D E F (mm) X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X 18 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X 11 X X 12 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X 11 X X 12 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X 11 X X 12 X X X 14 X X X 20 X X X 5 X X X 7 X X X 10 X X 11 X X 12 X X X 14 X X X 20 Minimum Marking Z110 - 00UL Z110 - 01UL Z110 - 02UL Z110 - 04UL Z110 - 10UL Z140 - 00UL Z140 - 01UL Z140 - 02UL Z140 - 04UL Z140 - 13UL Z170 - 00UL Z170 - 01UL Z170 - 03UL Z170 - 05UL Z170 - 15UL Z200 - 00UL Z200 - 01UL Z200 - 03UL Z200 - 06UL Z200 - 20UL Z250 - 01UL Z250 - 02UL Z250 - 04UL Z250 - 07UL Z250 - 24UL Z300 - 01UL Z300 - 02UL Z300 - 05UL Z300 - 09UL Z300 - 26UL Z300 - 30UL Z350 - 01UL Z350 - 02UL Z350 - 06UL Z350 - 10UL Z350 - 35UL Z400 - 01UL Z400 - 03UL Z400 - 07UL Z400 - 12UL Z400 - 40UL Z500 - 01UL Z500 - 02UL Z500 - 03UL Z500 - 04UL Z500 - 05UL Z500 - 06UL Z500 - 42UL Z600 - 01UL Z600 - 02UL Z600 - 03UL Z600 - 04UL Z600 - 05UL Z600 - 06UL Z600 - 45UL Z750 - 01UL Z750 - 02UL Z750 - 03UL Z750 - 04UL Z750 - 05UL Z750 - 06UL Z750 - 55UL Z950 - 01UL Z950 - 02UL Z950 - 03UL Z950 - 04UL Z950 - 05UL Z950 - 06UL Z950 - 65UL Applied Voltage (AC) 11 11 11 11 11 14 14 14 14 14 17 17 17 17 17 20 20 20 20 20 25 25 25 25 25 30 30 30 30 30 30 35 35 35 35 35 40 40 40 40 40 50 50 50 50 50 50 50 60 60 60 60 60 60 60 75 75 75 75 75 75 75 95 95 95 95 95 95 95 (DC) 14 14 14 14 14 18 18 18 18 18 22 22 22 22 22 26 26 26 26 26 31 31 31 31 31 38 38 38 38 38 38 45 45 45 45 45 56 56 56 56 56 66 66 66 66 66 66 66 81 81 81 81 81 81 81 102 102 102 102 102 102 102 127 127 127 127 127 127 127 Maximum Ratings Transient Energy 10 x 1000 μsec (J) 0.6 1.1 2.6 5.2 13 0.7 1.3 3.2 6.3 16 0.9 1.6 3.9 7.8 19 1.1 2 4.8 9.5 24 1.2 2.4 5.6 11 28 1.5 2.8 6.8 14 26 34 1.8 3.4 8.1 16 41 2.2 5.2 13 20 49 3.5 7 14 19 22 28 56 4.5 9 18 20 22 36 72 5.5 11 22 22 27 44 88 6.6 13 25 28 33 53 106 8 x 20 μsec (J) 0.6 1.1 2.6 5.2 13 0.7 1.3 3.2 6.3 16 0.9 1.6 3.9 7.8 19 1.1 2 4.8 9.5 24 1.2 2.4 5.6 11 28 1.5 2.8 6.8 14 26 34 1.8 3.4 8.1 16 41 2.2 5.2 13 20 49 3.5 7 14 19 22 28 56 4.5 9 18 20 22 36 72 5.5 11 22 22 27 44 88 6.6 13 25 28 33 53 106 Peak Current 8 x 20 μsec # Pulses 1 2 (A) (A) 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 2500 1500 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 250 125 500 250 1000 500 2000 1000 3000 2000 800 600 1750 1250 3500 2500 4000 2800 4500 3200 6000 5000 10000 7000 800 600 1750 1250 3500 2500 4000 2800 4500 3200 6000 5000 10000 7000 800 600 1750 1250 3500 2500 4000 2800 4500 3200 6000 5000 10000 7000 800 600 1750 1250 3500 2500 4000 2800 4500 3200 6000 5000 10000 7000 Electrical Characteristics Max Varistor Clamping Typical Voltage Voltage Cap. @1 mA DC (@Test Current) 1 V rms (8 x 20μsec) Vmin Vmax @1kHz (V) (V) (V) (A) (pF) 16 20 40 1 2200 16 20 36 2.5 3500 16 20 36 5 7500 16 20 36 10 18000 16 20 36 20 37000 20 24 48 1 2000 20 24 43 2.5 2800 20 24 43 5 6000 20 24 43 10 15000 20 24 43 20 30000 24 30 60 1 1600 24 30 53 2.5 2000 24 30 53 5 4000 24 30 53 10 10000 24 30 53 20 22000 30 36 73 1 1675 30 36 65 2.5 3614 30 36 65 5 6655 30 36 65 10 14447 30 36 65 20 33064 35 43 86 1 1417 35 43 77 2.5 3058 35 43 77 5 5632 35 43 77 10 12225 35 43 77 20 27977 42 52 99 1 1176 42 52 93 2.5 2537 42 52 93 5 4673 42 52 93 10 10144 42 52 93 20 18230 42 52 93 20 23215 50 62 117 1 987 50 62 110 2.5 2130 50 62 110 5 3922 50 62 110 10 8514 50 62 110 20 19484 61 75 138 1 438 61 75 135 2.5 945 61 75 135 5 1627 61 75 135 10 3285 61 75 135 20 7517 74 90 163 5 364 74 90 157 10 767 74 90 147 25 1375 74 90 147 30 1533 74 90 147 40 2602 74 90 147 50 2829 74 90 147 100 5041 90 110 190 5 299 90 110 180 10 629 90 110 175 25 1128 90 110 175 30 1257 90 110 175 40 2133 90 110 175 50 2319 90 110 175 100 5264 108 132 220 5 249 108 132 220 10 524 108 132 210 25 940 108 132 210 30 1048 108 132 210 40 1778 108 132 210 50 1933 108 132 210 100 4387 135 165 240 5 118 135 165 255 10 255 135 165 255 25 469 135 165 255 30 537 135 165 255 40 924 135 165 255 50 1019 135 165 255 100 2331 STANDARD SERIES ELECTRICAL SPECIFICATIONS Continuous Maida Style Number D58ZOV121RA02 D73ZOV121RA03 D68ZOV121RA03 D6121ZOV121RA04 D7121ZOV121RA05 D6221ZOV121RA07 D6921ZOV121RA09 D6321ZOV121RA65 D6521ZOV121RA20 D58ZOV131RA02 D73ZOV131RA03 D68ZOV131RA03 D6121ZOV131RA04 D7121ZOV131RA05 D6221ZOV131RA07 D6921ZOV131RA09 D6321ZOV131RA70 D6521ZOV131RA20 D6694ZOV131RA140 D58ZOV141RA02 D73ZOV141RA03 D68ZOV141RA03 D6121ZOV141RA04 D7121ZOV141RA05 D6221ZOV141RA07 D6921ZOV141RA09 D6321ZOV141RA75 D6521ZOV141RA20 D6694ZOV141RA150 D58ZOV151RA02 D73ZOV151RA03 D68ZOV151RA03 D6121ZOV151RA04 D7121ZOV151RA05 D6221ZOV151RA07 D6921ZOV151RA09 D6321ZOV151RA80 D6521ZOV151RA20 D6694ZOV151RA160 D58ZOV181RA02 D73ZOV181RA03 D68ZOV181RA03 D6121ZOV181RA04 D6221ZOV181RA07 D6921ZOV181RA09 D6321ZOV181RA100 D6521ZOV181RA20 D6694ZOV181RA200 D58ZOV211RA07 D73ZOV211RA18 D61ZOV211RA30 D62ZOV211RA45 D69ZOV211RA65 D63ZOV211RA100 D65ZOV211RA110 D6694ZOV211RA220 D58ZOV231RA08 D73ZOV231RA20 D61ZOV231RA35 D62ZOV231RA50 D69ZOV231RA70 D63ZOV231RA80 D65ZOV231RA115 D6694ZOV231RA230 Recognitions To Nominal Minimum Safety Size Marking Agency Standards A B C D E F (mm) X X X 5 Z121 - 02UL X X X 7 Z121 - 03UL X X X 8 Z121 - 03UL8 X X 10 Z121 - 04UL X X 11 Z121 - 05UL X X 12 Z121 - 07UL X X X 14 Z121 - 09UL X X 18 Z121 - 65UL X X X 20 Z121 - 20UL X X X 5 Z131 - 02UL X X X 7 Z131 - 03UL X X 8 Z131 - 03UL8 X X X 10 Z131 - 04UL X X 11 Z131 - 05UL X X 12 Z131 - 07UL X X X 14 Z131 - 09UL X X 18 Z131 - 70UL X X X 20 Z131 - 20UL X X X 25 Z131 - 140UL X X X 5 Z141 - 02UL X X X 7 Z141 - 03UL X X 8 Z141 - 03UL8 X X X 10 Z141 - 04UL X X 11 Z141 - 05UL X X 12 Z141 - 07UL X X X 14 Z141 - 09UL X X 18 Z141 - 75UL X X X 20 Z141 - 20UL X X X 25 Z141 - 150UL X X X 5 Z151 - 02UL X X X 7 Z151 - 03UL X X 8 Z151 - 03UL8 X X X 10 Z151 - 04UL X X 11 Z151 - 05UL X X 12 Z151 - 07UL X X X 14 Z151 - 09UL X X 18 Z151 - 80UL X X X 20 Z151 - 20UL X X X 25 Z151 - 160UL X X X 5 Z181 - 02UL X X X 7 Z181 - 03UL X X 8 Z181 - 03UL8 X X X 10 Z181 - 04UL X X 12 Z181 - 07UL X X X 14 Z181 - 09UL X X 18 Z181 - 100UL X X X 20 Z181 - 20UL X X X 25 Z181 - 200UL X X X 5 Z211 - 07UL X X X 7 Z211 - 18UL X X X 10 Z211 - 30UL X X 12 Z211 - 45UL X X X 14 Z211 - 65UL X X 18 Z211 - 100UL X X X 20 Z211 - 110UL X X X 25 Z211 - 220UL X X X 5 Z231 - 08UL X X X 7 Z231 - 20UL X X X 10 Z231 - 35UL X X 12 Z231 - 50UL X X X 14 Z231 - 70UL X X 18 Z231 - 80UL X X X 20 Z231 - 115UL X X X 25 Z231 - 230UL Applied Voltage (AC) 120 120 120 120 120 120 120 120 120 130 130 130 130 130 130 130 130 130 130 140 140 140 140 140 140 140 140 140 140 150 150 150 150 150 150 150 150 150 150 180 180 180 180 180 180 180 180 180 210 210 210 210 210 210 210 210 230 230 230 230 230 230 230 230 (DC) 160 160 160 160 160 160 160 160 160 175 175 175 175 175 175 175 175 175 175 180 180 180 180 180 180 180 180 180 180 200 200 200 200 200 200 200 200 200 200 230 230 230 230 230 230 230 230 230 270 270 270 270 270 270 270 270 300 300 300 300 300 300 300 300 Maximum Ratings Transient Energy 10 x 1000 μsec (J) 8 16 19 33 36 41 52 65 130 8.5 17.5 27 45 48 53 70 130 150 170 9 20 30 50 54 59 78 135 160 180 10.5 21 30 55 58 64 84 140 170 190 11 24 32 60 62 100 150 190 200 13 28 58 66 120 185 230 250 16 32 65 70 135 215 270 280 8 x 20 μsec (J) 8 16 19 33 36 41 52 65 130 8.5 17.5 27 45 48 53 70 130 150 170 9 20 30 50 54 59 78 135 160 180 10.5 21 30 55 58 64 84 140 170 190 11 24 32 60 62 100 150 190 200 13 28 58 66 120 185 230 250 16 32 65 70 135 215 270 280 Peak Current 8 x 20 μsec Electrical Characteristics Max Varistor Clamping Typical Voltage Voltage Cap. @1 mA DC (@Test Current) # Pulses 1 (A) 800 1750 2500 3500 4000 4500 6000 7500 10000 800 1750 2300 3500 4000 4500 6500 9000 12000 18000 800 1750 2400 3500 4000 4500 6500 9000 12000 18000 800 1750 2300 3500 4000 4500 6500 9000 12000 18000 800 1750 2400 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 2 Vmin (A) (V) 600 170 1250 170 1700 170 2500 170 2800 170 3200 170 5000 170 6500 170 7000 170 600 184 1250 184 1500 184 2500 184 2800 184 3200 184 5000 184 7000 184 9000 184 13000 184 600 198 1250 198 1700 198 2500 198 2800 198 3200 198 5000 198 7000 198 9000 198 13000 198 600 212 1250 212 1700 212 2500 212 2800 212 3200 212 5000 212 7000 212 9000 212 13000 212 600 255 1250 255 1700 255 2500 255 3200 255 5000 255 6000 255 7000 255 9000 255 600 297 1250 297 2500 297 3200 297 4500 297 6000 297 6500 297 9000 297 600 326 1250 326 2500 326 3200 326 4500 326 6000 326 6500 326 9000 326 Vmax (V) 207 207 207 207 207 207 207 207 207 224 224 224 224 224 224 224 224 224 224 242 242 242 242 242 242 242 242 242 242 259 259 259 259 259 259 259 259 259 259 311 311 311 311 311 311 311 311 311 363 363 363 363 363 363 363 363 397 397 397 397 397 397 397 397 (8 x 20μsec) (V) 310 320 320 320 320 320 320 320 320 350 340 340 340 340 340 340 340 340 340 380 360 360 360 360 360 360 360 360 360 430 395 395 395 395 395 395 395 395 395 510 445 445 465 465 465 465 465 465 545 545 545 545 545 545 545 545 595 595 595 595 595 595 595 595 (A) 5 10 15 25 30 40 50 100 100 5 10 15 25 30 40 50 100 100 100 5 10 15 25 30 40 50 100 100 100 5 10 15 25 30 40 50 100 100 100 5 10 15 25 40 50 100 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 100 100 100 1 V rms @1kHz (pF) 118 255 327 469 537 924 1019 1830 2331 116 250 316 438 494 835 890 1571 2001 3634 111 232 293 407 458 775 825 1457 1855 3370 101 212 268 373 420 710 756 1336 1701 3089 87 182 230 319 609 648 1145 1458 2648 74 154 271 516 550 971 1237 2247 68 141 248 473 504 890 1134 2059 STANDARD SERIES ELECTRICAL SPECIFICATIONS Continuous Maida Style Number D58ZOV251RA08 D73ZOV251RA21 D61ZOV251RA40 D62ZOV251RA55 D69ZOV251RA72 D63ZOV251RA90 D65ZOV251RA130 D6694ZOV251RA260 D58ZOV271RA09 D73ZOV271RA23 D61ZOV271RA43 D62ZOV271RA60 D69ZOV271RA75 D63ZOV271RA100 D65ZOV271RA140 D6694ZOV271RA280 D58ZOV301RA10 D73ZOV301RA25 D61ZOV301RA45 D62ZOV301RA65 D69ZOV301RA80 D63ZOV301RA105 D65ZOV301RA150 D6694ZOV301RA300 D58ZOV321RA11 D73ZOV321RA27 D61ZOV321RA45 D62ZOV321RA70 D69ZOV321RA90 D63ZOV321RA110 D65ZOV321RA160 D6694ZOV321RA320 D58ZOV361RA12 D73ZOV361RA28 D61ZOV361RA45 D62ZOV361RA70 D69ZOV361RA85 D63ZOV361RA110 D65ZOV361RA160 D6694ZOV361RA320 D58ZOV391RA13 D73ZOV391RA29 D61ZOV391RA45 D62ZOV391RA70 D69ZOV391RA85 D63ZOV391RA110 D65ZOV391RA150 D6694ZOV391RA320 D58ZOV421RA14 D73ZOV421RA30 D61ZOV421RA45 D62ZOV421RA70 D69ZOV421RA90 D63ZOV421RA110 D65ZOV421RA160 D6694ZOV421RA320 D61ZOV461RA50 D62ZOV461RA75 D69ZOV461RA100 D63ZOV461RA120 D65ZOV461RA175 D6694ZOV461RA340 Recognitions To Nominal Minimum Safety Size Marking Agency Standards A B C D E F (mm) X X X 5 Z251 - 08UL X X X 7 Z251 - 21UL X X X 10 Z251 - 40UL X X 12 Z251 - 55UL X X X 14 Z251 - 72UL X X 18 Z251 - 90UL X X X 20 Z251 - 130UL X X X 25 Z251 - 260UL X X X 5 Z271 -09UL X X X 7 Z271 - 23UL X X X 10 Z271 - 43UL X X 12 Z271 - 60UL X X X 14 Z271 - 75UL X X 18 Z271 - 100UL X X X 20 Z271 - 140UL X X X 25 Z271 - 280UL X X X 5 Z301 -10UL X X X 7 Z301 - 25UL X X X 10 Z301 - 45UL X X 12 Z301 - 65UL X X X 14 Z301 - 80UL X X 18 Z301 - 105UL X X X 20 Z301 - 150UL X X X 25 Z301 - 300UL X X 5 Z321 - 11UL X X X 7 Z321 - 27UL X X X 10 Z321 - 45UL X X 12 Z321 - 70UL X X X 14 Z321 - 90UL X X 18 Z321 - 110UL X X X 20 Z321 - 160UL X X X 25 Z321 - 320UL X X 5 Z361 - 12UL X X X 7 Z361 - 28UL X X X 10 Z361 - 45UL X X 12 Z361 - 70UL X X X 14 Z361 - 85UL X X 18 Z361 - 110UL X X X 20 Z361 - 160UL X X X 25 Z361 - 320UL X X 5 Z391 - 13UL X X X 7 Z391 - 29UL X X X 10 Z391 - 45UL X X 12 Z391 - 70UL X X X 14 Z391 - 85UL X X 18 Z391 - 110UL X X X 20 Z391 - 150UL X X X 25 Z391 - 320UL X X 5 Z421 - 14UL X X X 7 Z421 - 30UL X X X 10 Z421 - 45UL X X 12 Z421 - 70UL X X X 14 Z421 - 90UL X X 18 Z421 - 110UL X X X 20 Z421 - 160UL X X X 25 Z421 - 320UL X X X 10 Z461 - 50UL X X 12 Z461 - 75UL X X X 14 Z461 - 100UL X X 18 Z461 - 120UL X X X 20 Z461 - 175UL X X X 25 Z461 - 340UL Applied Voltage (AC) 250 250 250 250 250 250 250 250 270 270 270 270 270 270 270 270 300 300 300 300 300 300 300 300 320 320 320 320 320 320 320 320 360 360 360 360 360 360 360 360 390 390 390 390 390 390 390 390 420 420 420 420 420 420 420 420 460 460 460 460 460 460 (DC) 330 330 330 330 330 330 330 330 360 360 360 360 360 360 360 360 390 390 390 390 390 390 390 390 420 420 420 420 420 420 420 420 470 470 470 470 470 470 470 470 500 500 500 500 500 500 500 500 560 560 560 560 560 560 560 560 615 615 615 615 615 615 Maximum Ratings Transient Energy 10 x 1000 μsec (J) 17 35 70 80 145 240 300 315 20 40 80 91 160 260 325 340 21 42 85 105 175 280 350 360 21 46 92 140 190 310 385 430 22 47 97 145 205 320 410 440 25 51 107 150 215 330 420 460 26 57 110 156 225 340 430 480 115 162 230 360 450 500 8 x 20 μsec (J) 17 35 70 80 145 240 300 315 20 40 80 91 160 260 325 340 21 42 85 105 175 280 350 360 21 46 92 140 190 310 385 430 22 47 97 145 205 320 410 440 25 51 107 150 215 330 420 460 26 57 110 156 225 340 430 480 115 162 230 360 450 500 Peak Current 8 x 20 μsec Electrical Characteristics Max Clamping Varistor Typical Voltage Voltage Cap. @1 mA DC (@Test Current) # Pulses 1 (A) 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 800 1750 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 2 (A) 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 600 1250 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 Vmin (V) 354 354 354 354 354 354 354 354 382 382 382 382 382 382 382 382 425 425 425 425 425 425 425 425 453 453 453 453 453 453 453 453 522 522 522 522 522 522 522 522 552 552 552 552 552 552 552 552 594 594 594 594 594 594 594 594 651 651 651 651 651 651 Vmax (V) 432 432 432 432 432 432 432 432 466 466 466 466 466 466 466 466 518 518 518 518 518 518 518 518 553 553 553 553 553 553 553 553 638 638 638 638 638 638 638 638 674 674 674 674 674 674 674 674 725 725 725 725 725 725 725 725 795 795 795 795 795 795 (8 x 20μsec) (V) 675 650 650 650 650 650 650 650 740 710 710 710 710 710 710 710 810 790 790 790 790 790 790 790 850 850 850 850 850 850 850 850 960 960 960 960 960 960 960 960 1040 1040 1025 1025 1025 1025 1025 1025 1130 1120 1120 1120 1120 1120 1120 1120 1240 1240 1240 1240 1240 1240 (A) 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 5 10 25 40 50 75 100 100 25 40 50 75 100 100 1 V rms @1kHz (pF) 62 131 229 437 465 822 1047 1901 58 121 213 406 432 763 972 1765 52 108 190 363 386 682 869 1577 49 102 179 341 363 641 816 1483 42 88 154 294 313 553 704 1278 40 83 146 278 297 524 667 1211 37 77 136 258 275 486 618 1123 124 236 251 443 565 1025 STANDARD SERIES ELECTRICAL SPECIFICATIONS Continuous D61ZOV481RA50 D62ZOV481RA80 D69ZOV481RA105 D63ZOV481RA130 D65ZOV481RA180 D6694ZOV481RA360 D61ZOV511RA55 D62ZOV511RA85 D69ZOV511RA110 D63ZOV511RA140 D65ZOV511RA190 D6694ZOV511RA380 D61ZOV551RA60 D62ZOV551RA90 D69ZOV551RA115 D63ZOV551RA145 D65ZOV551RA200 D6694ZOV551RA400 D61ZOV581RA65 D62ZOV581RA95 D69ZOV581RA120 D63ZOV581RA160 D65ZOV581RA220 D6694ZOV581RA440 D61ZOV621RA65 D62ZOV621RA100 D69ZOV621RA130 D63ZOV621RA170 D65ZOV621RA230 D6694ZOV621RA460 D61ZOV681RA70 D62ZOV681RA105 D69ZOV681RA150 D63ZOV681RA200 D65ZOV681RA260 D6694ZOV681RA520 D69ZOV751RA165 D63ZOV751RA220 D65ZOV751RA290 D6694ZOV751RA560 D69ZOV102RA220 D63ZOV102RA280 D65ZOV102RA360 D6694ZOV102RA720 Recognitions To Nominal Minimum Safety Size Marking Agency Standards A B C D E F (mm) X X X 10 Z481 - 50UL X X 12 Z481 - 80UL X X X 14 Z481 - 105UL X X 18 Z481 - 130UL X X X 20 Z481 - 180UL X X X 25 Z481 - 360UL X X X 10 Z511 - 55UL X X 12 Z511 - 85UL X X X 14 Z511 - 110UL X X 18 Z511 - 140UL X X X 20 Z511 - 190UL X X X 25 Z511 - 380UL X X X 10 Z551 - 60UL X X 12 Z551 - 90UL X X X 14 Z551 - 115UL X X 18 Z551 - 145UL X X X 20 Z551 - 200UL X X X 25 Z551 - 400UL X X 10 Z581 - 65UL X X 12 Z581 - 95UL X X X 14 Z581 - 120UL X X 18 Z581 - 160UL X X X 20 Z581 - 220UL X X X 25 Z581 - 440UL X X X 10 Z621 - 65UL X X 12 Z621 - 100UL X X X 14 Z621 - 130UL X X 18 Z621 - 170UL X X X 20 Z621 - 230UL X X X 25 Z621 - 460UL X X X 10 Z681 - 70UL X X 12 Z681 - 105UL X X X 14 Z681 - 150UL X X 18 Z681 - 200UL X X X 20 Z681 - 260UL X X X 25 Z681 - 520UL X X X 14 Z751 - 165UL X X 18 Z751 - 220UL X X X 20 Z751 - 290UL X X X 25 Z751 - 560UL X X 14 Z102 - 220UL X X 18 Z102 - 280UL X X 20 Z102 - 360UL X X 25 Z102 - 720UL A = UL1449 B = cUL C = CSA D = VDE E = DEMKO F= Maida Style Number Applied Voltage (AC) 480 480 480 480 480 480 510 510 510 510 510 510 550 550 550 550 550 550 580 580 580 580 580 580 620 620 620 620 620 620 680 680 680 680 680 680 750 750 750 750 1000 1000 1000 1000 (DC) 640 640 640 640 640 640 675 675 675 675 675 675 700 700 700 700 700 700 735 735 735 735 735 735 800 800 800 800 800 800 860 860 860 860 860 860 900 900 900 900 1200 1200 1200 1200 Maximum Ratings Transient Energy 10 x 1000 μsec (J) 120 167 235 365 460 510 125 172 240 375 470 525 130 192 255 405 510 540 140 202 265 425 530 560 145 215 290 450 565 600 155 232 310 500 620 655 350 540 670 700 510 690 860 875 8 x 20 μsec (J) 120 167 235 365 460 510 125 172 240 375 470 525 130 192 255 405 510 540 140 202 265 425 530 560 145 215 290 450 565 600 155 232 310 500 620 655 350 540 670 700 510 690 860 875 Peak Current 8 x 20 μsec Electrical Characteristics Max Varistor Clamping Typical Voltage Voltage Cap. @1 mA DC (@Test Current) # Pulses 1 (A) 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 3500 4500 6000 7500 10000 13000 6000 7500 10000 13000 6000 7500 10000 13000 2 (A) 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 2500 3200 4500 6000 6500 9000 4500 6000 6500 9000 4500 6000 6500 9000 Vmin (V) 679 679 679 679 679 679 722 722 722 722 722 722 778 778 778 778 778 778 821 821 821 821 821 821 877 877 877 877 877 877 962 962 962 962 962 962 1062 1062 1062 1062 1414 1414 1414 1414 Vmax (V) 829 829 829 829 829 829 881 881 881 881 881 881 950 950 950 950 950 950 1002 1002 1002 1002 1002 1002 1071 1071 1071 1071 1071 1071 1175 1175 1175 1175 1175 1175 1300 1300 1300 1300 1728 1728 1728 1728 (8 x 20μsec) (V) 1300 1300 1300 1300 1300 1300 1350 1350 1350 1350 1350 1350 1400 1400 1400 1400 1400 1400 1500 1500 1500 1500 1500 1500 1650 1650 1650 1650 1650 1650 1800 1800 1800 1800 1800 1800 2100 2100 2100 2100 2700 2700 2700 2700 (A) 25 40 50 75 100 100 25 40 50 75 100 100 25 40 50 75 100 100 25 40 50 75 100 100 25 40 50 75 100 100 25 40 50 75 100 100 50 75 100 100 50 75 100 100 1 V rms @1kHz (pF) 119 227 242 427 544 989 112 213 227 401 510 927 104 198 211 373 475 862 98 187 199 352 449 815 92 175 186 329 419 761 84 160 170 300 382 694 151 267 340 618 115 204 259 471 12/22/2020 STANDARD SERIES MECHANICAL SPECIFICATIONS Dimension MAX. D MAX. T MAX. H TYP. X TYP. d 5mm 7mm 8mm 10mm 11mm 12mm 14mm 16mm 18mm 20mm 25mm 0.298" 0.354" 0.394" 0.472" 0.531" 0.590" 0.650" 0.710" 0.812" 0.905" 1.100" 0.161" - 0.161" - 0.204" - 0.161" - 0.161" - 0.161" - 0.161" - 0.161" - 0.161" - 0.161" - 0.161" 0.313" 0.313" 0.268" 0.405" 0.212" 0.385" 0.531" 0.212" 0.531" 0.531" 0.531" 0.423" 0.479" 0.519" 0.597" 0.656 0.715" 0.775" 0.835" 0.912" 1.030" 1.250" 0.200" 0.200" 0.200" 0.300" 0.300" 0.300" 0.300" 0.300" 0.300" 0.300" 0.500" 0.025" 0.025" 0.025" 0.032" 0.032" 0.032" 0.032" 0.032" 0.032" 0.032" 0.040" NOTES: 1. Alternate dimensional specifications, including lead styles, for any part listed may be available upon request. 2. Specifications are subject to change. Contact Maida for specific datasheet for exact dimensions. STANDARD SERIES - TYPICAL VOLTAGE-CURRENT CURVES D58 (5mm) SERIES 2000 < - - - - - - DC CURRENT - - - - - - > D73 (7mm) SERIES < - 8/20us CURRENT IMPULSE - > 2000 < - - - - - - DC CURRENT - - - - - - > < - 8/20us CURRENT IMPULSE - > D58ZOV271RA09 1000 900 800 700 600 D58ZOV251RA08 D58ZOV231RA08 500 D58ZOV211RA07 400 D58ZOV181RA02 300 D58ZOV151RA02 200 D58ZOV141RA02 D73ZOV301RA25 CLAMPING VOLTAGE, volts CLAMPING VOLTAGE, volts D58ZOV301RA10 D73ZOV271RA23 1000 900 800 700 600 D73ZOV251RA21 D73ZOV231RA20 500 D73ZOV211RA18 400 D73ZOV181RA03 300 D73ZOV151RA03 200 D73ZOV141RA03 D58ZOV131RA02 D73ZOV131RA03 100 100 10-6 10-5 10-4 10-3 10-2 100 101 102 103 104 10-6 10-5 10-4 CURRENT, amperes < - - - - - - DC CURRENT - - - - - - > 10-2 100 101 102 103 D61 (10mm) SERIES < - 8/20us CURRENT IMPULSE - > 2000 < - - - - - - DC CURRENT - - - - - - > < - 8/20us CURRENT IMPULSE - > D68ZOV301RA25 D68ZOV271RA23 1000 900 800 700 600 D68ZOV251RA21 D68ZOV231RA20 500 D68ZOV181RA03 400 D68ZOV151RA03 300 D68ZOV141RA03 200 D68ZOV131RA03 D61ZOV301RA45 CLAMPING VOLTAGE, volts CLAMPING VOLTAGE, volts 104 CURRENT, amperes D68 (8mm) SERIES 2000 10-3 D61ZOV271RA43 1000 900 800 700 600 D61ZOV251RA40 D61ZOV231RA35 500 D61ZOV211RA30 400 D61ZOV181RA04 300 D61ZOV151RA04 200 D61ZOV141RA04 D61ZOV131RA04 100 100 10-6 2000 10-5 10-4 10-3 10-2 100 101 102 103 104 10-6 10-5 10-4 10-3 10-2 100 101 CURRENT, amperes CURRENT, amperes D71 (11mm) SERIES D62 (12mm) SERIES < - - - - - - DC CURRENT - - - - - - > < - 8/20us CURRENT IMPULSE - > 2000 < - - - - - - DC CURRENT - - - - - - > 102 103 104 < - 8/20us CURRENT IMPULSE - > 1000 900 800 700 600 D71ZOV151RA05 500 D71ZOV141RA05 400 D71ZOV131RA05 300 200 CLAMPING VOLTAGE, volts CLAMPING VOLTAGE, volts D62ZOV301RA65 D62ZOV271RA60 1000 900 800 700 600 D62ZOV251RA55 D62ZOV231RA50 500 D62ZOV211RA45 400 D62ZOV181RA07 300 D62ZOV151RA07 200 D62ZOV141RA07 D62ZOV131RA07 100 100 10-6 10-5 10-4 10-3 10-2 100 101 CURRENT, amperes 102 103 104 10-6 10-5 10-4 10-3 10-2 100 101 102 103 104 CURRENT, amperes NOTE: For a more detailed V-I curve or for a voltage not listed on the graphs provided, please contact us. STANDARD SERIES - TYPICAL VOLTAGE-CURRENT CURVES D69 (14mm) SERIES 2000 < - - - - - - DC CURRENT - - - - - - > D63 (18mm) SERIES < - 8/20us CURRENT IMPULSE - > 2000 < - - - - - - DC CURRENT - - - - - - > < - 8/20us CURRENT IMPULSE - > D69ZOV271RA75 1000 900 800 700 600 D69ZOV251RA72 D69ZOV231RA70 500 D69ZOV211RA65 400 D69ZOV181RA09 300 D69ZOV151RA09 200 D69ZOV141RA09 D63ZOV301RA80 CLAMPING VOLTAGE, volts CLAMPING VOLTAGE, volts D69ZOV301RA80 D63ZOV271RA75 1000 900 800 700 600 D63ZOV251RA72 D63ZOV231RA70 500 D63ZOV211RA65 400 D63ZOV181RA09 300 D63ZOV151RA09 200 D63ZOV141RA09 D69ZOV131RA09 D63ZOV131RA09 100 100 10-6 10-5 10-4 10-3 10-2 100 101 102 103 104 10-6 10-5 10-4 CURRENT, amperes < - - - - - - DC CURRENT - - - - - - > 10-2 100 101 102 103 104 D66 (25mm) SERIES < - 8/20us CURRENT IMPULSE - > 2000 < - - - - - - DC CURRENT - - - - - - > < - 8/20us CURRENT IMPULSE - > D65ZOV301RA10 D65ZOV271RA09 1000 900 800 700 600 D65ZOV251RA08 D65ZOV231RA08 500 D65ZOV211RA07 400 D65ZOV181RA02 300 D65ZOV151RA02 200 D65ZOV141RA02 D66ZOV301RA10 CLAMPING VOLTAGE, volts CLAMPING VOLTAGE, volts 105 CURRENT, amperes D65 (20mm) SERIES 2000 10-3 D66ZOV271RA09 1000 900 800 700 600 D66ZOV251RA08 D66ZOV231RA08 500 D66ZOV211RA07 400 D66ZOV181RA02 300 D66ZOV151RA02 200 D66ZOV141RA02 D65ZOV131RA02 D66ZOV131RA02 100 100 10-6 10-5 10-4 10-3 10-2 100 101 CURRENT, amperes 102 103 104 105 10-6 10-5 10-4 10-3 10-2 100 101 102 103 104 105 CURRENT, amperes NOTE: For a more detailed V-I curve or for a voltage not listed on the graphs provided, please contact us. LEAD CODES and TAPE & REEL LEAD CODES The Maida Development Company prides itself on its ability to manufacture wire leaded devices to meet almost every request of its customers. The following table depicts common varieties of leads that are presently supplied. It should be noted that the dimensions (such as the X, Y, Z, height, lead length, epoxy “pant leg”, wire diameter, etc.) can be modified on any the items shown to meet almost any request. Maida is also capable of supplying the various lead forms in either right-hand or left-hand configurations. For any inquiries regarding specific lead forms please contact us. NOTE: The images shown depict a round varistor only. However, any lead configuration can be obtained on either round or square varistors. TAPE & REEL The Maida Development Company MOV’s are available in Bulk, Tape & Reel, or Ammo Pack packaging formats. All Tape & Reel and Ammo Pack part numbers are designated by suffixing the Maida style number with a T followed by a 1-2 digit alphanumeric code. The codes are generally given to indicate whether the packaging is either Ammo Pack or Tape & Reel, the typical lead spacing of the varistor, the lead style, the wire gauge (or wire diameter), and the taping pitch. Generally, through-hole varistors with a lead spacing of 0.394”, or less, and a nominal disc diameter of 20mm, or less, can be taped. Larger diameters and/or lead spacing’s may be offered taped; however customers should contact us for confirmation. All SMD Series, SMV Series, Encapsulated MOV Series, and MLV Series are provided Tape & Reel. For bulk packaging please contact us. Maida’s taping specifications comply with the requirements of the EIA taping standard. Configurations are available to meet almost any request. Detailed drawings for all taping codes are available upon request. COMMON LEAD CODES
D65ZOV321RA160 价格&库存
很抱歉,暂时无法提供与“D65ZOV321RA160”相匹配的价格&库存,您可以联系我们找货
