NDC7002N
NDC7002N
    UMW(友台)
    SOT23-6
    NDC7002N
NDC7002N 数据手册
UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor General Description Features 0.51A, 50V, RDS(ON) = 2Ω @ VGS=10V These dual N-Channel enhancement mode power field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology. This very high density process has been designed to minimize on-state resistance, provide rugged and reliable performance and fast switching. These devices is particularly suited for low voltage applications requiring a low current high side switch. High density cell design for low RDS(ON). Proprietary SOT23-6 package design using copper lead frame for superior thermal and electrical capabilities. High saturation current. ____________________________________________________________________________________________ 4 3 5 2 6 1 SOT23-6 Absolute Maximum Ratings T A = 25°C unless otherwise noted Symbol Parameter NDC7002N Units VDSS Drain-Source Voltage 50 V VGSS Gate-Source Voltage - Continuous 20 V ID Drain Current - Continuous 0.51 A (Note 1a) - Pulsed PD Maximum Power Dissipation 1.5 (Note 1a) (Note 1b) (Note 1c) TJ,TSTG Operating and Storage Temperature Range 0.96 W 0.9 0.7 -55 to 150 °C (Note 1a) 130 °C/W (Note 1) 60 °C/W THERMAL CHARACTERISTICS RθJA Thermal Resistance, Junction-to-Ambient RθJC Thermal Resistance, Junction-to-Case www.umw-ic.com 1 友台半导体有限公司 UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) Symbol Parameter Conditions Min Typ Max Units OFF CHARACTERISTICS BVDSS Drain-Source Breakdown Voltage VGS = 0 V, ID = 250 µA IDSS Zero Gate Voltage Drain Current VDS = 40 V, VGS = 0 V 50 V 1 µA 500 TJ = 125°C IGSSF Gate - Body Leakage, Forward VGS = 20 V, VDS = 0 V 100 nA IGSSR Gate - Body Leakage, Reverse VGS = -20 V, VDS= 0 V -100 nA V ON CHARACTERISTICS (Note 2) VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 µA TJ = 125°C RDS(ON) Static Drain-Source On-Resistance 1 1.9 2.5 0.8 1.5 2.2 VGS = 10 V, ID = 0.51 A TJ = 125°C VGS = 4.5 V, ID = 0.35 A 1 2 1.7 3.5 1.6 4 1.5 Ω ID(on) On-State Drain Current VGS = 10 V, VDS = 10 V A gFS Forward Transconductance VDS = 10 V, ID = 0.51 A 400 mS VDS = 25 V, VGS = 0 V, f = 1.0 MHz 20 pF 13 pF 5 pF DYNAMIC CHARACTERISTICS Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance SWITCHING CHARACTERISTICS (Note 2) tD(on) Turn - On Delay Time tr Turn - On Rise Time VDD = 25 V, ID = 0.25 A, VGS = 10 V, RGEN = 25 Ω 6 20 6 20 tD(off) Turn - Off Delay Time 11 20 tf Turn - Off Fall Time 5 20 Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge www.umw-ic.com VDS = 25 V, ID = 0.51 A, VGS = 10 V 2 nS 1 nC 0.19 nC 0.33 nC 友台半导体有限公司 UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) Symbol Parameter Conditions Min Typ Max Units DRAIN-SOURCE DIODE CHARACTERISTICS IS Maximum Continuous Source Current 0.51 A ISM Maximum Pulse Source Current (Note 2) 1.5 A VSD Drain-Source Diode Forward Voltage 1.2 V VGS = 0 V, IS = 0.51 A (Note 2) 0.8 Notes: 1. RθJA is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting surface of the drain pins. RθJC is guaranteed by design while RθCA is determined by the user's board design. P D (t ) = T J−TA R θJ A(t ) = T J−TA R θJ C+RθCA(t ) = I 2D (t ) × RDS(ON ) TJ Typical RθJA for single device operation using the board layouts shown below on 4.5"x5" FR-4 PCB in a still air environment: o 2 a. 130 C/W when mounted on a 0.125 in pad of 2oz cpper. b. 140oC/W when mounted on a 0.005 in2 pad of 2oz cpper. c. 180oC/W when mounted on a 0.0015 in2 pad of 2oz cpper. 1a 1b 1c Scale 1 : 1 on letter size paper 2. Pulse Test: Pulse Width < 300µs, Duty Cycle < 2.0%. www.umw-ic.com 3 友台半导体有限公司 UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor Typical Electrical Characteristics 1.5 3 8.0 7.0 VGS = 3.5V 6.0 1.2 RDS(on) , NORMALIZED 5.5 5.0 0.9 4.5 0.6 4.0 3.5 0.3 DRAIN-SOURCE ON-RESISTANCE I D , DRAIN-SOURCE CURRENT (A) V GS =10V 3.0 5.0 6.0 1.5 2 3 4 , DRAIN-SOURCE VOLTAGE (V) 8.0 10 1 0.3 5 0.6 0.9 I D , DRAIN CURRENT (A) 1.2 1.5 Figure 2. On-Resistance Variation with Gate Voltage and Drain Current. 2 2.5 V GS = 10V R DS(on), NORMALIZED DRAIN-SOURCE ON-RESISTANCE I D = 0.51A 1.8 R DS(ON), NORMALIZED 7.0 0 1 VDS DRAIN-SOURCE ON-RESISTANCE 5.5 0.5 Figure 1. On-Region Characteristics. V GS = 10V 1.6 1.4 1.2 1 0.8 0.6 0.4 -50 2 TJ = 125°C 1.5 25°C 1 -55°C 0.5 -25 0 25 50 75 100 TJ , JUNCTION TEMPERATURE (°C) 125 0 150 0.3 I Figure 3. On-Resistance Variation with Temperature. D 0.6 0.9 , DRAIN CURRENT (A) 1.2 1.5 Figure 4. On-Resistance Variation with Drain Current and Temperature. 1.2 V DS = 10V T J = -55°C 25°C 125°C V th, NORMALIZED 1.2 0.9 0.6 0.3 0 1 2 3 4 5 6 V GS , GATE TO SOURCE VOLTAGE (V) 7 8 V DS = V GS I D = 250µA 1.1 1 0.9 0.8 0.7 -50 -25 0 25 50 75 100 TJ , JUNCTION TEMPERATURE (°C) 125 150 Figure 6. Gate Threshold Variation with Temperature. Figure 5. Transfer Characteristics. www.umw-ic.com GATE-SOURCE THRESHOLD VOLTAGE 1.5 I D , DRAIN CURRENT (A) 4.5 2 0 0 4.0 2.5 4 友台半导体有限公司 UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor 1.16 I D 1.5 1 = 250µA 1.12 1.08 1.04 1 0.96 0.92 0.88 -50 -25 0 25 50 75 100 TJ , JUNCTION TEMPERATURE (°C) 125 TJ = 125°C -55°C 0.01 Figure 7. Breakdown Voltage Variation with Temperature. 0.4 0.6 0.8 1 V SD , BODY DIODE FORWARD VOLTAGE (V) 1.2 Figure 8. Body Diode Forward Voltage Variation with Current and Temperature. 10 100 VDS = 25V V GS , GATE-SOURCE VOLTAGE (V) 50 C iss CAPACITANCE (pF) 25°C 0.1 0.001 0.2 150 V GS = 0V 0.5 I S , REVERSE DRAIN CURRENT (A) BV DSS , NORMALIZED DRAIN-SOURCE BREAKDOWN VOLTAGE Typical Electrical Characteristics (continued) 20 C oss 10 C rss 5 f = 1 MHz 2 V GS = 0 V 1 0.1 8 I D = 0.51A 6 4 2 0 0.2 0.5 1 2 5 10 20 50 V DS , DRAIN TO SOURCE VOLTAGE (V) Figure 9. Capacitance Characteristics. 0 0.2 0.4 0.6 0.8 Q g , GATE CHARGE (nC) 1 1.2 Figure 10. Gate Charge Characteristics. 0.7 V DS = 10V T I D , DRAIN CURRENT (A) 0.6 0.5 J = -55°C 25°C 0.4 125°C 0.3 0.2 0.1 0 0 0.3 V GS 0.6 0.9 1.2 , GATE TO SOURCE VOLTAGE (V) 1.5 Figure 11. Transconductance Variation with Drain Current and Temperature. www.umw-ic.com 5 友台半导体有限公司 R UMW UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor Typical Thermal Characteristics 0.55 I D , STEADY-STATE DRAIN CURRENT (A) STEADY-STATE POWER DISSIPATION (W) 1.2 1.1 1a 1 0.9 1b 0.8 1c 4.5"x5" FR-4 Board 0.7 o TA = 2 5 C Still Air 0.6 0 0.2 0.4 0.6 0.8 2oz COPPER MOUNTING PAD AREA (in 2 ) 1 1a 0.5 1b 0.45 1c 0.4 4.5"x5" FR-4 Board o TA = 2 5 C Still Air VG S = 1 0 V 0.35 0 Figure 12. SOT23-6 Dual Package Maximum Steady-State Power Dissipation versus Copper Mounting Pad Area. 0.025 0.05 0.075 0.1 2 2oz COPPER MOUNTING PAD AREA (in ) 0.125 Figure 13. Maximum Steady-State Drain Current versus Copper Mounting Pad Area. 3 2 I D , DRAIN CURRENT (A) 1 RD S(O N) LIM IT 10 0 1m us s 0.5 10 0.2 10 0.1 V 0.05 GS 0m ms s 1s = 10V DC SINGLE PULSE R θJ A = See Note 1c 0.02 T A = 25°C 0.01 1 2 5 10 20 V DS , DRAIN-SOURCE VOLTAGE (V) 50 70 Figure 14. Maximum Safe Operating Area. r(t), NORMALIZED EFFECTIVE TRANSIENT THERMAL RESISTANCE 1 0 .5 D = 0.5 0 .2 0.2 0 .1 R JA (t) = r(t) * R JA θ θ R JA = See Note 1c θ 0.1 P(pk) 0.05 t1 0.05 0.02 0.01 0.02 0.01 0 .0 0 0 1 www.umw-ic.com = P * R JA (t) θ Duty Cycle, D = t 1 / t 2 A Single Pulse 0 .001 t2 TJ - T 0 .0 1 0 .1 t 1, TIME (sec) 6 1 10 100 300 友台半导体有限公司 UMW R UMW NDC7002N SOT23-6 Dual N-Channel Enhancement Mode Field Effect Transistor SOT23-6 www.umw-ic.com 7 友台半导体有限公司
NDC7002N 价格&库存
很抱歉,暂时无法提供与“NDC7002N”相匹配的价格&库存,您可以联系我们找货
NDC7002N
  • 1+0.66770
  • 200+0.45980
  • 1500+0.41800
  • 3000+0.39050
库存:5186
