UM805RE
UM805RE
    UNION(英联)
    SOT-143
    4引脚微处理器电压监控器,带手动复位输入
UM805RE 数据手册
UM805/811/812 4-Pin μP Voltage Monitors with Manual Reset Input UM805/811/812 SOT143 General Description The UM805/811/812 are low-power microprocessor (μP) supervisory circuits used to monitor power supplies in μP and digital systems. They provide excellent circuit reliability and low cost by eliminating external components and adjustments when used with 5V-powered or 3V-powered circuits. The UM805/811/812 also provide a debounced manual reset input. These devices perform a single function: They assert a reset signal whenever the VCC supply voltage falls below a preset threshold, keeping it asserted for at least 140ms after VCC has risen above the reset threshold. Reset thresholds are available for operation with a variety of supply voltages. The UM805 has an open-drain output stage, while the UM811/812 have push-pull outputs. The _____________ resistor that can be connected to a voltage UM805’s open-drain RESET output requires a pull-up _____________ higher than VCC. The UM805/811 have an active-low RESET output, while the UM812 has an active-high RESET output. The reset comparator is designed to ignore fast transients on VCC, and the outputs are guaranteed to be in the correct logic state for VCC down to 1V. Low supply current makes the UM805/811/812 ideal for use in portable equipments. The devices come in a 4-pin SOT143 package. Applications Features z z z z z z z z z Computers Controllers Portable/Battery-Powered Equipments Intelligent Instruments Critical μP and μC Power Monitoring z z z z z z No External Components VCC Transient Immunity Correct Logic Output Guaranteed to VCC=1.0V Precision VCC Monitoring of 3.0V, 3.3V and 5.0V Supplies 2μA Supply Current 140ms Minimum Power-On Reset Pulse Width Guaranteed Over Temperature Available in 3 Output Configurations: __________ Output (UM805) Open-Drain Active-Low_ _ _RESET _______ Push-Pull Active-Low RESET Output (UM811) Push-Pull Active-High RESET Output (UM812) 4-Pin SOT143 Package Wide Operation Temperature: -40°C to +85°C ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 1/14 UM805/811/812 Pin Configurations GND 1 RESET 2 (RESET) Top View 4 VCC 3 MR ( ) are for UM812 M: Month Code UM805/811/812 SOT143 Ordering Information UM8 XX Z P XX: Output Type =05 Open-Drain Active Low =11 Push-Pull Active Low =12 Push-Pull Active High Z: Reset Threshold (V) =L 4.63 =M 4.38 =J 4.00 =T 3.08 =S 2.93 =R 2.63 =Z 2.32 P: Package Type =E SOT143 Typical Operating Circuit ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 2/14 UM805/811/812 Pin Description Pin Number 1 Pin Name Function GND Ground _____________ Active-Low Reset Output. RESET remains low while VCC is below _______ the reset threshold or while MR is held low. It remains low for the Reset Active Timeout Period (tRP) after the reset conditions are terminated. See Figure 1. UM811: CMOS push-pull output (sources and sinks current). UM805: Open-drain, active low, NMOS output (sinks current only). Connect a ______________ pull-up resistor from RESET to any supply voltage up to 6V. Active-High Reset Output. RESET remains high while VCC is below _______ the reset threshold or while MR is held low. RESET remains high for Reset Active Timeout Period (tRP) after the reset conditions are terminated. ______________ RESET (UM805/811) 2 RESET (UM812) _______ 3 _______ MR Manual Reset Input._______ A logic low on MR asserts reset. _______Reset remains asserted as long as MR is low and for 240ms after MR returns high. This active-low input has an internal 20kΩ pull-up resistor. It can be driven from a TTL or CMOS-logic line, or shorted to ground with a switch. Leave open if unused. See Figure 2. 4 VCC +5V, +3.3V or +3V Supply Voltage Absolute Maximum Ratings (Note 1) Symbol VCC Parameter Supply Voltage RESET, RESET (Push-Pull) _____________ RESET (Open-Drain) IO PD TA TSTG Unit -0.3 to +6.0 _____________ ICC Value -0.3 to (VCC+0.3) V -0.3 to +6.0 _______ Input Current, VCC, MR _____________ 20 mA 20 mA Output Current, RESET, RESET Continuous Power Dissipation (Derate 4mW/°C above 70°C) Operating Temperature Range 320 mW -40 to +105 °C Storage Temperature Range -65 to +160 °C Lead Temperature (Soldering, 10s) +300 °C Note 1: Stresses beyond those listed under “Absolute maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 3/14 UM805/811/812 Electrical Characteristics (VCC=5V for L/M/J versions, VCC=3.3V for T/S versions, VCC=3V for R version, and VCC=2.5V for Z version, TA=-40°C to +85°C, unless otherwise noted. Typical values are at TA=+25°C.) (Note 2) Symbol Parameter Conditions Min VCC Supply Voltage Range TA=0°C to +70°C 1.0 ICC Supply Current L Version M Version J Version VTH+ Reset Threshold T Version S Version R Version Z Version tRP TA=+25°C 4.56 TA=-40°C to +85°C 4.50 TA=+25°C 4.31 TA=-40°C to +85°C 4.25 TA=+25°C 3.93 TA=-40°C to +85°C 3.89 TA=+25°C 3.04 TA=-40°C to +85°C 3.00 TA=+25°C 2.89 TA=-40°C to +85°C 2.85 TA=+25°C 2.59 TA=-40°C to +85°C 2.55 TA=+25°C 2.28 TA=-40°C to +85°C 2.25 Reset Threshold Tempco VCC to Reset Delay (Note 3) Reset Active Timeout Period 140 Typ Max Unit 5.5 V 2.0 5.0 μA 4.63 4.70 4.75 4.38 4.45 4.50 4.00 4.06 4.10 3.08 3.11 V 3.15 2.93 2.96 3.00 2.63 2.66 2.70 2.32 2.35 2.38 150 ppm/°C 10 μs 240 560 ms ______ tMR MR Minimum μs 10 Pulse Width ______ MR Glitch Immunity (Note 4) 100 ns 0.5 μs ______ tMD MR to Reset Propagation Delay VIH VIL VIH ______ MR Input Threshold VIL VCC>VTH(MAX) UM805/811/812LE/ME/JE 2.3 VCC>VTH(MAX) UM805/811/812TE/SE/RE/ZE 0.7×VCC 0.8 V 0.25×VCC ______ MR Pull-Up Resistance 10 20 30 kΩ ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 4/14 UM805/811/812 Electrical Characteristics (Continued) (VCC=5V for L/M/J versions, VCC=3.3V for T/S versions, VCC=3V for R version, and VCC=2.5V for Z version, TA=-40°C to +85°C, unless otherwise noted. Typical values are at TA=+25°C.) (Note 2) Symbol Parameter VOH VOL RESET Output Voltage VOH ____________ RESET Output Voltage VOL Conditions ISOURCE=150μA, 1.8VVTH(MAX) UM811LE/ME/JE ISINK=1.2mA, VCC=VTH(MIN) UM805/811TE/SE/RE/ZE ISINK=3.2mA, VCC=VTH(MIN) UM805/811LE/ME/JE ISINK=50μA, VCC>1.0V Min Typ Max Unit 0.3 V 0.8×VCC 0.4 0.8×VCC VCC-1.5 0.3 V 0.4 0.3 Note 2: Production testing done at TA=+25°C; limits over temperature guaranteed by design only. _____________ Note 3: RESET output for UM805/811; RESET output for UM812. Note 4: “Glitches” of 100ns or less typically will not generate a reset pulse. ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 5/14 UM805/811/812 Typical Operating Characteristics (TA=+25°C, unless otherwise noted.) Supply Current vs. Temperature (UM811RE) Power-down RESET Delay vs. Temperature (UM811RE) VCC=3.3V Power-up RESET Timeout vs. Temperature ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 6/14 UM805/811/812 Detailed Description RESET Timing The reset signal is asserted LOW for the UM811 and HIGH for the UM812 when the power supply voltage falls below the threshold trip voltage and remains asserted for at least 140ms after the power supply voltage has risen above the threshold. Figure 1. RESET vs. VCC Timing Diagram _______ The reset signal is asserted LOW for the _______ UM811 and HIGH for the UM812 when MR is low and remains asserted for at least 140ms after MR is high. HIGH tMR MR LOW tRP tMD VCC RESET 0V VCC RESET 0V _______ Figure 2. RESET vs. MR Timing Diagram Reset Output A microprocessor’s (µP’s) reset input starts the µP in a known state. These μP supervisory circuits assert reset to prevent code execution errors during power-up, power-down, or brownout conditions. _____________ RESET is guaranteed_____________ to be a logic low for VCC>1V. Once VCC exceeds the reset _____________ threshold, an internal timer keeps RESET low for the reset timeout period; after this interval, RESET goes high. _____________ If a brownout condition occurs (VCC dips below the reset threshold), RESET goes low. Any time ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 7/14 UM805/811/812 _____________ VCC goes below the reset threshold, the internal timer resets to zero,_____________ and RESET goes low. The internal timer starts after VCC returns above the reset threshold, and RESET remains low for the reset timeout period. _______ The manual reset input (MR ) can also initiate a reset. See the Manual Reset Input section. _____________ The UM812 has an active-high RESET output that is the inverse of the UM805/811’s RESET output. The UM805 uses an open-drain output, and the UM811/812 have a push-pull output stage. _____________ Connect a pull-up resistor on the UM805’s RESET output to any supply between 0 and 6V. Manual Reset Input Many μP-based products require manual reset capability, allowing the operator, a test technician, or _______ reset. Reset remains asserted external_______ logic circuitry to initiate a reset. A logic low on MR asserts _______ returns high. This input while MR is low, and for the Reset Active Timeout Period (tRP) after MR _______ has an internal 20kΩ pull-up resistor, so it can be left open if it is not used. MR can be driven with TTL or CMOS-logic levels, _______ or with open-drain/collector outputs. Connect a normally open to GND to create a manual-reset function; external debounce momentary switch from MR _______ cables or if the device is used in a noisy circuitry is not required. If MR is driven from long_______ environment, connecting a 0.1μF capacitor from MR to ground provides additional noise immunity. Reset Threshold Accuracy The UM805/811/812 are ideal for systems using a 5V±5% or 3V±5% power supply with ICs specified for 5V±10% or 3V±10%, respectively. They are designed to meet worst-case specifications over temperature. The reset is guaranteed to assert after the power supply falls out of regulation, but before power drops below the minimum specified operating voltage range for the system ICs. The thresholds are pre-trimmed and exhibit tight distribution, reducing the range over which an undesirable reset may occur. ________________________________________________________________________ http://www.union-ic.com Rev.02 Oct.2016 8/14 UM805/811/812 Applications Information Negative-Going VCC Transients In addition to issuing a reset to the µP during power-up, power-down, and brownout conditions, the UM805/811/812 are relatively immune to short-duration negative-going VCC transients (glitches). Figure 3 shows typical transient duration vs. reset comparator overdrive, for which the UM805/811/812 do not generate a reset pulse. The graph was generated using a negative-going pulse applied to VCC, starting above the actual reset threshold and ending below it by the magnitude indicated (reset comparator overdrive). The graph indicates the typical maximum pulse width a negative-going VCC transient may have without causing a reset pulse to be issued. As the magnitude of the transient increases (goes farther below the reset threshold), the maximum allowable pulse width decreases. Typically, for the UM8_ _LE/ME/JE, a VCC transient that goes 125mV below the reset threshold and lasts 40µs or less will not cause a reset pulse to be issued. A 0.1µF capacitor mounted as close as possible to the VCC provides additional transient immunity. UM8_ _LE/ME/JE UM8 TE/SE/RE/ZE Figure 3. Maximum Transient Duration without Causing a Reset Pulse vs. Reset Comparator Overdrive ______________ Ensuring a Valid RESET Output Down to VCC=0V _____________ When VCC falls below 1V, the UM811 RESET output no longer sinks current—it becomes an open _____________ circuit. Therefore, high-impedance CMOS-logic inputs connected to RESET can drift to undetermined voltages. This presents no problem in most applications since most µP and other _____________ circuitry is inoperative with VCC below 1V. However, _____________ in applications where RESET must be valid down to 0V, adding a pull-down _____________ resistor to RESET pin will causes any stray leakage currents to 4). R1’s value is not critical; 100kΩ is large enough flow to ground, holding RESET low (Figure _____________ _____________ not to load RESET and small enough to pull RESET to ground. A 100kΩ pull-up resistor to VCC is also recommended for the UM812 if RESET is required to remain valid for VCC
UM805RE 价格&库存
很抱歉,暂时无法提供与“UM805RE”相匹配的价格&库存,您可以联系我们找货
