SOD4001
SOD4001
    MDD(辰达半导体)
    SMF(SOD-123FL)
    整流二极管 VR=50V IF=1A VF=1.1V IR=5uA
SOD4001 数据手册
SOD4001 THRU SOD4007 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER Features SOD-123FL  Glass passivated device  Ideal for surface mouted applications  Low reverse leakage  Metallurgically bonded construction 0.079(2.00) 0.063(1.60) 0.046 (1.20) 0.031 (0.80) 0.118(3.00) 0.098(2.50)  High temperature soldering guaranteed:  250°C/10 seconds,0.375”(9.5mm) lead length, 5 0.052(1.35) 0.035(0.90) lbs. (2.3kg) tension 0.012(0.30) 0.002(0.05) 0.039(1.00) 0.012(0.30) 0.158(4.00) 0.134(3.45) Mechanical Data Case: JEDEC 6OD-123FL molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SOD4001 SOD4002 SOD4003 SOD4004 SOD4005 SOD4006 SOD4007 Parameter UNITS SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRRM VRMS VDC D1 D2 D3 D4 D5 D6 D7 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V Maximum average forward rectified current at TL(see fig.1) I(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 30 A Maximum instantaneous forward voltage at 1.0A VF 1.1 V Maximum DC reverse current at rated DCblocking voltage IR 5.0 50 uA TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range CJ RJA 8 pF 90 ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Note: 1.Averaged over any 20ms period. 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2025A4 Page :1 SOD4001 THRU SOD4007 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Instaneous Reverse Characteristics 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current (μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 100 T J =15 0 °C 10 1.0 T J =25 °C 0.01 Junction Capacitance (pF) C 2 5° TJ = TJ = 10 0°C 0°C 15 TJ = Instaneous Forward Current (A) 0.2 0.9 60 100 80 Fig.4 Typical Junction Capacitance 0.5 0.8 40 percent of Rated Peak Reverse Voltage (%) 1.0 0.7 20 0 Fig.3 Typical Forward Characteristic 0.6 T J =75 °C 0.1 Case Temperature (°C) 0.1 0.5 T J =125 °C 1.0 1.1 100 T J=25°C 10 1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surae Current 35 30 25 20 15 10 05 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2025A4 Page :2 SOD4001 THRU SOD4007 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 190*190*190 178 400*400*220 180,000 Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 1.2 0.047 B 1.2 3.2 0.126 D 2 0.079 E 4.4 0.173 C 0.047 Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A4 Page :3
SOD4001 价格&库存
很抱歉,暂时无法提供与“SOD4001”相匹配的价格&库存,您可以联系我们找货
SOD4001
  • 10+0.07570
  • 100+0.06200
  • 300+0.05460
  • 3000+0.03850
  • 6000+0.03450
  • 9000+0.03240
库存:12292
SOD4001
  • 50+0.06953
  • 600+0.05022
  • 1200+0.04947
  • 3000+0.03553
库存:3000
