BPC-817D
BPC-817D
    BRTLED(佰鸿)
    DIP-4
BPC-817D 数据手册
BRIGHT LED ELECTRONICS CORP. Specification for Approval ● ● SAMPLES  ATTACHED AREA  DEVICE NUMBER: BPC-817 CUSTOMER:大宇 PAGE DATE 20117/12/05 1 2 3 4 5 6 CONTENTS 1.0 1.0 1.0 1.0 1.0 1.0 Initial Released FOR CUSTOMER’S APPROVAL STAMP OR SIGNATURE APPROVED PURCHASE 佰鴻工業股份有限公司 MANUFACTURE QUALITY ENGINEERING ISSUED APPROVED PREPARED 張 鮑 劉 2017.12.05 2017.12.05 2017.12.05 孝 嚴 雙 玲 丹 丹 BRIGHT LED ELECTRONICS CORP. 新北市板橋區和平路 19 號 3 樓 3F., No.19, He Ping Road, Ban Qiao Dist., New Taipei City, Taiwan Tel: +886-2-29591090 Fax: +886-2-29547006/29558809 www.brtled.com BRIGHT LED ELECTRONICS CORP. BPC-817 ● Features: ● Outline Dimensions 1. Current transfer ratio (CTR: MIN. 50% at IF=5mA, VCE=5V) 2. High input-output isolation voltage (VISO=5,000Vrms) 3. Response time (tr: TYP. 4μs at VCE=2V, IC=2mA, RL=100 Ω) 4. VDE approved(NO.40007240) 5. UL/CUL approved(NO.E236324) 6. CQC approved(NO.CQC08001026994 NO.CQC05001014257) 7.This product doesn't contain restriction substance, comply RoHS standard ● Description 1. The BPC-817 series are optically coupled isolators containing a GaAs light emitting diode and an NPN silicon phototransistor 2. The lead pitch is 2.54mm ●NOTES: ● Applications: 1. Computer terminals. 2. System appliances, measuring instruments. 3. Registers, copiers, automatic vending machines. 4. Electric home appliances, such as fan heaters, etc. 5. Signal transmission between circuits of different potentials and impedances. ●Absolute Maximum Ratings *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (T:Taiwan, G:China) *4. Rank shall be or shall not be marked. 5.All dimensions are in millimeters (inches). 6.Tolerance is ±0.25mm (0.01”) unless otherwise specified. (Ta=25℃) Parameter Forward Current INPUT Reverse Voltage Power Dissipation Collector-Emitter Voltage Emitter- Collector Voltage OUTPUT Collector Current Collector Power Dissipation Total Power Dissipation *1 Isolation Voltage Rated impulse isolation voltage Rated repetitive peak isolation voltage Operating Temperature Storage Temperature *2 Soldering Temperature Symbol Rating Unit IF VR P VCEO VECO IC PC Ptot Viso VIOTM VIORM Topr Tstg Tsol 50 6 70 35 6 50 150 200 5,000 6,000 630 -30 to + 110 -55 to + 125 260 mA V mW V mA mW mW Vrms V V ℃ *1. AC For 1 minute, R.H. =40~60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Ver:1.0 Page 1 of 6 BRIGHT LED ELECTRONICS CORP. BPC-817 ●Electro-Optical Characteristics (Ta=25℃) Parameter Symbol Conditions Forward Voltage VF IF=20mA --- 1.2 1.4 V Reverse Current IR VR=6V --- --- 10 μA Terminal Capacitance Ct V=0, f=1KHz --- 30 250 pF Collector Dark Current ICEO VCE=20V, IF=0 --- --- 100 nA 35 --- --- V 6 --- --- V INPUT Collector-Emitter OUTPUT Breakdown Voltage Emitter-Collector Breakdown Voltage IC=0.1mA BVCEO IF=0 IE=10μA BVECO IF=0 MIN. TYP. MAX. Unit Collector Current Ic IF=5mA 2.5 --- 30 mA *1 Current Transfer Ratio CTR VCE=5V 50 --- 600 % --- 0.1 0.2 V --- Ω Collector-Emitter Saturation Voltage TRANSFER CHARACTERIS TICS IF=20mA VCE(sat) Isolation Resistance Riso Floating Capacitance Cf Cut-Off Frequency fc Response Time(Rise) tr Response Time(Fall) tf IC= 1mA DC500V 40~60%R.H. V=0, f=1MHz 5×1010 1×1011 --- 0.6 1 pF --- 80 --- kHz VCE=2V, IC=2mA --- 4 18 μs RL=100Ω --- 3 18 μs VCE=5V, IC=2mA RL=100Ω, -3dB *1 CTR= IC / IF × 100% ●RANK TABLE OF CURRENT TRANSFER RATIO(CTR) RANK MARK. M i n . ( %) M a x . ( %) L 50 100 A 80 160 B 130 260 C 200 400 D 300 600 L or A or B or C or D 50 600 Notes: *1. Conditions: IF=5mA, VCE=5V, Ta=25℃. Ver:1.0 Page 2 of 6 BRIGHT LED ELECTRONICS CORP. BPC-817 ●CHARACTERISTICS CURVES Ver.1.0 Page 2of 6 Ver:1.0 Page 3 of 6 BRIGHT LED ELECTRONICS CORP. BPC-817 ●Characteristics Curves Ver:1.0 Page 4 of 6 BRIGHT LED ELECTRONICS CORP. BPC-817 ● Reliability Test Classification Test Item Reference Standard MIL-STD-750:1026 MIL-STD-883:1005 JIS C 7021 :B-1 Operation Life Endurance Test High Temperature High Humidity Reverse Bias (H3TRB) High Temperature Reverse Bias (HTRB) High Temperature Storage Low Temperature Storage Autoclave JIS C 7021 :B-11 JIS C 7021 :B- 8 MIL-STD-883:1008 JIS C 7021 :B-10 JIS-C-7021 :B-12 JESD 22-A102-B MIL-STD-202:107D Temperature MIL-STD-750:1051 Cycling MIL-STD-883:1010 JIS C 7021 :A-4 MIL-STD-202:107D Environmental Thermal Shock MIL-STD-750:1051 Test MIL-STD-883:1011 MIL-STD-202:201A Solder Resistance MIL-STD-750:2031 JIS C 7021 :A-1 MIL-S-883:2003 Solder Ability JIS C 7021 :A-2 Test Conditions Result Connect with a power If=50mA Ta=Under room temperature Test time=1,000hrs Ta=+85℃±5℃, RH=85% PTR=VCE absolute max rating*80% Test time=1000hrs Ta=+105℃±5℃ PTR=VCE absolute max rating Test time=1000hrs High Ta=+125℃±5℃ Test time=1,000hrs Low Ta=-55℃±5℃ Test time=1,000hrs P=15PSIG, Ta=121℃ Humi. =100%RH, 48hrs 125℃ ~ 25℃ ~ -55℃ ~ 30min 5min 30min Test Time=20cycle 25℃ 5min 0/20 0/20 0/20 0/20 0/20 0/20 0/20 125℃ ~-55℃ 20min 20min Test Time=20cycle 0/20 Operation heating: 260℃, within 10±1seconds. 0/20 Operation heating: 235℃, within 5±1seconds. 0/20 ●Judgment Criteria Of Failure For The Reliability Symbol Measuring conditions Judgment criteria for failure VF (V) If=20mA Over Ux1.0 Ir(uA) Vr=6V Over Ux1.0 CTR(%) If=5mA, VCE=5V Shift>1.2 VCE(sat) IF=20mA, IC= 1mA Over Ux1.0 BVCEO IC=0.1mA, IF=0 Over Lx1.0 BVECO IE=10μA, IF=0 Over Lx1.0 Ver:1.0 Page 5 of 6 BRIGHT LED ELECTRONICS CORP. BPC-817 ● Packaging Box Dimensions (Units: mm) z Packaging Tube Dimensions 8.20 R V D E US Notes: 1、100pcs per tube, 5Kpcs per box. 2、All dimensions are in millimeters (inches). 3、Specifications are subject to change without notice. Ver:1.0 Page 6 of 6
BPC-817D 价格&库存
很抱歉,暂时无法提供与“BPC-817D”相匹配的价格&库存,您可以联系我们找货
