113990580
113990580
    SEEED(矽递科技)
113990580 数据手册
ESP32-CAM Wi-Fi+BT SoC Module V1.0 ink er ESP32-CAM Module Features Overview The -T h - The smallest 802.11b/g/n Wi-Fi BT SoC Module - Low power 32-bit CPU,can also serve the application processor - Up to 160MHz clock speed ESP32-CAM small-size camera has module a very that competitive can operate independently as a minimum system with a footprint Summary computing power up to 600 DMIPS - Built-in 520 KB SRAM, external 4MPSRAM of only 27*40.5*4.5mm and a deep sleep current of up to 6mA. ESP-32CAM can be widely used in various IoT - Supports UART/SPI/I2C/PWM/ADC/DAC applications. It is suitable for home smart devices, - Support OV2640 and OV7670 cameras,Built-in industrial wireless control, wireless monitoring, QR Flash lamp. wireless identification, wireless positioning system signals and other IoT applications. It is an ideal - Support TF card solution for IoT applications. Ai - Support image WiFI upload - Supports multiple sleep modes. ESP-32CAM adopts DIP package and can be - Embedded Lwip and FreeRTOS directly inserted into the backplane to realize rapid - Supports STA/AP/STA+AP operation mode production of products, providing customers with - Support Smart Config/AirKiss technology high-reliability connection mode, which is convenient - Support for serial port local and remote firmware for application in various IoT hardware terminals. upgrades (FOTA) Copyright © 2017 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved Page 1 of 4 ESP32-CAM Wi-Fi+BT SoC Module V1.0 Product Specifications ESP32-CAM Package DIP-16 Size 27*40.5*4.5 ±0.2 mm SPI Flash Default 32Mbit RAM 520KB SRAM +4M PSRAM Bluetooth Bluetooth 4.2 BR/EDR and BLE standards Wi-Fi 802.11 b/g/n/ Support interface UART Support TF card Maximum support 4G IO port 9 UART Baudrate Default 115200 bps Image Output Format JPEG( OV2640 support only ),BMP,GRAYSCALE Spectrum Range 2412 ~2484MHz Antenna Onboard PCB antenna, gain 2dBi Transmit Power 802.11b: 17±2 dBm (@11Mbps) 802.11g: 14±2 dBm (@54Mbps) 802.11n: 13±2 dBm (@MCS7) ink er Module Model PWM -T h SPI I2C Power Dissipation Turn off the flash lamp:180mA@5V Turn on the flash lamp and turn on the brightness to the maximum:310mA@5V Deep-sleep: Minimum power consumption can be achieved 6mA@5V Moderm-sleep: Minimum up to 20mA@5V Light-sleep: Minimum up to 6.7mA@5V Ai Receiving Sensitivity CCK, 1 Mbps : -90dBm CCK, 11 Mbps: -85dBm 6 Mbps (1/2 BPSK): -88dBm 54 Mbps (3/4 64-QAM): -70dBm MCS7 (65 Mbps, 72.2 Mbps): -67dBm Security WPA/WPA2/WPA2-Enterprise/WPS Power Supply Range 5V Operating Temperature -20 ~ 85 Storage Environment -40 ~ 90 , < 90%RH Copyright © 2017 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved Page 2 of 4 ESP32-CAM Wi-Fi+BT SoC Module V1.0 Weight 10g Format Size QQVGA JPEG 6 BMP 9 GRAYSCALE 9 ink er ESP32-CAM module picture output format rate QVGA VGA SVGA 7 7 8 9 - - 8 - - Internal Pin Connect ESP32 SD ESP32 D0 PIN5 CLK PIN14 D1 PIN18 CMD PIN15 D2 PIN19 DATA0 PIN2 D3 PIN21 DATA1/Flash lamp PIN4 D4 PIN36 DATA2 PIN12 D5 PIN39 DATA3 PIN13 D6 PIN34 D7 PIN35 XCLK PIN0 PCLK PIN22 VSYNC PIN25 HREF PIN23 SDA PIN26 SCL PIN27 POWER PIN PIN32 Ai -T h CAM Copyright © 2017 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved Page 3 of 4 ESP32-CAM Wi-Fi+BT SoC Module V1.0 -T h ink er Minimum system diagram Contact US Shenzhen Ai-Thinker Technology Co., Ltd Address: 7/F, Fengze Building B, Huafeng Industrial Park 2th, Hangkong street,Xixiang Raod, Baoan, Shenzhen China Ai Website:www.ai-thinker.com Tel 0755-29162996 Copyright © 2017 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved E-mail:support@aithinker.com Page 4 of 4
113990580 价格&库存
很抱歉,暂时无法提供与“113990580”相匹配的价格&库存,您可以联系我们找货
