ESD05V32D-A
ESD05V32D-A
    SOCAY(硕凯)
    SOD323
    ESD05V32D-A
ESD05V32D-A 数据手册
Transient Voltage Suppressors for ESD Protection ESDXXV32D-A Series Description SOD-323 The ESDXXV32D-A is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space is at a premium. Feature Functional Diagram u 225~408 Watts Peak Pulse Power per Line (tp=8/20μs) u Protects one I/O line or power line u Low clamping voltage u Working voltages : 3V, 5V, 8V, 12V, 15V,24V and 36V u Low leakage current u IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) u IEC61000-4-4 (EFT) 40A (5/50ns) u IEC61000-4-5 (Lightning) 24A (8/20μs) Applications u Cell Phone Handsets and Accessories u Microprocessor based equipment u Personal Digital Assistants (PDA’s) u Notebooks, Desktops, and Servers u Portable Instrumentation u Peripherals u Pagers Mechanical Characteristics u JEDEC SOD-323 Package u Molding Compound Flammability Rating : UL 94V-0 u Weight 5 Milligrams (Approximate) u Quantity Per Reel : 3,000pcs u Reel Size : 7 inch u Lead Finish : Lead Free Mechanical Characteristics Symbol Parameter Value Units TL Lead Soldering Temperature 260 (10sec) ºC TSTG Storage Temperature Range -55 to +150 ºC TOP Operating Temperature Range -55 to +150 ºC Air Discharge ±15 Contact Discharge ±8 IEC61000-4-2 (ESD) IEC61000-4-4 (EFT) 40 A IEC61000-4-5 ( Lightning ) 24 A SOCAY Electronics Corp., Ltd. Revision August 24, 2016 KV www.socay.com 1/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV32D-A Series I-V Curve Characteristics Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IF Working Peak Reverse Voltage IR Maximum Reverse leakage Current IT Test Current @ VRWM Breakdown Voltage @ IT IF Forward Current VF Forward Voltage @IF PPK Peak Power Dissipation V VB VRWM R VC VB C I Uni-directional IT IR VF IPP Max Capacitance @VR=0V & f=1MHz Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) Device Marking VRWM (V) (Max.) VB (V) (Min.) IT (mA) VC @1A (Max.) (Max.) ESD03V32D-A 03W 3 3.8 1 7.5 ESD05V32D-A 05W 5 6.0 1 9.8 ESD08V32D-A 08W 8 7.8 1 ESD12V32D-A 12W 12 13.3 1 ESD15V32D-A 15W 15 16.7 ESD24V32D-A 24W 24 26.7 ESD36V32D-A 36W 36 40.0 Part Number (@A) IR (μA) (Max.) C (pF) (Typ.) PPP (W) (tp=8/20μs wave form) 16 25 40 350 400 17 24 5 300 408 13.4 20 18 3 200 360 20 30 11 1 100 330 1 25 36 9 1 90 324 1 45 50 5 1 80 250 1 65 75 3 1 48 225 VC Characteristic Curves Fig1. 8/20μs Pulse Waveform Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) tr 100 Peak Value IPP 80 100% TEST WAVEFORM PARAMETERS tr=8μs td=20μs Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time (μs) SOCAY Electronics Corp., Ltd. Revision August 24, 2016 90% www.socay.com 2/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV32D-A Series Characteristic Curves Fig3. ESD Clamping (+8KV Contac per IEC61000-4-2) Fig4. ESD Clamping (-8KV Contac per IEC61000-4-2) SOD-323 Package Outline & Dimensions Millimeters Inches Symbol Min. Nom. Max. Min. Nom. Max. A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 Soldering Footprint 0.006 REF b 0.25 0.32 0.40 0.010 0.012 0.016 C 0.089 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.062 0.066 0.070 E 1.15 1.25 1.35 0.045 0.049 0.053 L 0.08 — — 0.003 — — HE 2.30 2.50 2.70 0.090 0.098 0.105 Symbol Millimeters Inches F 1.60 0.063 G 2.85 0.112 J 0.83 0.033 K 0.63 0.025 SOCAY Electronics Corp., Ltd. Revision August 24, 2016 0.15 REF www.socay.com 3/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
ESD05V32D-A 价格&库存
很抱歉,暂时无法提供与“ESD05V32D-A”相匹配的价格&库存,您可以联系我们找货
