74LVC1G04GX4
74LVC1G04GX4
    NEXPERIA(安世)
    74LVC1G04GX4
74LVC1G04GX4 数据手册
74LVC1G04 Single inverter Rev. 16 — 9 February 2022 Product data sheet 1. General description The 74LVC1G04 is a single inverter. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V Overvoltage tolerant inputs to 5.5 V High noise immunity CMOS low power dissipation IOFF circuitry provides partial Power-down mode operation ±24 mA output drive (VCC = 3.0 V) Latch-up performance exceeds 250 mA Direct interface with TTL levels Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) ESD protection: • HBM: ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2000 V • MM: JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C. 74LVC1G04 Nexperia Single inverter 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G04GW -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G04GV -40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G04GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1 × 1.45 × 0.5 mm 74LVC1G04GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74LVC1G04GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 74LVC1G04GX -40 °C to +125 °C X2SON5 plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 × 0.8 × 0.32 mm SOT1226-3 74LVC1G04GX4 -40 °C to +125 °C X2SON4 plastic thermal enhanced extremely thin small outline package; no leads; 4 terminals; body 0.6 × 0.6 × 0.32 mm SOT1269-2 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G04GW VC 74LVC1G04GV V04 74LVC1G04GM VC 74LVC1G04GN VC 74LVC1G04GS VC 74LVC1G04GX VC 74LVC1G04GX4 VC [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram A Y 1 Y A mna109 mna108 Fig. 1. Logic symbol 74LVC1G04 Product data sheet Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 mna110 Fig. 3. Logic diagram © Nexperia B.V. 2022. All rights reserved 2 / 18 74LVC1G04 Nexperia Single inverter 6. Pinning information 6.1. Pinning 74LVC1G04 n.c. 1 A 2 GND 3 74LVC1G04 5 VCC 4 Y n.c. 1 6 VCC A 2 5 n.c. GND 3 4 Y 001aaf050 Transparent top view 001aab618 Fig. 4. Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A) Fig. 5. Pin configuration SOT886, SOT1115 and SOT1202 (XSON6) 74LVC1G04 74LVC1G04 n.c. 1 5 VCC 4 Y A 1 4 VCC GND 2 3 Y 3 GND A Fig. 6. 2 aaa-003020 aaa-028400 Transparent top view Transparent top view Pin configuration SOT1226-3 (X2SON5) Fig. 7. Pin configuration SOT1269-2 (X2SON4) 6.2. Pin description Table 3. Pin description Symbol Pin Description TSSOP5, SC-74A and X2SON5 XSON6 X2SON4 n.c. 1 1, 5 - not connected A 2 2 1 data input GND 3 3 2 ground (0 V) Y 4 4 3 data output VCC 5 6 4 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Input Output A Y L H H L 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 3 / 18 74LVC1G04 Nexperia Single inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage Active mode [1] -0.5 VCC + 0.5 V Power-down mode; VCC = 0 V [1] -0.5 +6.5 V - ±50 mA VI < 0 V [1] IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation [1] [2] [3] VO = 0 to VCC mA Tamb = -40 °C to +125 °C TSSOP5, SC-74A, XSON6 and X2SON5 package [2] - 250 mW X2SON4 package [3] - 150 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT353-1 (TSSOP5) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT753 (SC-74A) package: Ptot derates linearly with 3.8 mW/K above 85 °C. For SOT886 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT1115 (XSON6) package: Ptot derates linearly with 3.2 mW/K above 71 °C. For SOT1202 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT1226-3 (X2SON5) package: Ptot derates linearly with 3.0 mW/K above 67 °C. For SOT1269-2 (X2SON4) package: Ptot derates linearly with 1.7 mW/K above 57 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74LVC1G04 Product data sheet Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO Power-down mode; VCC = 0 V 0 - 5.5 VO -40 - +125 °C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 4 / 18 74LVC1G04 Nexperia Single inverter 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - VCC = 4.5 V to 5.5 V - - VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 - - V IO = -8 mA; VCC = 2.3 V 1.9 - - V IO = -12 mA; VCC = 2.7 V 2.2 - - V IO = -24 mA; VCC = 3.0 V 2.3 - - V IO = -32 mA; VCC = 4.5 V 3.8 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V Tamb = -40 °C to +85 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V LOW-level output voltage 0.7 V 0.8 V 0.3 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL 0.35 × VCC V VI = VIH or VIL - - 0.55 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - ±0.1 ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - ±0.1 ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 μA ΔICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 μA CI input capacitance VCC = 3.3 V; VI = GND to VCC - 5 - pF 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 5 / 18 74LVC1G04 Nexperia Single inverter Symbol Parameter Conditions Min Typ[1] Max Unit 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - VCC = 4.5 V to 5.5 V - - VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 0.95 - - V IO = -8 mA; VCC = 2.3 V 1.7 - - V IO = -12 mA; VCC = 2.7 V 1.9 - - V IO = -24 mA; VCC = 3.0 V 2.0 - - V IO = -32 mA; VCC = 4.5 V 3.4 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage VOH HIGH-level output voltage VCC = 1.65 V to 1.95 V LOW-level output voltage 0.7 V 0.8 V 0.3 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL 0.35 × VCC V VI = VIH or VIL - - 0.80 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 μA ΔICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - - 500 μA [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 6 / 18 74LVC1G04 Nexperia Single inverter 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 9. Symbol Parameter -40 °C to +85 °C CPD power dissipation capacitance -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 1.0 3.0 7.5 1.0 9.5 ns VCC = 2.3 V to 2.7 V 0.5 2.0 5.0 0.5 6.5 ns VCC = 2.7 V 0.5 2.3 5.2 0.5 7.0 ns VCC = 3.0 V to 3.6 V 0.5 2.0 4.2 0.5 5.5 ns VCC = 4.5 V to 5.5 V 0.5 1.6 3.7 0.5 5.0 ns - 14 - - - pF propagation delay A to Y; see Fig. 8 tpd [1] [2] [3] Conditions [2] VI = GND to VCC; VCC = 3.3 V [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL x VCC x fo) = sum of outputs. 11.1. Waveform and test circuit VI VM A input GND t PHL t PLH VOH VM Y output VOL mna640 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. The input A to output Y propagation delays Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 x VCC 0.5 x VCC 2.3 V to 2.7 V 0.5 x VCC 0.5 x VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 x VCC 0.5 x VCC 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 7 / 18 74LVC1G04 Nexperia Single inverter VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G04 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 8 / 18 74LVC1G04 Nexperia Single inverter 12. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D SOT353-1 E B A X c (5x) y HE v M A e1 5 4 pin 1 index A 1 2 A1 3 A3 θ Lp w M B bp (5x) e A2 detail X e 0 3 mm scale Dimensions (mm are the original dimensions) Unit mm max min A A1 A2 A3 1.1 0.8 0.1 0 1.0 0.8 0.15 bp c 0.30 0.25 0.15 0.08 D(1) E(1) 2.2 1.8 1.35 0.65 1.15 e e1 HE Lp v w y θ 1.3 2.4 1.8 0.46 0.26 0.3 0.1 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. Outline version SOT353-1 References IEC JEDEC JEITA MO-203 SC-88A sot353-1_po European projection Issue date 21-12-15 21-12-16 Fig. 10. Package outline SOT353-1 (TSSOP5) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 9 / 18 74LVC1G04 Nexperia Single inverter Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Fig. 11. Package outline SOT753 (SC-74A) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 10 / 18 74LVC1G04 Nexperia Single inverter SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 12. Package outline SOT886 (XSON6) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 11 / 18 74LVC1G04 Nexperia Single inverter XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 e1 L L1 0.35 0.40 0.30 0.35 0.27 0.32 0.3 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 13. Package outline SOT1115 (XSON6) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 12 / 18 74LVC1G04 Nexperia Single inverter XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 14. Package outline SOT1202 (XSON6) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 13 / 18 74LVC1G04 Nexperia Single inverter X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.32 mm SOT1226-3 C Seating Plane X 5x y C D A B E A A3 pin 1 index area A1 pin 1 index area e 1 2 b (4x) v w y1 C C A B C L (4x) 3 k D h (6x) x) (4 5 4 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 A3 D Dh E b e K L max 0.35 0.04 0.85 0.30 0.85 0.25 0.27 0.10 0.80 0.25 0.80 0.20 0.50 0.22 nom 0.32 0.02 (Typ.) min 0.30 0.00 0.75 0.20 0.75 0.15 0.20 0.17 v 0.1 w y y1 0.05 0.05 0.05 sot1226-3_po Outline version SOT1226-3 References IEC JEDEC EIAJ European projection Issue date 19-11-06 19-11-07 --- Fig. 15. Package outline SOT1226-3 (X2SON5) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 14 / 18 74LVC1G04 Nexperia Single inverter X2SON4: plastic thermal enhanced extremely thin small outline package; no leads; 4 terminals; body 0.6 x 0.6 x 0.32 mm SOT1269-2 X A D B pin 1 ID area A E detail X A1 C e y1 C 2 y 3 L (4x) e 1 4 v w b (4x) C A B C 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 D E b e L max 0.35 0.04 0.65 0.65 0.20 nom 0.32 0.02 0.60 0.60 0.15 0.40 min 0.30 0.00 0.55 0.55 0.10 v w y y1 0.23 0.18 0.10 0.05 0.05 0.05 0.13 sot1269-2_po Outline version SOT1269-2 References IEC JEDEC JEITA European projection Issue date 17-04-07 17-06-30 --- Fig. 16. Package outline SOT1269-2 (X2SON4) 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 15 / 18 74LVC1G04 Nexperia Single inverter 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G04 v.16 20220209 Product data sheet - Modifications: • • • • • 74LVC1G04 v.15 20180608 Modifications: • 74LVC1G04 v.14 20171101 Modifications: • • 74LVC1G04 v.15 SOT1226 (X2SON5) package changed to SOT1226-3 (X2SON5) package. Fig. 10: Package outline drawing for SOT353-1 (TSSOP5) package has changed. Type number 74LVC1G04GF (SOT891/XSON6) removed. Table 5: Derating values for Ptot total power dissipation updated. Section 1 and Section 2 updated. Product data sheet - 74LVC1G04 v.14 Added type number 74LVC1G04GX4 (SOT1269-2) Product data sheet - 74LVC1G04 v.13 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74LVC1G04 v.13 20161128 Modifications: • 74LVC1G04 v.12 20120806 Modifications: • 74LVC1G04 v.11 20120412 Modifications: • • 74LVC1G04 v.10 20111207 Modifications: • 74LVC1G04 v.9 20101026 74LVC1G04 v.8 74LVC1G04 v.7 Product data sheet - 74LVC1G04 v.12 Table 7: The maximum limits for leakage current and supply current have changed. Product data sheet - 74LVC1G04 v.11 Package outline drawing of SOT1226 modified. Product data sheet - 74LVC1G04 v.10 Added type number 74LVC1G04GX (SOT1226) Package outline drawing of SOT886 (Fig. 12) modified. - 74LVC1G04 v.9 Product data sheet - 74LVC1G04 v.8 20090427 Product data sheet - 74LVC1G04 v.7 20070827 Product data sheet - 74LVC1G04 v.6 74LVC1G04 v.6 20070202 Product data sheet - 74LVC1G04 v.5 74LVC1G04 v.5 20040907 Product specification - 74LVC1G04 v.4 74LVC1G04 v.4 20021002 Product specification - 74LVC1G04 v.3 74LVC1G04 v.3 20020513 Product specification - 74LVC1G04 v.2 74LVC1G04 v.2 20010119 Product specification - 74LVC1G04 v.1 74LVC1G04 v.1 20011121 Product specification - - 74LVC1G04 Product data sheet Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 16 / 18 74LVC1G04 Nexperia Single inverter 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC1G04 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 17 / 18 74LVC1G04 Nexperia Single inverter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................7 11.1. Waveform and test circuit.......................................... 7 12. Package outline.......................................................... 9 13. Abbreviations............................................................ 16 14. Revision history........................................................16 15. Legal information......................................................17 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 February 2022 74LVC1G04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 9 February 2022 © Nexperia B.V. 2022. All rights reserved 18 / 18
74LVC1G04GX4
物料型号:74LVC1G04
器件简介: 74LVC1G04是一款单路反相器,能够接受3.3V或5V设备的输入,使其能够在3.3V和5V混合供电环境中作为转换器使用。所有输入都具有施密特触发器动作,使电路能够容忍较慢的输入上升和下降时间。该设备在部分断电应用中完全规范使用IOFF,IOFF电路在断电时禁用输出,防止可能有害的反向电流流过设备。
引脚分配: - n.c.(无连接):1, 1.5 - 数据输入(A):2, 2 - 地(GND):3, 3, 2 - 数据输出(Y):4, 4, 3 - 供电电压(VCC):5, 6, 4
参数特性: - 宽供电电压范围:1.65V至5.5V - 过压容忍输入至5.5V - 高噪声免疫力 - CMOS低功耗 - IOFF电路提供部分断电模式操作 - 输出驱动能力:±24mA(VCC = 3.0V) - 锁存性能超过250mA - 与TTL电平直接接口 - 符合JEDEC标准 - ESD保护等级:HBM Class 2超过2000V,MM超过200V
功能详解: 74LVC1G04的逻辑功能是将输入信号A取反后在输出Y端输出。功能表显示,当输入为低电平(L)时,输出为高电平(H);当输入为高电平(H)时,输出为低电平。
应用信息: 该器件适用于需要信号转换或逻辑反转的应用场景,例如在数字电路设计中。
封装信息: 74LVC1G04提供了多种封装选项,包括TSSOP5、SC-74A、XSON6、SOT886、SOT1115、SOT1202和X2SON5等,以适应不同的应用需求和空间限制。
74LVC1G04GX4 价格&库存
很抱歉,暂时无法提供与“74LVC1G04GX4”相匹配的价格&库存,您可以联系我们找货
