SQM500JB-10K 5%
SQM500JB-10K 5%
    YAGEO(国巨)
    WR-13X9MM_TM
    SQM500JB-10K 5%
SQM500JB-10K 5% 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET CEMENT RESISTORS High Power, Vertical Mount SQM Series NSM Series ±1%, ±5% 2W to 10W Product specification – August 12, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Cement Resistors Product Specification ORDERING INFORMATION Part number of the vertical mount cement resistor are identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER SQM 200 J B - 100R (1) (2) (3) (4) (5) (6) (1) SERIES SQM = General Purpose APPLICATIONS  Power applications NSM = Non-Inductive (2) POWER RATING  Home appliance 200 = 2W 500= 5W 10A= 10W  Industry 300 = 3W 700= 7W 10S=10W (3) TOLERANCE FEATURES  High power rating  Excellent pulse load capability  Axial terminal  Flameproof ceramic case  RoHS compliant and halogen free F = ±1% J = ±5% (4) PACKAGING B = Bulk for wirewound or metal oxide or fiberglass element W = Bulk for wirewound element M = Bulk for metal oxide element F = Bulk for fiberglass element (5) TEMPERATURE COEFFICIENT OF RESISTANCE F=±100ppm/°C - = Based on spec (6) RESISTANCE VALUE E24 & E96 Series Example: 1R = 1Ω, 10R = 10Ω, 100R = 100Ω www.yageo.com Aug. 12, 2021 V.0 2 8 SQM, NSM Through Hole Resistors Product Specification Cement Resistors 8 SQM, NSM DIMENSIONS Unit: mm Normal NonInductive H W S P SQM200 NSM200 20 ± 1.5 11.0 ± 1.0 7.0 ± 1.0 5+2-1 SQM300 NSM300 25 ± 1.5 12.0 ± 1.0 8.0 ± 1.0 5 SQM500 NSM500 25 ± 1.5 13.0 ± 1.0 9.0 ± 1.0 5 SQM700 NSM700 39 ± 1.5 13.0 ± 1.0 9.0 ± 1.0 5 SQM10A NSM10A 51 ± 1.5 13.0 ± 1.0 9.0 ± 1.0 5 SQM10S NSM10S 35 ± 1.5 16.0 ± 1.0 12.0 ± 1.0 7 +2-1 +2-1 +2-1 +2-1 +2-1 DERATING CURVE SQM2W, NSM2W Rated Power (%) 100 80 60 58 40 20 70 155 275 Ambient Temperature (°C) 155 275 Ambient Temperature (°C) SQM3W~10W, NSM3W~10W Rated Power (%) 100 80 60 51 40 20 40 www.yageo.com Aug. 12, 2021 V.0 3 Through Hole Resistors Cement Resistors Product Specification 8 SQM, NSM ELECTRICAL CHARACTERISTICS CHARACTERISTICS SQM200 Power Rating at 40 °C SQM300 SQM500 SQM700 SQM10A SQM10S 3W 5W 7W 10W 10W Power Rating at 70 °C 2W Maximum Working Voltage 250V 350V 350V 500V 500V 500V Maximum Overload Voltage 500V 700V 700V 1000V 1000V 1000V Voltage Proof on Insulation 500V 700V 700V 1000V 1000V 1000V Resistance Range (Ceramic based wirewound) 0.1Ω~36Ω 0.1Ω~68Ω 0.1Ω~130Ω 0.1Ω~330Ω 0.1Ω~510Ω 0.1Ω~270Ω Resistance Range ( Metal Oxide Film ) 39Ω~1MΩ 75Ω~1MΩ 150Ω~1MΩ 360Ω~1MΩ 560Ω~1MΩ 300Ω~1MΩ Resistance Range (Fiberglass based wirewound) 0.1Ω~1KΩ 0.1Ω~4.7KΩ 0.1Ω~4.7KΩ 0.1Ω~4.7KΩ 0.1Ω~5.6KΩ 0.1Ω~4.7KΩ Operating Temp. Range - 55°C to +155°C Temperature Coefficient Wirewound: ±100ppm/°C , ±300ppm/°C, Film:±300ppm/°C CHARACTERISTICS NSM200 Power Rating at 40 °C NSM300 NSM500 NSM700 NSM10A NSM10S 3W 5W 7W 10W 10W 1000V 1000V Power Rating at 70 °C 2W Maximum Working Voltage √(P X R) Voltage Proof on Insulation 500V 700V 700V 1000V Resistance Range (Ceramic based wirewound) 0.1Ω~10Ω 0.1Ω~30Ω 0.15Ω~65Ω 0.27Ω~100Ω 0.27Ω~100Ω 0.27Ω~100Ω Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Aug. 12, 2021 V.0 4 Through Hole Resistors Cement Resistors Product Specification 8 SQM, NSM TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more than ±2%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.39 4 times RCWV(or Umax., whichever less) ±2.0%+0.05Ω 10,000 cycles (1 Sec. on, 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C ±2.0%+0.05Ω  Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Note:. RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 12, 2021 V.0 5 Through Hole Resistors Product Specification Cement Resistors 8 SQM, NSM BULK PACKING Miniature Non-Inductive SQM200 NSM200 1,600 SQM300 NSM300 1,000 SQM500 NSM500 1,000 SQM700 NSM700 700 SQM10A NSM10A 500 SQM10S NSM10S 500 Piece/Per Inner Box MARKING Example: YAGEO 1439 7WN 100R JF YAGEO = Brand 1439 = Date code 7W = Power rating N = Non-inductive 100R = Resistance J = Tolerance F = Fiberglass www.yageo.com Aug. 12, 2021 V.0 6 Through Hole Resistors Cement Resistors Product Specification 8 SQM, NSM REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2 , 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 12, 2021 V.0 7 Through Hole Resistors Cement Resistors Product Specification 8 SQM, NSM LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 12, 2021 V.0 8
SQM500JB-10K 5% 价格&库存
很抱歉,暂时无法提供与“SQM500JB-10K 5%”相匹配的价格&库存,您可以联系我们找货
