BL1551
BL1551
    BL(博林)
    SOT-363
    BL1551
BL1551 数据手册
BL1551—Single SPDT Analog Switch 2.7Ω Ω Low Voltage SPDT Analog Switch in 6-pin SC70 Description Features  Wide Power Supply Range: 1.8V to 5.5V The BL1551 is a Single Wide-Bandwidth, fast single-  High Bandwidth: 300MHz pole double-throw (SPDT) CMOS switch featuring an  High Off-Isolation: On-Resistance of 2.7 ohm at VCC=5.0V and wide 84dB at 1MHz power supply range from 1.8V to 5.5V. It can be used 51dB at 10MHz as an analog switch or as a low-delay bus switch.  On-Resistance: 2.7Ω(typ) at 5.0V  Fast Switching Time The 300MHz high bandwidth performance supports the high frequency application. Break-before-make function for both parts eliminates ton = 12.0ns; toff = 5.0ns signal disruption during switching from preventing  TTL/CMOS Compatible  Break-Before-Make Switching  Rail-to-Rail Signal Range  Operation Temperature Range: both switches being enabled simultaneously. Block Diagram -40℃ to 85℃  BL1551 Lead (Pb) Free SC70-6 Package A1 1 6 ENB GND 2 5 VCC A2 3 4 B Applications  Wireless Handsets  MP3 Players  Portable Electronic Devices  Relay Replacement  PDAs  Audio & Video Signal Routing  PCMCIA Cards  Computer Peripherals  Modems Function Table Pin Configuration ENB VCC 6 5 B ENB Function 1 A1 Connected to B 0 A2 Connected to B 4 Pin Description ASSS 1 2 3 A1 GND A2 SSS: production id http://www.belling.com.cn -1- Pin Name Type Description VCC PWR Power Supply GND Ground Ground B Input/Output Data Port A1 Input/Output Data Port A2 Input/Output Data Port ENB Input Logic Control Signal Total 10 Pages BL1551—Single SPDT Analog Switch ABSOLUTE MAXIMUM RATINGS Parameter Symbol Min Max Units DC Supply Voltage VCC -0.3 6 V DC Switch Voltage VA1/ VA2/ VB -0.3 VSUP + 0.3 V DC Input Voltage VENB -0.3 VSUP + 0.3 V Continuous Current I(A1/A2/B) -200 +200 mA Peak Current(1) IPEAK(A1/A2/B) -300 +300 mA TA -40 85 ℃ Operating Temperature Range Notes: (1) Pulsed at 1ms, 50% duty circle (2) Stress beyond above listed “Absolute Maximum Ratings” may lead permanent damage to the device. These are stress ratings only and operations of the device at these or any other conditions beyond those indicated in the operational sections of the specifications are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. (3) Control input(VENB) must be held HIGH or LOW, and mustn’t be floated. RECOMMENDED OPERATING CONDITIONS DC Supply Voltage (VCC) …………………………………………….1.8V to 5.5V Switch Input Voltage (VS) ………………………………………………...0V to VCC Control Input Voltage (VENB)……………………………………………. 0V to VCC Operation Temperature (TA)……………………………………..-40℃ to +85℃ ORDERING INFORMATION MODEL PINPACKAGE SPECIFIED TEMPERATURE RANGE PACKAGE MARKING BL1551 SC70 - 6 - 40°C to +85°C Asss (1) PACKAGE OPTION Tape and Reel, 3000 WHERE(1): “sss” IS 3 DIGITS PRODUCTION ID SIZE OF ALL OTHER CHARACTERS = 20 mil COLOUR: LASER MARKING http://www.belling.com.cn -2- Total 10 Pages BL1551—Single SPDT Analog Switch DC ELECTRICAL CHARACTERISTICS @ +2.7V Supply Parameter Symbol Conditions Guaranteed Limit Min. Typ.(1) Max. Unit Analog Switch Analog Signal Range VA1/VA2/VB A1 On-Resistance RON(A1) VCC = 2.7V; IB =-10mA ; VA1=1.5V 5.5 Ω A2 On-Resistance 0 VCC V RON(A2) VCC = 2.7V; IB =-10mA ; VA2 =1.5V 5.5 Ω A1 On-Resistance Flatness (2) RFLAT(A1) VCC = 2.7V; IB =-10mA ; VA1 =1.5V 2.3 Ω A2 On-Resistance Flatness (2) RFLAT(A2) VCC = 2.7V; IB =-10mA ; VA2 =1.5V 2.3 Ω On-Resistance Match Between Channels (3) A1 or A2 Off Leakage Current B On Leakage Current △RON VCC = 2.7V; IB =-10mA ; VA2 /VA1=1.5 IOFF(A1) or VCC = 3.6V; VA1 or VA2 = 3V, 0.3V; IOFF(A2) VB = 0.3V, 3 V ION(B) VCC = 3.6V; VA1 or VA2 = 3.3V, 0.3V; VB = 0.3V, 3.3 V or floating 0.15 1 Ω 0.01 1 uA 0.01 1 uA Digital I/O Input Voltage High VIH Minimum High Level Input Voltage Input Voltage Low VIL Maximum Low Level Input Voltage Input Leakage Current IENB VENB = 0 or Vcc 1 V 0.01 0.5 V 1 uA Note: (1) Typical characteristics are at +3V supply and +25°C (2) Flatness is defined as the difference between the maximum and minimum value of on resistance as measured over the specified analog signal ranges. (3) △RON= RON(MAX) - RON(MIN), between A1 and A2 . http://www.belling.com.cn -3- Total 10 Pages BL1551—Single SPDT Analog Switch DYNAMIC CHARACTERISTICS @ +2.7V Supply Parameter Symbol Conditions Guaranteed Limit Min. Typ. (1) Max. Unit AC ELECTRICAL CHARACTERISTICS Turn-On Time tON Turn-Off Time tOFF Break-Before-Make Time tBBM VCC = 2.7V; VA1 or VA2 = 1.5V, RL = 300Ω; CL = 35pF, VIH=1.5V,VIL=0V VCC = 2.7V; VA1 or VA2 = 1.5V, RL = 300Ω; CL = 35pF, VIH=1.5V,VIL=0V VCC = 2.7V; VA1 or VA2 = 1.5V, RL = 300Ω; CL = 35pF 17.0 ns 9.0 ns 15.0 ns NC OFF Capacitance COFF(A1) f = 1MHz 5.5 pF NO OFF Capacitance COFF(A2) f = 1MHz 5.5 pF NC ON Capacitance CON(A1) f = 1MHz 15.5 pF NO ON Capacitance CON(A2) f = 1MHz 15.5 pF 300 MHz ADDITIONAL APPLICATION CHARACTERISTICS 3dB Bandwidth Off Isolation (2) f3dB VIso Signal = 0dBm, RL = 50Ω, CL = 5pF RL = 50Ω, CL = 5pF, f = 1MHz -84 dB Signal = 0dBm f =10MHz -51 dB Supply Power Supply Range Vcc 1.8 5.5 Note: (1) Typical characteristics are at +3V supply and 25°C (2) Off Channel Isolation = 20log10 [(VA1\A2)/VB] http://www.belling.com.cn -4- Total 10 Pages V BL1551—Single SPDT Analog Switch DC ELECTRICAL CHARACTERISTICS @ +5.0V Supply Parameter Symbol Conditions Guaranteed Limit Min. Typ.(1) Max. Unit Analog Switch Analog Signal Range VA1/VA2/VB A1 On-Resistance RON(A1) VCC = 5.0V; IB =-10mA ; VA1=3.5V 2.7 Ω A2 On-Resistance 0 VCC V RON(A2) VCC = 5.0V; IB =-10mA ; VA2 =3.5V 2.7 Ω A1 On-Resistance Flatness (2) RFLAT(A1) VCC = 5.0V; IB =-10mA ; VA1=3.5V 0.8 Ω A2 On-Resistance Flatness (2) RFLAT(A2) VCC = 5.0V; IB =-10mA ; VA2 =3.5V 0.8 Ω 0.15 Ω On-Resistance Match Between Channels (3) A1 or A2 Off Leakage Current B On Leakage Current △RON VCC = 5.0V; IB =-10mA ; VA2 /VA1=3.5 IOFF(A1) or VCC = 5.5V; VNO or VNC = 4.5V, 1.0V; IOFF(A2) ION(B) VCOM = 1.0V, 4.5 V VCC = 5.5V; VA1 or VA2 = 4.5V, 1.0V; VB = 1.0V, 4.5 V or floating 0.01 1 uA 0.01 1 uA Digital I/O Input Voltage High VIH Minimum High Level Input Voltage Input Voltage Low VIL Maximum Low Level Input Voltage Input Leakage Current IENB VENB = 0 or Vcc 1 V 0.01 0.5 V 1 uA Note: (1) Typical characteristics are at +5.0V supply and +25°C (2) Flatness is defined as the difference between the maximum and minimum value of on resistance as measured over the specified analog signal ranges. (3) △RON= RON(MAX) - RON(MIN), between A1 and A2 . http://www.belling.com.cn -5- Total 10 Pages BL1551—Single SPDT Analog Switch DYNAMIC CHARACTERISTICS @ +5.0V Supply Parameter Symbol Conditions Guaranteed Limit Min. Typ. (1) Max. Unit AC ELECTRICAL CHARACTERISTICS Turn-On Time tON Turn-Off Time tOFF Break-Before-Make Time tBBM VCC = 5.0V; VA1 or VA2 = 3.0V, RL = 300Ω; CL = 35pF, VIH=1.5V,VIL=0V VCC = 5.0V; VA1 or VA2 = 3.5V, RL = 300Ω; CL = 35pF, VIH=1.5V,VIL=0V VCC = 5.0V; VA1 or VA2 = 3.5V, RL = 300Ω; CL = 35pF 12.0 ns 5.0 ns 8.5 ns NC OFF Capacitance COFF(A1) f = 1MHz 5.5 pF NO OFF Capacitance COFF(A2) f = 1MHz 5.5 pF NC ON Capacitance CON(A1) f = 1MHz 15.5 pF NO ON Capacitance CON(A2) f = 1MHz 15.5 pF 300 MHz ADDITIONAL APPLICATION CHARACTERISTICS 3dB Bandwidth Off Isolation (2) f3dB VIso Signal = 0dBm, RL = 50Ω, CL = 5pF RL = 50Ω, CL = 5pF, f = 1MHz -84 dB Signal = 0dBm f =10MHz -51 dB Supply Power Supply Range Vcc 1.8 5.5 Note: (1) Typical characteristics are at +5.0V supply and 25°C (2) Off Channel Isolation = 20log10 [(VA1\A2)/VB] http://www.belling.com.cn -6- Total 10 Pages V BL1551—Single SPDT Analog Switch TEST SETUP CIRCUITS 10mA V1 VCC BL1551 VCC B VA1 or VA2 0.1uF VA2 or VA1 Ron=V1/ 10mA GND Figure1. Test Circuit for On Resister VCC DC=VCC/ 2 AC=1 50 ohm VCC BL1551 B A1 or A2 VOUT VCC 0.1uF CL=5pF 50 ohm GND ENB GND Figure2. Test Circuit for Bandwidth VCC DC=VCC/ 2 AC=1 50 ohm VCC BL1551 B A1 or A2 VOUT VCC 0.1uF CL=5pF 50 ohm GND ENB GND Figure3. Test Circuit for Off Isolation http://www.belling.com.cn -7- Total 10 Pages BL1551—Single SPDT Analog Switch VCC A2 or A1 VCC BL1551 B A1 or A2 VOUT 300 ohm VCC 0.1uF CL =35pF GND ENB GND 50% VENB 50% 90% 10% VOUT tON tOFF Test Circuit 4. Test Circuit for Switch Times VCC A2 or A1 A1 or A2 VCC BL1551 B VOUT 300 ohm VCC 0.1uF CL =35pF GND ENB GND VENB 50% VOUT tD Test Circuit 5. Test Circuit for Break-Before-Make Time Delay, tD http://www.belling.com.cn -8- Total 10 Pages BL1551—Single SPDT Analog Switch PACKAGE OUTLINE DIMENSIONS (SC70-6) SC70-6 D e1 e E1 b A1 A2 A E θ 0.20 L http://www.belling.com.cn C L1 -9- Total 10 Pages BL1551—Single SPDT Analog Switch Symbol A A1 A2 b c D E E1 e e1 L L1 θ http://www.belling.com.cn Dimensions in Millimeters Min Max 0.900 1.100 0.000 0.100 0.900 1.000 0.150 0.350 0.080 0.150 2.000 2.200 1.150 1.350 2.150 2.450 0.650TYP 1.200 1.400 0.525REF 0.260 0.460 0° 8° - 10 - Dimensions in Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026TYP 0.047 0.055 0.021REF 0.010 0.018 0° 8° Total 10 Pages
BL1551 价格&库存
很抱歉,暂时无法提供与“BL1551”相匹配的价格&库存,您可以联系我们找货
